Multiband High Precision GNSS Stacked Patch Antenna
Part No:
GPDF5012.A
Description:
Passive Multiband High Precision GNSS Stacked Patch Antenna
Features:
Bands Covered:
• GPS (L1/L2/L5)
• IRNSS (L5)
• QZSS (L1/L2C/L5)
• Galileo (E1/E5a/E5b)
• GLONASS (G1/G2/G3)
• BeiDou (B1/B2a/B2b)
Dual pin, dual feed, 4-pin configuration
Dimensions: 50 x 50 x 12mm
RoHS & Reach Compliant
SPE-20-8-103-E
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics (with hybrid coupler)
6
4.
Radiation Patterns
11
5.
Field Test Data
17
6.
Mechanical Drawing
19
7.
Evaluation Board Mechanical Drawing
Antenna Integration Guide
21
9.
Packaging
28
Changelog
29
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-20-8-103-E
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The Taoglas GPDF5012.A is a high performance, multi-band passive GNSS antenna that has been carefully
designed to provide fantastic positional accuracy on the full GNSS spectrum. It covers GPS/QZSS L1/L2/L5,
GLONASS G1/G2/G3, Galileo E1/E5a/E5b, BeiDou B1/B2a/B2b, NAVIC L5, as well as SBAS
(WAAS/EGNOS/GAGAN/SDCM/SNAS).
Introduction
Correct implementation of the GPDF5012.A allows the user to achieve higher location accuracy, as well as
stability of position tracking in urban environments. The stacked patch construction has excellent
performance across the full bandwidth of the antenna. Its design has an even gain across the hemisphere,
giving excellent axial ratio, which in turn makes it extremely resilient to multipath rejection and provides
excellent phase centre stability.
Introduction
Typical applications that benefit from high precision capabilities include:
• Autonomous Driving
• Precision Positioning for Robotics
• Precision Agriculture
• Telematics & Container / Asset Tracking
• Timing Accuracy Synchronization
Introduction
The GPDF5012.A is the latest embedded addition to Taoglas’ product portfolio of high precision GNSS
antennas. When used on the base and/or the rover as part of an RTK configuration, the GPDF5012.A can
achieve genuine cm-level accuracy with proven results.
Full integration guidelines are contained in Section 8 of this datasheet including the Taoglas HC125.A hybrid
coupler that will be required for use for dual pin feed patch integrations. An active version of this antenna,
the ADFGP.50A.07.0100C is available and supplied with 100mm cable and I-PEX MHFI connector as standard.
Contact your local Taoglas Customer Services team for more information on any of the products listed above
or for support regarding integration.
SPE-20-8-103-E
www.taoglas.com
3
2.
Specifications
GNSS Frequency Bands Covered
L2
L5
3. GPS AntennaL1 Characteristics2.
Specifications
GLONASS
3.
G1
G2
G3
Antenna▓ Characteristics
Galileo
E1
E5a
E5b
E6
B2a
B2b
B3
4. BeiDouAntennaB1 Radiation
Patterns3.
Antenna
QZSS
Characteristics2.
L1
(Regional)
3.
IRNSS
(Regional)
Specifications
L2C
L5
L5
Antenna Characteristics2.
L6
Specifications
SBAS
L1/E1/B1
L5/B2a/E5a
G1
G2
G3
3.*SBAS systems:
Antenna
Characteristics
WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5).
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Bands and
Constellations
Antenna RadiationGNSS
Patterns3.
Antenna
Characteristics2.
SPE-20-8-103-E
Specifications
www.taoglas.com
4
GNSS Electrical
Frequency (MHz)
1176.45
1227.6
1561
1575.42
1602
VSWR (max.)
1.5:1
1.5:1
1.5:1
1.5:1
1.5:1
Passive Antenna Efficiency (%)
27.6
30.6
51.2
65.3
68.6
Passive Antenna Gain at Zenith (dBi)
0.90
0.92
2.96
4.32
4.44
Axial Ratio (dB)
1.46
1.03
1.24
1.08
1.19
Group Delay (ns)
2.5
6
3
3
3
PCO (cm)
0.9
1.0
1.1
1.1
1.1
PCV (cm)
1.0
1.1
1.2
1.2
1.2
Polarization
RHCP
Impedance
50Ω
Note: The antenna with Hybrid coupler was tested on a 70X70 mm ground plane
The PCO and PCV are calculated using a field of view of 60° elevation from zenith
Mechanical
Height
12.5 mm
Planner Dimension
50 x 50 mm diameter
Weight
86 g
Environmental
Temperature Range
-40°C to 85°C
RoHS Compliant
Yes
REACH Compliant
Yes
SPE-20-8-103-E
www.taoglas.com
5
3.
Antenna Characteristics(with hybrid coupler)
3.1
4.
L2_L5 - Return Loss (From Hybrid Couplers)
Antenna
Characteristics
-10
-15
4.
Antenna
Radiation Patterns
-20
Return Loss [dB]
4.
-25
-30
-35
Characteristics
-40
-45
-50
4.
Antenna
Radiation
Antenna
1000
1050
1100 Patterns3.
1150
1200
1250
1300
1350
1400
1700
1750
1800
Frequency [MHz]
Characteristics
3.2
L1 - Return Loss (From Hybrid Couplers)
Antenna
Radiation Patterns
-5
-10
4.
4.
Return Loss [dB]
-15
Antenna
Radiation Patterns
-20
-25
-30
-35
-40
4.
-45
Antenna
-50
1400
Characteristics1450
4.
1500
1550
1600
1650
Frequency [MHz]
SPE-20-8-103-E
www.taoglas.com
6
3.3
L2_L5 - Efficiency
100
90
80
Efficiency[%]
70
60
50
40
30
1050
1100
1150
1200
1250
1300
1350
1400
1650
1700
1750
1800
Frequency [MHz]
3.4
L1 – Efficiency
100
90
80
Efficiency[%]
70
60
50
40
30
1450
1500
1550
1600
Frequency [MHz]
SPE-20-8-103-E
www.taoglas.com
7
3.5
L2_L5 - Average Gain
Average Gain (dB)
-2
-4
-6
-8
-10
-12
1000
1050
1100
1150
1200
1250
1300
1350
1650
1700
1750
1400
Frequency [MHz]
3.6
L1 – Peak Gain
Average Gain (dB)
-2
-4
-6
-8
-10
-12
1400
1450
1500
1550
1600
1800
Frequency [MHz]
SPE-20-8-103-E
www.taoglas.com
8
3.7
L2_L5 - Peak Gain
10
8
6
Peak Gain [dBi]
4
2
-4
-6
-8
-10
1000
1050
1100
1150
1200
1250
1300
1350
1400
Frequency [MHz]
3.8
L1 - Peak Gain
10
8
6
Peak Gain [dBi]
4
2
-4
-6
-8
-10
1400
1450
1500
1550
1600
1650
1700
1750
1800
Frequency [MHz]
SPE-20-8-103-E
www.taoglas.com
9
3.9
Axial Ratio
L1
18
L2_L5
16
Axial Ratio [dB]
14
12
10
8
6
4
2
1100
1200
1300
1400
1500
1600
1700
1800
Frequency [MHz]
Phi=0
SPE-20-8-103-E
Phi=90
www.taoglas.com
10
4.
Radiation Patterns
4.
4.
4.
4.1
Test Setup
Z
4.
4.
4.
4.
4.
SPE-20-8-103-E
X
Y
www.taoglas.com
11
4.2
GNSS L1 Band 3D and 2D Radiation Patterns
Gain total, 1560MHz
XY Plane
SPE-20-8-103-E
XZ Plane
YZ Plane
www.taoglas.com
12
Gain total, 1575.42MHz
XY Plane
SPE-20-8-103-E
XZ Plane
YZ Plane
www.taoglas.com
13
Gain total, 1600MHz
XY Plane
SPE-20-8-103-E
XZ Plane
YZ Plane
www.taoglas.com
14
4.3
GNSS L2 L5 Band 3D and 2D Radiation Patterns
Gain total, 1177MHz
XY Plane
SPE-20-8-103-E
XZ Plane
YZ Plane
www.taoglas.com
15
Gain total, 1228MHz
XY Plane
SPE-20-8-103-E
XZ Plane
YZ Plane
www.taoglas.com
16
5.
Field Test Results
This section outlines the field test result for GPDF5012.A antenna. The test was performed when the antenna was
6.mounted
Packaging5.
Drawing
on a static rooftop testMechanical
set up in an open sky
environment for a minimum of 6 hours.
Taoglas will show the field test results using the following receivers:
6.5.1 Packaging
Ublox ZED-F9P-0XB
Receiver features:
7.
Multi-band GNSS: 184-channel GPS L1C/A L2C, GLONASS: L1OF L2OF, Galileo: E1B/C E5b, BeiDou: B1I B2I, QZSS: L1C/A L2C
Multi‑band RTK with fast convergence times and reliable performance
Nav. update rate RTK up to 20 Hz
Position accuracy = RTK 0.01 m + 1 ppm CEP
Application Note6. Packaging5.
Mechanical
Drawing
Positioning Accuracy Table (2D Accuracy)
Test
Condition
6.
DRMS(cm)
CEP (50%)
DRMS (68%)
RTK DISABLED
46.6
56.4
Packaging5.
Mechanical
Drawing
70x70mm
Ground
Plane
RTK ENABLED
1.0
1.2
6.
Packaging
7.
2DRMS (95-98.2%)
TTFF (sec)
112.8
32
2.4
32
RTK Availability
70x70 mm ground plane
No RTK
Float
7.
Application Note
7.
7.
Fixed
Mechanical
Drawing
6.
Packaging5.
SPE-20-8-103-E
Mechanical Drawing
www.taoglas.com
17
5.2
Ublox NEO-F9P-15B
Receiver features:
Multi-band GNSS: GPS / QZSS (L1C/A, L5) GLONASS (L1OF) Galileo (E1-B/C, E5a) BeiDou (B1I, B2a) NavIC (SPS-L5)
Multi‑band PPP-RTK with fast convergence times and reliable performance
Nav. update rate RTK up to 25 Hz
Test
Condition
70x70mm
Ground
Plane
DRMS(cm)
CEP (50%)
DRMS (68%)
2DRMS (95-98.2%)
TTFF (sec)
PPP-RTK
DISABLED
103.19
123.52
247.06
27
PPP-RTK
ENABLED
16.7
20.04
40.08
33
*The RTK correction service used in previous measurements provides superior corrections compared to the PPP-RTK service used for
measurements on the NEO-F9P.
PPP-RTK Availability
6%
No PPP-RTK
PPP-RTK Float
PPP-RTK Fixed
94%
SPE-20-8-103-E
www.taoglas.com
18
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-20-8-103-E
Mechanical Drawing
www.taoglas.com
19
8.
7.
Packaging Board Drawing (Units: mm)
Evaluation
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-20-8-103-E
Mechanical Drawing
www.taoglas.com
PackagingIntegration Guide
Antenna
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-20-8-103-E
Mechanical Drawing
www.taoglas.com
21
8.1
Schematic Symbol and Pin Definitions
The circuit symbol for the antenna is shown below. The antenna has 4 pins as indicated below. The L1P1 and L1P2
(Pin 1 and 2) represent the higher GNSS frequency bands at 1559 - 1610MHz and the L2P1 and L2P2 (Pin 3 and 4)
represent the lower GNSS frequency bands at 1164 - 1300MHz, including L5, E5a and E5b bands.
SPE-20-8-103-E
Pin
Description
1
L1P1 (0˚)
2
L1P2 (-90˚)
3
L2P1 (0˚)
4
L2P2 (-90˚)
www.taoglas.com
22
8.2
Antenna Integration
The antenna should be placed at the center of the PCB, in our integration we have used a 70mm X 70mm PCB
evaluation board. Maintaining a symmetric ground plane shape and symmetric environment around the antenna
is critical to maintaining the excellent axial ratio and phase center performance shown in this datasheet. The
opposite side of the PCB from the antenna may be used for device electronics and does not need to maintain
symmetry.
SPE-20-8-103-E
www.taoglas.com
23
8.3
PCB Layout
The footprint and clearance on the PCB must comply with the antenna specification. The PCB layout shown in the
diagram below demonstrates the antenna footprint.
Note that the hybrid couplers may be placed closer to the antenna pins. It is important that the trace length from
the antenna pins are equal to their respected hybrid coupler. This is necessary to maintain the integrity of the
phase in the signal.
SPE-20-8-103-E
www.taoglas.com
24
8.4
Eval Board
SPE-20-8-103-E
www.taoglas.com
25
8.5
Matching Circuit
Each patch element uses two orthogonal feeds that need to be combined in a hybrid coupler to ensure optimal
axial ratio. Taoglas recommends our HC125.A, a high-performance hybrid coupler specifically engineered for use
with our multi feed patches.
Two HC125.A’s are required for this antenna, one for the high GNSS band of operation (1559-1610MHz) and
another for the low GNSS band (1164MHz – 1300MHz). These hybrid couplers should be placed close to the
antenna pins and terminated correctly using 2x 100ohm resistors in parallel.
The output of each of the hybrid couplers can feed into separate paths for high and low band GNSS filtering and
amplification.
Designator
Type
Value
Manufacturer
Manufacturer Part Number
R1, R2, R3, R4
Resistor
100Ω (1%)
Vishay
CRCW0603100RFKEC
SPE-20-8-103-E
www.taoglas.com
26
8.6
Footprint
SPE-20-8-103-E
www.taoglas.com
27
8.
9.
Packaging
6.
Weight: 690g
Packaging5.
6.
Packaging
7.
Dimensions: 263*154*96
mm
Application
Note6.
Packaging5.
Weight: 3Kg
8pcs GPDF5012.A per Tray
Mechanical Drawing
32pcs GPDF5012.A per Inner Carton
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
128pcs GPDF5012.A per Inner Carton
Dimensions: 327*280*218 mm
Weight: 12.5Kg
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-20-8-103-E
Mechanical Drawing
www.taoglas.com
28
Changelog for the datasheet
SPE-20-8-103 – GPDF5012.A
Revision: E (Current Version)
Date:
Notes:
Author:
2023-07-25
Updated Antenna Field Testing
Gary West
Previous Revisions
Revision: D
Date:
Notes:
Author:
2023-05-16
Updated test data
Gary West
Revision: C
Date:
Notes:
Author:
2022-01-11
Added integration guide
Gary West
Revision: B
Date:
Notes:
Author:
2022-01-11
Gary West
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-20-8-103-E
2020-10-14
Initial Release
Jack Conroy
www.taoglas.com
29
www.taoglas.com
SPE-20-8-103-E
www.taoglas.com
© Taoglas
30
很抱歉,暂时无法提供与“GPDF5012.A”相匹配的价格&库存,您可以联系我们找货
