FC1604A01-FSYYBW-51*K
    FORDATA
    FORDATA - FC1604A01-FSYYBW-51*K - DISPLAY, ALPHANUMERIC, 16X4, YELLOW GRN
FC1604A01-FSYYBW-51*K 数据手册
FC1604A01-FSYYBW-51SK 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC1604A01 1~6 DISPLAY FORMAT 16 Characters by 4 Lines POLARIZER OPTIONS Positive Transflective F 7 BACKLIGHT TYPE OPTIONS Edge Type LED Backlight (Standard version) S 8 BACKLIGHT COLOR OPTIONS Yellow-Green color Y 9 LCD PANEL OPTIONS Yellow-Green STN Y 10 VIEWING ANGLE OPTIONS 6:00 ( Bottom ) B 11 TEMPERATURE RANGE OPTIONS -20 C ~ 70 C, Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 5.0V Vled = 5.0V 5 13 SUGGESTED LED DRIVING MODE PIN15: LED+, PIN16:LED- 1 14 ST7066U+ST7063C+ST7065C S 15 FONT MAP CODE K Ve r s i o n K 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 87.0W x 60.0H mm THICKNESS max 14.5 mm VIEWING AREA 61.8W x 25.2H mm HOLE-HOLE 82.0W x 55.0H mm CHARACTER SIZE 2.96W x 4.76H mm CHARACTER PITCH 0.59W x 0.59H mm DOT SIZE 0.56W x 0.56H mm DOT PITCH 0.04W x 0.04H mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL INPUT VOLTAGE Vlcm = Vdd SUPPLY CURRENT Idd CONDITION MIN Vdd=5V -20 C TYP 5.0 V 1.5 mA 4.80 4.40 0C DRIVING VOLTAGE FOR LCD PANEL Vlcd = (Vdd - V0) 25 C 4.25 4.50 4.75 50 C 70 C * All data are recorded from TEST REPORT #FSYP000700002 4.05 4.55 V FC1604A01-FSYYBW-51SK 4 LCD / LED CHARACTERISTICS LCD CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V dd =5.0V ± 0.5V) ICONS ITEM CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K 10 FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Non-Select B1 TR T F Time(ms) Rise Time Setpoint Driving Voltage Non-Select 10% Brightness Curve for selected Segment 90% Brlghtness(%) Select Signal 100% Brightness Curve for Non- selected Segment Fall Time LED CHARACTERISTICS ICONS ITEM SYMBOL CONDITION MIN LED FORWARD VOLTAGE Vf 25 C If = 15mA 2.8 If 25 C LED FORWARD CURRENT 2 TYP MAX UNIT 3.1 V 15 mA 10 A 575 nm LED REVERSE CURRENT Ir LED PEAK WAVE LENGTH p 25 C If = 15mA LED BRIGHTNESS (WITHOUT LCD) Lv 25 C If = 15mA LED BRIGHTNESS UNIFORMITY Lvmin/Lvmax 25 C If = 15mA 70 Ratio 25 C If = 15mA 9K Hours LED LIFE TIME 3 25 C Vr=5.0V 569 180 cd/m2 2 ,  .,! YOUR ATTENTION: It is constant current (not constant voltage) that should be applied when driving LED backlight. Therefore, this data is very important! * -)*/$25 C0, Ifm,Ifp1Pd2345; 456 -0.36*1mA/ C (8) ,+-0.86*1 mA/ C (:
FC1604A01-FSYYBW-51*K 价格&库存
很抱歉,暂时无法提供与“FC1604A01-FSYYBW-51*K”相匹配的价格&库存,您可以联系我们找货
