HC125.A
HC125.A
    TAOGLASLIMITED
    Multiband GNSS Hybrid Coupler
HC125.A 数据手册
High Performance Multiband GNSS Hybrid Coupler Part No: HC125A Description: Low Profile, High Performance Multiband GNSS Hybrid Coupler Features: Frequencies Covered: • 1150-1630 MHz Low Insertion Loss Tight amplitude balance and high isolation Low VSWR Au surface plated to prevent oxidation Supplied on Tape & Reel Dimensions: 6.35 x 5.08 x 1.5mm RoHS & Reach Compliant SPE-20-8-104-C 1. Introduction 3 2. Specifications 4 3. Typical Performance 6 4. Pin Configuration 7 5. Performance @ 25°C 8 6. Mechanical Drawing 10 7. PCB Layout 11 8. Solder Reflow Diagram 12 9. Packaging 13 Changelog Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-20-8-104-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas HC125A is a low profile, high performance, 3dB hybrid coupler in an easy to integrate surface mount package. It is designed for multi feed GNSS applications. The HC125A is particularly used for applications where balanced power and low noise amplifiers are required. It has low insertion loss and tight amplitude and can be used in power applications up to 30 Watts. It has been engineered to cover the full GNSS bandwidth of 1150 – 1630MHz. Introduction The HC125A has been subjected to rigorous qualification testing and it is manufactured using materials with coefficients of thermal expansion (CTE) compatible with common substrates such as FR4, G-10, RF-35, RO4350 and polyimide. Introduction The HC125A is the perfect companion to ensure successful integration of multi feed high performance, high precision GNSS patches from Taoglas such as the full band GPDF5012.A or the dual L1 feed GPDF254.A. Integration details are included in specific product datasheets but for further information regarding the HC125A or it’s integration with any of our antennas, please contact your regional Taoglas customer support team. Introduction SPE-20-8-104-C www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications 3. GPS GLONASS L1 L2 L5 ▓ ▓ ▓ G1 G2 G3 Antenna▓ Characteristics ▓ Galileo ▓ E1 E5a E5b E6 ▓ ▓ ▓ ▓ 4. BeiDouAntennaB1 Radiation Patterns3. Antenna B2a B2b B3 ▓ Characteristics2. QZSS (Regional) ▓ ▓ Specifications ▓ L1 L2C L5 L6 ▓ ▓ ▓ ▓ 3. IRNSS AntennaL5 Characteristics2. (Regional) Specifications ▓ SBAS 3. L1/E1/B1 L5/B2a/E5a Antenna▓ Characteristics ▓ G1 G2 G3 ▓ ▓ ▓ *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. GNSS Bands and Constellations Antenna Radiation Patterns3.Antenna Characteristics2. SPE-20-8-104-C Specifications www.taoglas.com 4 Electrical Specifications Parameter Value Frequency 1150 – 1630MHz Isolation 22dB Min Insertion Loss 0.3 dB Max VSWR 1.2 Amplitude Balance +/- 0.35 dB Max Phase Balance 90 Degrees Power 30 CW Watts Avg. Note: All of the above data is based on HCD125A evaluation board. Mechanical Dimensions 6.35 x 5.08 x 1.5mm Weight 1g Environmental Temperature Range -55°C to +125°C RoHS & REACH Compliant Yes SPE-20-8-104-C www.taoglas.com 5 3. Typical Performance Data (@25°c) 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-20-8-104-C www.taoglas.com 6 4. Pin Configuration The HC125A has an orientation marker to denote Pin 1. Once port one has been identified the other ports are known automatically. Please see the chart below for clarification: 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Note: The “A” is the amplitude of the applied signals. When two quadrature signals with equal amplitudes are applied to the coupler as described in the table, they will combine at the output port. If the amplitudes are not equal, some of the applied energy will be directed to the isolated port. SPE-20-8-104-C www.taoglas.com 7 5. Typical Performance (-55°C, 25°C, 95°C, 125°C: 1150-1630 MHz) . Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-104-C Mechanical Drawing www.taoglas.com 8 SPE-20-8-104-C www.taoglas.com 9 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-104-C Mechanical Drawing www.taoglas.com 10 8. 7. Packaging Recommended PCB Layout 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note Notes: 1. 50Ω line width is shown above designing from RO4350B dielectric thickness 0.762mm; copper 1 OZ 2. Bottom side of the PCB is continuous ground plane. 3. All dimensions shown in mm. 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-104-C Mechanical Drawing www.taoglas.com 11 8. Reflow Profile 6. Packaging5. Mechanical Drawing The HC125.A can be assembled by following the recommended soldering temperatures are as follows: 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-104-C Mechanical Drawing www.taoglas.com 12 8. 9. Packaging pcs HC125A per Reel 6.1,000 Packaging5. Reel Dimensions: Ø177 x 20.1mm Mechanical Drawing Weight: 1.1Kg A.10 Sprocket hole pitch cumulative tolerance is 0.2mm. B. Carrier camber shall be not more than 1mm per 100mm through a length of 250mm. C. All dimensions meet EIA-418-B requirements D. A0 & B0 measured as indicated. E. K0 measured from a place on the inside bottom of the pocket to top surface of carrier. F. Material: PE 100 G. Thickness: 0.30±0.05mm H. 1000 units (maximum) / T&R 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-104-C Mechanical Drawing www.taoglas.com 13 Changelog for the datasheet SPE-20-8-103 – HC125A Revision: C (Current Version) Date: Changes: Changes Made by: 2023-09-19 Updated PCB layout information. Cesar Sousa Previous Revisions Revision: B Date: Changes: Changes Made by: 2021-01-02 Updated Part number Jack Conroy Revision: A (Original First Release) Date: Notes: 2020-10-28 Initial Release Author: David Connolly SPE-20-8-104-C www.taoglas.com 14 www.taoglas.com SPE-20-8-104-C © Taoglas www.taoglas.com 15
HC125.A 价格&库存
很抱歉,暂时无法提供与“HC125.A”相匹配的价格&库存,您可以联系我们找货
HC125.A
    库存:1520
