FC1602E01-FHYYBW-51*K
    FORDATA
    FORDATA - FC1602E01-FHYYBW-51*K - DISPLAY, ALPHANUMERIC, 16X2, YELLOW GRN
FC1602E01-FHYYBW-51*K 数据手册
FC1602E01-FHYYBW-51SK 3 GENERAL SPECIFICATIONS FEATURES CHARACTERISTICS AVAILABLE OPTIONS CODE No. FC1602E01 1~6 DISPLAY FORMAT 16Characters by 2 Lines POLARIZER OPTIONS Positive Transflective F 7 BACKLIGHT TYPE OPTIONS Edge Type LED Backlight (Long life span version) H 8 BACKLIGHT COLOR OPTIONS Yellow-Green color Y 9 LCD PANEL OPTIONS STN ( Yellow-Green color) Y 10 VIEWING ANGLE OPTIONS 6:00 (Bottom ) B 11 TEMPERATURE RANGE OPTIONS -20 C ~ 70 C,Single Supply Voltage W 12 SUGGESTED DRIVING VOLTAGE Vlcm = 5.0V Vled = 5.0V 5 13 SUGGESTED LED DRIVING MODE PIN15: LED+, PIN16:LED- 1 14 ST7066U+ST7065C S 15 FONT MAP CODE K Ve r s i o n K 16 DRIVING DUTY 1/16 DRIVING BIAS 1/5 1 CONTROLLER 1 Please ask for datasheet of the mentioned controller from FORDATA or FORDATA's authorized distributors. You can find the related 1 information including AC & DC characteristics, Write & Read Timing diagram, Instruction table and descriptions, DDRAM & CGRAM, Rest Function and so on from the datasheet of controller. You can ask for the example of software program (C language) from FORDATA or FORDATA's authorized distributors. MECHANICAL SPECIFICATIONS OVERALL SIZE 84.0W x 44.0H mm THICKNESS max 13.5 mm VIEWING AREA 64.5W x 16.4H mm HOLE-HOLE 79.0/76.0W x 36.0H mm CHARACTER SIZE 3.00W x 5.23H mm CHARACTER PITCH 0.51W x 0.52H mm DOT SIZE 0.56W x 0.61H mm DOT PITCH 0.05W x 0.05H mm ABSOLUTE MAXIMUM RATINGS MAX UNIT -0.3 7.0 V 25 C Vdd -13.5 Vdd +0.3 V 25 C -0.3 Vdd +0.3 V Vopr -20 70 C Vstg -30 80 C MAX UNIT ITEM SYMBOL CONDITION MIN POWER SUPPLY ( LOGIC) Vdd 25 C POWER SUPPLY (LCD) V0 INPUT VOLTAGE Vin OPERATING TEMPERATURE STORAGE TEMPERATURE TYP ELECTRONIC CHARACTERISTICS * ICONS ITEM SYMBOL INPUT VOLTAGE Vdd SUPPLY CURRENT Idd DRIVING VOLTAGE FOR LCD PANEL CONDITION MIN Vdd=5V Vlcd = (Vdd - V0) * All data are recorded from TEST REPORT #FSYP000700037 TYP 5.0 V 1.5 mA -20 C 4.45 4.90 0C 4.35 4.85 25 C 4.25 50 C 4.15 4.70 70 C 4.05 4.60 4.50 4.80 V FC1602E01-FHYYBW-51SK 4 LCD / LED CHARACTERISTICS LCD CHARACTERISTICS FOR STN /FSTN TYPE LCD Panel (TA=25 C, V lcd =5.0V ICONS ITEM 0.5V) CONDITION SYMBOL _ 2 1 TYP MIN MAX 40 VIEWING ANGLE UNIT deg K=4 60 HC CONTRAST RATIO K 10 FFF RESPONSE TIME(RISE) TR 150 250 ms RESPONSE TIME(FALL) TF 150 250 ms DEFINITION OF VIEWING ANGLE & 2 Y ( = 180 ) 1& 2 Contrast Ratio K DEFINITION OF ANGLE 1 1.4 X X` 1 Y( =0 ) Brightness(%) DEFINITION OF CONTRAST RATIO K(=B2/B1) 2 Viewing Angle DEFINITION OF OPTICAL RESPONSE TIME TR & TF B2 Non-Select B1 TR T F Time(ms) Rise Time Setpoint Driving Voltage Non-Select 10% Brightness Curve for selected Segment 90% Brlghtness(%) Select Signal 100% Brightness Curve for Non- selected Segment Fall Time LED CHARACTERISTICS ICONS ITEM SYMBOL CONDITION MIN LED FORWARD VOLTAGE Vf 25 C 2.8 If 25 C LED FORWARD CURRENT 2 TYP MAX UNIT 3.1 V 5 mA 10 A 575 nm LED REVERSE CURRENT Ir 25 C Vr=5.0V LED PEAK WAVE LENGTH p 25 C If = 5mA LED BRIGHTNESS (WITHOUT LCD) Lv 25 C If = 5mA LED BRIGHTNESS UNIFORMITY Lvmin/Lvmax 25 C If = 5mA 70 Ratio 25 C If = 5mA 20K Hours LED LIFE TIME 569 88 cd/m2 2 ,  .,! YOUR ATTENTION: It is constant current (not constant voltage) that should be applied when driving LED backlight. Therefore, this data is very important! * -)*/$25 C0, Ifm,Ifp1Pd2345; 456 -0.36*1mA/ C (8) ,+-0.86*1 mA/ C (:
物料型号:FC1602E01-FHYYBW-51SK
器件简介:文档提供了一个16字符x2行的液晶显示屏的详细规格和特性,包括不同的选项如显示格式、偏振器选项、背光类型、颜色、LCD面板、视角、温度范围、建议的驱动电压和模式、控制器型号等。
引脚分配:文档列出了16个引脚的分配,包括地线(Vss)、电源(Vdd)、对比度调整(VO)、寄存器选择信号(RS)、数据读写(R/W)、使能信号(E)、数据线(DB0-DB7)、LED正负电源(PIN15和PIN16)。
参数特性:包括电源电压、输入电压、工作温度、存储温度、LCD面板的驱动电压、背光LED的正向电压、电流、反向电流、峰值波长、亮度、亮度均匀性和寿命等。
功能详解:文档建议从FORDATA或其授权经销商获取控制器的数据手册,以获取包括交流和直流特性、写入和读取时序图、指令表和描述、数据和字符生成器、复位功能等相关信息。同时,也可以获取C语言的软件程序示例。
应用信息:文档没有明确提供应用信息,但根据提供的特性和规格,该显示屏适用于需要在一定温度范围内显示16个字符x2行信息的应用场景。
封装信息:文档提供了机械规格,包括整体尺寸、观看区域、字符大小、点大小和点间距,以及安装孔的尺寸。
FC1602E01-FHYYBW-51*K 价格&库存
很抱歉,暂时无法提供与“FC1602E01-FHYYBW-51*K”相匹配的价格&库存,您可以联系我们找货
