FRD0805J154 TS
FRD0805J154 TS
    FOJAN(富捷)
FRD0805J154 TS 数据手册
FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 超高阻值厚膜片式电阻器(Thick Film Chip HighResistor ) ■应用(Application) - Entertainment:Stereo,TV tuners,Tape recorder - 娱乐:立体声、电视调谐器、录音机 - Appliance: Air conditioner, Refrigerator - 电器:空调、冰箱 - Computer & relative products : Main board, PDA - 电脑及相关产品:主板、PDA - Communication equipment: Cell phone, Fax machine - 通讯设备:手机、传真机 - Power equipment: Power supply , II Lumination equipment - 电源设备:电源、二级照明设备 - Measuring instrument: Electric meter,Navigation equipment - 测量仪器:电表、导航设备 ■特点(Features) small size and light weight - 体积小、重量轻 - - 可靠性,高质量 Reliability, high quality ■产品料号(Parts Number Explanation) 示例(Example): FRG1206J226 TS F R G 1206 J 226 T S 公司名 产品别 功能别 尺寸 公差 字码 包装别 端电极 特殊码 FOJAN R:Resistor C:Normal 0603 B:±0.1% ±5%:E24 T: 7 inch reel S:Sn N: C:Capacitor P:Hi-Power 0805 C:±0.25% 3-digits+blank Q:10 inch reel C:Cu Normal L:Inductor L:Lowohmic 1206 D:±0.5% 102=1KΩ R:13 inch reel A:Au D:Diode A:Array 1210 F:±1% 1R0=1Ω B:Bulk A:Audion S:Surge 1218 J:±5% ±1%&Below: H:Hi-Precision 1812 P:Jumper E24+E96: V:Hi-Voltage 2010 4-digits Q:Auto-motive 2512 1001=1KΩ R:Anti-sulfur D:LED 1R00=1Ω M:Metal D: LED G:Hi-Resistence Compa Type code Functional code ny code FJ-JS-3001-V1.0 / 2021.1.25 Size Tolerance Resistance Packaging Termination Special code code code code code Case 1 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■本体标识(Marking on the Resistor's Body) 0201 及 0402 因本体太小,本体上无字码标示 For 0201 and 0402 size, no marking on the body due to the small size of the resistor 472=47×102=4.7KΩ 公差±5%的产品,以三字码标示,前两位表示阻值 的有效数字,最后一位表示 10 的乘幂 ±5% tolerance product: the marking is 3 digits, the first 2 digits are significant figures of resistance value and the 3rd one denotes the power number of 10, (10X) 10Ω以下标示:5R6=5.6Ω Below 10Ω: 5R6=5.6Ω ±0.5%, ±1%, ±2%的产品,以四字码标示,前三位 表示阻值的有效数字,最后一位表示 10 的乘幂 ±0.5%, ±1%,±2% tolerance product: the marking is 4 digits, the first 3 digits are significant figures of resistance value and the 4th one denotes the power number of 10, (10X) 4992=499×102=49.9KΩ 0603 ±1% E96 系列的标准阻值,因电阻本体太小, 采用三位代码标示。 Standard E96 series values of 0603 ±1%: due to the small size of the resistor’s body, use 3digits code to indicate the resistance value. 100Ω以下标示: 6R81=6.81Ω Below 100Ω: 6R81=6.81 Ω ■0603±1% E96 系列电阻值代码 Standard E96 Series Resistance Value Code for 0603 代码 阻值 Code Value 01 100 02 102 03 105 04 107 05 110 06 113 07 115 08 118 09 121 10 124 11 127 12 130 13 133 14 137 15 140 16 143 代码 Code 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 FJ-JS-3001-V1.0 / 2021.1.25 阻值 Value 147 150 154 158 162 165 169 174 178 182 187 191 196 200 205 210 代码 Code 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 阻值 Value 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 代码 Code 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 2 阻值 Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 代码 Code 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 阻值 Value 464 475 487 499 511 523 536 549 562 576 590 604 619 634 649 665 ±1% Marking 代码 Code 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 阻值 Value 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■0603±1%标记的倍增码 Multiplier Code for 0603 代码 Code 指数 Multiplier Y X -2 10 10 ±1% Marking A -1 10 B 0 10 C 1 10 D 2 10 E 3 F 10 4 105 阻值标示如下(So the resistance value are marked as the following examples) 10D=124×103=124KΩ 38Y=243×10-2=2.43Ω 0603 ±1%的产品,在标准 E24 系列中,但不属于 E96 系列,标示与 5%的字码相同,但是在中间字码 下加一条线(Standard E24 and not belong to E96 series values of 0603 ±1%, the marking is the same as 5% tolerance but marking as underline) 331=33×101=330Ω ■ 560=56×100=56Ω 尺寸(Dimension): 尺寸 dimension 单位(unit): mm 型别(Type) L W H T1 T2 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 1218 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 1812 4.50±0.20 3.10±0.20 0.55±0.10 0.55±0.20 0.70±0.20 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 FJ-JS-3001-V1.0 / 2021.1.25 3 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 功率衰减曲线( Derating Curve) ■ 电阻结构(Construction) NO. 1 2 3 4 5 6 7 8 9 FJ-JS-3001-V1.0 / 2021.1.25 4 结构 construction 主要材料 Major material 陶瓷基板 Ceramic substrate 银电极 Conductive layer 侧电极 Side conductive layer 阻体层 Resistive layer 内保护层 Inner protective layer 外保护层 Outer Protective layer 文字 Marking 镍电极 Ni plating layer 锡电极 Sn plating layer 三氧化二铝 Al2O3 银 Ag 镍铬合金 NiCr 氧化钌+玻璃 RuO2+ glass 玻璃 Glass 环氧树脂 Epoxy 环氧树脂 Epoxy 镍 Ni 锡 Matte Tin www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 电气特性(Electrical characteristics) 型别 Type 0603 0805 1206 1210 1218 1812 2010 2512 额定功率 Rated power 1/10W 1/8W 1/4W 1/2W 1W 3/4W 3/4W 1W 最大工作电压 Max Working Voltage 75V 150V 200V 200V 200V 200V 200V 200V 最大过负荷电压 Max Overload Voltage 150V 300V 400V 400V 500V 400V 400V 400V 绝缘耐压 Dielectric Withstanding Voltage 100V 300V 500V 500V 500V 500V 500V 500V 备注(remark): 额定电压计算公式(The rated voltage is calculated by the following formula) : E= RP E:额定电压(Rated Voltage) (V) P:额定功率(Rated Power ) (W) R:电阻阻值(Resistance ) (ohm) 如果计算出的电压超过此型别的最大工作电压,则此型别的最大工作电压为此电阻的额定电压。 In case the value calculated by the formula exceed the maximum working voltage as above table 8, the maximum working voltage shall be regarded as rated voltage. FJ-JS-3001-V1.0 / 2021.1.25 5 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 电性规格(Standard Electrical Specifiations) 额定功率 (PowerRating at 70℃) Max. RCWV 0603 1/10W 50V 100V 0805 1/8W 150V 300V 1206 1/4W 200V 400V 1210 1/2W 200V 400V 型别 Type 最高 工作电压 最大过负荷电压 Max. Overload Voltage 1218 1W 200V 500V 1812 3/4W 200V 400V 2010 3/4W 200V 400V 2512 1W 200V 400V FJ-JS-3001-V1.0 / 2021.1.25 6 阻值范围 T.C.R. (PPM/℃) Resistance Range ± 200 10MΩ~100MΩ www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 性能(Performance Specifications) 内容 Item 温度系数 Temperature Coefficient 短时间过负荷 Short-time overload 焊锡性 Solderability 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification JIS C 5201 4.8 TCR=(R-R0 )/(t-t0)R0 ×106(ppm) R0 电阻在室 温下的阻值(resistance at room temperature) R 电 阻 在 125 ℃ 或 -55 ℃ 下 的 阻 值 (resistance at 125℃ or -55℃) t0 室温(room temperature) t 测试温度(test temperature 125℃ or -55℃) JIS C 5201 4.13 加载 2.5 倍的额定电压,时间 5 秒后测 量试验前后的阻值变化率。 Applied 2.5 times of rated voltage for 5 second. Measure the variation of resistance. ±(1.00% +0.05Ω) JIS C 5201 4.17 沾助焊剂后浸入锡炉,锡炉温度 245± 5℃,时间 3±0.5 秒。 Dip the terminal in a flux and then dip into a soldering bath at 245±5℃ for 3± 0.5sec. >95%面积上锡 (>95% coverage) 抗焊锡热 Resist to soldering heat JIS C 5201 4.18 绝缘电阻 Insulation resistance JIS C 5201 4.6 FJ-JS-3001-V1.0 / 2021.1.25 沾助焊剂后浸入锡炉,锡炉温度 260± 5℃,时间 10±0.5 秒, 测量试验前后的 阻值变化率。 Dip the terminal in a flux and then dip into a soldering bath at 260±5℃ for 10± 0.5sec. Measure the variation of resistance. 电阻本体上加载绝缘耐压 60±5 秒后, 测量绝缘阻抗。 Applied the dielectric withstanding voltage on the center of body for 60± 5seconds. Then measure insulation resistance. 7 0603~2512 规格: 10MΩ10GΩ www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 内容 Item 绝缘耐压 Dielectric withstanding voltage 测试方法 Test Methods JIS C 5201 4.7 测试条件 Test Conditions 电阻本体上加载绝缘耐压 60±5 秒。 Applied the dielectric withstanding voltage on the center of body for60± 5seconds. 规格 Specification 无击穿、飞弧及可见机 械性损伤 No evidence of flashover, mechanical damage arcing or insulation breakdown 电阻焊接在测试板上进行弯折,弯折保持时 间 20 ± 1 秒 , 1206( 含 ) 以 下 的尺 寸 弯曲 5+0.2/0 mm; 1206 以上的尺寸弯曲 2+0.2/0 mm; 量测试验前后阻值变化率 Specimen shall be mounted on test board, then bend the board and maintained for 20± 1s. the distance of bending is 5+0.2/0 mm for resistors which size no larger than 1206 or 2+0.2/0 mm which size larger than 1206. Measure the variation of resistance. 测试板(test board) 压头(jig) 端子弯曲 Terminal bending ±(1.00% +0.05Ω) JIS C 5201 4.33 FJ-JS-3001-V1.0 / 2021.1.25 8 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 内容 Item 温度循环 Temperature Cycling 耐湿特性 Humidity 负荷寿命 Load life 温湿循环 Moisture resistance 测试方法 Test Methods 测试条件 Test Conditions JIS C 5201 4.19 电阻放入温度循环机中,温度 155±2℃ 至-55±3℃,共 5 个循环。量测试验前后 阻值变化率. Put specimen in a chamber which temperature can be changed to 155±2℃ or -55±3℃, repeated 5 times. Measure the variation of resistance. ±(2.00% +0.05Ω) JIS C 5201 4.24 电阻放入恒温恒湿箱,温度 40±2℃,湿 度 90~95 %RH;通电额定电压 1.5 小时, 断电 0.5 小时;重复通断电至试验时间 1000 +48/-0 小时. 量测试验前后阻值变 化率. Put the specimen in a chamber at 40±2℃ temperature and 90~95% relative humidity, then applied rated voltage for1.5H and rested for 0.5H repeatedly till total test time is 1000+48/-0 H. Measure the variation of resistance. ±(2.00% +0.05Ω) JIS C 5201 4.25.1 电阻放入恒温箱中,温度 70±2℃,ON TIME:1.5H,OFF TIME:0.5H,通电额定电 压 1000 +24/-0 小时,量测试验前后阻值变 化率. Put the specimen in a chamber at 70±2℃ temperature, ON TIME:1.5H,OFF TIME:0.5H, and applied rated voltage for 1000 +24/-0H. Measure the variation of resistance. ±(2.00% +0.05Ω) MIL-STD-202 METHOD 106 25°C~65°C,90~100%RH, 2.5 小时; 65°C 90~100%RH, 3 小时; 65°C~25° C,80~100%RH,2.5 小时,10 个循环,试验结 束 24±4 小时后进行测试. 25°C~65°C,90~100%RH, 2.5H; 65°C 90~100%RH, 3H; 65°C~25°C 80~100%RH, 2.5H, 10 cycles, Measurement at 24±4 hours after test conclusion. ±(2.00% +0.05Ω) FJ-JS-3001-V1.0 / 2021.1.25 9 规格 Specification www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 包装规格(Tapping Specification) -卷盘尺寸(Reel dimension) Type Size Unit A B C F W 0603/0805/1206/1210 7” 5K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0603/0805/1206 10” 10K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0603/0805/1206 13” 20K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 1218/1812/2010/2512 7” 4K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 15.4±1.0 13.0±0.3 -包装尺寸(packing dimension) FJ-JS-3001-V1.0 / 2021.1.25 10 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 Unit: mm Dimensions A B D F P0 P1 P2 W 0603 1.10±0.10 1.90±0.10 1.50± 0.1 0 .0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 0805 1.65±0.20 2.40±0.20 1.50± 0.1 0 .0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1206 1.90±0.20 3.50±0.20 1.50± 0.1 0 .0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1210 2.80±0.20 3.50±0.20 1.50± 0.1 0 .0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1218 2.80±0.20 4.60±0.20 1.50± 0.1 0 .0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 1812 3.30±0.20 4.60±0.20 1.50± 0.1 0 .0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 2010 2.90±0.10 5.30±0.10 1.50± 0.1 0 .0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 2512 3.40±0.10 6.60±0.10 1.50± 0.1 0 .0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 ■上胶带剥离力测试(Peel force of top cover tape) 上胶带以 200mm/分钟的速度,沿 165〜180 度角的方向进行剥离,如下图所示。纸带的剥离力范围为 10g〜70g; 载带的剥离力范围为 30〜100g。 The top cover tape is pulled at a speed of 200 mm/min with the angle between the tape during peel and the direction of unreeling maintained at 165 to 180 degree as following picture. The peel force of paper carrier tape shall be 0.1N to 0.7N(10 to 70 g), the peel force of plastic carrier tape shall be 0.3N to 1N (30 to 100 g) ■焊接 (soldering): FJ-JS-3001-V1.0 / 2021.1.25 11 www.fojan.cn FRG-Series Thick Film Chip High Resistor Product Specifications FRG 系列厚膜片式超高阻值电阻器规格说明书 ■ 焊接 (soldering) -建议回流焊曲线(Recommend reflow soldering profile) -建议波峰焊曲线(Recommend wave soldering profile) -手工焊温度(hand soldering temperature) 烙铁温度 350±10℃ 3 秒之內,避免烙铁接触电阻本体 The iron temperature is 350±10℃, hand soldering time less than 3S. Avoid solder iron tip direct touch the components body FJ-JS-3001-V1.0 / 2021.1.25 12 www.fojan.cn
FRD0805J154 TS 价格&库存
很抱歉,暂时无法提供与“FRD0805J154 TS”相匹配的价格&库存,您可以联系我们找货
