FR107(60*58)
FR107(60*58)
    DY(迪一电子)
    DO-41(DO-204AL)
    停产
FR107(60*58) 数据手册
FR101 THRU FR107 1.0 AMP.Fast Recovery Rectifiers Features · Low power loss. DO-41 · High current capability · High reliability · High surge current capability · Plastic material-UL flammability 94V-0 MIN. Mechanical Data DIA. · Case: Molded plastic DO-41 MAX · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end DIA. · Mounting Position: Any MIN. · Making: Type Number · Lead Free: For RoHS/Lead Free Version Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL FR101 FR102 FR103 FR104 FR105 FR106 FR107 Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Average Rectified Output Current (Note 1) @TL =90 ℃ IF(AV) 1.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A I2t Rating for Fusing (t < 8.3ms) I 2t 3.735 A2s Forward Voltage VFM 1.3 V @IF=1.0A Peak Reverse Current @TA =25℃ At Rated DC Blocking Voltage @TA =125 ℃ 5.0 IR Maximum Reverse Recovery Time (Note 2 ) TRR 150 Typical Junction Capacitance (Note 3) CJ 25 Typical Thermal Resistance Junction to Ambient(Note 1) Operating Temperature Range Storage Temperature Range uA 100 500 250 15 pF 25 ℃/W TJ -55 to + 125 ℃ TSTG -55 to + 150 ℃ RθJA Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Reverse Recovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A. 3. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C version:02 nS 1of3 www.dyelec.com FR101 THRU FR107 FIG. 1 – FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD CHARACTERISTICS INSTANTANEOUS FORWARD CURRENT (A) 0.8 0.6 0.4 0.2 0 25 50 75 100 125 150 175 LEAD TEMPERATURE, . (( ℃)) 10 1.0 TA = 25°C 0.1 PULSE WIDTH 300us 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD (V) FIG.4 – TYPICAL JUNCTION CAPACITANCE FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 100 40 FR101 - FR104 30 CAPACITANCE (pF) PEAK FORWARD SURGE CURRENT (A) AVERAGE FORWARD CURRENT (A) 1.0 20 10 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) FR105 - FR107 10 T J = 25°C f = 1 MHz 0 1 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz 1 1 4 10 REVERSE VOLTAGE (V) version:02 2of3 www.dyelec.com 100 FR101 THRU FR107 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
FR107(60*58) 价格&库存
很抱歉,暂时无法提供与“FR107(60*58)”相匹配的价格&库存,您可以联系我们找货
