ADFGP.25E.07.0060A
ADFGP.25E.07.0060A
    TAOGLASLIMITED
    TAOGLAS - ADFGP.25E.07.0060A - Antenna, Patch, 1.559 GHz to 1.61 GHz, -5.4 dB, Right Hand Circular, ...
ADFGP.25E.07.0060A 数据手册
Part No: ADFGP.25E.07.0060A Description: Embedded GPS/GLONASS/BeiDou/Galileo Dual Pin Active Patch Antenna with 60mm of 1.13 Grey Microcoax & IPEX MHFI (U.FL Compatible) Features: Embedded Dual-Pin Patch for Lowest Axial Ratio Covering Bands: • GPS L1 • GLONASS L1CR & L1PT • Galileo E2 & L1 • BeiDou B1 Cable: 60mm of 1.13mm Connector: IPEX MHFI (U.FL Compatible) Dimensions: 25 x 25 x 7.5mm Tuned for Free Space RoHS & Reach Compliant SPE-20-8-069-B 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 8 4. Radiation Patterns 11 5. LNA Characteristics 14 6. Mechanical Drawing 16 7. Packaging 17 Changelog 18 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-20-8-069-B www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Taoglas ADFGP.25E is an embedded patch antenna covering 1559MHz to 1610MHz. It has a dual feed, Introduction active patch design which makes it ideal for next-generation GNSS devices that require excellent positional accuracy in a small factor. The active patch antenna, by means of a double resonance design, has a wide- 1. band operation over GNSS systems including GPS (L1), GLONASS (G1), Galileo (E1) and BeiDou(B1). The 25 Introduction mm patch uses a dual-feed configuration that combines both feeds with a 90° hybrid coupler to obtain an optimal axial ratio. 1. The ADFGP.25E includes an LNA and front-end SAW filter to reduce out of band noise, such as from nearby Introduction cellular transceivers. It offers better protection from nearby radiated power surges and greatly reduces the probability of damaging your GNSS receiver from nearby transmissions. The ADFGP.25E is manufactured and 1. tested in a TS16949 first tier automotive approved facility. Introduction The antenna is supplied with Ø 1.13 cable and an IPEX MHFI (U.FL compatible) connector. The patch, the PCB (ground plane), the LNA, and front-end SAW components are all integrated into a form factor of just 25.1 x 25.1 x 7.5 mm. It connects via a 60mm Ø 1.13 coaxial cable and IPEX MHFI connector. Features: • Compact Dual Feed Patch Antenna • Excellent signal to noise ratio (C/N0) • Good 2DRMS and fast TTFF • Axial ratio < 5dB typ. across all bands SPE-20-8-069-B www.taoglas.com 3 Benefits: • Excellent positional accuracy • Great for use in difficult environments • Excellent out-of-band signal rejection • Ideal antenna solution for RTK systems. Typical applications include: • High accuracy positioning and navigation systems • UAVs, Robotics & Autonomous Vehicles • Micro-Mobility Solutions • Mapping & GIS • Transportation & Telematics • Precision Agriculture • Public Safety, Search & Rescue • RTK Systems This antenna has been tuned for Free space, we also provide a version of this with a 70*70mm ground plane: ADFGP.25A.07.0060A. Custom antenna modifications are subject to possible NRE and minimum order quantity. For further information or support to test and integrate Taoglas Sure technology please contact your regional Taoglas customer support team. SPE-20-8-069-B www.taoglas.com 4 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications GPS L1 L2 L5 GLONASS 3. □ □ G1 G2 G3 ▓ □ Antenna Characteristics Galileo BeiDou 4. ▓ E1 E5a E5b E6 ▓ □ □ □ B1 B2a B2b B3 ▓ □ □ □ Antenna Radiation Patterns3. Antenna QZSS (Regional) L1 Characteristics2. ▓ IRNSS (Regional) 3. 4. L2C L5 L6 □ □ □ Specifications L5 □ Antenna Characteristics2. SBAS L1/E1/B1 L5/B2a/E5a ▓ □ ◼ GNSS Frequency Bands Covered. 3. □ Specifications G1 G2 G3 ▓ □ □ □ GNSS Frequency Bands Not Covered. *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). Antenna Characteristics Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3. Antenna GNSS Bands and Constellations Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-20-8-069-B Characteristics2. Specifications www.taoglas.com 5 GNSS Electrical Frequency (MHz) 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 Efficiency (%) 20.4 34.6 29 Peak Gain at Zenith (dBi) -1.9 0.5 -0.8 Average Gain (dB) -6.8 -4.6 --5.4 Axial Ratio (dB) 2.4 1.7 1.6 Phase Centre Offset PCO (cm) 0.2 0.2 0.2 Phase Centre Variation 0.8 0.8 0.8 Polarization R.H.C.P. Impedance 50Ω Note. The patch antenna test with hybrid coupler HC125A LNA and Filter Electrical Properties Frequency (MHz) 1561 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 2.0:1 Gain@1.8V (Typ.) 31.3 dB 30.2 dB 29.8 dB Gain@3.0V (Typ.) 31.1 dB 30.1 dB 30.0 dB Gain@5.5V (Typ.) 33.5 dB 33.0 dB 33.1 dB Noise@1.8V (Typ.) 3.1 dB 2.7 dB 3.0 dB Noise@3.0V (Typ.) 3.1 dB 2.7 dB 3.0 dB Noise@5.5V (Typ.) 3.3 dB 2.9 dB 3.2 dB Power consumption@1.8V (Typ.) 5.0mA Power consumption@3.0V (Typ.) 5.1mA Power consumption@5.5V (Typ.) 5.2mA Total Specification (Through Antenna, SAW Filter and LNA) Frequency (MHz) 1561 1575.42 1602 Gain@3V (dB) 32.8dB 35.5dB 33.7dB Output Impedance SPE-20-8-069-B 50 Ω www.taoglas.com 6 Mechanical Ceramic Dimension 25 x 25 x 4.0mm Total Dimension (Including Shielding Case) 28x28 mm Connector IPEX MHFI (U.FL) Cable Coaxial Cable ø1.13, length 60mm Weight 13.5g Environmental Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH RoHS Compliant Yes REACH Compliant Yes SPE-20-8-069-B www.taoglas.com 7 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -5 Antenna Radiation Patterns Return Loss (dB) 4. 4. -10 Antenna Radiation Patterns3.Antenna -15 Characteristics -20 1400 4. 1450 1500 1550 Frequency (MHz) 1600 1650 1700 Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 100 4. Antenna Radiation Patterns 90 80 4. Efficiency [%] 4. 70 Antenna Radiation Patterns 60 50 40 Antenna Radiation Patterns 30 20 4. Antenna Radiation Patterns3.Antenna 10 0 1500 1510 1520 Characteristics 4. 1530 1540 1550 1560 1570 1580 1590 Antenna Radiation Patterns3.Antenna SPE-20-8-069-B 1600 1610 1620 1630 1640 1650 Frequency [MHz] www.taoglas.com 8 3.3 Average Gain 0 -1 -2 Average Gain [dBi] -3 -4 -5 -6 -7 -8 -9 -10 1500 1510 1520 1530 1540 1550 1560 1570 1580 1590 1600 1610 1620 1630 1640 1650 1600 1610 1620 1630 1640 1650 Frequency [MHz] 3.4 Peak Gain 5 4 3 2 Gain [dBi] 1 0 -1 -2 -3 -4 -5 1500 1510 1520 1530 1540 1550 1560 1570 1580 1590 Frequency [MHz] SPE-20-8-069-B www.taoglas.com 9 3.5 Axial Ratio vs Frequency Axial Ratio vs Frequency 8 7 With Hybrid Coupler Axial Ratio [dB] 6 5 4 3 2 1 0 1550 1560 1570 1580 1590 1600 1610 1620 1630 1640 1650 Frequency [MHz] 3.6 Axial Ratio vs Degrees AR vs Degrees 6 5 4 Axial Ratio [dB] L1 Phi=0 L1 Phi=90 3 2 1 0 -80 -60 -40 -20 0 20 40 60 80 Degrees [˚] SPE-20-8-069-B www.taoglas.com 10 4. Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup SPE-20-8-069-B www.taoglas.com 11 4.2 2D Radiation Patterns XY Plane X 10 5 0 -5 -10 -15 -20 -25 -30 Y 1575MHz 1585MHz 1600Mhz XZ Plane Z 10 5 0 -5 -10 -15 -20 -25 -30 X 1575MHz 1585MHz 1600Mhz SPE-20-8-069-B www.taoglas.com 12 ZY Plane Z 10 5 0 -5 -10 -15 -20 -25 -30 Y 1575MHz 1585MHz 1600Mhz SPE-20-8-069-B www.taoglas.com 13 5. LNA Characteristics 5.1 4. Block Diagram (Active Antenna) Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics LNA GainRadiation & Noise Figure (dB) 4.5.2 Antenna Patterns3. Antenna 40 Characteristics 30 4. 20 Antenna Radiation Patterns 10 0 4. Antenna Radiation Patterns -10 -20 4. Antenna Radiation Patterns -30 -40 4. 1500 1520 1560 1580 Antenna Radiation Patterns3. Antenna FREQUENCY(MHZ) S11-Sample 1 S12-Sample 3 Characteristics 4. 1540 S11-Sample 2 S11-Sample 3 S12-Sample 1 1561MHz 1575.42MHz 1602MHz Antenna Radiation Patterns3.Antenna SPE-20-8-069-B 1600 1620 1640 S12-Sample 2 www.taoglas.com 14 5.3 S12 Wide Band Plot 40 30 20 10 (DB) 0 -10 -20 -30 -40 -50 -60 300 500 700 900 1100 1300 1500 1700 1900 2100 2300 2500 2700 2900 FREQUENCY(MHZ) 5.4 Noise Figure - LNA 10 9 8 7 (dB) 6 5 4 3 2 1 0 1500 1520 1540 1560 1580 1600 1620 1640 Frequency(MHz) SPE-20-8-069-B www.taoglas.com 15 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-20-8-069-B Mechanical Drawing www.taoglas.com 16 7. Packaging 30pcs ADFGP.25E.07.0060A per Tray Weight: 615g 4. Antenna Radiation Patterns3.Antenna Characteristics 150pcs ADFGP.25E.07.0060A per PE 4. Bag Dimensions: Antenna Radiation Patterns 420*560 mm Weight: 3.075Kg 4. Antenna Radiation Patterns3.Antenna Characteristics 450pcs ADFGP.25E.07.0060A per carton Dimensions - 390*320*290mm Weight: 9.4Kg 4. Antenna Radiation Patterns3.Antenna Characteristics 290mm 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 320mm 390mm 4. Changelog Antenna Radiation Patterns3.Antenna for the datasheet Characteristics SPE-20-8-069-B www.taoglas.com 17 SPE-20-8-069 – ADFGP.25A.07.0060A Revision: B Date: Changes: Changes Made by: 2024-01-30 Drawing updated Cesar Sousa Previous Revisions Revision: A Date: Changes: Changes Made by: SPE-20-8-069-B 2020-06-12 Initial Release Jack Conroy www.taoglas.com 18 www.taoglas.com © Taoglas SPE-20-8-069-B www.taoglas.com 19
ADFGP.25E.07.0060A
1. 物料型号:ADFGP.25E.07.0060A 2. 器件简介:ADFGP.25E是嵌入式贴片天线,覆盖1559MHz至1610MHz频段,具有双馈电、主动贴片设计,适合需要极高精度的下一代GNSS设备。它通过双共振设计,实现了对GPS (L1)、GLONASS (G1)、Galileo (E1)和BeiDou(B1)等GNSS系统的宽带操作。 3. 引脚分配:嵌入式双针贴片,通过90°混合耦合器组合两个馈电以获得最佳轴比。 4. 参数特性: - 轴比:< 5dB典型值,覆盖所有频段。 - 效率:20.4%至34.6%。 - 增益:在不同频率下,峰值增益从-1.9 dBi至0.5 dBi,平均增益从-6.8 dB至-4.6 dB。 - 相位中心偏移:0.2cm。 - 极化:右旋圆极化。 - 阻抗:50欧姆。 5. 功能详解:ADFGP.25E包括一个低噪声放大器(LNA)和前端SAW滤波器,以减少带外噪声,如附近蜂窝收发器的干扰。它提供了更好的保护,以防止附近的辐射功率突增损坏GNSS接收器。 6. 应用信息:适用于高精度定位和导航系统、无人机、机器人和自动驾驶车辆、微型移动解决方案、测绘和地理信息系统、交通和远程通信、精准农业、公共安全、搜索和救援等。 7. 封装信息:尺寸为25 x 25 x 7.5mm,带有60mm长的1.13mm微同轴电缆和兼容U.FL的IPEX MHFI连接器。环境操作温度范围为-40°C至85°C。
ADFGP.25E.07.0060A 价格&库存
很抱歉,暂时无法提供与“ADFGP.25E.07.0060A”相匹配的价格&库存,您可以联系我们找货
ADFGP.25E.07.0060A
    • 3+250.758463+32.44230
    • 20+214.9483020+27.80930
    • 80+205.0786780+26.53240
    • 200+196.16980200+25.37980
    库存:500
    ADFGP.25E.07.0060A
    • 1+348.684891+45.11170
    • 10+283.9117310+36.73156
    • 25+267.7360125+34.63880
    • 100+249.95198100+32.33796
    • 300+240.03416300+31.05483
    库存:29
    ADFGP.25E.07.0060A
      • 7+142.96401
      • 20+136.10842
      • 80+129.97828
      • 200+124.31969
      库存:500
      ADFGP.25E.07.0060A
      • 3+232.90023
      • 20+199.60139
      • 80+190.45020
      • 200+182.18538
      库存:500
      ADFGP.25E.07.0060A
      • 1+210.473501+27.23037
      • 20+151.0357120+19.54050
      • 80+144.2995780+18.66900
      • 200+137.96921200+17.85000
      库存:500
