GBU406
GBU406
    DY(迪一电子)
    GBU
    耐压:600V 电流:4A
GBU406 数据手册
GBU4005 THRU GBU410 Single Phase 4.0AMP Glass Passivated Bridge Rectifier Features Case: GBU · Glass passivated die construction 0.874(22.2) 0.858(21.8) · Low forward voltage drop · High current capability · High surge current capability · Plastic material-UL flammability 94V-0 Mechanical Data · Case: G B U , molded plastic · Terminals: Plated Leads Solderable per · · · · 0.720(18.3) 0.680(17.3) MIL-STD-202, Method 208 Polarity: As Marked on Case Mounting Position: Any Marking: Type Number Lead Free: For RoHS / Lead Free Version 0.209(5.30) 0.189(4.80) - ~ ~ + dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL GBU 4005 VRRM 50 VRWM TYPE NUMBER Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage GBU 401 GBU 402 GBU 404 GBU 406 GBU 408 GBU 410 UNITS 100 200 400 600 800 1000 V 70 140 280 420 560 700 V VDC RMS Reverse Voltage VRMS Average Rectified Output Current (Note 1)@TC =90℃ IF(AV) 4.0 A IFSM 80 64 A IFSM 160 128 A Non-Repetitive Peak Forward Surge Current @TJ=25℃ 8.3ms Single half sine-wave superimposed @TJ=1 25℃ on rated load (JEDEC Method) Non-Repetitive Peak Forward Surge @TJ=25℃ Current 1 ms Single half sine-wave @TJ=1 25℃ superimpose on rated load (JEDEC Method) @IF=2.0A Forward Voltage per element @IF=4.0A Peak Reverse Current @TJ=25℃ At Rated DC Blocking Voltage TJ=1 25℃ 2 I t Rating for fusing (t
GBU406 价格&库存
很抱歉,暂时无法提供与“GBU406”相匹配的价格&库存,您可以联系我们找货
