FC1602N04-NSWBBW-91*E
    FORDATA
    FORDATA - FC1602N04-NSWBBW-91*E - Alphanumeric LCD, 16 x 2, White on Blue, 3V, English, Japanese, Tr...
FC1602N04-NSWBBW-91*E 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England Telephone +44 (0)1493 602602 Fax +44 (0)1493 665111 Email:sales@midasdisplays.com www.midasdisplays.com MANAGEMENT SYSTEMS LCD MODULE SPECIFICATION ITEM CODE FC1602N04-NSWBBW-91SE SPECIFICATION ESTABLISHED DATE: 2017.06.28 UV FFF HC ISSUED BY: COPYRIGHT RoHS CHECKED BY: 70 C -20 C N 3.0V APPROVED BY: 2000 ~ 2015 FORDATA ELECTRONIC CO., LTD. ALL RIGHTS RESERVED CLASSIC is an attitude of insisting on "unnecessary" details INDEX CONTENTS PAGE DATASHEET STATEMENT 1 CODE SYSTEM 2 GENERAL SPECIFICATIONS FEATURES MECHANICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ELECTRONIC CHARACTERISTICS 3 LCD PANEL CHARACTERISTICS 4 LED BACKLIGHT CHARACTERISTICS 4 LCD MODULE CHARACTERISTICS PIN ASSIGNMENT BLOCK DIAGRAM POWER SUPPLY DIAGRAM 5 FONT MAP 6 MECHANICAL DRAWING 7 PACKING DETAILS 8 AMENDMENT RECORD MARK DATE DESCRIPTION ITEM PAGE 1 2017.06 INITIAL ISSUED ALL ALL APPROVED FC1602N04-NSWBBW-91SE 1 DATASHEET STATEMENT 1. The following icons are absolutely designed by FORDATA independently in 2007-SEP. They are unique in the LCD industry and are used for marking out FORDATA products’ characteristics quickly and simply without any special meaning. FORDATA reserves the composing right and copyright. No one else is allowed to adopt these icons without FORDATA’s approval. 2. The ISO9001 logo used in this document is authorized by SGS (www.sgs.com). FORDATA has already successfully passed the strict and professional ISO9001:2000 Quality Management System Certification and got the certificate. (No.: CN07/00404) 3. The technologies/techniques/crafts which denoted by the following icons are not exclusively owned by FORDATA but also shared by FORDATA’s LCD strategic cooperators, however all these technologies/techniques/crafts have been finally confirmed by FORDATA’s professional engineers and QC department. 4. As the difference in test standard and test conditions, also FORDATA’s insufficient familiarity with the actual LCD using environment, all the referred information in this DATASHEET (including the icons) only have two functions: 4.1: providing quick reference when you are judging whether the product meets your requirements or not. 4.2: listing out the tolerance. FORDATA declares seriously: you should first test the corresponding sample(s) before signing the formal FORDATA SAMPLE APPROVAL document rather than consider this DATASHEET as the standard for judging whether the LCD meets your requirements or not . Once you place bulk order(s) to FORDATA without testing samples. FORDATA will disclaim all responsibility if the mass-production is proved not to meet with your requirements. 5. The sequence of the icons is random and doesn’t indicate the importance grade. 6. Icons explanation 2000 Version 2006 Version 2012 Version FORDATA is an integrated manufacturer of flat panel display (FPD). All above listed icons and words compses FORDATA’s logo. From 2000, FORDATA has supplied LCD module From 2006, FORDATA has supplied TN, HTN, STN, FSTN monochrome LCD panel From 2012, FORDATA has supplied all kinds of LED backlight. FFF HC FAST RESPONSE TIME This icon on the cover indicates the product is with high response speed; Otherwise not. PROTECTION CIRCUIT This icon on the cover indicates the product is with protection circuit; Otherwise not. HIGH CONTRAST This icon on the cover indicates the product is with high contrast; Otherwise not. LONG LIFE VERSION This icon on the cover indicates the product is long life version (over 9K hours guaranteed); Otherwise not. WIDE VIEWING SCOPE This icon on the cover indicates the product is with wide viewing scope; Otherwise not. RoHS 3.0V UV Anti UV VERSION This icon on the cover indicates the product is against UV line. Otherwise not. RoHS COMPLIANCE This icon on the cover indicates the product meets ROHS requirements; Otherwise not. EASY OPERATION TEMPERATURE This icon on the cover indicates the product can have good contrast on one driving voltage in indicated operation temperature range . 3TIMEs 100% QC EXAMINATION This icon on the cover indicates the product has passed FORDATA’s thrice 100% QC. Otherwise not. TWICE SELECTION OF LED MATERIALS This icon on the cover indicates the LED has passed FORDATA’s twice strict selection which promises the product’s identical color and brightness; Otherwise not. Vlcm = 3.0V This icon on the cover indicates the product can work at 3.0V exactly; otherwise not. N N SERIES TECHNOLOGY (2008 developed) FORDATA adopts new structure, new craft, new technology and new materials inside both LCD module and LCD panel to improve the "RainBow" FC1602N04-NSWBBW-91SE 2 * * Please refer INDICATED VOLTAGE of LED in Page4 and Page5. CODE SYSTEM FC1602N04-NSWBBW-91SE 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC1602N04 1~6 DISPLAY FORMAT 16 Characters by 1 2 Lines POLARIZER OPTIONS Negative Transmissive N 7 BACKLIGHT TYPE OPTIONS Edge Type LED Backlight (Standard version) S 8 BACKLIGHT COLOR OPTIONS White color W 9 LCD PANEL OPTIONS Blue STN B 10 VIEWING ANGLE OPTIONS 6:00 ( Bottom ) B 11 TEMPERATURE RANGE OPTIONS -20 C ~ 70 C, Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 3.0V Vled = 3.0V 9 13 SUGGESTED LED DRIVING MODE PIN15: LED+, PIN16:LED- 1 14 ST7066U+ST7065C S 15 FONT MAP CODE E Ve r s i o n E 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 80.0W x 36.0H mm THICKNESS max 13.5 mm VIEWING AREA 64.5W x 13.8H mm HOLE-HOLE 75.0W x 31.0H mm CHARACTER SIZE 2.95W x 4.35H mm CHARACTER PITCH 0.7W x 0.7H mm DOT SIZE 0.55W x 0.50H mm DOT PITCH 0.05W x 0.05H mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL 3.0V INPUT VOLTAGE Vlcm = Vdd SUPPLY CURRENT Idd CONDITION Vdd=3V MIN TYP 3.0 V 2.0 mA -20 C 0C DRIVING VOLTAGE FOR LCD PANEL Vlcd = (Vdd - V0) 25 C 50 C 70 C * All data are recorded from TEST REPORT #FSYP000700079 V FC1602N04-NSWBBW-91SE 4 LCD / LED CHARACTERISTICS LCD CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V lcd = 5 .0V ± 0.5V) ICONS ITEM CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 6 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Non-Select B1 TR T F Time(ms) Rise Time Setpoint Driving Voltage Non-Select 10% Brightness Curve for selected Segment 90% Brlghtness(%) Select Signal 100% Brightness Curve for Non- selected Segment Fall Time LED CHARACTERISTICS ICONS ITEM LED FORWARD VOLTAGE LED FORWARD CURRENT 2 LED REVERSE CURRENT UNIT SYMBOL CONDITION Vf 25 C 3.0 V 25 C 15 mA If Ir Y coordinate TYP 25 C If = 15mA MAX A 10 25 C Vr=5.0V X coordinate LED COLOR RANGE MIN 0.26 0.30 0.27 0.31 cd/m2 LED BRIGHTNESS (WITHOUT LCD) Lv 25 C If = 15 mA LED BRIGHTNESS UNIFORMITY Lvmin/Lvmax 25 C If = 15 mA 70 Ratio 25 C If = 15 mA 9K Hours LED LIFE TIME 3 390 2 ,  .,! YOUR ATTENTION: It is constant current (not constant voltage) that should be applied when driving LED backlight. Therefore, this data is very important! * -)*/$25 C0, Ifm,Ifp1Pd2345; 456 -0.36*1mA/ C (8) ,+-0.86*1 mA/ C (:
FC1602N04-NSWBBW-91*E 价格&库存
很抱歉,暂时无法提供与“FC1602N04-NSWBBW-91*E”相匹配的价格&库存,您可以联系我们找货
