FXUB66.54.0150C
FXUB66.54.0150C
    TAOGLASLIMITED
    780MHz,1.4125GHz,1.575GHz,1.85GHz,1.9625GHz,2.45GHz,2.6GHz,3.55GHz,5.4GHz 2G,3G,4G,5G,GNSS,ISM,Wi-Fi...
FXUB66.54.0150C 数据手册
Maximus Part No: FXUB66.54.0150C Description: Flexible Wide Band 5G/4G Antenna 600-6000MHz Features: Ground Plane Independent 600-6000MHz Wideband 5G/4G fully operational on all Sub-6GHz bands Efficiencies up to 80% on all cellular bands (600-6000MHz) 120.4 x 50.4 x 0.2 mm size Connector: I-PEX MHF®4L HSC Compatible Cable: 150mm of Ø1.37 CE Certified RoHS & REACH Compliant SPE-21-8-014-A 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. 2D Radiation Patterns 9 5. Mechanical Drawing 18 6. Packaging 19 Changelog 20 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-21-8-014-A www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction Maximus FXUB66 flexible wideband antenna has been designed to cover all working frequencies in 1.The patented Introduction the 600-6000 MHz spectrum, including all Cellular(5G/4G/3G/2G), NB-IoT, Cat-M, Wi-Fi, ISM and GNSS bands. Its use in a device improves substantially the radiated power and sensitivity, and enables the highest throughput rates of today's broadband devices. is delivered with a flexible body with ground breaking high efficiencies on all bands, ground-plane 1.The antenna Introduction independent, with a cable and connector for easy installation. It is made of durable flexible polymer, with a peak gain of 5dBi, an efficiency of more than 60% across all cellular bands and is designed to be mounted directly onto a plastic or glass enclosure / cover. 1.At 120.4x50.4x0.2mm, Introduction the antenna is ultra thin. It is assembled by a simple “peel and stick” process, attaching securely to non-metal surfaces via 3M adhesive. It enables designers to use only one antenna that covers all frequencies and future proofs device design for 5G and 4G globally. It is also the ideal antenna to fit in devices that are being retrofitted with wireless functionality, as it will cover non cellular applications such as 868, 915MHz or Zigbee applications. Its inherently wide bandwidth is more resistant to detuning than traditional small but narrow-band legacy antennas. 1. Introduction The Maximus antenna has a unique hybrid design. Within one antenna structure the electromagnetic waves travel in two predominant propagation modes - one for lower frequencies, (e.g. 5G/4G at 600 MHz) and the other for higher 5G/4G and Wi-Fi frequencies up to 6GHz. It is an ideal choice for any device maker that needs to keep manufacturing costs down over the lifetime of a product, as the same antenna can be used if the radio module is upgraded to work on a different frequency band. The FXUB66 uses a future proof I-PEX MHF® 4L connector for 5G applications to match the many module providers new 5G modules who utilize this smaller receptacle. Cables and Connectors are fully customizable, subject to MOQ, for further information please contact your regional Taoglas Customer support team. SPE-21-8-014-A www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Frequency (MHz) 3. 600-960 13901435 1575.42 Antenna Characteristics 2mm ABS 0.2dBi 2.5dBi 4.1dBi Specifications Electrical 17101990 17552170 24002500 25002700 33003800 48006000 2.8dBi 2.6dBi 3.5dBi 4.8dBi -2dB -1.8dB -1.8dB -2.4dB Peak Gain (dBi) 2dBi 1.6dBi Average Gain (dB) 2mm ABS 4. -2.7dB -2.6dB -1.3dB -2.1dB -2.5dB Antenna Radiation Patterns3.Max Antenna VSWR 2mm ABS 3.5:1 3.5:1 1.1:1 3:1 3.3:1 2.2:1 2:1 2.2:1 3:1 2mm ABS -5dB -5dB -20dB -6dB -5.5dB -7dB -10dB -7dB -6dB 65% 66% 57% Characteristics2. Specifications Max Return Loss(dB) Efficiency 3. 3. Antenna 60%Characteristics2. 48% 73% 2mm ABS Specifications 56% 63% 61% Impedance 50Ω Polarization Linear Antenna Radiation PatternCharacteristics Omni-Directional Input Power 5W Mechanical 4. Antenna Dimensions Radiation Patterns3.Antenna 120.4 x 50.4 x 0.2 mm Material Characteristics 4. 4. Flexible Polymer Cable 150mm of Ø1.37 (Fully customizable) Connector I-PEX MHF® 4L HSC Compatible(Fully customizable) Antenna Radiation PatternsEnvironmental Operating Temperature -40°C to 85°C Storage Temperature -40°C to 85°C RoHS Compliant Yes Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-21-8-014-A Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 3550 to 3700 48 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 79 4400 to 5000 85 SPE-21-8-014-A 698-716 728-746 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 0 -5 Return Loss (dB) -10 4. Antenna Radiation Patterns -15 -20 -25 4. Antenna Radiation Patterns3.Antenna -30 -35 Characteristics FXUB66 -40 600 900 1200 1500 1800 2100 2400 2700 3000 3300 3600 3900 4200 4500 4800 5100 5400 5700 6000 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 VSWR 7 4. 6 Antenna Radiation Patterns VSWR 5 4. 4 3 Antenna Radiation Patterns 2 4. 1 Antenna Radiation Patterns FXUB66 0 600 900 1200 1500 1800 2100 2400 2700 3000 3300 3600 3900 4200 4500 4800 5100 5400 5700 6000 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-21-8-014-A www.taoglas.com 6 3.3 Efficiency 100 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 600 900 1200 1500 1800 2100 2400 2700 3000 3300 3600 3900 4200 4500 4800 5100 5400 5700 6000 Frequency (MHz) 3.4 Peak Gain 7 6 5 4 Peak gain (dBi) 3 2 1 0 -1 -2 -3 -4 -5 600 900 1200 1500 1800 2100 2400 2700 3000 3300 3600 3900 4200 4500 4800 5100 5400 5700 6000 Frequency (MHz) SPE-21-8-014-A www.taoglas.com 7 3.5 Average Gain 0 -0.5 -1 -1.5 Average gain (dB) -2 -2.5 -3 -3.5 -4 -4.5 -5 -5.5 -6 600 900 1200 1500 1800 2100 2400 2700 3000 3300 3600 3900 4200 4500 4800 5100 5400 5700 6000 Frequency (MHz) SPE-21-8-014-A www.taoglas.com 8 4. 2D Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup On 2mm ABS 4. Antenna Radiation Patterns SPE-21-8-014-A www.taoglas.com 9 XY Plane SPE-21-8-014-A www.taoglas.com 10 SPE-21-8-014-A www.taoglas.com 11 XZ Plane SPE-21-8-014-A www.taoglas.com 12 SPE-21-8-014-A www.taoglas.com 13 SPE-21-8-014-A www.taoglas.com 14 YZ Plane SPE-21-8-014-A www.taoglas.com 15 SPE-21-8-014-A www.taoglas.com 16 SPE-21-8-014-A www.taoglas.com 17 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-014-A Mechanical Drawing www.taoglas.com 18 6. Packaging 6. 100pcsPackaging5. Mechanical Drawing FXUB66.54.0150C per PE Bag Weight – 380g 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 1000pcs FXUB66.54.0150C per carton Dimensions - 370*320*180mm Weight – 4.1Kg 6. Packaging5. 6. Packaging Mechanical Drawing Dimensions 1200*1000*1460mm 7. Pallet Application Note6. Packaging 63 Cartons per Pallet 9 Cartons per layer 7 Layers 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-014-A Mechanical Drawing www.taoglas.com 19 Changelog for the datasheet SPE-21-8-014 – FXUB66.54.0150C Revision: A (Original First Release) Date: Notes: 2021-03-18 Author: Jack Conroy Previous Revisions SPE-21-8-014-A www.taoglas.com 20 www.taoglas.com © Taoglas SPE-21-8-014-A www.taoglas.com 21
FXUB66.54.0150C 价格&库存
很抱歉,暂时无法提供与“FXUB66.54.0150C”相匹配的价格&库存,您可以联系我们找货
FXUB66.54.0150C
    • 20+48.08592
    • 60+45.80072
    库存:125
