ADFGP.50A.07.0100C
ADFGP.50A.07.0100C
    TAOGLASLIMITED
ADFGP.50A.07.0100C 数据手册
Part No: ADFGP.50A.07.0100C Description: Embedded Active GNSS Dual Stacked Patch Antenna with 100mm of 1.37 & IPEX MHFI Features: Embedded Dual Patch, Dual Feed 4-Pin Assembly Covering Bands: • • • • • GPS/QZSS (L1/L2) GPS/QZSS/IRNSS (L5) Galileo (E1/E5a/E5b) GLONASS (G1/G2/G3) BeiDou (B1/B2a/B2b) Low Axial Ratio Cable: 100mm of 1. 37mm Connector: IPEX MHFI (U.FL) Dimensions: 50 x 50 x 16.8mm RoHS & Reach Compliant SPE-19-8-133-F 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 8 4. Radiation Patterns 12 5. LNA Characteristics 18 6. Field Test Result 20 7. Mechanical Drawing 21 8. Packaging 22 9. Installation Suggestion 23 Changelog 24 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-19-8-133-F www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction The ADFGP.50A, with Taoglas Sure Technology, is a precision-engineered active dual patch, dual-feed antenna for GPS (L1/L2/L5), GLONASS (G1/G2/G5), Galileo (E1/E5a/E5b) and BeiDou (B1/B2). The antenna comes mounted on a 50*50 mm PCB (ground plane). It consists of two stacked patches, 50mm, and 40mm 1. Introduction in width and is 16.8mm thick. It has been tuned and tested on a 50*50mm ground plane specifically for GPS L1: 1575.42MHz, L2: 1227.6MHz and L5: 1176.45MHz as well as the GLONASS, Galileo, BeiDou and IRNSS bands shown in Section 2. 1. Introduction Each patch element uses two orthogonal feeds that are combined in a hybrid coupler to ensure optimal axial ratio. The antenna exhibits excellent gain and good radiation pattern stability leading to a reliable GNSS fix in areas of weaker signal strength. All these elements combined ensure the best possible positional accuracy 1. for your device. Introduction Both patch elements have a dual pin feed to ensure a low axial ratio and should be used in conjunction with a hybrid coupler. The ADFGP.50A includes LNAs and front-end SAW filters to reduce out of band noise, such as from nearby cellular transceivers. It offers better protection from nearby radiated power surges and greatly reduces the probability of damaging your GNSS receiver from nearby transmissions. Features: • Multi-GNSS, high-performance antenna • Excellent signal to noise ratio (C/N0) • Good 2DRMS and fast TTFF • Axial ratio < 2dB typ. across all bands • Phase stability provides excellent Phase Center Variation (PCV) SPE-19-8-133-F www.taoglas.com 3 Benefits: • Excellent positional accuracy • Great for use in difficult environments • Multiband improves the receiver’s position estimation in terms of accuracy and reliability • Ideal antenna solution for multiband RTK systems. The ADFGP.50A is connected via an IPEX MHFI connector and works well without modifications in most environments, however, it can be tuned and optimized for different ground planes and enclosures if required. It is manufactured and tested in a TS16949 first tier automotive approved facility. Typical applications include: • High accuracy positioning and navigation systems • UAVs, Robotics & Autonomous Vehicles • Micro-Mobility Solutions • Mapping & GIS • Transportation & Telematics • Precision Agriculture • Public Safety, Search & Rescue • RTK Systems Custom antenna modifications are subject to possible NRE and minimum order quantity. For further information or support to test and integrate Taoglas Sure technology please contact your regional Taoglas customer support team. We recommend installing this antenna with an adhesive foam backing as shown in section 9, to configure this product with adhesive foam please contact your regional Taoglas customer support team. SPE-19-8-133-F www.taoglas.com 4 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications GPS L1 L2 L5 GLONASS 3. ▓ ▓ G1 G2 G3 ▓ ▓ Antenna Characteristics Galileo Bei Dou 4. ▓ E1 E5a E5b E6 ▓ ▓ ▓ □ B1I B1C B2a B2b ▓ ▓ ▓ ▓ Antenna Radiation Patterns3. Antenna QZSS (Regional) L1 Characteristics2. ▓ IRNSS (Regional) 3. ▓ L2C L5 L6 ▓ ▓ □ Specifications B3 □ L5 ▓ Antenna Characteristics2. SBAS L1/E1/B1 L5/B2a/E5a ▓ ▓ Specifications G1 G2 G3 ▓ ▓ ▓ *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics GNSS Bands and Constellations 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-19-8-133-F Specifications www.taoglas.com 5 GNSS Electrical Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 2.0:1 2.0:1 Efficiency (%) 39.1% 43.7% 51.3% 62.8% 57.5% Peak Gain at Zenith (dBi) 0.7 1.6 2.4 3.4 3.2 Axial Ratio (dB) 2.6 1.9 1.9 1.8 1.4 Group Delay 11 11 20 20 20 PCO (cm) 1 1.1 1.1 1.2 1.2 PCV (cm) 6 9 6 6 6 Polarization RHCP Impedance 50Ω Note. The patch antenna test with hybrid coupler XC1400P-03S LNA and Filter Electrical Properties Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 2.0:1 2.0:1 Gain@1.8V (Typ.) 24.1dB 24.6dB 23.6dB 24.2 dB 23.7 dB Gain@3.0V (Typ.) 24.1dB 24.6dB 23.7dB 24.2 dB 23.8 dB Gain@5.5V (Typ.) 24.2dB 24.6dB 23.7dB 24.2 dB 23.8 dB Noise@1.8V (Typ.) 5.15 dB 3.97 dB 2.74 dB 2.68 dB 2.72 dB Noise@3.0V (Typ.) 5.15 dB 4.13 dB 2.75 dB 2.67 dB 2.74 dB Noise@5.5V (Typ.) 5.12 dB 4.03 dB 2.72 dB 2.77 dB 2.81 dB Power consumption@1.8V (Typ.) 17.95 mA Power consumption@3.0V (Typ.) 18.02 mA Power consumption@5.5V (Typ.) 18.05 mA Total Specification (Through Antenna, SAW Filter and LNA) Frequency (MHz) 1176.45 1227.6 1561 1575.42 1602 Gain@3V (dBi) 24.8 26.2 26.1 27.6 27 Output Impedance SPE-19-8-133-F 50 Ω www.taoglas.com 6 Mechanical Dimensions 50 x 50 x 16.8mm Connector IPEX MHFI (U.FL) Cable Coaxial Cable ø1.37: Length 100mm Weight 95.5g Environmental Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-19-8-133-F www.taoglas.com 7 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -5 -10 4. -15 Antenna Radiation Patterns (dB) -20 4. -25 Antenna Radiation Patterns3.Antenna -30 Characteristics -35 -40 1200 1300 4. 1100 Antenna Radiation Patterns3.1400 Antenna1500 1600 (MHz) Characteristics 3.2 1700 Efficiency 100 4. Antenna Radiation Patterns 90 80 4. 70 Antenna Radiation Patterns (%) 60 4. 50 Antenna Radiation Patterns 40 30 4. 20 Antenna Radiation Patterns3.Antenna 10 Characteristics 0 1100 4. 1200 1300 1400 1500 Antenna Radiation Patterns3.Antenna SPE-19-8-133-F 1600 1700(MHz) www.taoglas.com 8 3.3 Average Gain 5 (dB) 0 -5 -10 1100 3.4 1200 1300 1400 1500 1600 1700(MHz) 1300 1400 1500 1600 1700 (MHz) Peak Gain 10 (dBi) 5 0 -5 1100 SPE-19-8-133-F 1200 www.taoglas.com 9 3.5 Axial Ratio X-Z 20 18 16 14 (dB) 12 10 8 6 4 2 0 -180 -150 -120 -90 -60 -30 0 1176.45(MHz) 20 30 60 90 120 150 180 1227.6(MHz) (degree) Y-Z 18 16 14 (dB) 12 10 8 6 4 2 0 -180 -150 -120 -90 -60 -30 0 1176.45(MHz) SPE-19-8-133-F 30 60 90 120 150 180 1227.6(MHz) (degree) www.taoglas.com 10 20 X-Z 18 16 14 (dB) 12 10 8 6 4 2 0 -180 -150 -120 -90 -60 -30 0 30 60 90 120 150 180 1561(MHz) 1575.42(MHz) 1602(MHz) 20 (degree) Y-Z 18 16 14 (dB) 12 10 8 6 4 2 0 -180 -150 -120 -90 -60 -30 0 30 60 1561(MHz) 1575.42(MHz) SPE-19-8-133-F 90 120 150 180 1602(MHz) (degree) www.taoglas.com 11 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns X 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-19-8-133-F Y www.taoglas.com 12 4.2 1176.45MHz 3D and 2D Radiation Patterns XY Plane XZ Plane Z X 330 100 -10 300 -20 -30 270 -40 1176.45MHz 0 30 60 90 240 120 210 SPE-19-8-133-F Y 330 100 -10 300 -20 -30 270 -40 (dBi) Z 1176.45MHz 0 30 60 90 X 240 120 210 150 180 YZ Plane 150 180 330 100 -10 300 -20 -30 270 -40 30 60 90 Y 240 120 210 (dBi) 1176.45MHz 0 150 180 (dBi) www.taoglas.com 13 4.3 1227.6MHz 3D and 2D Radiation Patterns XY Plane 330 100 -10 300 -20 -30 270 -40 X 0 XZ Plane 1227.6MHz 30 60 90 Y 240 120 210 SPE-19-8-133-F (dBi) 1227.6MHz 30 60 90 X 240 120 210 150 180 330 100 -10 300 -20 -30 270 -40 Z 0 YZ Plane 150 180 330 100 -10 300 -20 -30 270 -40 Z 0 30 60 90 Y 240 120 210 (dBi) 1227.6MHz 150 180 (dBi) www.taoglas.com 14 4.4 1561MHz 3D and 2D Radiation Patterns XY Plane 330 100 -10 300 -20 -30 270 -40 X 0 XZ Plane 1561MHz 30 60 90 Y 240 120 210 150 180 SPE-19-8-133-F 330 100 -10 300 -20 -30 270 -40 Z 0 1561MHz 30 60 90 X 240 120 210 (dBi) YZ Plane 150 180 330 100 -10 300 -20 -30 270 -40 Z 0 60 90 Y 240 120 210 (dBi) 1561MHz 30 150 180 (dBi) www.taoglas.com 15 4.5 1575.42MHz 3D and 2D Radiation Patterns XY Plane XZ Plane X 330 100 -10 300 -20 -30 270 -40 1575.42MHz 0 30 60 90 240 120 210 150 180 SPE-19-8-133-F Y 330 100 -10 300 -20 -30 270 -40 Z Z 0 1575.42MHz 30 60 90 X 240 120 210 (dBi) YZ Plane 150 180 330 100 -10 300 -20 -30 270 -40 30 60 90 Y 240 120 210 (dBi) 1575.42MHz 0 150 180 (dBi) www.taoglas.com 16 4.6 1602MHz 3D and 2D Radiation Patterns XY Plane 330 100 -10 300 -20 -30 270 -40 X 0 XZ Plane 1602MHz 30 60 90 Y 240 120 210 150 180 SPE-19-8-133-F 330 100 -10 300 -20 -30 270 -40 Z Z 0 1602MHz 30 60 90 X 240 120 210 (dBi) YZ Plane 150 180 330 100 -10 300 -20 -30 270 -40 30 60 90 Y 240 120 210 (dBi) 1602MHz 0 150 180 (dBi) www.taoglas.com 17 5. LNA Characteristics Block Diagram (ActivePatterns3. Antenna) Antenna 4.5.1 Antenna Radiation Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. 5.2 Antenna Radiation Patterns3.Antenna LNA Gain (dB) Characteristics 30 L1-BAND-S12(1.8V) L1-BAND-S12(3.0V) L1-BAMD-S12(5.5V) L2-BAND-S12(1.8V) L2-BAND-S12(3.0V) L2-BAND-S12(5.5V) 1176.45MHz 1227.6MHz 1575.42MHz 1561MHz 1602MHz 20 4. Antenna 10 Radiation Patterns 0 4. Antenna -10 Radiation Patterns -20 4. -30 Antenna Radiation Patterns -40 4. -50 Antenna Radiation Patterns3.Antenna -60 Characteristics 100 4. 600 1100 1600 Antenna Radiation Patterns3.Antenna SPE-19-8-133-F 2100 2600 MHz www.taoglas.com 18 5.3 Noise Figure @3.0V 20 LNA_Noise_1.8V LNA_Noise_3V LNA_Noise_5V 15 1575.42MHz (dB) 1561MHz 1602MHz 1227.6MHz 10 1176.45MHz 5 0 1150 SPE-19-8-133-F 1250 1350 1450 1550 1650 (MHz) www.taoglas.com 19 6. Field Test Results 4. 4. 6.1 Rooftop test Antenna Radiation Patterns In this section Taoglas will present the field test result for ADFGP.50 antenna. The test was performed when the antenna was mounted on a static rooftop test set up in an open sky environment for at least 6 hours. will show the field test results using the following receiver: 4.TaoglasAntenna Radiation Patterns 1. U-blox ZED-F9P Receiver features: 4. 4. • • • • Multi-band GNSS: 184-channel GPS L1C/A L2C, GLONASS: L1OF L2OF, Galileo: E1B/C E5b, BeiDou: B1I B2I, QZSS: L1C/A L2C Antenna Radiation Patterns Multi‑band RTK with fast convergence times and reliable performance Nav. update rate RTK up to 20 Hz Position accuracy = RTK 0.01 m + 1 ppm CEP Positioning Accuracy Table (2D Accuracy) Antenna Radiation Patterns Correction Test Condition 4. Free Space RTK DISABLED CEP (50%) DRMS (68%) 2DRMS (95-98.2%) TTFF (sec) 56.42 cm 73.23 cm 146.46 cm 15 1.08 cm 2.16 cm 15 RTL ENABLED cm Antenna Radiation0.9Patterns 30x30 cm Ground Plane 4. Service RTK DISABLED 46.69 cm 58.83 cm 117.65 cm 12 RTL ENABLED 0.8 cm 0.96 cm 1.93 cm 12 Antenna Radiation Patterns RTK Availability Free space 4. RTK Availability 30x30 cm ground plane Antenna Radiation Patterns SPE-19-8-133-F No RTK No RTK Float Float Fixed Fixed www.taoglas.com 20 7. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-133-F Mechanical Drawing www.taoglas.com 21 8. Packaging 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics SPE-19-8-133-F www.taoglas.com 22 9. 6. Installation Suggestion We do not supply our standard ADFGP.50A with adhesive backing however this can be requested via your regional Taoglas customer support team. The below details the optimum way to install the ADFGP.50A Antenna for use in conjunction with adhesive backing. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging 7. 7. Item Number Description Material 1 Adhesive Mounting Pad for ADFGP.50A Acrylic Foam Application Note 2 Small Adhesive Mounting Pad for ADFGP.50A Acrylic Foam 3 Shielding Case SPTE Application Note6. Packaging 4 1.37 Coaxial Cable 5 7. Mechanical Drawing FEP PCB Stacked Patch 40x40x4 mm & Application Note6. Packaging5. 6 50x50x8 mm Composite 0.8† Mechanical Ceramic Drawing 6. SPE-19-8-133-F Packaging5. Mechanical Drawing www.taoglas.com 23 Changelog for the datasheet SPE-19-8-133 – ADFGP.50A.07.0100C Revision: F (Current Version) Date: Changes: Changes Made by: 2022-11-17 Updated GNSS Band and constellations. Gary West Previous Revisions Revision: E Date: Changes: Changes Made by: 2022-07-28 Added Installation Suggestion Gary West Revision: D Date: Changes: Changes Made by: 2021-12-22 Updated packaging Gary West Revision: C Date: Changes: Changes Made by: 2020-05-29 Added Field Test Section Victor Pinazo Revision: B Date: Changes: Changes Made by: 2020-03-02 Updated Introduction Yu Kai Yeung Revision: A Date: Changes: Changes Made by: SPE-19-8-133-F 2019-10-17 Initial Release Jack Conroy www.taoglas.com 24 www.taoglas.com © Taoglas SPE-19-8-133-F www.taoglas.com 25
ADFGP.50A.07.0100C 价格&库存
很抱歉,暂时无法提供与“ADFGP.50A.07.0100C”相匹配的价格&库存,您可以联系我们找货
ADFGP.50A.07.0100C
  • 50+423.4843250+54.78900
  • 100+413.01489100+53.43450
库存:200
ADFGP.50A.07.0100C
  • 1+904.498831+117.02107
  • 5+642.184185+83.08367
  • 10+616.9585410+79.82006
  • 25+584.7711425+75.65576
库存:48
ADFGP.50A.07.0100C
  • 50+416.2245950+53.84976
  • 100+405.93463100+52.51848
库存:200
ADFGP.50A.07.0100C
    ADFGP.50A.07.0100C
    • 1+730.394311+94.49600
    • 10+607.7177010+78.62451
    • 50+558.6272050+72.27334
    • 100+543.43389100+70.30768
    库存:99
