GSA.8835.A.101111
GSA.8835.A.101111
    TAOGLASLIMITED
    TAOGLAS - GSA.8835.A.101111 - RF Antenna, 6 GHz to 600 MHz, 2.81 dBi, 2 W, 50ohm, Linear, Adhesive
GSA.8835.A.101111 数据手册
Phoenix II Part No: GSA.8835.A.101111 Description: 5G/4G I-Bar Adhesive Mount Fully Waterproof Rated Low Profile Wideband Antenna Features: 5G/4G Adhesive Mount Antenna 600-6000MHz Wideband Operation IP67 & IP68 Rated Enclosure Dimensions: 105 x 30 x 7.9mm Connector: SMA Male Straight Cable: 1m of RG-174 RoHS & REACH Compliant SPE-19-8-112-D 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 25 6. Packaging 26 Changelog 27 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-19-8-112-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas GSA.8835 is a fully IP67/68 rated waterproof 5G/4G external adhesive mount antenna designed for use with all Cellular modules worldwide including new 5G bands. The GSA.8835 has been designed as a fully IP67 waterproof rated enclosure and with extended wideband cellular frequency range coverage of 6006000MHz, the newly designed GSA.8835 is ready for use at all cellular bands across 5G/4G/3G/2G. Introduction Typical Applications Include: - Transportation - Agriculture - Autonomous Vehicles/Robotics Introduction Providing excellent efficiency and gain, this low profile(7.9mm) antenna is ideal in areas where space is at a premium. The Phoenix II is fully IP67 rated, making it an ideal solution for outdoor applications. The GSA.8835 can be mounted on glass or plastic and comes with a strong 3M 1600T adhesive already adhered to the bottom side of the antenna for ease of installation. Introduction The Cable length and connector type is fully customizable, for more information or installation instructions, please contact your regional Taoglas Customer Support Team. SPE-19-8-112-D www.taoglas.com 3 2. Specifications 3. Electrical Antenna Characteristics2. Specifications Frequency Average Gain Peak Gain Band 5GNR/4G Band 71 4G/3G Band 12,13,14,17,28,29 4G/3G Band 5,8,18,19,20,26,27 5GNR/4G Band 21,32,74,75,76 4G/3G Band 1,2,3,4,9,23,25,35,39,66 4G/3G Band 7,38,41 5GNR/4G Band 22,42,48,77,78 5GNR/4G Band 43,48,77,78 LTE5200/ Wi-Fi 5800 3. 4. (MHz) Efficiency (%) (dB) (dBi) 617-698 37.8 -4.22 0.95 698-806 52.2 -2.82 2.44 824-960 64.1 -1.93 2.59 1427-1518 82.6 -0.83 3.25 Antenna Characteristics Polarization Radiation Pattern Max. input power 50 Ω Linear Omni 2W 1710-2200 76.9 -1.14 4.12 Antenna Radiation Patterns3. Antenna -1.82 3.78 Characteristics2.3300-3500 Specifications 62.9 -2.01 3.79 3. Impedance 2490-2690 65.8 3500-4200 39.3 -4.06 3.70 5150-5925 51.8 -2.86 2.81 Antenna Characteristics2. Specifications Mechanical 3. 4. Antenna Characteristics Dimensions 30*105*7.9mm Casing PC+ABS Cable RG-174, 1000mm Connector SMA Male Straight Antenna Radiation Patterns3.Antenna 3M 1600T Adhesive Weight Characteristics 35g Environmental Ingress Protection IP67 & IP68 Temperature Range -40°C to 85°C 4. Antenna Radiation Patterns Humidity Non-condensing 65°C 95% RH Shock (Drop Test) 1m drop on concrete 6 axes Cable Pull 8kgf 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-19-8-112-D Specifications www.taoglas.com 4 5G/4G Bands Band Number B1 B2 B3 B4 B5 B7 B8 B9* B11 B12 B13 B14 B17 B18 B19 B20 B21 B22* B23* B24 B25 B26 B27* B28 B29 B30 B31 B32 B34 B35 B36 B37 B38 B39 B40 B41 B42 B43 B45 B46 B47 B48 B49 B50 B51 B52 B53 B65 B66 B68 B69 B70 B71 B72 B73 B74 B75 B76 B77 B78 B79 B85 B87 B88 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink 1920 to 1980 1850 to 1910 1710 to 1785 1710 to 1755 824 to 849 2500 to 2570 880 to 915 1749.9 to 1784.9 1427.9 to 1447.9 699 to 716 777 to 787 788 to 798 704 to 716 815 to 830 830 to 845 832 to 862 1447.9 to 1462.9 3410 to 3490 2000 to 2020 1626.5 to 1660.5 1850 to 1915 814 to 849 807 to 824 703 to 748 Downlink 2110 to 2170 1930 to 1990 1805 to 1880 2110 to 2155 869 to 894 2620 to 2690 925 to 960 1844.9 to 1879.9 1475.9 to 1495.9 729 to 746 746 to 756 758 to 768 734 to 746 860 to 875 875 to 890 791 to 821 1495.9 to 1510.9 3510 to 3590 2180 to 2200 1525 to 1559 1930 to 1995 859 to 894 852 to 869 758 to 803 717 to 728 2305 to 2315 452.5 to 457.5 2350 to 2360 462.5 to 467.5 1452 to 1496 2010 to 2025 1850 to 1910 1930 to 1990 1910 to 1930 2570 to 2620 1880 to 1920 2300 to 2400 2496 to 2690 3400 to 3600 3600 to 3800 1447 to 1467 5150 to 5925 5855 to 5925 3550 to 3700 3550 to 3700 1432 to 1517 1427 to 1432 3300 to 3400 2483.5 to 2495 1920 to 2010 1710 to 1780 698 to 728 2110 to 2200 2110 to 2200 753 to 783 2570 to 2620 1695 to 1710 663 to 698 451 to 456 450 to 455 1427 to 1470 1995 to 2020 617 to 652 461 to 466 460 to 465 1475 to 1518 1432 to 1517 1427 to 1432 3300 to 4200 3300 to 3800 4400 to 5000 698 to 716 410 to 415 412 to 417 728 to 746 420 to 425 422 to 427 Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓ ✓   * Covered Bands represent at least 20% efficiency SPE-19-8-112-D www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-19-8-112-D www.taoglas.com 6 3.3 Average Gain 3.4 Peak Gain SPE-19-8-112-D www.taoglas.com 7 4. Radiation Patterns 4. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.1 Test Setup Y X 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Free space SPE-19-8-112-D www.taoglas.com 8 4.2 3D and 2D Radiation Patterns 617MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 9 650MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 10 750MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 11 824MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 12 960MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 13 1710MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 14 1950MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 15 2200MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 16 2500MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 17 2690MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 18 3300MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 19 3500MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 20 4200MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 21 5150MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 22 55500MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 23 5925MHz XZ Plane SPE-19-8-112-D YZ Plane XY Plane www.taoglas.com 24 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-112-D Mechanical Drawing www.taoglas.com 25 6. 6. 6. 7. Packaging 1pcs GSA.8835.A.101111 per Small PE Bag Dimensions - 200*80mm Weight - 39g Packaging5. Mechanical Drawing Packaging 10pcs GSA.8835.A.101111 per Large PE Bag Dimensions - 460*250mm Weight - 440g Application Note6. Packaging5. Mechanical Drawing 6. 6. 7. Packaging5. Mechanical Drawing 200pcs GSA.8835.A.101111 per carton Dimensions - 400*330*230mm Weight – 9.75Kg Packaging Application Note6. Packaging 230mm 400mm 7. 7. 330mm Application Note Pallet Dimensions: 1200*1000*1350mm 45 Cartons Per Pallet 9 Cartons Per Layer, 5 Layers Application Note6. Packaging 1350mm 7. Application Note6. Packaging5. Mechanical Drawing 1200mm 6. Packaging5. SPE-19-8-112-D Mechanical Drawing 1000mm www.taoglas.com 26 Changelog for the datasheet SPE-19-8-112 – GSA.8835.A.101111 Revision: D (Current Version) Date: Notes: Author: 2023-07-12 Updated Specifications Jack Conroy Previous Revisions Revision: C Date: Notes: Author: 2022-10-27 Updated Specifications Cesar Sousa Revision: B Date: Notes: Author: 2021-03-08 Updated Antenna Weight. Gary West Revision: A (Original First Release) Date: Notes: 2019-08-21 Author: Jack Conroy SPE-19-8-112-D www.taoglas.com 27 www.taoglas.com SPE-19-8-112-D © Taoglas 28 www.taoglas.com
GSA.8835.A.101111 价格&库存
很抱歉,暂时无法提供与“GSA.8835.A.101111”相匹配的价格&库存,您可以联系我们找货
GSA.8835.A.101111
  • 1+153.498861+19.95111
  • 10+133.5998410+17.36472
  • 25+126.7120825+16.46948
  • 100+117.25687100+15.24054
  • 300+110.52623300+14.36572
  • 500+107.60844500+13.98648
库存:868
