DSS32 THRU DSS3 25
SINGLE PHASE 3.0AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
· The plastic package carries Underwriters Laboratory
SOD-123FL
Flammability Classification 94V-0
· Metal silicon junction,majority carrier conduction
· Low power loss,high efficiency
8°(8°)
2°(2°)
0.079(2.0)
· High temperature soldering guaranteed:
260℃ /10 seconds,0.375"(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.150(3.8)
0.134(3.4)
MIL-STD-750, Method 2026
· Polarity: Color band denotes cathode end
· Mounting position: Any
0.047(1.2)
0.032(0.8)
0.079(2.0)
· Case: SOD-123FL, molded plastic
· Terminals: plated leads solderable per
0.063(1.6)
0.111(2.8)
0.095(2.4)
0.150(3.8)
0.134(3.4)
Mechanical Data
0.043(1.1)
0.035(0.9)
0.008(0.2)
0.004(0.1)
0.063(1.6)
0.047(1.2)
0.032(0.8)
0.037(0.95)
0.022(0.55)
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified.
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
SYMBOL
Code
TYPE NUMBER
VRWM
RMS Reverse Voltage
VRMS
@TL=90℃
I2t Rating for Fusing (t < 8.3ms)
Peak Reverse Current
At Rated DC Blocking Voltage
UNITS
D32
D34
D35
D36
D38
D310
D315
D320
D325
40
50
60
80
100
150
200
250
V
14
21
28
35
42
56
70
105
140
175
V
F(AV)
3.0
A
IFSM
80
A
I 2t
@IF=3.0A
@TA =25℃
@TA =100 ℃
Operating junction temperature range
Operating and Storage Temperature Range
version:02
DSS38 DSS310 DSS315 DSS320 DSS325
VDC
Non-Repetitive Peak Forward Surge Current 8.3ms
Single half sine-wave superimposed on rated load
(JEDEC Method)
Forward Voltage per element
DSS36
D33
VRRM
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Output Current
DSS32 DSS33 DSS34 DSS35
VFM
IR
A2s
26.560
0.55
0.7
0.92
0.85
0.1
0.05
10
5
0.95
V
mA
TJ
- 55to+150
TSTG
- 55to+150
1 of 3
www.dyelec.com
DSS32 THRU DSS3 25
I FIN S TA N TA N E O U S FO R W A R D C U R R E N T,(A )
I(AV)AVERAGE FORWARD CURRENT (A)
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
0.6
50
75
100
125
150
175
80
64
48
32
16
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
T A=25℃
PULSE WIDTH=300 µs
1%DUTY CYCLE
10
1
DSS32-DSS34
DSS35-DSS36
DSS38-DSS310
DSS315-DSS320
DSS325
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
VF , INSTANTANEOUS FORWARD VOLTAGE (V)
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
I R INSTANTANEOUS REVERSE CURRENT (mA)
I FSMPEAK FORWARD SURGE CURRENT (A)
O
2.4
LEAD TEMPERATURE(
C)
FIG. 2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
100
NUMBER OF CYCLES AT 60 Hz
100
10
TA=100℃
1
TA=75℃
0.1
TA=25℃
0.01
0.001
60
80
100
PERCENT OF RATED PEAK REVERSE VOLYAGE(%)
(1.3)
Fig.5 TYPICAL CAPACITANCE
version:02
2 of 3
www.dyelec.com
DSS32 THRU DSS3 25
Important Notice and Disclaimer
•Reproducing and modifying information of the document is prohibited without permission
from DIYI.
• DIYI reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design, purchase or use.
•DIYI disclaims any and all liability arising out of the application or use of
any product including damages incidentally and consequentially occurred.
•DIYI does not assume any and all implied warranties, including warranties of fitness for
particular purpose, non-infringement and merchantability.
Applications shown on the herein document are examples of standard use and
operation. Customers are responsible in comprehending the suitable use in particular
applications.
DIYI makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
•The products shown herein are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving
or life-sustaining, such as medical instruments, transportation equipment, aerospace
machinery et cetera. Customers using or selling these products for use in such applications
do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such
improper use or sale.
•Since DIYI uses lot number as the tracking base, please provide the lot number for tracking
when complaining.
I
version:02
3 of 3
www.dyelec.com
很抱歉,暂时无法提供与“D36”相匹配的价格&库存,您可以联系我们找货
