IC254V-12-40-0743-P1524
    XFCN(台湾兴飞)
    DIP-40
    间距2.54MM P数:40P 圆孔
IC254V-12-40-0743-P1524 数据手册
1 2 Technical Data Materlal: Pin(outer sleeve):Brass,machined CuZn38Pb2 Plating(outer sleeve): Tin Plated:2 μm/80 μ"NI,5 μm/200 μ"Sn Gold Plated:2 μm"/80 μ"Ni,0.8 μ" gold Plating(Contact ):2 μm/80μ"NI,gold or Tin plated Insuiator:PPS UL94V-0 Cllp(Contact 4 Flnger):Beryllium copper,heat teated 3 Electrical: Current rating:3Amps/contact max. Contact resistance:≤4m Ω/contact Insuiation resistance:≥1000M Ω at V=100V Operaing voitage:60VAC/DC 5 4 6 7 Mechanical: Average Insertion force with steel pin of ∅0.432:<250g Average withdrawal force with steel pin of ∅0.432:>70g Mechanical lige cycle:min 200 Operaling temperature:-40 °C to+105°C Soldering temperature:+255 °C Critical Dimensions: * P.C.B LAYOUT 2.54mm IC Socket Connectors IC254V-12-40-0743-P1524
IC254V-12-40-0743-P1524 价格&库存
很抱歉,暂时无法提供与“IC254V-12-40-0743-P1524”相匹配的价格&库存,您可以联系我们找货
  • 1+3.19000
  • 30+3.08000
  • 100+2.86000
  • 500+2.64000
  • 1000+2.53000
  • 2000+2.42000
库存:120
  • 1+4.48074
  • 12+4.15338
库存:12
    • 1+5.51988
    • 10+4.54518
    • 30+3.74490
    • 100+3.26268
    • 500+2.97540
    • 1000+2.82150
    库存:1348
    • 1+3.79500
    • 50+3.28900
    • 100+3.16250
    • 500+3.03600
    • 1000+2.98540
    库存:24
