FXUB85.07.0150C
FXUB85.07.0150C
    TAOGLASLIMITED
    788.5MHz,1.4725GHz,1.955GHz,2.495GHz,4.15GHz,5.5375GHz,6.525GHz 3G,4G,5G,LTE 扁平插接线 RF 天线 617MHz ~ 96...
FXUB85.07.0150C 数据手册
Pylon Part No: FXUB85.07.0150C Description: Ultra Wide Band 5G Flex Antenna 600MHz to 8GHz Features: Ultra-wide bandwidth, covering all 5G/4G/3G applications 600 MHz – 8 GHz Operating Frequency Covers Full Wi-Fi Spectrum Including Wi-Fi 6 Small form factor High efficiency Excellent radiation pattern quality Cable: 150mm of 1.37mm coaxial cable Connector: I-PEX MHF®I (U.FL Compatible) RoHS and Reach Compliant SPE-21-8-017-A 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 11 5. Mechanical Drawing 26 6. Packaging 27 7. Application Note 28 Changelog 29 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-21-8-017-A www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas Pylon FXUB85 is an ultra-wideband flexible PCB antenna designed for the next generation of connectivity. The Pylon FXUB85 provides best-in-class performance for all 5G sub 6 GHz (FR1) and Wi-Fi 6 applications. Covering the entire spectrum from 600 MHz – 8 GHz, the Pylon allows for coverage in the 3.5 GHz CBRS bands, the 1400 MHz 5G NR bands 74,75,76, and the 3.6-4.6 GHz Japan 5G NR bands 77,78,79. It maintains excellent performance in all the traditional 4G LTE bands, including 4G LTE band 71 and allows for fallback to 3G/2G bands when necessary. Introduction The Pylon FXUB85 PCB has been expertly designed by Taoglas, to be the smallest size possible. At just 163 x 21 x 0.3mm, it can be neatly placed in the next generation of connected devices. As devices become more compact, the Pylon alleviates size constraint issues. The antenna performs well at a reasonable distance, typically 20mm, from a ground and has demonstrated ease of integration into complex end user equipment. Introduction Introduction Typical Applications Include: - IoT and Connected Devices - UAVs and Autonomous Vehicles - Precision Tracking - Industrial Robotics and Factory Automation - Field and Body Sensors and Wearables The Pylon FXUB85 antenna has a typical efficiency of more than 70% across both low and high frequency bands. The Pylon is designed to be mounted directly onto a plastic or glass enclosures. It is an ideal choice for any device maker that desires ease of integration and needs to keep manufacturing costs down over the lifetime of a product without compromising performance. Cable and connector are fully customizable, contact your regional Taoglas customer support team for more information. SPE-21-8-017-A www.taoglas.com 3 2. Specifications 5G/4G Bands 3. 3. 4. 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Antenna Characteristics2. Specifications Band Number Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 Antenna UL:Characteristics 1710 to 1755 4 DL: 2110 to 2155 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 9 Antenna Radiation Patterns3. Antenna UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 11 12 UL: 699 to 716 DL: 729 to 746 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 Characteristics2. UL: 777 to 787 Specifications DL: 746 to 756 13 3. 3. 4. UL: 830 to 845 19 Antenna Characteristics2. UL: 832 to 862 20 DL: 875 to 890 Specifications DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 Antenna Characteristics UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 30 UL: 2305 to 2315 DL: 2350 to 2360 Antenna Patterns3.DL:Antenna UL:Radiation - N/A 717 to 728 29 Characteristics 4. 4. 31 UL: 452.5 to 457.5 32 UL: - N/A DL: 462.5 to 467.5 DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 Antenna Radiation Patterns 2300 to 2400 40 3550 to 3700 48 Antenna Radiation Patterns3. Antenna UL: 1710-1780 DL: 2110-2200 66 617 to 698 71 Characteristics 74/75/76 1427 to 1518 3300 to 3800 78 4400 to 5000 79 85 4. 698-716 728-746 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Antenna Radiation Patterns3.Antenna Characteristics2. SPE-21-8-017-A Specifications www.taoglas.com 4 Electrical Band Frequency (MHz) Return Loss (dB) Efficiency (%) Average Gain (dB) Peak Gain (dBi) 5GNR/4G Band 5,8,12,13,14,17,18,20, 26,27,28, 29,71 617~960 -8 69 -1.7 2.1 5GNR/4G Band 21,32,74,75,76 1427~1518 -7 62 -2.1 2.4 4G/3G Band 1,2,3,4,9,23,25,35,39,66 1710~2200 -6 65 -1.9 1.9 4G/3G Band 7,30,38,40,41 2300~2690 -8 62 -2.1 1.8 5GNR/4G Band 22,42,43,48,77,78,79 3300~5000 -15 80 -1 5.3 LTE5200/ Wi-Fi 5800 5150~5925 -11 72 -1.4 5.6 Wi-Fi 6 5925~7125 -8 59 -2.3 4.5 Max Input Power Impedance Polarization Radiation Pattern 5 50 Ω Linear Omni Mechanical Dimensions 163 x 21 x .3mm Connector I-PEX MHF I Cable 150mm of 1.37 mm Coax Weight 1.9 g Environmental Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Relative Humidity Non-condensing 65°C 95% RH RoHS & REACH Compliant Yes *All testing done on 1.5mm of Polycarbonate Plastic *Cable and connector are fully customizable SPE-21-8-017-A www.taoglas.com 5 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-21-8-017-A www.taoglas.com 6 3.2 Efficiency SPE-21-8-017-A www.taoglas.com 7 3.3 SPE-21-8-017-A Average Gain www.taoglas.com 8 3.4 Peak Gain SPE-21-8-017-A www.taoglas.com 9 3.5 VSWR SPE-21-8-017-A www.taoglas.com 10 Test Setup (Chamber) 4.4.1 Radiation Patterns 4. 4.1 Test Set-Up Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Return loss Test Setup of the FXUB85.07.0150C 4. Antenna Radiation Patterns Figure 1. OTA Setup of the FXUB85.07.0150C in the SG24-L Satimo Test System 4. Antenna Radiation Patterns OTA Setup of the FXUB85.07.0150C in the SG24-L Satimo Test System For 600 MHz – 6 GHz Testing SPE-21-8-017-A OTA Setup of the FXUB85.07.0150C in the ETS AMS-8500 Test System For 6 GHz – 8 GHz Testing www.taoglas.com 11 4.2 2D and 3D Radiation Patterns 650 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 12 750 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 13 850 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 14 1470 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 15 1575 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 16 1850 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 17 1950 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 18 2155 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 19 2450 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 20 2700 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 21 3400 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 22 4100 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 23 5500 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 24 6525 MHz XY Plane SPE-21-8-017-A XZ Plane YZ Plane www.taoglas.com 25 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-017-A Mechanical Drawing www.taoglas.com 26 6. Packaging 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4.SPE-21-8-017-A Antenna Radiation Patterns3.Antenna www.taoglas.com 27 7. Application Note Like all flex antennas, the FXUB85 Pylon antenna performance is somewhat sensitive to the routing of the cable 6.during Packaging5. Mechanical integration. The preferred routing is to the Drawing right, as shown in the photo below. All data presented here was taken in the “Preferred” configuration. Routing the cable to the left also works, but routing the cable down the center along the ground plane of the antenna is suboptimal. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-21-8-017-A Mechanical Drawing www.taoglas.com 28 Changelog for the datasheet SPE-21-8-017 - FXUB85.07.0150C Revision: A (Original First Release) Date: Changes: Changes Made by: 2021-03-15 First Release Tim Kelley Previous Revisions SPE-21-8-017-A www.taoglas.com 29 www.taoglas.com SPE-21-8-017-A © Taoglas 30 www.taoglas.com
FXUB85.07.0150C 价格&库存
很抱歉,暂时无法提供与“FXUB85.07.0150C”相匹配的价格&库存,您可以联系我们找货
