AA.200.151111
AA.200.151111
    TAOGLASLIMITED
    GNSS L1/L2/L5 External 1500mm RG-174 SMA(M) ST
AA.200.151111 数据手册
MagmaX2 Part No: AA.200.151111 Description: MagmaX2 Multiband Active GNSS Magnetic Mount Antenna With 1.5m RG-174 Cable and SMA(M) Connector Features: Magnetic mount with robust IPXX Rated Enclosure Covering Bands: • GPS/QZSS (L1/L2) •GPS/QZSS/IRNSS (L5) •Galileo (E1/E5a/E5b) •GLONASS (G1/G2/G3) •BeiDou (B1/B2a/B2b) Low Axial Ratio Cable: 1.5m RG-174 Cable Connector: SMA Male Straight CE Certified RoHS & Reach Compliant SPE-20-8-002-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 7 4. Active Antenna Characteristics 14 5. Radiation Patterns 20 6 Field Test Results 26 7. Mechanical Drawing 28 8. Packaging 29 Changelog 30 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-20-8-002-E www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction The Taoglas MagmaX2 AA.200 is an active GNSS magnetic mount antenna for use across most major 1.constellations Introduction including GPS (L1/L2/L5), GLONASS (G1/G2/G5), Galileo(E1/E5a/E5b) and BeiDou(B1/B2). The antenna exhibits excellent gain and good radiation pattern stability leading to a reliable GPS fix in areas of weaker signal strength. These elements combine to ensure the best possible positional accuracy in both RTK and non-RTK systems. 1. Introduction Typical applications include: - UAVs and Robotics - RTK Systems 1. Introduction 1. Introduction - Autonomous Vehicles - Precision Agriculture - High Accuracy Positioning - Navigation The AA.200 provides excellent positional accuracy, this is due to outstanding signal to noise ratio(C/N0) and a low axial ratio of less than 2 thus ensuring the antenna maintains stable when a location is required. With great 2DRMS and Fast time to first fix the AA.200 is the ideal antenna solution for Multiband GNSS RTK Systems as it performs very well, with stable gains and low axial ratio values across all major GNSS bands. The AA.200 includes LNAs and front-end SAW filters to reduce out of band noise, such as from nearby cellular transceivers. It offers better protection from nearby radiated power surges and greatly reduces the probability of damaging your GNSS receiver from nearby transmissions. The AA.200 has 1 cable feed as the L1, L2 and L5 feeds are combined with a hybrid coupler and the antenna performance results are shown in the below sections. The cable and connector are fully customizable, subject to NRE and MOQ. For further information please contact your regional Taoglas customer support team. SPE-20-8-002-E www.taoglas.com 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications GPS L1 L2 L5 GLONASS 3. ▓ ▓ G1 G2 G3 ▓ ▓ Antenna Characteristics Galileo BeiDou 4. ▓ E1 E5a E5b E6 ▓ ▓ ▓ □ B1 B2a B2b B3 ▓ ▓ ▓ ▓ Antenna Radiation Patterns3. Antenna QZSS (Regional) L1 Characteristics2. ▓ IRNSS (Regional) 3. ▓ L2C L5 L6 ▓ ▓ □ Specifications L5 ▓ Antenna Characteristics2. SBAS L1/E1/B1 L5/B2a/E5a ▓ ▓ Specifications G1 G2 G3 ▓ ▓ ▓ *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. GNSS Bands and Constellations Antenna Radiation Patterns3.Antenna Characteristics2. SPE-20-8-002-E Specifications www.taoglas.com GNSS Electrical Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 2.0:1 2.0:1 Passive Antenna Efficiency (%) (Without cable loss) 51.5 33.3 51.0 60.4 51.6 Passive Antenna Gain at Zenith (dBi) (Without cable loss) 0.6 -0.9 2.1 2.9 2.4 Axial Ratio(dB) 1.8 1.2 1.1 1.1 1.1 Group Delay 5 10 5 5 5 PCO (cm) 1.7 0.9 1.4 1.2 1.2 PCV (cm) 2.3 2.2 0.51 0.51 0.51 Polarization RHCP Impedance 50Ω Cable RG-174, 1.5m Connector SMA(M) Straight LNA and Filter Electrical Properties Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 2.0:1 2.0:1 Gain@1.8V (dB) 25.17 27.81 27.48 27.76 26.79 Gain@3.0V (dB) 25.15 27.8 27.48 27.8 26.79 Gain@5.5V (dB) 25.2 27.83 27.48 27.8 26.8 Noise@1.8V (dB) 4.96 2.94 2.30 2.13 2.40 Noise@3.0V (dB) 4.95 2.94 2.33 2.15 2.44 Noise@5.5V (dB) 4.98 2.94 2.36 2.13 2.43 Power consumption@1.8V (mA) 17.86 Power consumption@3.0V (mA) 17.91 Power consumption@5.5V (Typ. 17.93 SPE-20-8-002-E www.taoglas.com Total Specification (Through Antenna, SAW Filter and LNA) Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 Gain@3V (dBi) 24.8 dBi 26.2 dBi 26.1 dBi 26.1 dBi 26.1 dBi Output Impedance 50 Ω Mechanical Housing Dimensions 63.2*67.2*26.5 mm Housing Material ABS Cable 1.5m of RG-174 Connector SMA(M) Weight 160g Magnetic Pull Force Average vertical pull force(kgf): 2.5 Environmental Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH Protection IP67 RoHS Compliant Yes REACH Compliant Yes SPE-20-8-002-E www.taoglas.com 3. Antenna Characteristics Return Loss (dB) 4.3.1 Antenna Radiation Patterns3.Antenna Characteristics 0 -5 4. Antenna Radiation Patterns -10 -15 4. Antenna Radiation Patterns3.Antenna -20 -25 Characteristics -30 1.10 1.22 1.34 1.46 1.58 1.70 Frequency [GHz] Antenna Radiation Patterns3. Antenna 4. GNSS L1 GNSS L2/L5 Characteristics 3.2 4. 4. VSWR Antenna Radiation Patterns 5.0 4.0 Antenna Radiation Patterns 3.0 4. Antenna Radiation Patterns 2.0 4. Antenna Radiation Patterns3. Antenna 1.00 1.17 1.33 1.50 1.0 Characteristics 4. 1.83 2.00 Frequency [GHz] GNSS L1 GNSS L2/L5 Antenna Radiation Patterns3.Antenna SPE-20-8-002-E 1.67 www.taoglas.com 3.3 Efficiency (%) 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 1.00 1.17 1.33 1.50 1.67 1.83 2.00 1.83 2.00 Frequency [GHz] GNSS L1 3.4 GNSS L2/L5 Average Gain (dB) 0.0 -2.0 -4.0 -6.0 -8.0 -10.0 1.00 1.17 1.33 1.50 1.67 Frequency [GHz] GNSS L1 SPE-20-8-002-E GNSS L2/L5 www.taoglas.com 3.5 Peak Gain (dBi) 5.0 3.0 1.0 -1.0 -3.0 -5.0 1.00 1.17 1.33 1.50 1.67 1.83 2.00 Frequency [GHz] GNSS L1 SPE-20-8-002-E GNSS L2/L5 www.taoglas.com 3.6 Axial Ratio – Free Space L1 Phi =Ratio 90 Axial - L1 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 L1 Phi=0 Axial Ratio [dB] L1 Phi=90 -100 -80 -60 -40 -20 0 20 Degrees [˚] 40 60 80 100 40 60 80 100 40 60 80 100 L2 Phi =Ratio 90 Axial - L2 Axial Ratio [dB] 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 L2 Phi=0 L2 Phi=90 -100 -80 -60 -40 -20 0 20 Degrees [˚] L5 = 90 - L5 AxialPhi Ratio Axial Ratio [dB] 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 L5 Phi=0 L5 Phi=90 -100 SPE-20-8-002-E -80 -60 -40 -20 0 20 Degrees [˚] www.taoglas.com 3.7 Axial Ratio – 30*30cm Ground Plane L1 Phi =Ratio 90 Axial - L1 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Axial Ratio [dB] L1 Phi=0 L1 Phi=90 -100 -80 -60 -40 -20 0 20 Degrees [˚] 40 60 80 100 40 60 80 100 40 60 80 100 L2 Phi =Ratio 90 Axial - L2 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Axial Ratio [dB] L2 Phi=0 L2 Phi=90 -100 -80 -60 -40 -20 0 20 Degrees [˚] L5 Axial Ratio [dB] Phi = 90 Axial Ratio - L5 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 L5 Phi=0 L5 Phi=90 -100 SPE-20-8-002-E -80 -60 -40 -20 0 20 Degrees [˚] www.taoglas.com 3.8 Axial Ratio vs Frequency – Free Space L1 Phi = 90 Axial Ratio vs Frequency 10 9 Axial Ratio [dB] 8 7 L1/E1/B1/G1 6 5 L-Band Corrections 4 3 L-Band Corrections 2 1 0 1500 1520 1540 1560 1580 1600 Frequency [MHz] 1620 1640 1660 L2 Axial Ratio [dB] Phi = 90 10 9 8 7 6 5 4 3 2 1 0 1200 Axial Ratio vs Frequency G2 B2b/E5b/G3 1210 1220 1230 1240 1250 1260 Frequency [MHz] B3/E6/L6 1270 1280 1290 1300 L5 Axial Ratio [dB] Phi = 90 10 9 8 7 6 5 4 3 2 1 0 1150 SPE-20-8-002-E Axial Ratio vs Frequency L5/B2a/E5a 1160 1170 1180 Frequency [MHz] 1190 1200 www.taoglas.com 3.9 Axial Ratio vs Frequency – 30*30cm Ground Plane L1 Phi = 90 Axial Ratio vs Frequency 10 9 Axial Ratio [dB] 8 7 L1/E1/B1/G1 6 5 L-Band Corrections 4 3 L-Band Corrections 2 1 0 1500 1520 1540 1560 1580 1600 Frequency [MHz] 1620 1640 1660 L2 Axial Ratio [dB] Phi = 90 10 9 8 7 6 5 4 3 2 1 0 1200 Axial Ratio vs Frequency G2 B2b/E5b/G3 1210 1220 1230 1240 1250 1260 Frequency [MHz] B3/E6/L6 1270 1280 1290 1300 L5 Phi = 90 Axial Ratio [dB] 10 9 8 7 6 5 4 3 2 1 0 1150 Axial Ratio vs Frequency SPE-20-8-002-E L5/B2a/E5a 1160 1170 1180 Frequency [MHz] 1190 1200 www.taoglas.com 4. Active Antenna Characteristics LNA Block Diagram 6.4.1 Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 4.2 6. Mechanical Drawing LNA Gain L2 & L5 @3V Packaging 50 40 7. 30 Application Note6. Packaging 20 (DB) 7. 10 Application Note 0 -10 -20 7. Application Note6. Packaging -30 (MHZ) -40 1100 7. 1200 1250 1300 1350 S11 LNA Return loss(3.0V) Mechanical S12 LNA GAIN(3.0V) Application Note6. Packaging5. Drawing 6. 1150 Packaging5. SPE-20-8-002-E 1207MHz 1176.45MHz Mechanical Drawing 1227.6MHz www.taoglas.com 4.3 LNA Gain L1 Band @3V 40 30 20 (DB) 10 0 -10 -20 -30 -40 1500 4.4 1550 S11 LNA Return loss(3.0V) 1561MHz 1602MHz 1650 (MHZ) 1600 S12 LNA GAIN(3.0V) 1575.42MHz LNA Noise Figure @3V (dB) 10 5 0 1100 SPE-20-8-002-E 1200 1300 1400 1500 LNA_Noise-3.0V 1176.45MHz 1207MHz 1561MHz 1575.42MHz 1602MHz 1600 (MHz) 1227.6MHz www.taoglas.com 4.5 S12 Wide Band Plot 50 40 30 20 10 (DB) 0 -10 -20 -30 -40 -50 -60 (MHZ) -70 300 4.6 500 700 900 1100 1300 1500 1700 L2-S12 3.0V L1-S12 3.0V 1900 2100 2300 2500 2700 2900 Combined Gain – 30*30cm Ground Plane 50 B2b/E5b/G3 40 30 L1/E1/B1/G1 B2 B3/E6/L6 L-Band Corrections L-Band Corrections Gain [dBi] 20 10 0 -10 -20 -30 -40 1100 SPE-20-8-002-E 1150 1200 1250 1300 1350 1400 1450 Frequency [MHz] 1500 1550 1600 1650 1700 www.taoglas.com 4.7 Combined Gain – Free Space 50 B2b/E5b/G3 40 B2 B3/E6/L6 L1/E1/B1/G1 L-Band L-Band Corrections Corrections 30 Gain [dBi] 20 10 0 -10 -20 -30 -40 1100 SPE-20-8-002-E 1150 1200 1250 1300 1350 1400 1450 Frequency [MHz] 1500 1550 1600 1650 1700 www.taoglas.com 4.8 Group Delay vs Frequency – Free Space L1 Phi = 90 Group delay vs Frequency - L1 Band 60 Group Delay (ns) 55 50 45 Raw data smoothed data 40 35 1.5 1.52 1.54 1.56 1.58 1.6 Frequency (GHz) 1.62 1.64 L2 Phi = 90 Group delay vs Frequency - L2 band 45 Group Delay (ns) 40 35 30 Raw data 25 smoothed data 20 1.15 1.17 1.19 1.21 1.23 1.25 1.27 1.29 Frequency (GHz) L5 Phi = 90 Group delay vs Frequency - L5 band 60 Raw data Group Delay (ns) 55 smoothed data 50 45 40 35 1.15 1.16 1.17 1.18 1.19 1.2 Frequency (GHz) SPE-20-8-002-E www.taoglas.com 4.9 Group Delay vs Frequency – 30*30cm Ground Plane L1 Phi = 90 Group delay vs Frequency - L1 Band 60 Group Delay (ns) 55 50 45 Raw data smoothed data 40 35 1.5 1.52 1.54 1.56 1.58 1.6 1.62 1.64 Frequency (GHz) L2 Phi = 90 Group delay vs Frequency - L2 band 45 Group Delay (ns) 40 35 30 Raw data 25 smoothed data 20 1.15 1.17 1.19 1.21 1.23 Frequency (GHz) 1.25 1.27 1.29 L5 Phi = 90 Group delay vs Frequency - L5 band 60 Raw data Group Delay (ns) 55 50 45 40 35 1.15 SPE-20-8-002-E smoothed data 1.16 1.17 1.18 Frequency (GHz) 1.19 1.2 www.taoglas.com 5. Radiation Patterns 4. 4. 5.1 Test Setup – Free Space Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-20-8-002-E www.taoglas.com 5.2 1176.45MHz 3D and 2D Radiation Patterns 330 300 270 XY Plane XZ Plane YZ Plane X Z Z 0 0 5 -5 -15 -25 -35 -45 30 330 60 300 90 240 Y 120 210 150 180 SPE-20-8-002-E (dBi) 1176.45MHz 270 10 0 -10 -20 -30 -40 30 330 60 90 240 300 X 120 210 150 180 (dBi) 1176.45MHz 270 10 0 -10 -20 -30 -40 0 30 60 90 240 Y 120 210 150 180 (dBi) 1176.45MHz www.taoglas.com 5.3 1227.6MHz 3D and 2D Radiation Patterns XY Plane 330 300 270 5 -5 -15 -25 -35 -45 XZ Plane YZ Plane X Z Z 0 0 30 330 60 300 90 240 Y 120 210 150 180 SPE-20-8-002-E (dBi) 1227.6MHz 270 10 0 -10 -20 -30 -40 30 330 60 300 90 X 240 120 210 150 180 (dBi) 1227.6MHz 270 10 0 -10 -20 -30 -40 0 30 60 90 240 Y 120 210 150 180 (dBi) 1227.6MHz www.taoglas.com 5.4 1561MHz 3D and 2D Radiation Patterns 330 300 270 XY Plane XZ Plane X Z 0 0 5 -5 -15 -25 -35 -45 330 30 60 90 240 120 210 150 180 SPE-20-8-002-E (dBi) 300 Y 270 10 0 -10 -20 -30 -40 YZ Plane Z 30 330 60 90 240 120 210 150 180 (dBi) 300 X 270 10 0 -10 -20 -30 -40 0 30 60 90 240 Y 120 210 150 (dBi) 180 www.taoglas.com 5.5 1575.42MHz 3D and 2D Radiation Patterns 330 300 270 XY Plane XZ Plane YZ Plane X Z Z 0 0 5 -5 -15 -25 -35 -45 330 30 60 90 240 300 Y 120 210 150 180 SPE-20-8-002-E (dBi) 1575.42MHz 270 10 0 -10 -20 -30 -40 30 330 60 90 240 300 X 120 210 150 180 (dBi) 1575.42MHz 270 10 0 -10 -20 -30 -40 0 30 60 90 240 Y 120 210 150 180 (dBi) 1575.42MHz www.taoglas.com 5.6 1602MHz 3D and 2D Radiation Patterns 330 300 270 XY Plane XZ Plane X Z 0 0 5 -5 -15 -25 -35 -45 330 30 60 90 240 300 Y 120 210 150 180 SPE-20-8-002-E (dBi) 1602MHz 270 10 0 -10 -20 -30 -40 YZ Plane Z 30 330 60 90 240 300 X 120 210 150 180 (dBi) 1602MHz 270 10 0 -10 -20 -30 -40 0 30 60 90 240 Y 120 210 150 180 (dBi) 1602MHz www.taoglas.com 6. Field Test Results 4. 4. 6.1 Rooftop test Antenna Radiation Patterns In this section Taoglas will present the field test result for AA.200 antenna. The test was performed when the antenna was mounted on a static rooftop test set up in an open sky environment for at least 6 hours. will show the field test results using the following receiver: 4.TaoglasAntenna Radiation Patterns 1. Septentrio AsteRx-U S/N 4. 4. • • Multi-band GNSS: 544 channels GPS: L1, L2, L5 GLONASS: L1, L2, L3 Galileo: E1, E5ab, AltBoc, E6 BeiDou: B1, B2, B3 NavIC: L51 QZSS: L1, L2, L5, L6 SBAS: EGNOS, WAAS, GAGAN, MSAS, SDCM(L1, L5) RTK (base and rover), Integrated dual-channel L-band receiver, Support for PPP Nav. update rate up to 100 Hz Position accuracy = RTK 0.6 cm + 0.5 ppm Antenna Radiation Patterns • • • • Antenna Radiation Patterns Positioning Accuracy Table (2D Accuracy) 4. Test Condition 4. CEP (50%) DRMS (68%) 2DRMS (95-98.2%) TTFF (sec) RTK DISABLED 51.64 cm 61.89 cm 123.78 cm 22 RTK ENABLED 1.37 cm 1.65 cm 3.29 cm 22 RTK DISABLED 48.11 cm 57.8 cm 115.61 cm 21 1.4 cm 2.8 cm 21 Antenna Radiation Patterns Free Space 4. Correction Service 30x30 cm Ground Plane Antenna Radiation1.17Patterns RTK ENABLED cm Antenna Radiation Patterns RTK Availability Free Space 0% RTK Availability 30x30 cm GP 0% No RTK No RTK Float Float Fixed 100% SPE-20-8-002-E Fixed 100% www.taoglas.com 2. U-blox ZED F9P • • • • • Multi-band GNSS: 184-channel GPS L1C/A L2C, GLONASS: L1OF L2OF, Galileo: E1B/C E5b, BeiDou: B1I B2I, QZSS: L1C/A L2C Multi‑band RTK with fast convergence times and reliable performance Nav. update rate RTK up to 20 Hz Position accuracy = RTK 0.01 m + 1 ppm CEP Positioning Accuracy Table (2D Accuracy) Test Condition Free Space 30x30 cm Ground Plane Correction Service CEP (50%) DRMS (68%) 2DRMS (95-98.2%) TTFF (sec) RTK DISABLED 42.78 cm 55.74 cm 111.48 cm 23 RTK ENABLED 1.57 cm 1.9 cm 3.81 cm 23 RTK DISABLED 30.52 cm 36.91 cm 73.83 cm 19 RTK ENABLED 0.58 cm 0.69 cm 1.39 cm 19 RTK Availability Free Space RTK Availability 30x30 cm GP 0% 0% No RTK No RTK Float Float Fixed 100% Fixed 100% . SPE-20-8-002-E www.taoglas.com 7. Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-002-E Mechanical Drawing www.taoglas.com 8. Packaging 1pcs AA.200.151111 per Small PE Bag - 165g 6. WeightPackaging5. 6. Mechanical Drawing Packaging AA.200.151111 per Large PE Bag 7. 10pcsApplication Note6. Packaging5. Mechanical Weight – 1650g Drawing 6. Packaging5. 6. Packaging Mechanical Drawing 100pcs AA.200.151111 per carton Dimensions - 370*370*300mm Weight – 17Kg 7. Application Note6. Packaging 300mm 7. Application Note 370mm 7. Application Note6. Packaging 7. Application Note6. Packaging5. 370mm Mechanical Drawing 6. Packaging5. SPE-20-8-002-E Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-20-8-002 – AA.200.151111 Revision: E (Current version) Date: Notes: Author: 2021-09-03 Updated Mechanical Drawing Gary West Previous Revisions Revision: D Date: Notes: Author: 2021-08-13 Updated Drawing Jack Conroy Revision: C Date: Notes: Author: 2020-06-30 Updated Data and graphs Jack Conroy Revision: B Date: Notes: Author: 2020-05-28 Added Field Test Results Victor Pinazo Revision: A (Original First Release) Date: Notes: Author: SPE-20-8-002-E 2020-03-31 Initial Release Jack Conroy www.taoglas.com SPE-20-8-002-E © Taoglas www.taoglas.com
AA.200.151111 价格&库存
很抱歉,暂时无法提供与“AA.200.151111”相匹配的价格&库存,您可以联系我们找货
AA.200.151111
  • 1+824.063951+107.10347
