ES2D
ES2D
    DY(迪一电子)
    SMA(DO-214AC)
    耐压:200V 电流:2A 反向恢复时间:35NS
ES2D 数据手册
ES2A THRU ES2K 2.0AMP Surface Mount Glass Superfast Recovery Rectifier Features Case: SMA(DO-214AC) · Low Power Loss, High Efficiency · Ideally Suited for Automatic Assembly · Guard Ring Die Construction · Plastic Case Material has UL Flammability Classification Rating 94V- 0 Mechanical Data · Case: Molded plastic SMA · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed · Polarity: Color band dentes cathode end · Mounting Position: Any · Making: Type Number Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL ES2A ES2B ES2D ES2G ES2J ES2K Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 V Average Rectified Output Current @TL =100 ℃ IF(AV) Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 8.3ms Single half sine-wave @Tj=125 ℃ IFSM 2.0 A 60 A 48 Superimposed On Rated Load (JEDEC Method) Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 1.0ms Single half sine-wave @T j=125℃ Superimposed On Rated Load (JEDEC Method) IFSM 10000 times of the wave surge current ( time width 1ms, time interval 3s ) IFSM Rating for fusing (t
很抱歉,暂时无法提供与“ES2D”相匹配的价格&库存,您可以联系我们找货
