HER207
HER207
    DY(迪一电子)
    DO-15(DO-204AC)
    HER207
HER207 数据手册
HER201 THRU HER208 2.0 AMP. High Plastic silicon Efficient Rectifiers Features · Low forward voltage drop DO-15 · High current capability · High reliability MIN. Mechanical Data DIA. · Case: Molded plastic DO-15 · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed · Polarity: Color band dentes cathode end DIA. · Mounting Position: Any MIN. Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL HER HER HER HER HER HER HER HER 201 202 203 204 205 206 207 208 Unit Maximum Recurrent Peak Reverse Voltage VRM 50 100 200 300 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 210 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 300 400 600 800 1000 V Average Rectified Output Current (Note 1) @TL =100 ℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=2.0A Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=125℃ IF(AV) 2.0 A IFSM 60 A I 2t 14.94 A2s 1.0 VFM 1.3 1.7 5.0 IR V uA 100 Maximum Reverse Recovery Time (Note2 ) TRR 50 75 nS Typical Junction Capacitance (Note 3) Cj 60 40 pF Typical Thermal Resistance Junction to Ambient Operating Temperature Range Storage Temperature Range R θJA 25 ℃/W Tj -65 to + 125 ℃ TSTG -65 to + 150 ℃ Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2.Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 3. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C version:02 1of3 www.dyelec.com HER201 THRU HER208 FIG.2 – TYPICAL FORWARD CHARACTERISTICS 10 1.5 1.0 0.5 0 50 75 100 125 150 175 LEAD TEMPERATURE, ℃ 1.0 HER204 HER205 C HER206-HER208 0.1 TJ = 25° PULSE WIDTH 300us 0.01 0 1.2 1.4 0.4 0.6 0.8 1.0 4 INSTANTANEOUS FORWARD VOLTAGE 0.2 1.6 ) 25 HER205 HER201-HER203 V 1.8 ( AVERAGE FORWARD CURRENT AMPERES (A) 2.0 INSTANTANEOUS FORWARD CURRENT(A) FIG. 1 - FORWARD CURRENT DERATING CURVE 2.5 FIG. 4 – TYPICAL JUNCTION CAPACITANCE 100 60 FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT HER201-HER205 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) 60 45 30 CAPACITANCE, (pF) , 40 20 HER206-HER208 10 TJ = 25°C f = 1 MHz 4 15 2 0 2 5 10 20 50 100 1 1 NUMBER OF CYCLES AT 60Hz 4 10 REVERSE VOLTAGE version:02 2of3 40 ) 1 V ( PEAK FORWARD SURGE CURRENT AMPERES (A) 75 www.dyelec.com 100 HER201 THRU HER208 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
HER207 价格&库存
很抱歉,暂时无法提供与“HER207”相匹配的价格&库存,您可以联系我们找货
