FC0801A04-RNNYBW-16*E
    FORDATA
    FORDATA - FC0801A04-RNNYBW-16*E - DISPLAY, ALPHANUMERIC, 8X1, NO BACKLIGHT
FC0801A04-RNNYBW-16*E 数据手册
FC0801A04-RNNYBW-16LE 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC0801A04 1~6 DISPLAY FORMAT 8 Characters by 1 Lines POLARIZER OPTIONS Positive Reflective R 7 BACKLIGHT TYPE OPTIONS No Backlight N 8 BACKLIGHT COLOR OPTIONS No Backlight N 9 LCD PANEL OPTIONS Yellow-Green STN Y 10 VIEWING ANGLE OPTIONS 6:00 ( Bottom ) B 11 TEMPERATURE RANGE OPTIONS - 20 C ~ 7 0 C, Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 3.0V 1 13 SUGGESTED LED DRIVING MODE No Backlight 6 14 SPLC780D L 15 FONT MAP CODE E Ve r s i o n E 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 84.0W x 44.0H mm THICKNESS max 13.5 mm VIEWING AREA 61.0W x 15.8H mm HOLE-HOLE 79.0/76.0W x 36.0H mm 6.45W x 10.75H mm CHARACTER PITCH 1.25W x 1.30H mm DOT PITCH CHARACTER SIZE DOT SIZE 0.7W 0.05W x 0.05H mm mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL 3.0V INPUT VOLTAGE Vlcm = Vdd SUPPLY CURRENT Idd CONDITION Vdd=3.0V MIN TYP 3.0 V 1.5 mA -20 C 0C DRIVING VOLTAGE FOR LCD PANEL Vlcd = (Vdd - V0) 25 C 50 C 70 C All data are recorded from TEST REPORT #FSYP0000 V FC0801A04-RNNYBW-16LE 4 LCD PANEL CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V dd = 3.0 V ± 0.5V) ICONS ITEM CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K 10 FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Brightness Curve for selected Segment B1 90% Brlghtness(%) Select Signal TR Setpoint Driving Voltage Rise Time Non-Select 10% Non-Select 100% Brightness Curve for Non- selected Segment T F Time(ms) Fall Time FC0801A04-RNNYBW-16LE 5 LCM CHARACTERISTICS PIN ASSIGNMENT PIN SYMBOL DESCRIPTION REMARKS 1 Vss GND 2 Vdd Power supply for LCM 3 NC No connection 4 RS Register Select Signal 5 R/W 6 E Enable Signal 7 DB0 Data bus line 8 DB1 Data bus line 9 DB2 Data bus line 10 DB3 Data bus line 11 DB4 Data bus line 12 DB5 Data bus line 13 DB6 Data bus line 14 DB7 Data bus line 15 NC No connection 16 NC No connection 3.0V Data Read / Write BLOCK DIAGRAM POWER SUPPLY DIAGRAM SINGLE SUPPLY TYPES U2 Vss Vdd SEG1--40 40 RS R/W E SEG1 U1 V SS Vdd SEG100 LCD 20 2 8 DB 7 SEG41-100 COM1 COM16 16 DB 0 60 COM16 DC-DC Vdd +3V FC0801A04-RNNYBW-16LE Upper 4bit Lower 4bit 6 FONT MAP LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH LLLL CG RAM (1) LLLH (2) LLHL (3) LLHH (4) LHLL (5) LHLH (6) LHHL (7) LHHH (8) HLLL (1) HLLH (2) HLHL (3) HLHH (4) HHLL (5) HHLH (6) HHHL (7) HHHH (8) FC0801A04-RNNYBW-16LE 7 MECHANICAL DRAWING FC0801A04-RNNYBW-16LE FULL-SIZED PACKAGE 8 HALF-SIZED PACKAGE 45 PCS/BOX 45 PCS/BOX 10 BOXES/CARTON 5 BOXES/CARTON 450 PCS/CARTON 225 PCS/CARTON 13.00 KGS/CTN(G.W.) 6.00 KGS/CTN(G.W.) 3 0.0 2 7 M 3/CARTON 0.0 54 M /CARTON Anti - static Bag FORDATA LCD Module BOX CARTON PACKING DETAILS PACKING DECLARATION 1. This packaging information is for reference only. The actual information is subject to the actual packaging. Especially for packaging of LCL, tolerances may exist. 2. FORDATA will not be responsible for quality problems caused by unnormal transportation conditions (including but not limited to climate factors or human factors, such as improper handling).
FC0801A04-RNNYBW-16*E 价格&库存
很抱歉,暂时无法提供与“FC0801A04-RNNYBW-16*E”相匹配的价格&库存,您可以联系我们找货
