D16
D16
    DY(迪一电子)
    SOD-123F
    直流反向耐压(Vr):60V;平均整流电流(Io):1A;正向压降(Vf):700mV@1A;
D16 数据手册
DSS12 THRU DSS125 SINGLE PHASE 1.0AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features · The plastic package carries Underwriters Laboratory SOD-123FL Flammability Classification 94V-0 · Metal silicon junction,majority carrier conduction · Low power loss,high efficiency 8°(8°) 2°(2°) 0.079(2.0) 0.150(3.8) 0.134(3.4) 0.079(2.0) · Case: SOD-123FL, molded plastic · Terminals: plated leads solderable per MIL-STD-750, Method 2026 · Polarity: Color band denotes cathode end · Mounting position: Any 0.047(1.2) 0.032(0.8) 0.111(2.8) 0.095(2.4) 0.150(3.8) 0.134(3.4) Mechanical Data 0.043(1.1) 0.035(0.9) 0.008(0.2) 0.004(0.1) 0.063(1.6) 260 ℃ /10 seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension 0.063(1.6) · High temperature soldering guaranteed: 0.047(1.2) 0.032(0.8) 0.037(0.95) 0.022(0.55) Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL Code TYPE NUMBER DSS12 DSS13 D12 D13 D14 D15 D16 D18 D110 D115 D120 D125 20 30 40 50 60 80 100 150 200 250 V 14 21 28 35 42 56 70 105 140 175 V DSS14 DSS15 DSS16 DSS110 DSS115 DSS120 DSS125 DSS18 UNITS VRRM Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRWM RMS Reverse Voltage VRMS Average Rectified Output Current @TL =90℃ IF(AV) 1.0 A IFSM 30 A I 2t 3.735 A2s Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I 2t Rating for Fusing (t < 8.3ms) Forward Voltage per element @IF=1.0A Peak Reverse Current At Rated DC Blocking Voltage @TA =25℃ @TA =100 ℃ VDC VFM 0.55 IR 0.7 0.85 0.92 0.1 0.05 10 5 80 V mA Typical junction capacitance (NOTE 1) CJ Operating junction temperature range TJ -55to+150 ℃ TSTG -55to+150 ℃ Operating and Storage Temperature Range 110 0.95 Note:1. Measured at 1MHZ and applied reverse voltage of 4.0V D.C. version:02 1 of 3 www.dyelec.com pF DSS12 THRU DSS125 I FINSTANTANEOUS FORWARD CURRENT,(A) I (AV)AVERAGE FORWARD CURRENT (A) FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 Single Phase Half Wave 60Hz Resistive or inductive Load 0.6 0.4 0.2 0 0 25 50 75 100 125 150 175 O 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 25 20 15 10 5.0 0 1 10 20 DSS12-DSS14 DSS15-DSS16 DSS18-DSS110 DSS115-DSS120 DSS125 10 1 0.1 TA=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.01 0.2 0.4 0.6 0.8 1.0 1.1 VF, INSTANTANEOUS FORWARD VOLTAGE (V) FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT I R INSTANTANEOUS REVERSE CURRENT (mA) I FSM PEAK FORWARD SURGE CURRENT (A) LEAD TEMPERATURE( C) FIG. 2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 NUMBER OF CYCLES AT 60 Hz 100 10 TA=100 C 1 TA=75 C 0.1 TA=25 C 0.01 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLYAGE(%) (1.3) Fig.5 TYPICAL CAPACITANCE version:02 2 of 3 www.dyelec.com DSS12 THRU DSS125 Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from DIYI. • DIYI reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. •DIYI disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •DIYI does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the herein document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. DIYI makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify DIYI for any damages resulting from such improper use or sale. •Since DIYI uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:02 3 of 3 www.dyelec.com
很抱歉,暂时无法提供与“D16”相匹配的价格&库存,您可以联系我们找货
D16
    • 50+0.11934
    • 500+0.09450
    • 3000+0.07258
    库存:2956
