ER3G
ER3G
    DY(迪一电子)
    SMB(DO-214AA)
    耐压:400V 电流:3A 反向恢复时间:35NS
ER3G 数据手册
ER3A(H) THRU ER3J (H) 3.0AMP SURFACE MOUNT SUPERFAST RECTIFIERS Features SMB/DO-214AA · Glass passivated junction chip · Low Power Loss, High Efficiency · Ideally Suited for Automatic Assembly ·Guard Ring Die Construction · Plastic Case Material has UL Flammability Classification Rating 94V- 0 0.154(3.90) 0.130(3.30) 0.083(2.11) 0.075(1.91) 0.187(4.75) 0.163(4.15) Mechanical Data · Case: Molded plastic SMB 0.012(0.300) 0.004(0.100) · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed 0.096(2.44) 0.084(2.13) · Polarity: Color band dentes cathode end · Mounting Position: Any 0.057(1.45) 0.033(0.85) · Making: Type Number 0.008(0.20) 0.004(0.10) 0.008(0.20) 0.002(0.05) 0.217(5.50) 0.197(5.00) Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number (Note 4) SYMBOL ER3A(H) ER3B(H) ER3C(H) ER3D(H) ER3E(H) ER3G(H) ER3J(H) Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Average Rectified Output Current @TL =100℃ IF(AV) Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM Forward Voltage VFM @IF=3.0A Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @TA =125 ℃ 2 3.0 A 110 A 0.95 1.25 1.7 5.0 IR uA 100 2 V I t Rating for fusing (t
很抱歉,暂时无法提供与“ER3G”相匹配的价格&库存,您可以联系我们找货
