DSS22 THRU DSS 225
SINGLE PHASE 2.0AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
· The plastic package carries Underwriters Laboratory
SOD-123FL
Flammability Classification 94V-0
· Metal silicon junction,majority carrier conduction
· Low power loss,high efficiency
8°(8°)
2°(2°)
0.079(2.0)
· High temperature soldering guaranteed:
260℃ /10 seconds,0.375"(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.043(1.1)
0.035(0.9)
0.008(0.2)
0.004(0.1)
0.063(1.6)
· Case: SOD-123FL, molded plastic
· Terminals: plated leads solderable per
0.047(1.2)
0.032(0.8)
0.079(2.0)
Mechanical Data
0.063(1.6)
0.111(2.8)
0.095(2.4)
0.150(3.8)
0.134(3.4)
0.150(3.8)
0.134(3.4)
0.047(1.2)
0.032(0.8)
MIL-STD-750, Method 2026
· Polarity: Color band denotes cathode end
· Mounting position: Any
0.037(0.95)
0.022(0.55)
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified.
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
SYMBOL
Code
TYPE NUMBER
VRWM
RMS Reverse Voltage
VRMS
=90℃
I2t Rating for Fusing (t < 8.3ms)
Peak Reverse Current
At Rated DC Blocking Voltage
DSS225
DSS28
D24
D25
D26
D28
D210
D215
D220
D225
40
50
60
80
100
150
200
250
V
14
21
28
35
42
56
70
105
140
175
V
UNITS
VDC
Non-Repetitive Peak Forward Surge Current
8.3ms
Single half sine-wave superimposed on
rated load (JEDEC Method)
Forward Voltage per element
DSS25
DSS210 DSS215 DSS220
DSS26
D23
D22
VRRM
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Output Current @TL
DSS22 DSS23 DSS24
@IF=2.0A
@TA =25℃
@TA =100 ℃
IF(AV)
2.0
A
IFSM
50
A
I 2t
10.375
VFM
0.55
IR
0.7
0.92
0.85
0.1
0.05
10
5
80
mA
Typical junction capacitance (NOTE 1)
CJ
Operating junction temperature range
TJ
-55to+150
TSTG
-55to+150
Operating and Storage Temperature Range
220
A2s
0.95
V
Note:1. Measured at 1MHZ and applied reverse voltage of 4.0V D.C.
version:02
1 of 3
www.dyelec.com
pF
I(AV)AVERAGE FORWARD CURRENT (A)
2.0
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
0.4
50
75
100
125
150
175
IFSM PEAK FORWARD SURGE CURRENT (A)
LEAD TEMPERATURE(OC)
FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
50
40
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
100
NUMBER OF CYCLES AT 60 Hz
FIG. 2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
T A=25℃
PULSE WIDTH=300 µs
1%DUTY CYCLE
10
1
DSS22-DSS24
DSS25-DSS26
DSS28-DSS210
DSS215-DSS220
DSS225
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
VF , INSTANTANEOUSFORWARD VOLTAGE (V)
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
IR INSTANTANEOUS REVERSE CURRENT (mA)
FIG. 1- FORWARD CURRENT DERATING CURVE
IF INSTANTANEOUS FORWARD CURRENT,(A)
DSS22 THRU DSS 225
100
TA=100℃
10
1
TA=75℃
0.1
TA=25℃
0.01
0.001
60
80
100
PERCENT OF RATED PEAK REVERSE VOLYAGE(%)
FIG. 5-TYPICAL JUNCTION CAPACITANCE
Fig.6 TYPICAL CAPACITANCE
2000
C j CAPACITANCE(pF)
1000
DSS22-DSS24
DSS25-DSS225
100
TJ=25 C
10
0.1
1.0
10
100
VR REVERSE VOLTAGE, (V))
version:02
2 of 3
www.dyelec.com
DSS22 THRU DSS 225
Important Notice and Disclaimer
•Reproducing and modifying information of the document is prohibited without permission
from DIYI.
• DIYI reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design, purchase or use.
•DIYI disclaims any and all liability arising out of the application or use of
any product including damages incidentally and consequentially occurred.
•DIYI does not assume any and all implied warranties, including warranties of fitness for
particular purpose, non-infringement and merchantability.
Applications shown on the herein document are examples of standard use and
operation. Customers are responsible in comprehending the suitable use in particular
applications.
DIYI makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
•The products shown herein are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving
or life-sustaining, such as medical instruments, transportation equipment, aerospace
machinery et cetera. Customers using or selling these products for use in such applications
do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such
improper use or sale.
•Since DIYI uses lot number as the tracking base, please provide the lot number for tracking
when complaining.
version:02
3 of 3
www.dyelec.com
很抱歉,暂时无法提供与“D22”相匹配的价格&库存,您可以联系我们找货
