Specification
Part No.
GW.20.A151W
Product Name
White 2dBi 2.4GHz Dipole Antenna
with RP-SMA(M) Straight Connector
Features
Terminal Antenna
IP65 UV Resistant Waterproof Housing
RP-SMA(M) Connector
Dimension: 89.5mm * 9.6mm
RoHS & REACH Compliant
SPE-18-8-125/A Page 1 of 15
1. Introduction
The GW.20.A151W dipole RP-SMA(M) plug mount antenna is ideal for 2.4~2.5GHz
wireless applications such as Bluetooth and Wireless LAN. The antenna structure is
flexible, so is designed for robust handling and the housing is made with UV
Resistant TPE giving superior environmental reliability and a quality finish.
Many module manufacturers specify peak gain limits for any antennas that are to
be connected to that module. Those peak gain limits are based on free-space
conditions. In practice, the peak gain of an antenna tested in free-space can
degrade by at least 1 or 2dBi when installed. So ideally you should go for a slightly
higher peak gain antenna than mentioned on the module specification to
compensate for this effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of appropriate
layout, integration technique, or cable, Taoglas can make sure any of our
antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a
specification and/or report for the selected antenna in your device that will clearly
show it complying with the peak gain limits, so you can be assured you are meeting
regulatory requirements for that module.
Choosing a Taoglas antenna with a higher peak gain than what is specified by the
module manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
For further information, please contact your regional Taoglas customer support
team.
SPE-18-8-125/A Page 2 of 15
2. Specification
ELECTRICAL
Frequency (MHz)
2400
2450
2500
Efficiency (%)
Free Space
68.14
79.43
88.59
On 30cm*30cm Ground Center
93.35
91.70
85.72
On 30cm*30cm Ground Edge
86.36
88.49
83.11
Average Gain (dBi)
Free Space
-1.67
-1.00
-0.53
-1.07
-0.38
-0.67
-1.30
-0.53
-0.81
Peak Gain (dBi)
Free Space
0.65
1.26
1.68
5.38
5.38
5.26
2.45
2.29
2.11
Return Loss
很抱歉,暂时无法提供与“GW.20.A151W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+88.078801+11.39535
