GW.20.A151
GW.20.A151
    TAOGLASLIMITED
    Antenna Dipole -1.67dBi Gain Bag
GW.20.A151 数据手册
Specification Part No. : GW.20.A151 Product Name : 2dBi 2.4GHz Dipole Antenna with RP-SMA(M) Straight Connector Features : Terminal Antenna IP65 UV Resistant Waterproof Housing RP-SMA(M) Connector Dimension: 89.5mm * 9.6mm RoHS & REACH Compliant SPE-17-8-074/A Page 1 of 17 1. Introduction The GW.20 dipole RP-SMA(M) plug mount antenna is ideal for 2.4~2.5GHz wireless applications such as Bluetooth and Wireless LAN. The antenna structure is flexible, so is designed for robust handling and the housing is made with UV Resistant TPE giving superior environmental reliability and a quality finish. Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi when installed. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. For Further information, please contact your regional Taoglas customer support team. SPE-17-8-074/A Page 2 of 17 2. Specification Electrical Frequency (MHz) 2400 2450 2500 Efficiency (%) Free Space 68.14 79.43 88.59 On 30cm*30cm Ground Center 93.35 91.70 85.72 On 30cm*30cm Ground Edge 86.36 88.49 83.11 Average Gain (dBi) Free Space -1.67 -1.00 -0.53 On 30cm*30cm Ground Center -1.07 -0.38 -0.67 On 30cm*30cm Ground Edge -1.30 -0.53 -0.81 Peak Gain (dBi) Free Space 0.65 1.26 1.68 On 30cm*30cm Ground Center 5.38 5.38 5.26 On 30cm*30cm Ground Edge 2.45 2.29 2.11 Return Loss
GW.20.A151 价格&库存
很抱歉,暂时无法提供与“GW.20.A151”相匹配的价格&库存,您可以联系我们找货
GW.20.A151
  • 1+81.462731+10.53845
