FXUB71.A.54.C.001
FXUB71.A.54.C.001
    TAOGLASLIMITED
    3.3GHz 4G/5G 扁平插接线 RF 天线 600MHz ~ 6GHz IPEX MHF4L 胶合剂
FXUB71.A.54.C.001 数据手册
Part No: FXUB71.A.54.C.001 Description: 5G/4G 2*MIMO Wideband 600-6000MHz Flex Circuit PCB with 150mm of 1.37 and I-PEX MHF 4L Features: Flexible PCB Antenna for ease of installation Worldwide 5G functionality with 4G and 3G/2G Wideband 600-6000MHz Operational Dimensions: 240mm*21mm*0.15mm Cable: 150mm 1.37 Connector: I-PEX MHF® 4L (HSC compatible) 3M adhesive tape for “Peel and Stick” Mounting RoHS & Reach Compliant SPE-21-8-016-A 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 30 6. Packaging 31 Changelog 32 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-21-8-016-A www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The patent pending FXUB71 antenna is an industry leading embedded 5G/4G 2*2 MIMO flexible polymer monopole type antenna for worldwide 5G/4G applications, which operates across the full 600-6000MHz spectrum. The antenna comes with a micro coax cable and connector, and has good efficiency and isolation between ports, critical for optimal 5G/4G MIMO wireless performance. 1. Typical applications - Gateways and Routers - High speed HD streaming - Wireless Access Points - Handheld Devices - High capacity MIMO networks for Public Transportation 1. 1. Introduction Introduction Introduction With over 30% efficiency on all bands, isolation performance between the two ports is under -10dB in all bands. The antenna has been designed in a slim rectangular form-factor, with its own automotive quality 3M 467 adhesive backing tape, to ensure good isolation and convenient installation into typical M2M/IOT devices. Simply peel and stick onto your plastic housing. Introduction The antenna is tuned to work on a reference ABS plastic of 2mm of thickness which is a common standard for most device plastics. Cable routing has been carefully planned to ensure no cross-over of cable, and a logical and hassle free installation. Like all such antennas, care should be taken to mount the antenna at least 10mm from metal components or surfaces, and ideally 20mm for best radiation efficiency. The FXUB71 uses a future proof I-PEX MHF® 4L connector for 5G applications to match the many module providers new 5G modules who utilize this smaller receptacle. Before integration of the antenna in your device, especially if you require PTCRB or US network approvals, please contact your regional Taoglas customer support team. Cable length and connector type are fully customizable, for further information please contact your regional Taoglas customer support team. SPE-21-8-016-A www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Band Frequency (MHz) 5GNR/4G Band 71 617~698 4G/3G Band 12,13,14,17,28,29 698~806 3. Efficiency (%) MIMO 1 Electrical Specifications Average Gain Peak Gain (dB) (dBi) 33.7 MIMO 2 32.7 Antenna Characteristics -4.73 1.08 -4.85 1.18 MIMO 1 34.5 -4.62 1.48 MIMO 2 34.3 -4.65 1.68 4G/3G/NB-IoT/Cat M MIMO 1 37.2 -4.29 1.46 5GNR/4G Characteristics2. 1427~1518 Band 21,32,74,75,76 MIMO 1 75.7 -1.21 Specifications 3.56 Impedance Max Input Power 50 Ω 2W Polarization Radiation Pattern 4. 5,8,18,19,20,26,27 Antenna824~960 Radiation Patterns3. Antenna Band MIMO 2 38.9 -4.10 1.71 MIMO 1 4G/3G Band 1,2,3,4,9,23,25,35,39,66 1710~2200 4G/3G Band 7,30,38,40,41 2300~2690 5GNR/4G Band 22,42,48,77,78 3300~4200 LTE5200/ Wi-Fi 5800 5150~5925 3. 3. MIMO 2 74.1 -1.30 72.5 -1.39 70.8 Antenna Characteristics2. MIMO 2 3.79 4.83 OmniDirectional -1.50 4.51 Specifications MIMO 1 63.0 -2.01 4.01 MIMO 2 64.5 -1.91 3.78 MIMO 1 46.9 -3.29 3.85 -2.69 3.66 Antenna Characteristics MIMO 2 53.8 Linear MIMO 1 35.4 -4.51 3.76 MIMO 2 36.4 -4.39 5.26 on 2mm ABS 4.*Tested Antenna Radiation Patterns3.Antenna Characteristics 4. Mechanical Dimensions 240mm X 21mm X 0.15mm Weight 4.2g Antenna Radiation Patterns Material Connector 4. Flexible Polymer I-PEX MHF® 4L (HSC Compatible) Cable 150mm of Ø1.37 Coaxial cable Antenna Radiation Patterns3.Antenna Adhesive Characteristics 3M 467 Environmental Temperature Range 4. -40°C to 85°C Antenna Radiation Patterns3.Antenna Characteristics2. SPE-21-8-016-A Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-21-8-016-A Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Isolation 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-21-8-016-A www.taoglas.com 6 3.3 Efficiency 3.4 Average Gain SPE-21-8-016-A www.taoglas.com 7 Peak Gain dBi 3.5 SPE-21-8-016-A www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup – 2mm ABS 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y X 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns SPE-21-8-016-A www.taoglas.com 9 4.2 MIMO 1, 3D and 2D Radiation Patterns 652MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 10 751MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 11 890MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 12 1470MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 13 1805MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 14 1920MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 15 1990MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 16 2595MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 17 3550MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 18 5530MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 19 4.3 MIMO 2, 3D and 2D Radiation Patterns 652MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 20 751MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 21 890MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 22 1470MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 23 1805MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 24 1920MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 25 1990MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 26 2595MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 27 3550MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 28 5530MHz XY Plane SPE-21-8-016-A XZ Plane YZ Plane www.taoglas.com 29 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-016-A Mechanical Drawing www.taoglas.com 30 6. Packaging 6. 50pcsPackaging5. Mechanical Drawing FXUB71.A.54.C.001 per PE Bag Weight – 235.5g 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 2000pcs FXUB71.A.54.C.001 per carton Dimensions - 390*350*270mm Weight – 5.4Kg 6. Packaging5. 6. Packaging Mechanical Drawing Dimensions 1200*1200*1000mm 7. Pallet Application Note6. Packaging 30 Cartons per Pallet 10 Cartons per layer 3 Layers 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-016-A Mechanical Drawing www.taoglas.com 31 Changelog for the datasheet SPE-21-8-016 – FXUB71.A.54.C.001 Revision: A (Original First Release) Date: Notes: 2021-03-18 Author: Jack Conroy Previous Revisions SPE-21-8-016-A www.taoglas.com 32 www.taoglas.com SPE-21-8-016-A © Taoglas 33 www.taoglas.com
FXUB71.A.54.C.001 价格&库存
很抱歉,暂时无法提供与“FXUB71.A.54.C.001”相匹配的价格&库存,您可以联系我们找货
