AccuraUWB FXUWB10
Part No:
FXUWB10.07.0100C
Description:
AccuraUWB Flex Series 3~10GHz Ultra-Wide Band (UWB) Flex Antenna with
100mm 1.37mm IPEX MHFHT
Features:
Flexible UWB Antenna
Mounting on non-metal surfaces
For European and USA UWB Applications
For Channels 1-15
Frequency: 3.0–10.3GHz
Cable:100mm 1.37 Coaxial
Connector: IPEX MHFHT (U.FL compatible)
Dimensions: 34.9*24.5*0.24mm
RoHS & REACH Compliant
SPE-17-8-052-C
1.
Introduction
3
2.
Specifications
5
3.
Antenna Characteristics
6
4.
Radiation Patterns
13
5.
Mechanical Drawing
16
6.
Packaging
17
7.
Application Note
18
Changelog
19
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-17-8-052-C
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
FXUWB10 flexible polymer antenna, at 35*24.5*0.2 mm, is a small form factor, ultra-thin Ultra1.The AccuraUWB
Introduction
Wideband (UWB) antenna with high efficiencies across the pulsed UWB communications operational bands. It is
assembled by a simple “peel and stick” process, attaching securely to non-metal surfaces via 3M adhesive. It
enables designers to use only one antenna that covers all available UWB commercial bands, namely bands 1
through 15 simultaneously.
1.
Introduction
The AccuraUWB antenna is a durable flexible polymer antenna that has an average peak gain of 5dBi, an
efficiency of more than 75% across the bands and is designed to be mounted directly onto a plastic cover. It is an
ideal choice for any device maker that needs to keep manufacturing costs down over the lifetime of a product. It
is ground plane independent and delivered with a cable and connector for easy connecting to the wireless
module or customer PCB. Cables and Connectors are customizable, however, the maximum microcoax cable
length is 100 mm. Like all such antennas, care should be taken to mount the antenna at least 10mm from metal
components or surfaces, and ideally, 20mm for best radiation efficiency.
1.
Introduction
Like all such antennas, care should be taken to mount the antenna at least 10mm from metal components or
1.surfaces,Introduction
Ultra-wideband (also known as UWB) is a low-power digital wireless technology for transmitting large amounts of
digital data over a wide spectrum of frequency bands typically spanning more than 500MHz with very low power
for short distances.
While the cable type and length are customizable, as is the connector, do note that a custom-designed antenna
may be needed in those circumstances. Also tuning of the antenna may be needed in specific customer device
environments. Taoglas offers this testing and tuning service subject to NRE and MOQ. Contact your regional
Taoglas office for support.
The low power requirements of UWB mean increased battery life of sensors and tags leading to a reduction in
overall operational costs. Taoglas has developed various innovative and new-to-market flexible embedded UWB
antennas designed for seamless integration on plastics and using highly flexible micro-coaxial cable mounting
while achieving high performance where space is limited. Taoglas UWB antennas have been designed for use
with the recently launched Decawave ScenSor DW1000 module and are also compatible with any other UWB
sensor modules on the market.
1.
SPE-17-8-052-C
Introduction
www.taoglas.com
3
1.1
Return Loss
Radar - These short-pulsed antennas provide very fine range resolution and precision distance and
positioning measurement capabilities. UWB signals enable inexpensive high-definition radar antennas
which find use in automotive sensors, smart airbags, and precision surveying applications amongst many
others.
Home Network Connectivity - Smart home and entertainment systems can take advantage of high data
rates for streaming high-quality audio and video content in real-time for consumer electronics and
computing within a home environment.
Position location & Tracking - UWB antennas also find use in Position Location and Tracking applications
such as locating patients in case of critical condition, hikers injured in remote areas, tracking cars, and
managing a variety of goods in a big shopping mall. UWB offers better noise immunity and better
accuracy within a few cm compared to current localization technologies such as Assisted GPS for
Indoors, Wi-Fi, and cellular which are at best able to offer meter level precision. Tethered Indoor
positioning UWB systems that measure the angles of arrival of ultra-wideband (UWB) radio signals
perform triangulation by using multiple sensors to communicate with a tag device.
SPE-17-8-052-C
www.taoglas.com
4
2.
Specifications
3.
Antenna Characteristics2.
3.
4.
Electrical
Specifications
Standard
US UWB channels 1-4
US UWB channels 5-9
EU UWB band
US UWB channels 10 - 15
Operation Frequency (GHz)
3.1 – 5.0
6.0 – 8.2
8.2 – 10.3
很抱歉,暂时无法提供与“FXUWB10.07.0100C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 15+35.08809
- 75+30.90461
- 100+28.89750
- 国内价格
- 14+53.62551
- 70+48.25936
- 国内价格 香港价格
- 1+60.957221+7.92260
- 10+52.8079010+6.86344
- 50+47.9808250+6.23606
- 100+46.09301100+5.99070
- 250+43.76294250+5.68787
- 500+42.11816500+5.47409
- 1000+40.568761000+5.27272
