G45.A.201111
G45.A.201111
    TAOGLASLIMITED
    G45.A.201111
G45.A.201111 数据手册
Olympian II 5G/4G Part No: G45.A.201111 Description: Olympian II - 5G/4G Permanent Mount Antenna with 2m RG-174 and SMA(M) Features: 5G/4G Permanent Mount Antenna Covering Sub 6GHz 5GNR Bands Covering Worldwide 5G Bands 3G/2G Backward compatible IP67 Rated Enclosure IK10 Rated Enclosure Cable: 2m RG-174 Connector: SMA(M) Dimensions: Ø50.15*48.5mm RoHS & REACH Compliant SPE-19-8-115-B 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 8 4. Radiation Patterns 10 5. Mechanical Drawing 31 6. Packaging 32 7. Application Note 33 Changelog 38 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-19-8-115-B www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. Introduction The Taoglas Olympian II G45 is a low profile, robust external 5G/4G Antenna. The permanent mount antenna has a compact housing at only 48.5mm tall and 50mm in diameter. It is ideal for external use, due to its IP67 rated housing, on vehicles and outdoor assets requiring cellular connectivity. The 5G/4G antenna, covers all major worldwide cellular bands including Sub 6GHz, 5G FR1 bands, worldwide 4G bands and includes fallback to 3G/2G where necessary. Introduction Typical Applications Include: - Digital Signage - Gateways/Routers 1. 1. - Transportation Introduction The G45 can be mounted on metal or plastic but if the lower frequency bands are required, it functions best when mounted on a metal ground-plane. The antenna can still work well with short cable lengths below 1m on plastic structures. Taoglas recommends minimum of 1m cable length for stable antenna performance. When mounted on a ground-plane, the antenna can function well at all frequencies up to 3 meters cable length. Introduction The IP67 rated enclosure is made from a durable, UV resistant ABS material making it resistant to vandalism due to an IK10 rating. An integrated rubber O-ring under the enclosure prevents water ingress underneath the antenna. It is mounted from the inside of the user device enclosure and the small thread allows for installation in the tightest of environments. Customized cable length and connectors are available, contact your regional Taoglas Customer Support Team for more information. SPE-19-8-115-B www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2.5G/4G Specifications Electrical Band 3. Frequency (MHz) Ground Plane Efficiency (%) Average Gain Peak Gain (dB) (dBi) Free space 34.5 Antenna Characteristics 617~698 5G/4G Band 71 4G/3G Band 12,13,14,17,28,29 698~806 4G/3G -4.6 0.9 30x30cm 21.4 -6.7 1.3 Free space 22.8 -6.4 -2.1 30x30cm 36.7 -4.4 0.6 Free space 42.9 -3.7 0.8 Free space 25.9 -5.4 -0.8 -6.4 -1.2 Impedance Max Power Input Polarization Radiation Pattern 50Ω 2W Linear Omni 824~960 4. Antenna Radiation Patterns3. Antenna Band 5,8,18,19,20,26,27 30x30cm 49.8 -3 1.4 5G/4G Band 21,32,74,75,76 1427~1518 Characteristics2. 4G/3G Band 1,2,3,4,9,23,25,35,39,66 1710~2200 4G/3G Band 7,30,38,40,41 2300~2690 5G NR Band 22,42,48,77,78 3300~4200 5G NR Band 79 4400~5000 3. 30x30cm 23.1 Specifications Free space 41.8 -3.8 1.5 30x30cm 45.6 -3.3 1.1 Free space 43.2 -5 1 30x30cm 23.2 Antenna Characteristics2. Free space 21.3 -6.4 -1.9 Specifications -6.7 -1.3 30x30cm 14 -8.7 -3.5 Free space 24.4 -6.2 0.2 30x30cm 23.4 -6.3 0.7 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-19-8-115-B Specifications www.taoglas.com 4 Mechanical Height 48.5 mm Planner Dimension Ø50.15mm Casing ABS + Anti-UV Cable 2000mm of RG-174 Connector SMA(M) Base and Thread Brass with nickel plated Thread Diameter M12 Sealant Rubber Weight 75g Impact Rating IK10 Environmental SPE-19-8-115-B Protection IP67 Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH Thermal Shock 200 cycles -40°C to +90°C Shock (Drop Test) 1m drop on concrete 6 axes Cable Pull 8kgf www.taoglas.com 5 5G/4G Bands Free Space Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 79 4400 to 5000 SPE-19-8-115-B Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 6 5G/4G Bands 30x30cm Ground Plane Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 78 3300 to 3800 79 4400 to 5000 SPE-19-8-115-B Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ www.taoglas.com 7 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-19-8-115-B www.taoglas.com 8 3.3 Average Gain 3.4 Peak Gain SPE-19-8-115-B www.taoglas.com 9 4. Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns On 30x30cm Ground Plane 4. Antenna Radiation Patterns SPE-19-8-115-B www.taoglas.com 10 4.2 Free Space 3D and 2D Radiation Patterns 652MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 11 751MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 12 890MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 13 1470MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 14 1805MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 15 1920MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 16 1990MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 17 2592MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 18 3550MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 19 5330MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 20 4.3 30*30cm Ground Plane 3D and 2D Radiation Patterns 652MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 21 751MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 22 890MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 23 1470MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 24 1805MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 25 1920MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 26 1990MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 27 2595MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 28 3550MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 29 5530MHz XY Plane SPE-19-8-115-B XZ Plane YZ Plane www.taoglas.com 30 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-115-B Mechanical Drawing www.taoglas.com 31 6. Packaging 1pc G45.A.201111 per PE Bag 75g 6. Weight: Packaging5. 6. 7. Mechanical Drawing Packaging 10pcs G45.A.201111 per Large PE Bag Weight: 850g Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 80pcs G45.A.201111 per Carton Weight: 7.2Kg 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-115-B Mechanical Drawing www.taoglas.com 32 7. Application Note 7.1 Return Loss 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-115-B Mechanical Drawing www.taoglas.com 33 7.2 Efficiency SPE-19-8-115-B www.taoglas.com 34 7.3 Average Gain SPE-19-8-115-B www.taoglas.com 35 7.4 Peak Gain SPE-19-8-115-B www.taoglas.com 36 7.5 Table Electrical Frequency (MHz) 5G NR Band 71 LTE700 617 ~698 698 ~806 GSM 5G NR Band 850/900 74, 75, 76 824 ~960 1427 ~1518 5G NR Band LTE5200/ 77, 78, 79 Wi-Fi 5800 DCS PCS UMTS1 LTE2600 1710 ~1880 1850 ~1990 1920 ~2170 2300 ~2690 3300 ~5000 5150 ~5925 Efficiency (%) Free Space 30x30cm Ground Plane 0.3m 44.92 30.41 58.63 38.27 61.29 70.56 72.08 56.45 42.08 51.43 1.0m 40.29 27.01 51.54 32.57 50.51 57.68 58.45 44.67 31.79 35.54 2.0m 34.50 22.80 42.87 25.87 38.32 43.25 43.33 31.98 21.30 20.97 3.0m 29.54 19.25 35.65 20.55 29.07 32.44 32.12 22.90 14.27 12.37 5.0m 21.65 13.73 24.67 12.97 16.73 18.25 17.65 11.74 6.41 4.31 0.3m 27.80 49.15 68.06 34.23 80.12 77.53 69.59 40.89 27.02 48.80 1.0m 24.94 43.58 59.83 29.13 66.03 63.40 56.43 32.37 20.40 33.73 2.0m 21.35 36.72 49.76 23.14 50.09 47.56 41.83 23.19 13.66 19.91 3.0m 18.28 30.93 41.39 18.38 37.99 35.68 31.01 16.61 9.14 11.75 5.0m 13.40 21.97 28.64 11.60 21.86 20.09 17.04 8.53 4.10 4.10 Average Gain (dB) Free Space 30x30cm Ground Plane 0.3m -3.48 -5.17 -2.32 -4.17 -2.13 -1.51 -1.42 -2.48 -3.76 -2.89 1.0m -3.95 -5.69 -2.88 -4.87 -2.97 -2.39 -2.33 -3.50 -4.98 -4.49 2.0m -4.62 -6.42 -3.68 -5.87 -4.17 -3.64 -3.63 -4.95 -6.72 -6.78 3.0m -5.30 -7.16 -4.48 -6.87 -5.37 -4.89 -4.93 -6.40 -8.46 -9.08 5.0m -6.64 -8.62 -6.08 -8.87 -7.77 -7.39 -7.53 -9.30 -11.93 -13.65 0.3m -5.56 -3.09 -1.67 -4.66 -0.96 -1.11 -1.57 -3.88 -5.68 -3.12 1.0m -6.03 -3.61 -2.23 -5.36 -1.80 -1.98 -2.48 -4.90 -6.90 -4.72 2.0m -6.71 -4.35 -3.03 -6.36 -3.00 -3.23 -3.78 -6.35 -8.65 -7.01 3.0m -7.38 -5.10 -3.83 -7.36 -4.20 -4.48 -5.08 -7.80 -10.39 -9.30 5.0m -8.73 -6.58 -5.43 -9.36 -6.60 -6.97 -7.68 -10.69 -13.87 -13.87 Peak Gain (dBi) Free Space 30x30cm Ground Plane 0.3m 2.00 -0.90 2.11 0.90 3.24 3.84 3.64 3.46 1.66 2.03 1.0m 1.53 -1.42 1.55 0.20 2.40 2.97 2.73 2.44 0.45 0.42 2.0m 0.85 -2.15 0.75 -0.80 1.20 1.72 1.43 0.99 -1.29 -1.88 3.0m 0.18 -2.89 -0.05 -1.80 -0.00 0.47 0.13 -0.46 -3.03 -4.18 5.0m -1.17 -4.37 -1.65 -3.80 -2.40 -2.02 -2.47 -3.36 -6.50 -8.77 0.3m 2.47 1.83 2.78 0.52 3.37 3.19 2.92 0.55 -0.59 2.62 1.0m 2.00 1.31 2.22 -0.18 2.53 2.31 2.01 -0.47 -1.81 1.02 2.0m 1.33 0.58 1.42 -1.18 1.33 1.06 0.71 -1.92 -3.56 -1.27 3.0m 0.65 -0.16 0.62 -2.18 0.13 -0.18 -0.59 -3.36 -5.30 -3.56 5.0m -0.70 -1.63 -0.98 -4.18 -2.27 -2.68 -3.19 -6.26 -8.79 -8.13 SPE-19-8-115-B www.taoglas.com 37 Changelog for the datasheet SPE-19-8-115 – G45.A.201111 Revision: B (Current Version) Date: Notes: 2020-12-08 Author: Jack Conroy Previous Revisions Revision: A (Original First Release) Date: Notes: Author: SPE-19-8-115-B 2019-08-26 David Connolly www.taoglas.com 38 www.taoglas.com SPE-19-8-115-B © Taoglas 39 www.taoglas.com
G45.A.201111 价格&库存
很抱歉,暂时无法提供与“G45.A.201111”相匹配的价格&库存,您可以联系我们找货
G45.A.201111
