1N5399
1N5399
    DY(迪一电子)
    DO-15(DO-204AC)
    1N5399
1N5399 数据手册
1N5391 THRU 1N5399 1.5 AMP.Plastic silicon Rectifier Features DO-15 · Low forward voltage drop · High current capability · High reliability · High surge current capability MIN. Mechanical Data DIA. · Case: Molded plastic DO-15 · Terminals: Axial leads solderable to MIL-STD-202,Method 208 · Polarity: Color band dentes cathode end DIA. · Mounting Position: Any MIN. Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL 1N 1N 1N 1N 1N 1N 1N 1N 1N 5391 5392 5393 5394 5395 5396 5397 5398 5399 Unit Maximum Recurrent Peak Reverse Voltage VRM 50 100 200 300 400 500 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 210 280 350 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 300 400 500 600 800 1000 V Average Rectified Output Current (Note 1) @TL =100 ℃ IF(AV) 1.5 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50 A I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=1.5A Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=100℃ I 2t A2s 10.375 1.1 VFM V 5.0 IR uA 100 Typical Junction Capacitance (Note 2) Cj 20 pF Typical Thermal Resistance Junction to Ambient RθJA 26 ℃ /W Tj -55 to +125 ℃ TSTG -55 to +150 ℃ Operating Temperature Range Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C version:02 1of3 www.dyelec.com 1N5391 THRU 1N5399 FIG. 1 – FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD CHARACTERISTICS 0.9 0.6 0.3 0 25 50 75 100 125 150 175 LEAD TEMPERATURE, ℃ 1.0 0.1 T A = 25°C PULSE WIDTH 300us 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 INSTANTANEOUS FORWARD VOLTAGE V 1.8 FIG.4 – TYPICAL JUNCTION CAPACITANCE FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT 100 50 CAPACITANCE, (pF) 40 30 20 10 10 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) TA = 25°C f = 1 MHz 0 2 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz 1 1 4 REVERSE VOLTAGE version:02 2of3 100 10 ) 1 V ( PEAK FORWARD SURGE CURRENT, AMPERES (A) 1.6 1.4 ) 1.2 INSTANTANEOUS FORWARD CURRENT, (A) 10 ( AVERAGE FORWARD CURRENT AMPERES ( A) 1.5 www.dyelec.com 1N5391 THRU 1N5399 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3of3 www.dyelec.com
1N5399 价格&库存
很抱歉,暂时无法提供与“1N5399”相匹配的价格&库存,您可以联系我们找货
