D23
D23
    DY(迪一电子)
    SOD-123F
    直流反向耐压(Vr):30V;平均整流电流(Io):2A;正向压降(Vf):550mV@2A;
D23 数据手册
DSS22 THRU DSS 225 SINGLE PHASE 2.0AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features · The plastic package carries Underwriters Laboratory SOD-123FL Flammability Classification 94V-0 · Metal silicon junction,majority carrier conduction · Low power loss,high efficiency 8°(8°) 2°(2°) 0.079(2.0) · High temperature soldering guaranteed: 260℃ /10 seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension 0.043(1.1) 0.035(0.9) 0.008(0.2) 0.004(0.1) 0.063(1.6) · Case: SOD-123FL, molded plastic · Terminals: plated leads solderable per 0.047(1.2) 0.032(0.8) 0.079(2.0) Mechanical Data 0.063(1.6) 0.111(2.8) 0.095(2.4) 0.150(3.8) 0.134(3.4) 0.150(3.8) 0.134(3.4) 0.047(1.2) 0.032(0.8) MIL-STD-750, Method 2026 · Polarity: Color band denotes cathode end · Mounting position: Any 0.037(0.95) 0.022(0.55) Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL Code TYPE NUMBER VRWM RMS Reverse Voltage VRMS =90℃ I2t Rating for Fusing (t < 8.3ms) Peak Reverse Current At Rated DC Blocking Voltage DSS225 DSS28 D24 D25 D26 D28 D210 D215 D220 D225 20 30 40 50 60 80 100 150 200 250 V 14 21 28 35 42 56 70 105 140 175 V UNITS VDC Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) Forward Voltage per element DSS25 DSS210 DSS215 DSS220 DSS26 D23 D22 VRRM Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Output Current @TL DSS22 DSS23 DSS24 @IF=2.0A @TA =25℃ @TA =100 ℃ IF(AV) 2.0 A IFSM 50 A I 2t 10.375 VFM 0.55 IR 0.7 0.92 0.85 0.1 0.05 10 5 80 mA Typical junction capacitance (NOTE 1) CJ Operating junction temperature range TJ -55to+150 ℃ TSTG -55to+150 ℃ Operating and Storage Temperature Range 220 A2s 0.95 V Note:1. Measured at 1MHZ and applied reverse voltage of 4.0V D.C. version:02 1 of 3 www.dyelec.com pF I(AV)AVERAGE FORWARD CURRENT (A) 2.0 1.6 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.8 0.4 0 0 25 50 75 100 125 150 175 IFSM PEAK FORWARD SURGE CURRENT (A) LEAD TEMPERATURE(OC) FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 10 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 100 NUMBER OF CYCLES AT 60 Hz FIG. 2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 T A=25℃ PULSE WIDTH=300 µs 1%DUTY CYCLE 10 1 DSS22-DSS24 DSS25-DSS26 DSS28-DSS210 DSS215-DSS220 DSS225 0.1 0.01 0.2 0.4 0.6 0.8 1.0 1.1 VF , INSTANTANEOUSFORWARD VOLTAGE (V) FIG. 4-TYPICAL REVERSE CHARACTERISTICS IR INSTANTANEOUS REVERSE CURRENT (mA) FIG. 1- FORWARD CURRENT DERATING CURVE IF INSTANTANEOUS FORWARD CURRENT,(A) DSS22 THRU DSS 225 100 TA=100℃ 10 1 TA=75℃ 0.1 TA=25℃ 0.01 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLYAGE(%) FIG. 5-TYPICAL JUNCTION CAPACITANCE Fig.6 TYPICAL CAPACITANCE 2000 C j CAPACITANCE(pF) 1000 DSS22-DSS24 DSS25-DSS225 100 TJ=25 C 10 0.1 1.0 10 100 VR REVERSE VOLTAGE, (V)) version:02 2 of 3 www.dyelec.com DSS22 THRU DSS 225 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3 of 3 www.dyelec.com
很抱歉,暂时无法提供与“D23”相匹配的价格&库存,您可以联系我们找货
