FC1602B01-FHYYBW-51SK
    FORDATA
    FORDATA - FC1602B01-FHYYBW-51SK - Alphanumeric LCD, 16 x 2, Black on Yellow / Green, 5V, English, Eu...
FC1602B01-FHYYBW-51SK 数据手册
FC1602B01-FHYYBW-51SK 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC1602B01 1~6 DISPLAY FORMAT 16 Characters by 2 Lines POLARIZER OPTIONS Positive Transflective F 7 BACKLIGHT TYPE OPTIONS Edge Type LED Backlight (Long life span version) H 8 BACKLIGHT COLOR OPTIONS Yellow-Green color Y 9 LCD PANEL OPTIONS Yellow-Green STN Y 10 VIEWING ANGLE OPTIONS 6:00 ( Bottom ) B 11 TEMPERATURE RANGE OPTIONS -20 C ~ 70 C, Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 5.0V Vled = 5.0V 5 13 SUGGESTED LED DRIVING MODE PIN15: LED+, PIN16:LED- 1 14 ST7066U+ST7065C S 15 FONT MAP CODE K Ve r s i o n K 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 85.0W x 36.0H mm THICKNESS max 13.5 mm VIEWING AREA 64.5W x 16.4H mm HOLE-HOLE 80.0W x 31.0H mm CHARACTER SIZE 3.00W x 5.23H mm CHARACTER PITCH 0.51W x 0.52H mm DOT SIZE 0.56W x 0.61H mm DOT PITCH 0.05W x 0.05H mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL INPUT VOLTAGE Vdd SUPPLY CURRENT Idd DRIVING VOLTAGE FOR LCD PANEL CONDITION MIN Vdd=5V Vlcd = (Vdd - V0) * All data are recorded from TEST REPORT #FSYP000700037 TYP 5.0 V 1.5 mA -20 C 4.45 4.90 0C 4.35 4.85 25 C 4.25 50 C 4.15 4.70 70 C 4.05 4.60 4.50 4.80 V FC1602B01-FHYYBW-51SK 4 LCD / LED CHARACTERISTICS LCD CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V lcd =5.0V ICONS ITEM 0.5V) CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K 10 FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Non-Select B1 TR T F Time(ms) Rise Time Setpoint Driving Voltage Non-Select 10% Brightness Curve for selected Segment 90% Brlghtness(%) Select Signal 100% Brightness Curve for Non- selected Segment Fall Time LED CHARACTERISTICS ICONS UNIT ITEM SYMBOL CONDITION LED FORWARD VOLTAGE Vf 25 C If = 5mA 3.0 V If 25 C 5 mA LED FORWARD CURRENT 2 LED REVERSE CURRENT Ir 25 C Vr= 5V MIN TYP MAX 10 A 575 nm LED PEAK WAVE LENGTH p 25 C If = 5mA LED BRIGHTNESS (WITHOUT LCD) Lv 25 C If = 5mA LED BRIGHTNESS UNIFORMITY Lvmin/Lvmax 25 C If = 5mA 70 Ratio 25 C If = 5mA 20K Hours LED LIFE TIME 569 125 cd/m2 2 ,  .,! YOUR ATTENTION: It is constant current (not constant voltage) that should be applied when driving LED backlight. Therefore, this data is very important! * -)*/$25 C0, Ifm,Ifp1Pd2345; 456 -0.36*1mA/ C (8) ,+-0.86*1A/ C (:
FC1602B01-FHYYBW-51SK 价格&库存
很抱歉,暂时无法提供与“FC1602B01-FHYYBW-51SK”相匹配的价格&库存,您可以联系我们找货
