GSA.8842.A.105111
GSA.8842.A.105111
    TAOGLASLIMITED
    GSA.8842.A.105111
GSA.8842.A.105111 数据手册
Specification Part No. : GSA.8842.A.105111 Product Name : Wideband 5G/4G, ISM and Wi-Fi Adhesive Mount I-Bar Antenna with 1M CFD-200 SMA(M) Features : 5G/4G/3G / GPS / Wi-Fi 176.5mm * 59.2mm *13.6mm 617MHz to 6000MHz Cable: 1M CFD-200 Connector: SMA(M) RoHS & REACH Compliant SPE-18-8-062-C Page 1 of 37 1. Introduction The GSA.8842 Wideband Dipole Antenna has been designed to cover all 5G/4G, ISM and Wi-Fi working frequencies in the 617-6000 MHz spectrum. It has the highest wide-band efficiency in its range of any terminal antenna on the market today and exhibits stable, omni-directional radiation patterns across all bands. It is an ideal solution for any device requiring high, reliable performance. When appropriately integrated, it can maximize the likelihood of meeting type approval or carrier certification requirements from an efficiency standpoint. The GSA.8842 has been primarily designed for use with 5G/4G modules and devices that require the highest possible efficiency and peak gain to deliver best-in-class throughput on all major cellular (2G/3G/4G/5G) bands worldwide, vital for applications such as high speed video and real-time streaming, or high capacity MIMO networks on public transportation. It also provides good efficiency on both 2.4 and 5.8GHz Wi-Fi bands and is backwards-compatible with 2G and 3G cellular applications such as GSM, LTE, UMTS, Wi-Fi. This antenna also makes an excellent reference antenna for test purposes. GSA.8842 has a low-profile, compact form factor and is easily mounted via high quality, first tier automotive approved 3M adhesive foam. The standard cable assembly includes 1 meter coaxial cable and SMA (M) connector. Cable and connector are customizable. Contact your regional Taoglas sales office for support. SPE-18-8-062-C Page 2 of 37 2. Specification Electrical Frequency (MHz) 617~698 698~960 1565~1612 1710~1990 1920~2170 2400~2500 2500~2700 4900~5850 Efficiency (%) In free space On the 2mm ABS Base On the Glass Base 0.3M 68.69 70.38 29.13 74.62 73.03 70.51 72.54 61.16 1M 64.49 66.77 26.57 68.07 67.08 64.37 66.17 52.55 2M 60.19 61.85 24.09 60.23 58.78 56.06 57.08 42.55 3M 56.17 57.31 21.60 53.42 51.98 48.83 49.43 34.48 5M 48.92 49.16 17.19 42.02 40.53 37.04 37.08 22.61 0.3M 69.05 72.92 56.73 73.06 70.03 73.19 72.43 62.01 1M 64.82 69.20 51.73 66.62 64.31 66.75 66.04 53.29 2M 60.49 64.09 46.98 58.96 56.35 58.13 56.97 43.15 3M 56.46 59.38 42.05 52.30 49.83 50.63 49.34 34.98 5M 49.17 50.93 33.48 41.14 38.85 38.41 37.01 22.94 0.3M 65.08 72.21 72.81 70.19 71.02 79.11 65.80 51.55 1M 61.11 68.55 66.40 64.00 65.26 72.16 59.98 44.27 2M 57.03 63.47 60.34 56.64 57.17 62.85 51.81 35.85 3M 53.22 58.79 53.97 50.26 50.56 54.74 44.87 29.05 5M 46.35 50.42 43.01 39.52 39.40 41.52 33.65 19.05 Average Gain(dB) In free space On the 2mm ABS Base On the Glass Base 0.3M -1.63 -1.53 -5.36 -1.27 -1.37 -1.52 -1.39 -2.14 1M -1.90 -1.75 -5.76 -1.67 -1.73 -1.91 -1.79 -2.79 2M -2.20 -2.09 -6.18 -2.20 -2.31 -2.51 -2.44 -3.71 3M -2.50 -2.42 -6.66 -2.72 -2.84 -3.11 -3.06 -4.62 5M -3.10 -3.08 -7.65 -3.77 -3.92 -4.31 -4.31 -6.46 0.3M -1.61 -1.37 -2.46 -1.36 -1.55 -1.36 -1.40 -2.08 1M -1.88 -1.60 -2.86 -1.76 -1.92 -1.76 -1.80 -2.73 2M -2.18 -1.93 -3.28 -2.29 -2.49 -2.36 -2.44 -3.65 3M -2.48 -2.26 -3.76 -2.82 -3.02 -2.96 -3.07 -4.56 5M -3.08 -2.93 -4.75 -3.86 -4.11 -4.16 -4.32 -6.39 0.3M -1.87 -1.41 -1.38 -1.54 -1.49 -1.02 -1.82 -2.88 1M -2.14 -1.64 -1.78 -1.94 -1.85 -1.42 -2.22 -3.54 2M -2.44 -1.97 -2.19 -2.47 -2.43 -2.02 -2.86 -4.46 3M -2.74 -2.31 -2.68 -2.99 -2.96 -2.62 -3.48 -5.37 5M -3.34 -2.97 -3.66 -4.03 -4.04 -3.82 -4.73 -7.20 SPE-18-8-062-C Page 3 of 37 698~960 1920~2170 2400~2500 2500~2700 4900~5850 0.3M 2.63 2.75 -0.14 3.65 3.65 4.20 4.20 4.17 1M 2.33 2.55 2M 2.03 2.15 -0.54 3.25 3.25 3.80 3.80 3.47 -1.04 2.71 2.71 3.20 3.20 3M 1.73 2.57 1.85 -1.44 2.15 2.15 2.60 2.60 5M 1.57 1.43 1.55 -1.84 1.65 1.65 2.00 2.00 0.57 0.3M 2.34 2.71 1.42 3.65 3.58 3.73 4.36 4.50 1M 2.04 2.51 1.02 3.25 3.18 3.33 3.96 3.80 2M 1.74 2.11 0.52 2.75 2.68 2.73 3.26 2.90 3M 1.44 1.81 0.12 2.15 2.08 2.13 2.66 1.93 Frequency (MHz) In free space On the 2mm ABS Base On the Glass Base Peak Gain(dBi) 1565~1612 1710~1990 617~698 5M 1.14 1.51 -0.28 1.55 1.48 1.53 2.06 1.03 0.3M 2.02 2.89 3.63 4.77 4.60 5.28 5.28 4.32 1M 1.72 2.69 3.23 4.37 4.20 4.88 4.88 3.62 2M 1.42 2.29 2.73 3.87 3.70 4.28 4.28 2.62 3M 1.12 1.99 2.33 3.37 3.10 3.68 3.68 1.72 5M 0.82 1.69 1.93 2.87 2.50 3.08 3.08 0.82 Impedance 50Ω Polarization Linear VSWR
GSA.8842.A.105111 价格&库存
很抱歉,暂时无法提供与“GSA.8842.A.105111”相匹配的价格&库存,您可以联系我们找货
