FRG-Series
Thick Film Chip High Resistor Product Specifications
FRG 系列厚膜片式超高阻值电阻器规格说明书
超高阻值厚膜片式电阻器(Thick Film Chip HighResistor )
■应用(Application)
Entertainment:Stereo,TV tuners,Tape recorder
- 娱乐:立体声、电视调谐器、录音机
Appliance: Air conditioner, Refrigerator
- 电器:空调、冰箱
Computer & relative products : Main board, PDA
- 电脑及相关产品:主板、PDA
Communication equipment: Cell phone, Fax machine
- 通讯设备:手机、传真机
Power equipment: Power supply , II Lumination equipment
- 电源设备:电源、二级照明设备
Measuring instrument: Electric meter,Navigation equipment
- 测量仪器:电表、导航设备
■特点(Features)
small size and light weight
- 体积小、重量轻
- 可靠性,高质量
Reliability, high quality
■产品料号(Parts Number Explanation)
示例(Example):
FRG1206J226 TS
F
R
G
1206
J
226
T
S
公司名
产品别
功能别
尺寸
公差
字码
包装别
端电极
特殊码
FOJAN
R:Resistor
C:Normal
0603
B:±0.1%
±5%:E24
T: 7 inch reel
S:Sn
N:
C:Capacitor
P:Hi-Power
0805
C:±0.25%
3-digits+blank
Q:10 inch reel
C:Cu
Normal
L:Inductor
L:Lowohmic
1206
D:±0.5%
102=1KΩ
R:13 inch reel
A:Au
D:Diode
A:Array
1210
F:±1%
1R0=1Ω
B:Bulk
A:Audion
S:Surge
1218
J:±5%
±1%&Below:
H:Hi-Precision
1812
P:Jumper
E24+E96:
V:Hi-Voltage
2010
4-digits
Q:Auto-motive
2512
1001=1KΩ
R:Anti-sulfur
D:LED
1R00=1Ω
M:Metal
D: LED
G:Hi-Resistence
Compa
Type code
Functional code
ny code
FJ-JS-3001-V1.0 / 2021.1.25
Size
Tolerance
Resistance
Packaging
Termination
Special
code
code
code
code
code
Case
1
www.fojan.cn
FRG-Series
■本体标识(Marking on the Resistor's Body)
0201 及 0402 因本体太小,本体上无字码标示
For 0201 and 0402 size, no marking on the body due to the
small size of the resistor
472=47×102=4.7KΩ
公差±5%的产品,以三字码标示,前两位表示阻值
的有效数字,最后一位表示 10 的乘幂
±5% tolerance product: the marking is 3 digits, the first
2 digits are significant figures of resistance value and
the 3rd one denotes the power number of 10, (10X)
10Ω以下标示:5R6=5.6Ω
Below 10Ω: 5R6=5.6Ω
±0.5%, ±1%, ±2%的产品,以四字码标示,前三位
表示阻值的有效数字,最后一位表示 10 的乘幂
±0.5%, ±1%,±2% tolerance product: the marking is 4
digits, the first 3 digits are significant figures of
resistance value and the 4th one denotes the power
number of 10, (10X)
4992=499×102=49.9KΩ
0603 ±1% E96 系列的标准阻值,因电阻本体太小,
采用三位代码标示。
Standard E96 series values of 0603 ±1%: due to the
small size of the resistor’s body, use 3digits code to
indicate the resistance value.
100Ω以下标示:
6R81=6.81Ω
Below 100Ω: 6R81=6.81
Ω
■0603±1% E96 系列电阻值代码 Standard E96 Series Resistance Value Code for 0603
代码 阻值
Code Value
01
100
02
102
03
105
04
107
05
110
06
113
07
115
08
118
09
121
10
124
11
127
12
130
13
133
14
137
15
140
16
143
代码
Code
17
18
19
22
23
24
25
26
27
28
29
30
31
32
阻值
Value
147
150
154
158
162
165
169
174
178
182
187
191
196
200
205
210
代码
Code
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
阻值
Value
215
221
226
232
237
243
249
255
261
267
274
280
287
294
301
309
代码
Code
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
2
阻值
Value
316
324
332
340
348
357
365
374
383
392
402
412
422
432
442
453
代码
Code
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
阻值
Value
464
475
487
499
511
523
536
549
562
576
590
604
619
634
649
665
±1% Marking
代码
Code
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
阻值
Value
681
698
715
732
750
768
787
806
825
845
866
887
909
931
953
976
www.fojan.cn
FRG-Series
■0603±1%标记的倍增码 Multiplier Code for 0603
代码 Code
指数 Multiplier
Y
X
-2
10
10
±1% Marking
A
-1
10
B
C
1
10
D
2
10
E
3
F
10
4
105
阻值标示如下(So the resistance value are marked as the following examples)
10D=124×103=124KΩ
38Y=243×10-2=2.43Ω
0603 ±1%的产品,在标准 E24 系列中,但不属于 E96 系列,标示与 5%的字码相同,但是在中间字码
下加一条线(Standard E24 and not belong to E96 series values of 0603 ±1%, the marking is the
same as 5% tolerance but marking as underline)
331=33×101=330Ω
560=56×100=56Ω
尺寸(Dimension):
尺寸
dimension
单位(unit): mm
型别(Type)
L
W
H
T1
T2
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.25±0.15
0.25±0.15
0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.35±0.20
1206
3.10±0.10
1.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
1210
3.10±0.10
2.60±0.15
0.55±0.10
0.45±0.15
0.50±0.20
1218
3.10±0.10
4.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
1812
4.50±0.20
3.10±0.20
0.55±0.10
0.55±0.20
0.70±0.20
2010
5.00±0.10
2.50±0.15
0.55±0.10
0.45±0.15
0.50±0.20
2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.20
0.50±0.20
3
www.fojan.cn
FRG-Series
■ 功率衰减曲线( Derating Curve)
■ 电阻结构(Construction)
NO.
1
2
3
4
5
6
7
8
9
4
结构
construction
主要材料
Major material
陶瓷基板
Ceramic substrate
银电极
Conductive layer
侧电极
Side conductive layer
阻体层
Resistive layer
内保护层
Inner protective layer
外保护层
Outer Protective layer
文字
Marking
镍电极
Ni plating layer
锡电极
Sn plating layer
三氧化二铝
Al2O3
银
Ag
镍铬合金
NiCr
氧化钌+玻璃
RuO2+ glass
玻璃
Glass
环氧树脂
Epoxy
环氧树脂
Epoxy
镍
Ni
锡
Matte Tin
www.fojan.cn
FRG-Series
■ 电气特性(Electrical characteristics)
型别 Type
0603
0805
1206
1210
1218
1812
2010
2512
额定功率
Rated power
1/10W
1/8W
1/4W
1/2W
1W
3/4W
3/4W
1W
最大工作电压
Max Working Voltage
75V
150V
200V
200V
200V
200V
200V
200V
最大过负荷电压
Max Overload Voltage
150V
300V
400V
400V
500V
400V
400V
400V
绝缘耐压
Dielectric Withstanding
Voltage
100V
300V
500V
500V
500V
500V
500V
500V
备注(remark): 额定电压计算公式(The rated voltage is calculated by the following formula)
E=
RP
E:额定电压(Rated Voltage) (V)
P:额定功率(Rated Power ) (W)
R:电阻阻值(Resistance
) (ohm)
如果计算出的电压超过此型别的最大工作电压,则此型别的最大工作电压为此电阻的额定电压。
In case the value calculated by the formula exceed the maximum working voltage as above table 8, the maximum working
voltage shall be regarded as rated voltage.
5
www.fojan.cn
FRG-Series
■ 电性规格(Standard Electrical Specifiations)
额定功率
(PowerRating
at 70℃)
Max. RCWV
0603
1/10W
50V
100V
0805
1/8W
150V
300V
1206
1/4W
200V
400V
1210
1/2W
200V
400V
型别
Type
最高
工作电压
最大过负荷电压
Max. Overload Voltage
1218
1W
200V
500V
1812
3/4W
200V
400V
2010
3/4W
200V
400V
2512
1W
200V
400V
6
阻值范围
T.C.R.
(PPM/℃)
Resistance Range
± 200
10MΩ~100MΩ
www.fojan.cn
FRG-Series
■ 性能(Performance Specifications)
内容
Item
温度系数
Temperature
Coefficient
短时间过负荷
Short-time
overload
焊锡性
Solderability
测试方法
Test Methods
测试条件
Test Conditions
规格
Specification
JIS C 5201 4.8
TCR=(R-R0 )/(t-t0)R0 ×106(ppm)
R0 电阻在室 温下的阻值(resistance at
room temperature)
R 电 阻 在 125 ℃ 或 -55 ℃ 下 的 阻 值
(resistance at 125℃ or -55℃)
t0 室温(room temperature)
t 测试温度(test temperature 125℃ or
-55℃)
JIS C 5201 4.13
加载 2.5 倍的额定电压,时间 5 秒后测
量试验前后的阻值变化率。
Applied 2.5 times of rated voltage for 5
second. Measure the variation of
resistance.
±(1.00% +0.05Ω)
JIS C 5201 4.17
沾助焊剂后浸入锡炉,锡炉温度 245±
5℃,时间 3±0.5 秒。
Dip the terminal in a flux and then dip
into a soldering bath at 245±5℃ for 3±
0.5sec.
>95%面积上锡
(>95% coverage)
抗焊锡热
Resist to
soldering heat
JIS C 5201 4.18
绝缘电阻
Insulation
resistance
JIS C 5201 4.6
沾助焊剂后浸入锡炉,锡炉温度 260±
5℃,时间 10±0.5 秒, 测量试验前后的
阻值变化率。
into a soldering bath at 260±5℃ for 10±
0.5sec. Measure the variation of
resistance.
电阻本体上加载绝缘耐压 60±5 秒后,
测量绝缘阻抗。
Applied the dielectric withstanding
voltage on the center of body for 60±
5seconds. Then measure insulation
resistance.
7
0603~2512 规格:
10MΩ10GΩ
www.fojan.cn
FRG-Series
内容
Item
绝缘耐压
Dielectric
withstanding
voltage
测试方法
Test Methods
JIS C 5201 4.7
测试条件
Test Conditions
电阻本体上加载绝缘耐压 60±5 秒。
voltage on the center of body for60±
5seconds.
规格
Specification
无击穿、飞弧及可见机
械性损伤
No evidence of
flashover, mechanical
damage arcing or
insulation breakdown
电阻焊接在测试板上进行弯折,弯折保持时
间 20 ± 1 秒 , 1206( 含 ) 以 下 的尺 寸 弯曲
5+0.2/0 mm; 1206 以上的尺寸弯曲 2+0.2/0
mm; 量测试验前后阻值变化率
Specimen shall be mounted on test board,
then bend the board and maintained for 20±
1s. the distance of bending is 5+0.2/0 mm for
resistors which size no larger than 1206 or
2+0.2/0 mm which size larger than 1206.
Measure the variation of resistance.
测试板(test board) 压头(jig)
端子弯曲
Terminal
bending
±(1.00% +0.05Ω)
JIS C 5201 4.33
8
www.fojan.cn
FRG-Series
内容
Item
温度循环
Temperature
Cycling
耐湿特性
Humidity
负荷寿命
Load life
温湿循环
Moisture
resistance
测试方法
Test Methods
测试条件
Test Conditions
JIS C 5201 4.19
电阻放入温度循环机中,温度 155±2℃
至-55±3℃,共 5 个循环。量测试验前后
阻值变化率.
Put specimen in a chamber which
temperature can be changed to 155±2℃
or -55±3℃, repeated 5 times. Measure
±(2.00% +0.05Ω)
JIS C 5201 4.24
电阻放入恒温恒湿箱,温度 40±2℃,湿
度 90~95 %RH;通电额定电压 1.5 小时,
断电 0.5 小时;重复通断电至试验时间
1000 +48/-0 小时. 量测试验前后阻值变
化率.
Put the specimen in a chamber at 40±2℃
temperature and 90~95% relative
humidity, then applied rated voltage
for1.5H and rested for 0.5H repeatedly
till total test time is 1000+48/-0 H. Measure
±(2.00% +0.05Ω)
JIS C 5201
4.25.1
电阻放入恒温箱中,温度 70±2℃,ON
TIME:1.5H,OFF TIME:0.5H,通电额定电
压 1000 +24/-0 小时,量测试验前后阻值变
化率.
Put the specimen in a chamber at 70±2℃
temperature, ON TIME:1.5H,OFF
TIME:0.5H, and applied rated voltage for
1000 +24/-0H. Measure the variation of
resistance.
±(2.00% +0.05Ω)
MIL-STD-202
METHOD 106
25°C~65°C,90~100%RH, 2.5 小时; 65°C
90~100%RH, 3 小时; 65°C~25°
C,80~100%RH,2.5 小时,10 个循环,试验结
束 24±4 小时后进行测试.
25°C~65°C,90~100%RH, 2.5H; 65°C
90~100%RH, 3H; 65°C~25°C
80~100%RH, 2.5H, 10 cycles,
Measurement at 24±4 hours after test
conclusion.
±(2.00% +0.05Ω)
9
规格
Specification
www.fojan.cn
FRG-Series
■ 包装规格(Tapping Specification)
-卷盘尺寸(Reel dimension)
Type
Size
Unit
A
B
C
F
W
0603/0805/1206/1210
7”
5K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
0603/0805/1206
10”
10K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
0603/0805/1206
13”
20K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
1218/1812/2010/2512
7”
4K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
15.4±1.0
13.0±0.3
-包装尺寸(packing dimension)
10
www.fojan.cn
FRG-Series
Unit: mm
Dimensions
A
B
D
F
P0
P1
P2
W
0603
1.10±0.10
1.90±0.10
1.50± 0.1
0 .0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
0805
1.65±0.20
2.40±0.20
1.50± 0.1
0 .0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1206
1.90±0.20
3.50±0.20
1.50± 0.1
0 .0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1210
2.80±0.20
3.50±0.20
1.50± 0.1
0 .0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1218
2.80±0.20
4.60±0.20
1.50± 0.1
0 .0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
1812
3.30±0.20
4.60±0.20
1.50± 0.1
0 .0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
2010
2.90±0.10
5.30±0.10
1.50± 0.1
0 .0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
2512
3.40±0.10
6.60±0.10
1.50± 0.1
0 .0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
■上胶带剥离力测试(Peel force of top cover tape)
上胶带以 200mm/分钟的速度,沿 165〜180 度角的方向进行剥离,如下图所示。纸带的剥离力范围为
10g〜70g; 载带的剥离力范围为 30〜100g。
The top cover tape is pulled at a speed of 200 mm/min with the angle between the tape during peel and
the direction of unreeling maintained at 165 to 180 degree as following picture. The peel force of paper
carrier tape shall be 0.1N to 0.7N(10 to 70 g), the peel force of plastic carrier tape shall be 0.3N to 1N (30
to 100 g)
■焊接 (soldering):
11
www.fojan.cn
FRG-Series
■ 焊接 (soldering)
-建议回流焊曲线(Recommend reflow soldering profile)
-建议波峰焊曲线(Recommend wave soldering profile)
-手工焊温度(hand soldering temperature)
烙铁温度 350±10℃ 3 秒之內,避免烙铁接触电阻本体
The iron temperature is 350±10℃, hand soldering time less than 3S. Avoid solder iron tip direct
touch the components body
12
www.fojan.cn
很抱歉,暂时无法提供与“FRG0603F2205TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.02647
- 1000+0.02166
- 5000+0.01827
- 10000+0.01714
- 50000+0.01560
- 国内价格
- 100+0.02426
- 1000+0.01985
- 2000+0.01955
- 5000+0.01674
- 国内价格
- 1+0.06941
- 500+0.02310
- 2500+0.01540
- 5000+0.01265
