ELC.10B
ELC.10B
    TAOGLASLIMITED
    EDGE IoT Starter kit with High Precision GNSS, RTK, 4G + 3G Connectivity (US), on-board sensors and ...
ELC.10B 数据手册
DATASHEET ELC.10 - EDGE IoT Starter Kit with High Precision GNSS and RTK Instant IoT across many verticals and applications • High precision GNSS with RTK capabilities allows for gathering of high precision positioning data in minutesIntegrated onboard sensors such as temperature, humidity, accelerometer, gyroscope, magnetometer, light and air pressure • Cellular support for LTE, 3G, 2G, Cat-M, NB-IoT to give a global coverage footprint • Contains rechargeable battery with multi year battery performance • Predictive insights that drive optimization and new revenue opportunities • Built with EDGE Insights cloud-based enterprise-level software platform with network, sensor, security and data management • Completely cloud configurable EDGE hardware (no need to change device firmware) Build a cloud-powered IoT application in minutes with the Taoglas® precertified EDGE IoT Starter Kit. • Easy 3rd party sensor and machine interfacing and integration through server side Sensor Management System • Over-The-Air (OTA) updates and device diagnostics • Supported by a full IoT security stack, power, device management and Data-as-a-Service out of the box • Includes 1 month of EDGE Insights™ and cellular data subscription* Industry’s most comprehensive IoT Starter kit including cellular, Bluetooth, on-board sensors, multiband GNSS and RTK, and cloud based management platform. Key Benefits • Can help you build your IoT prototype in minutes • OEM boards inside can be customized and purchased separately for new product introductions • Reduce the cost and complexity of introducing IoT strategies into enterprises avoiding lengthy design, development, integration, testing, data services and customization spend with fast time-to-value The Taoglas EDGE IoT Starter Kit is preconfigured with an active cellular data plan. • Provides real-time sensor and positioning data and can enable real-time intelligence from the EDGE instantly * Includes 1 month subscription of HxGN SmartNet Typical Applications Ground Robotics Navigation Lane-level Navigation Vehicle Telematics & Asset Tracking Heavy Machine Navigation Connected Vehicles e-Bike & Scooters Commercial UAV Precision Agriculture All copyrights, trademarks and any other intellectual property rights related are owned by Taoglas Group Holdings Limited. IoT Gateways Smart Metering Smart Medical Smart Lighting www.taoglas.com DATASHEET ELC.10 - EDGE IoT Starter Kit PRODUCT SPECIFICATIONS System ELC.10B ELC.10L Processor ARM Cortex M7 (300MHz) RAM 384 KB Flash 2048 KB Firmware/OS RTOS + Applications Libraries (Real Time Performance) Security Radios Cloud Mutual authentication, hardware root of trust, secure key storage Cellular Cellular Bands On-board sensors LTE US with 3G fallback LTE EMEA with 2G fallback 4G (B2, B4, B5, B17) 3G (B2, B5) 4G (B3, B8, B20) 2G (900, 1800MHz) Carrier Acceptance Vodafone acceptance, other carriers to follow GNSS, RTK GPS/GLONASS/Galileo/BEIDOU (Optional RTK) Bluetooth BLE 4.2 Temperature Range: -40 to 125 °C Accuracy: ±0.3 °C (Standard), ±0.2 °C (High-End Version) Humidity Range: -40 (-104°F) to 125 °C (257°F) Accuracy: ±0.3 °C (32.5°F) (Standard), ±0.2 °C (32.3°F) (High-End Version) Light Range: 0.045-188,000 Lux Atmospheric Pressure Range: 300 … 1100 hPa Accelerometer Accuracy: typ. ±1 hPa Range: up to ± 16g Accuracy: up to 16384 LSB/g with 16 bit resolution Gyroscope Range: up to 2000°/s Accuracy: up to 262.4 LSB/°/s with 16 bit resolution Magnetometer Range: ±1300µT (x, y-axis), ±2500µT (z-axis) Accuracy: ~0.3µT Expansion External Connector Physical Operating temperature RS485, CAN, UART, GPIO, PWM, ADC, I2C, SPI -20°C (-4F) to +60°C (140F) Power Voltage: 3.2V – 4.5V, Current 2A- 3A Battery 2400 mAh rechargeable lithium battery Charging temperature 0°C (32F) to +45°C (113F) EDGE Insights and Data Plan Includes 1-month EDGE Insights subscription and cellular data plan* * Includes 1 month subscription of HxGN SmartNet 1) LTE-Cat1, CatM, NB-IoT 2) eSim EDGE Connect Board 3) RGB User LED 4) User Button 5) Green LED (USB Power Applied) 6) Bluetooth 7) Orange LED (Charging Status) 8) Reset Button 9) SPI Serial Flash Memory 10) Secure Element 24) Ceramic 4G Antenna 11) Battery Charger IC 23) RF Switch Antenna 158.3mm 12) Edge Expansion 22) Alternative uFL Antenna 21) Power Button 20) Temperature /Humidity 19) Pressure Sensor 18) Magnetometer 17) Micro USB (Charging Logging) 16) Accellerometer, Gyroscope 42mm 15) Light Sensor 14) ARM M4/7MCU 13) DC-DC Converter 54.3mm Dimensions: 158.3*54.3*42mm For further details go to www.taoglas.com/product/taoglas-edge-iot-starter-kit SPE-20-8-016-A Weight: 200g www.taoglas.com
ELC.10B 价格&库存
很抱歉,暂时无法提供与“ELC.10B”相匹配的价格&库存,您可以联系我们找货
ELC.10B
  • 1+11451.932131+1481.61311
  • 3+10993.954713+1422.36150
库存:5
