FFM107
FFM107
    STARSEA(星海)
FFM107 数据手册
FFM101 THRU FFM107 SURFACE MOUNT FAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0Ampere SOD-123FL FEATURES Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension MECHANICAL DATA Case: SOD-123FL molded plastic body over passivated chip Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL =100 C (NOTE 1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=125 C Maximum reverse recovery time (NOTE 2) VRRM VRMS VDC FFM101 FFM102 FFM103 FFM104 FFM105 FFM106 FFM107 F1 F2 F3 F4 F5 F6 F7 50 100 200 400 600 800 35 50 70 100 140 200 280 400 420 600 560 800 1000 700 1000 V V V I(AV) 1.0 A IFSM 25.0 A VF 1.3 V IR 5.0 50.0 µA trr Typical junction capacitance (NOTE 3) CJ Typical thermal resistance (NOTE 4) RθJA Operating junction and storage temperature range TJ,TSTG Note: 1.Averaged over any 20ms period. 2.Measured with IF=0.5A, IR=1A, Irr=0.25A. 3.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 4.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas DN:S09D06A0 UNITS 250 150 15 95 -55 to +150 500 ns pF C/W C STAR SEA AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES FFM101 THRU FFM107 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 P.C.B mounted on 0.2*0.2"(5.0*5.0mm) copper pad areas 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 25 8.3ms SINGLE HALF SINE-WAVE 20 15 10 5 0 1 175 10 100 NUMBER OF CYCLES AT 60 Hz LEAD TEMPERATURE, C 20 10 TJ=25 C PULSE WIDTH=300 µs 2%DUTY CYCLE 1 0.1 0.01 0.2 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 200 TJ=25 C 100 10 1 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS DN:S09D06A0 STAR SEA
FFM107 价格&库存
很抱歉,暂时无法提供与“FFM107”相匹配的价格&库存,您可以联系我们找货
