FC2004C03-NSWBBW-91*E
    FORDATA
    FORDATA - FC2004C03-NSWBBW-91*E - Alphanumeric LCD, 20 x 4, White on Blue, 3V, Parallel, English, Ja...
FC2004C03-NSWBBW-91*E 数据手册
FC2004C03-NSWBBW-91LE 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC2004C03 1~6 DISPLAY FORMAT 20 Characters by 4 Lines POLARIZER OPTIONS Negative Transmissive N 7 BACKLIGHT TYPE OPTIONS Edge Type LED Backlight (Standard version) S 8 BACKLIGHT COLOR OPTIONS White color W 9 LCD PANEL OPTIONS Blue STN B 10 VIEWING ANGLE OPTIONS 6:00 ( Bottom ) B 11 TEMPERATURE RANGE OPTIONS -20 C ~ 70 C, Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 3.0V Vled = 3.0V 9 13 SUGGESTED LED DRIVING MODE PIN15: LED+, PIN16:LED- 1 14 SPLC780D + SPLC063A L 15 FONT MAP CODE E Ve r s i o n E 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 77.0W x 47.0H mm THICKNESS max 14.5 mm VIEWING AREA 60.0W x 22.0H mm HOLE-HOLE 70.0W x 40.0H mm CHARACTER SIZE 2.30W x 4.03H mm CHARACTER PITCH 0.48W x 0.48H mm DOT SIZE 0.42W x 0.46H mm DOT PITCH 0.05W x 0.05H mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL 3.0V INPUT VOLTAGE Vdd SUPPLY CURRENT Idd CONDITION Vdd=3V MIN TYP 3.0 V 1.5 mA -20 C 0C DRIVING VOLTAGE FOR LCD PANEL Vlcd = (Vdd - V0) 25 C 50 C 70 C All data are recorded from TEST REPORT #FSYP027800122 V FC2004C03-NSWBBW-91LE 4 LCD / LED CHARACTERISTICS LCD CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V lcd =5.0V ICONS ITEM 0.5V) CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K 10 FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Non-Select B1 TR ICONS LED CHARACTERISTICS SYMBOL ITEM LED FORWARD VOLTAGE LED FORWARD CURRENT Vf 2 LED REVERSE CURRENT If Ir CONDITION Y coordinate Fall Time MIN 25 C If = 15mA 25 C TYP 25 C If = 15mA MAX UNIT 3.0 V 15 mA 25 C Vr= 5.0V X coordinate LED COLOR RANGE T F Time(ms) Rise Time Setpoint Driving Voltage Non-Select 10% Brightness Curve for selected Segment 90% Brlghtness(%) Select Signal 100% Brightness Curve for Non- selected Segment A 10 0.26 0.30 0.27 0.31 cd/m2 LED BRIGHTNESS (WITHOUT LCD) Lv 25 C If = 15mA LED BRIGHTNESS UNIFORMITY Lvmin/Lvmax 25 C If = 15mA 70 Ratio 25 C If = 15mA 9K Hours LED LIFE TIME 3 295 2 ,  .,! YOUR ATTENTION: It is constant current (not constant voltage) that should be applied when driving LED backlight. Therefore, this data is very important! * -)*/$25 C0, Ifm,Ifp1Pd2345; 456 -0.36*1mA/ C (8) ,+-0.86*1mA/ C (:
FC2004C03-NSWBBW-91*E 价格&库存
很抱歉,暂时无法提供与“FC2004C03-NSWBBW-91*E”相匹配的价格&库存,您可以联系我们找货
