ADX111AMSOP10
ADX111AMSOP10
    ANALOGYSEMI(类比半导体)
    MSOP-10
    超小型、低功耗、支持I2C接口、采样率860SPS、带内部基准源、振荡器和可编程比较器的16BIT ADC
ADX111AMSOP10 数据手册
ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 1. • 3. AEC-Q100 ( • ADX111Q) ADX111(Q) (ADC) 3mm × 3mm MSOP • QFN 2.0V • 145µA ( (PGA) 5.5V • ) 8SPS I 2C QFN-10 ADX111(Q) 2mm × 1.5mm × 0.4mm • 16 MSOP-10 ADX111(Q) 8SPS 860SPS PGA ±256mV 860SPS ±6.144V ADX111(Q) (MUX) ADX111(Q) • • • • ADX111(Q) 2 IC • ADX111(Q) ADX111(Q) • • –40°C Table 1 125°C 2. • • • • • VDD Comparator Voltage Reference AIN0 AIN1 AIN2 MUX PGA 16-Bit ΔΣ ADC ALERT/RDY ADDR I2C Interface SCL SDA AIN3 Oscillator ADX111(Q) GND © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 1 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator Table 1 lists the order information. Table 1. Order Information BODY SIZE (mm) MARK ODR (SPS) INTERFACE COMPARATOR MSOP-10 3× 3 ADX111 860 I2C Yes No No –40-125 T/R-3000 16 MSOP-10 3× 3 ADX111Q 860 I2C Yes No No –40-125 T/R-3000 16 QFN-10 2 × 1.5 111 860 I2C Yes No No –40-125 T/R-4000 MARK ODR (SPS) INTERFACE COMPARATOR ORDER NUMBER(1) CH (#) ADX111AMSOP10 2(4) 16 2(4) 2(4) ADX111QAMSOP10 (1) ADX111AQFN10 BITS PACKAGE TEMP 50/60 SENSOR REJECTION OP. TEMP (°C) PKG. OPTION Table 2. Family Selection Guide ORDER NUMBER(1) CH (#) BITS PACKAGE BODY SIZE (mm) TEMP 50/60 SENSOR REJECTION OP. TEMP (°C) PKG. OPTION ADX112AMSOP10 2(4) 16 MSOP-10 3× 3 ADX112 860 SPI No Yes No –40-125 T/R-3000 ADX112QAMSOP10(1) 2(4) 16 MSOP-10 3× 3 ADX112Q 860 SPI No Yes No –40-125 T/R-3000 ADX112AQFN10 2(4) 16 QFN-10 2 × 1.5 112 860 SPI No Yes No –40-125 T/R-4000 ADX113AMSOP10 2(4) 16 MSOP-10 3× 3 ADX113 860 I2C Yes No Yes –40-125 T/R-3000 ADX114AMSOP10 2(4) 16 MSOP-10 3× 3 ADX114 3571 SPI No Yes Yes –40-125 T/R-3000 ADX121AMSOP10 2(4) 20 MSOP-10 3× 3 ADX121 3571 I2C Yes No Yes –40-125 T/R-3000 ADX121AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 121 3571 I2C Yes No Yes –40-125 T/R-4000 ADX122AMSOP10 2(4) 20 MSOP-10 3× 3 ADX122 3571 SPI No No Yes –40-125 T/R-3000 ADX122QAMSOP10(1) 2(4) 20 MSOP-10 3× 3 ADX122Q 3571 SPI No No Yes –40-125 T/R-3000 ADX122AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 122 3571 SPI No No Yes –40-125 T/R-4000 ADX128AMSOP10(1) 2(4) 20 MSOP-10 3× 3 ADX128 7143 SPI No No Yes –40-125 T/R-3000 ADX128AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 128 7143 SPI No No Yes –40-125 T/R-4000 ADX125AMSOP10 2(4) 20 MSOP-10 3× 3 ADX125 3571 I2C Yes Yes Yes –40-125 T/R-3000 ADX126AMSOP10 2(4) 20 MSOP-10 3× 3 ADX126 3571 SPI No Yes Yes –40-125 T/R-3000 ADX125AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 125 3571 I2C Yes Yes Yes –40-125 T/R-4000 ADX126AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 126 3571 SPI No Yes Yes –40-125 T/R-4000 ADX131AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 131 440 I2C Yes No Yes –40-125 T/R-4000 ADX132AQFN10(1) 2(4) 20 QFN-10 2 × 1.5 132 440 SPI No No Yes –40-125 T/R-4000 ADX123AMSOP10(1) 2(4) 20 MSOP-10 3× 3 ADX123 No No Yes –40-125 T/R-3000 3571 Daisy Chain Note: Available in the future. Devices can be ordered via the following two ways: 1. Place orders directly on our website (www.analogysemi.com), or; 2. Contact our sales team by mailing to sales@analogysemi.com. Page 2 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 4. PIN CONFIGURATION AND FUNCTIONS 10 SCL Figure 1 illustrates the pin configuration. 1 10 SCL ALERT/RDY 2 9 SDA GND 3 8 VDD AIN0 4 7 AIN3 AIN1 5 6 AIN2 ADDR 1 9 SDA ALERT/RDY 2 8 VDD GND 3 7 AIN3 AIN0 4 6 AIN2 AIN1 5 ADDR MSOP-10 Package QFN-10 Package Figure 1. Pin Configuration Table 3 lists the pin functions. Table 3. Pin Functions POSITION NAME TYPE DESCRIPTION 1 ADDR Digital input 2 ALERT/RDY Digital output I2C slave address select Comparator output or conversion ready, open drain, connected to a pull-up resistor 3 4 5 6 7 GND AIN0 AIN1 AIN2 AIN3 Power Analog input Analog input Analog input Analog input 8 VDD Power 9 10 SDA SCL Digital I/O Digital input © 2023 AnalogySemi Ltd. All Rights Reserved. Ground Analog input 0 Analog input 1 Analog input 2 Analog input 3 Power supply. Connects a 0.1μF, power-supply decoupling capacitor to GND. Serial data. Transmits and receives data. Serial clock input. Locks data on SDA. Public www.analogysemi.com | Page 3 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5. SPECIFICATIONS 5.1 ABSOLUTE MAXIMUM RATINGS Table 4 lists the absolute maximum ratings of the ADX111(Q). Table 4. Absolute Maximum Ratings PARAMETER DESCRIPTION Power-Supply Voltage Analog Input Voltage Digital Input Voltage VDD to GND AIN0, AIN1, AIN2, AIN3 SDA, SCL, ADDR, ALERT/RDY Any pin except power supply pins Operating ambient, TA Junction, TJ Storage, Tstg Input Current, Continuous Temperature MIN MAX UNITS –0.3 GND – 0.3 GND – 0.3 7 VDD + 0.3 5.5 V V V –10 10 mA –40 –40 –60 125 150 150 °C Note: Stresses beyond those listed under Table 4 may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Table 6. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 5.2 ESD RATINGS Table 5 lists the ESD ratings of the ADX111(Q). Table 5. ESD Ratings PARAMETER Electrostatic Discharge SYMBOL V(ESD) DESCRIPTION Human-body model (HBM), per ANSI/ESDA/JEDEC VALUE JS-001(1) Charged-device model (CDM), per JEDEC specification JESD22-C101(2) ±6000 ±1500 UNITS V Note 1: The JEDEC document JEP155 indicates that 500V HBM allows safe manufacturing with a standard ESD control process. Note 2: The JEDEC document JEP157 indicates that 250V CDM allows safe manufacturing with a standard ESD control process. Page 4 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.3 RECOMMENDED OPERATING CONDITIONS Table 6 lists the recommended operating conditions for the ADX111(Q). Table 6. Recommended Operating Conditions PARAMETER POWER SUPPLY Power Supply ANALOG INPUTS(1) Full-Scale Input Voltage Range(2) DESCRIPTION SYMBOL MAX UNITS 2 5.5 V FSR ±0.256 ±6.144 V V(AINx) GND VDD V VDIG GND 5.5 V TA –40 125 °C VDD to GND VIN = V(AINP) – V(AINN) Absolute Input Voltage DIGITAL INPUTS Digital Input Voltage TEMPERATURE RANGE Operating Ambient Temperature MIN NOM Note 1: AINP and AINN denote the selected positive and negative inputs. AINx denotes one of the four available analog inputs. Note 2: This parameter expresses the full-scale range of the ADC scaling. No more than VDD + 0.3V must be applied to the analog inputs of the device. See Table 12 for more information. 5.4 THERMAL INFORMATION Table 7 lists the thermal information for the ADX111(Q). Table 7. Thermal Information PARAMETER Junction-to-Ambient Thermal Resistance Junction-to-Case (Top) Thermal Resistance Junction-to-Board Thermal Resistance Junction-to-Top Characterization Parameter Junction-to-Board Characterization Parameter Junction-to-Case (Bottom) Thermal Resistance © 2023 AnalogySemi Ltd. All Rights Reserved. Public SYMBOL MSOP-10 QFN-10 UNITS RθJA RθJC(top) RθJB ψJT ψJB RθJC(bot) 150 54 90 3 86 90 119 60 39 4 39 45 °C/W °C/W °C/W °C/W °C/W °C/W www.analogysemi.com | Page 5 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.5 ELECTRICAL CHARACTERISTICS Table 8 lists the electrical characteristics of ADX111(Q). At VDD = 3.3V, data rate = 8SPS, and full-scale input voltage range (FSR) = ±2.048V (unless otherwise noted). Maximum and minimum specifications apply from TA = –40°C to 125°C. Typical specifications are at TA = 25°C. Table 8. Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS ANALOG INPUT FSR = ±6.144V(1) FSR = ±4.096V(1) FSR = ±2.048V FSR = ±1.024V FSR = ±0.512V, FSR = ±0.256V FSR = ±6.144V(1) FSR = ±4.096V(1) FSR = ±2.048V FSR = ±1.024V FSR = ±0.512V, ±0.256V Common-Mode Input Impedance Differential Input Impedance SYSTEM PERFORMANCE Resolution (No Missing Codes) Data Rate Data Rate Variation DR All data rates Output Noise Integral Nonlinearity INL Offset Error Offset Drift Over Temperature Offset Power-Supply Rejection Offset Channel Match Gain Error(3) Gain Drift Over Temperature(3) Long-Term Gain Drift(3) Gain Power-Supply Rejection Gain Match(3) Gain Channel Match Common-Mode Rejection Ratio CMRR DIGITAL INPUT/OUTPUT High-Level Input Voltage Low-Level Input Voltage Low-Level Output Voltage Input Leakage Current VIH VIL VOL MΩ 0.5 1 LSB 0 2 –2 LSB ±2 0.005 LSB/°C 0.5 LSB 0.5 LSB/V 2 0.01% 8 8 8 LSB 0.10% 30 ±0.05 70 0.01% 0.03% >110 At DC, FSR = ±2.048V At DC, FSR = ±6.144V(1) fCM = 60Hz, DR = 8SPS fCM = 50Hz, DR = 8SPS >105 100 103 104 Public MΩ Bits SPS Match between any two gains Match between any two inputs At DC, FSR = ±0.256V IOL = 3mA GND < VDIG < VDD MΩ 16 8, 16, 32, 64, 128, 250, 475, 860 –7% 6% See NOISE PERFORMANCE section FSR = ±2.048V FSR = ±2.048V, TA = 125°C, 1000 hrs FSR = ±2.048V, DC supply variation Match between any two inputs FSR = ±2.048V, TA = 25°C FSR = ±0.256V FSR = ±2.048V FSR = ±6.144V(1) FSR = ±2.048V, TA = 125°C, 1000 hrs Long-Term Offset Drift Page 6 of 39 | www.analogysemi.com DR = 8SPS, FSR = ±2.048V(2) FSR = ±2.048V, differential inputs FSR = ±2.048V, single-ended inputs 9 7 6 5 6 26 17 3 1.5 0.9 0.7 VDD GND GND –10 0.15 ppm/°C % ppm/V 0.05% 0.05% dB 5.5 0.3 VDD 0.4 10 V V V µA © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS TA = 25°C 0.65 TA = 25°C 145 1 3.5 170 300 µA POWER SUPPLY Power-down Supply Current IVDD Operating Power Dissipation PD VDD = 5.0V VDD = 3.3V VDD = 2.0V 0.9 0.5 0.3 mW Note 1: This parameter expresses the full-scale range of the ADC scaling. No more than VDD + 0.3V must be applied to the analog inputs of the device. See Table 11 for more information. Note 2: Best-fit INL; covers 98% of full-scale. Note 3: Includes all errors from onboard PGA and voltage reference. © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 7 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.6 TIMING REQUIREMENTS: I2C INTERFACE Table 9 lists the timing requirements for the I2C interface. Table 9. Timing Requirements: I2C Interface PARAMETER FAST MODE MIN MAX SYMBOL SCL Clock Frequency Bus Free Time Between START and STOP Condition Hold Time After Repeated START Condition. (After this period, the first clock is generated.) Setup Time for A Repeated START Condition Setup Time for STOP Condition Data Hold Time Data Setup Time Low Period of the SCL Clock Pin High Period for the SCL Clock Pin Rise Time for Both SDA and SCL Signals(1) Fall Time for Both SDA and SCL Signals(1) HIGH-SPEED MODE MIN MAX 0.4 0.01 UNITS fSCL 0.01 3.4 MHz tBUF 600 160 ns tHDSTA 600 160 ns tSUSTA 600 160 ns tSUSTO tHDDAT tSUDAT tLOW 600 0 100 1300 160 0 10 160 ns ns ns ns tHIGH tF tR 600 60 300 300 ns ns ns 160 160 Note: For high-speed mode maximum values, the capacitive load on the bus line must not exceed 400pF. Figure 2 shows the I2C interface timing. tLOW tR tHDSTA tF SCL tHIGH tHDSTA tHDDAT SDA tSUSTO tSUSTA tSUDAT tBUF P S S P Figure 2. I2C Interface Timing Page 8 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.7 TYPICAL CHARACTERISTICS TA = 25°C, VDD = 3.3V, FSR = ±2.048V, DR = 8SPS, unless otherwise noted. Figure 3. Operating Current vs. Temperature Figure 4. Power-Down Current vs. Temperature Figure 5. Single-Ended Offset Error vs. Temperature Figure 6. Differential Offset vs. Temperature Figure 7. Gain Error vs. Temperature Figure 8. Gain Error vs. Supply Voltage © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 9 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.8 TYPICAL CHARACTERISTICS (CONTINUED) TA = 25°C, VDD = 3.3V, FSR = ±2.048V, DR = 8SPS, unless otherwise noted. Figure 9. INL vs. Supply Voltage Figure 10. INL vs. Temperature Figure 11. Noise vs. Supply Voltage Figure 12. Data Rate vs. Temperature Figure 13. Gain Error Histogram Figure 14. Offset Histogram Page 10 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 5.9 TYPICAL CHARACTERISTICS (CONTINUED) TA = 25°C, VDD = 3.3V, FSR = ±2.048V, DR = 8SPS, unless otherwise noted. Figure 15. Digital Filter Frequency Response © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 11 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 6. 6.1 Table 10 Table 11 Table 11 ( ADX111(Q) ) TA = 25 C Table 10 μVRMS Equation 1 μVRMS RMS ADC μVPP Equation 2 Effective Resolution = In (FSR / VRMS-Noise ) / In(2) (1) Noise-Free Resolution = In (FSR / VPP-Noise ) / In (2) (2) Table 10. Noise in μVRMS (μVPP) at VDD = 3.3V FSR (Full-Scale Range) ±2.048V ±1.024V DATA RATE (SPS) ±6.144V ±4.096V 8 16 32 64 128 250 475 187.5 (187.5) 187.5 (187.6) 187.5 (187.7) 187.5 (187.8) 187.5 (187.9) 187.5 (375) 187.5 (375) 125 (125) 125 (125) 125 (125) 125 (125) 125 (125) 125 (250) 125 (250) 62.5 (62.5) 62.5 (62.5) 62.5 (62.5) 62.5 (62.5) 62.5 (62.5) 62.5 (125) 62.5 (125) 860 187.5 (520.8) 125 (319.4) 62.5 (152.7) ±0.512V ±0.256V 31.25 (31.25) 31.25 (31.25) 31.25 (31.25) 31.25 (31.25) 31.25 (31.25) 31.25 (62.5) 31.25 (62.5) 15.625 (15.625) 15.625 (15.625) 15.625 (15.625) 15.625 (15.625) 15.625 (17.333) 15.625 (31.25) 15.625 (31.25) 7.8125 (7.8125) 7.8125 (7.8125) 7.8125 (7.8125) 7.8125 (13.889) 7.8125 (15.625) 7.8125 (23.4375) 7.8125 (32.986) 31.25 (90.2) 15.625 (38.19) 8.6799 (45.138) Table 11. Effective Resolution from RMS Noise (Noise-Free Resolution from Peak-to-Peak Noise) at VDD = 3.3V DATA RATE (SPS) ±6.144V 8 16 32 64 128 250 475 860 16 (16) 16 (16) 16 (16) 16 (16) 16 (16) 16 (15) 16 (15) 16 (14.52) Page 12 of 39 | www.analogysemi.com ±4.096V FSR (Full-Scale Range) ±2.048V ±1.024V ±0.512V ±0.256V 16 (16) 16 (16) 16 (16) 16 (16) 16 (16) 16 (15) 16 (15) 16 (14.64) 16 (16) 16 (16) 16 (16) 16 (16) 16 (16) 16 (15) 16 (15) 16 (14.7) 16 (16) 16 (16) 16 (16) 16 (16) 16 (15.85) 16 (15) 16 (15) 16 (14.71) 16 (16) 16 (16) 16 (16) 16 (15.17) 16 (15) 16 (14.41) 16 (13.92) 15.9 (13.47) Public 16 (16) 16 (16) 16 (16) 16 (16) 16 (16) 16 (15) 16 (15) 16 (14.47) © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7. 7.1 ADX111(Q) 16 Δ-Σ (ΔΣ) (ADC) ADX111(Q) (PGA) I 2C 23 ΔΣ ADC Figure ADX111(Q) ADX111(Q) ADC VIN V(AINP) V(AINN) ADX111(Q) ΔΣ ADC ADC 7.2 VDD Comparator Device ALERT/RDY Voltage Reference MUX AIN0 ADDR AIN1 16-Bit ΔΣ ADC PGA I2C Interface SCL SDA AIN2 Oscillator AIN3 GND Figure 16. Functional Block Diagram © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 13 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.3 7.3.1 ADX111(Q) AIN1 (MUX) Figure 17 CONFIG REGISTER GND AIN3 AIN0 ADC MUX[2:0] Device VDD AIN0 VDD GND AINP AIN1 AINN VDD GND AIN2 VDD GND AIN3 GND GND Figure 17. Input Multiplexer VDD GND (ESD) ADX111(Q) Equation 3 ESD (3) GND – 0.3V < V(AINx) < VDD + 0.3V ( Table 4) Page 14 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.3.2 ADX111(Q) AINP (fMOD) 250kHz ADX111(Q) AINN 1MHz 4 fMOD Figure 19 Figure 18 V(AINP) CA2 V(AINN) CB (V(AINP) – V(AINN)) 0.7V CB 0V ADX111(Q) (Zeff) Zeff = VIN / IAVERAGE Figure 18 S1 S2 S1 CA1 CA1 CA2 0.7V CA1 AINP S1 S2 CB ZCM Equivalent Circuit 0.7V AINP ZDIFF S2 S1 AINN AINN 0.7V ZCM fMOD = 250kHz CA2 0.7V Figure 18. Simplified Analog Input Circuit tSAMPLE ON S1 OFF ON S2 OFF Figure 19. S1 and S2 Switch Timing AINP AINN 6M AINP Figure 18 ZCM AINN 0.7V Figure 18 0.7V ZDIFF ADX111(Q) © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 15 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.3.3 (FSR) LSB (PGA) ADX111(Q) ΔΣ ADC CONFIG REGISTER ±6.144V ±4.096V ±2.048V ±1.024V ±0.512V ±0.256V Table 12 FSR Equation 4 LSB LSB = FSR / 2 PGA[2:0] LSB 16 (4) Table 12. Full-Scale Range and Corresponding LSB Size FSR LSB SIZE ±6.144V(1) 187.5μV 125μV 62.5μV 31.25μV 15.625μV 7.8125μV ±4.096V(1) ±2.048V ±1.024V ±0.512V ±0.256V ADC |VIN| VDD + 0.3V ABSOLUTE MAXIMUM RATINGS ADC VDD = 3.3V > 3.3V VDD FSR = ±4.096V VDD ±2.048V VDD = 2V VIN = ±3.3V ±2.048V 7.3.4 ADX111(Q) ELECTRICAL CHARACTERISTICS 7.3.5 ADX111(Q) 1MHz 7.3.6 ADX111(Q) 128SPS 250SPS 475SPS CONFIG REGISTER DR[2:0] 8SPS 16SPS 32SPS 64SPS 860SPS ADX111(Q) 1/DR 7.3.7 ADX111(Q) ALERT/RDY ALERT/RDY ( CONFIG REGISTER COMP_MODE (Hi_thresh) (Lo_thresh) Lo_thresh ALERT/RDY ) Hi_thresh CONFIG REGISTER CONVERSION REGISTER ALERT/RDY Figure 20 CONFIG REGISTER (Hi_thresh CONFIG REGISTER COMP_QUE[1:0] COMP_QUE[1:0] Page 16 of 39 | www.analogysemi.com COMP_LAT Public SMBus COMP_POL Lo_thresh) ALERT/RDY ALERT/RDY ALERT/RDY © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.3.8 ALERT/RDY Hi_thresh COMP_POL 0 11 COMP_MODE 2 COMP_LAT ADX111(Q) ALERT/RDY 1 ALERT/RDY ALERT/RDY COMP_POL Lo_thresh COMP_QUE[1:0] ALERT/RDY ALERT/RDY 8µs Figure 21 0 TH_H TH_H Input Signal Input Signal TH_L TH_L Time Time Latching Comparator Output Successful SMBus Alert Response Latching Comparator Output Successful SMBus Alert Response Successful SMBus Alert Response Time Time Non-Latching Comparator Output Non-Latching Comparator Output Time Time Traditional Comparator Mode Window Comparator Mode Figure 20. ALERT Pin Timing Diagram ADX111(Q) Status Converting Converting Converting Conversion Ready Conversion Ready Converting Conversion Ready 8µ s ALERT/RDY (Active High) Figure 21. Conversion Ready Pulse in Continuous-Conversion Mode 7.3.9 SMBUS (COMP_LAT = 1) ALERT/RDY I2C ALERT/RDY SMBus ALERT/RDY ALERT/RDY ADX111(Q) SMBus I 2C SMBus 2 IC SMBus (00011001) I2C ALERT/RDY ADX111(Q) I 2C SMBus 1 0 © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 17 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.4 7.4.1 ADX111(Q) ADX111(Q) ADC CONFIG REGISTER ADX111(Q) I2C ADX111(Q) ADX111(Q) (06h) 7.4.2 ADX111(Q) CONFIG REGISTER 7.4.2.1 CONFIG REGISTER MODE 1 ADX111(Q) ADX111(Q) CONFIG REGISTER (OS) OS ADC 0 ADC 0 CONFIG REGISTER ADX111(Q) 25 s OS 1 OS 1 7.4.2.2 (MODE 0) ADX111(Q) ADX111(Q) CONVERSION REGISTER 1 CONFIG REGISTER MODE 7.4.3 ΔΣ ADC ADX111(Q) ADX111(Q) 125 ADX111(Q) 860SPS 860SPS (8SPS) 123.8ms ADX111(Q) 1.2ms 1/100 ADX111(Q) Page 18 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.5 7.5.1 I2C I2C ADX111(Q) I2C I2C I 2C master ADX111(Q) I2C master I 2C I 2C SDA 1) SDA SCL SDA SCL slave I2C SCL SDA SCL SCL slave (SDA SDA 0 I2C 25 I 2C SDA START START master ADX111(Q) slave slave SCL STOP START I 2C START 7 I 2C ( ) ( SDA ) SDA SDA SDA START START ADX111(Q) I2C TIMING REQUIREMENTS 7.5.1.1 I2C ADX111(Q) I 2C ADDR Table 13 SCL SDA ADDR SDA 100ns GND VDD SDA SCL GND VDD I 2C SCL Table 13. ADDR Pin Connection and Corresponding Slave Address ADDR PIN CONNECTION SLAVE ADDRESS GND VDD SDA 1001000 1001001 1001010 SCL 1001011 © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 19 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.5.1.2 I2C 0 ADX111(Q) I2C 00000110 (06h) ADX111(Q) (0000000) 7.5.1.3 I2C 100kHz Hs ) Hs 400kHz ( 3.4MHz ADX111(Q) ADX111(Q) 00001xxx xxx / ADX111(Q) 3.4MHz START Hs Hs I2C ADX111(Q) Hs ADX111(Q) Hs I 2C 7.5.2 ADX111(Q) ADX111(Q) SCL 7.5.2.1 7 R/W ADDRESS P[1:0] POINTER REGISTER ADX111(Q) ADX111(Q) 7.5.2.2 7 R/W ADX111(Q) P[1:0] START STOP Page 20 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.5.3 ADX111(Q) P[1:0] ADDRESS POINTER REGISTER R/W STOP START ADX111(Q) P[1:0] P[1:0] P[1:0] R/W STOP R/W Figure 22 P[1:0] ADX111(Q) 1 9 1 9 SCL SDA 1 0 0 1 0 A1(1) A0(1) R/W Start By Master 0 0 0 0 0 0 P1 P0 ACK By Device ACK By Device Frame 1: Slave Address Byte Stop By Master Frame 2: Address Pointer Register 1 9 1 9 SCL (Continued) SDA (Continued) 1 0 0 1 0 A1(1) A0(1) R/W Start By Master D15 ACK By Device Frame 3: Slave Address Byte 1 D14 D13 D12 D11 D10 D9 D8 From Device ACK By Master(2) Frame 4: Data Byte 1 Read Register 9 SCL (Continued) SDA (Continued) D7 D6 D5 D4 D3 D2 D1 D0 From Device ACK By Master(3) Stop By Master Frame 5: Data Byte 2 Read Register (1) The values of A0 and A1 are determined by the ADDR pin. (2) Master can leave SDA high to terminate a single-byte read operation. (3) Master can leave SDA high to terminate a two-byte read operation. Figure 22. Timing Diagram for Reading from ADX111(Q) © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 21 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 1 9 1 9 SCL 1 SDA 0 0 1 0 A1(1) A0(1) R/W Start By Master 0 0 0 0 0 0 P1 P0 ACK By Device ACK By Device Frame 1: Slave Address Byte Frame 2: Address Pointer Register 1 9 1 9 SCL (Continued) SDA (Continued) D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 ACK By Device D0 ACK By Device Frame 3: Data Byte 1 Stop By Master Frame 4: Data Byte 2 (1) The values of A0 and A1 are determined by the ADDR pin. Figure 23. Timing Diagram for Writing to ADX111(Q) ALERT 1 9 1 9 SCL SDA 0 0 0 1 1 0 0 R/W Start By Master 1 ACK By Device Frame 1: SMBus ALERT Response Address Byte 0 0 1 A1 A0 From Device Status NACK By Master Stop By Master Frame 2: Slave Address (1) The values of A0 and A1 are determined by the ADDR pin. Figure 24. Timing Diagram for SMBus Alert Response Page 22 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 7.5.4 ADX111(Q) 8000h 16 (+FS) 7FFFh Table 14 ( FS) Table 14. Input Signal versus Ideal Output Code INPUT SIGNAL VIN = (VAINP – VAINN) IDEAL OUTPUT CODE (EXCLUDES THE EFFECTS OF NOISE, INL, OFFSET, AND GAIN ERRORS) ≥ +FS (215 – 1) / 215 +FS / 215 0 –FS / 215 ≤ –FS 7FFFh 0001h 0000h FFFFh 8000h Figure 25 7FFFh 7FFEh Output Code .. . 0001h 0000h FFFFh .. . 8001h 8000h –FS –FS +FS 0 Input Voltage VIN 215 – 1 215 +FS 215 – 1 215 Figure 25. Code Transition Diagram ADX111(Q) VAINN = 0V VAINP = 0V VAINP 0V © 2023 AnalogySemi Ltd. All Rights Reserved. +FS 0000h Public 7FFFh www.analogysemi.com | Page 23 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 8. REGISTER MAPS The ADX111(Q) has four registers that are accessible through the I2C interface using the ADDRESS POINTERREGISTER. The CONVERSION REGISTER contains the result of the last conversion. The CONFIG REGISTER is used to change the ADX111(Q) operating modes and query the status of the device. The other two registers, Lo_thresh and Hi_thresh, set the threshold values used for the comparator function. 8.1.1 ADDRESS POINTER REGISTER (ADDRESS = N/A) [RESET = N/A] All four registers are accessed by writing to the Address Pointer register; see Figure 22. Table 15. Address Pointer Register 7 6 5 4 3 0 0 0 0 0 W-0h W-0h W-0h W-0h W-0h LEGEND: R/W = Read/Write; R = Read only; -n = value after reset 2 1 0 W-0h W-0h 0 P[1:0] W-0h Table 16. Address Pointer Field Descriptions BIT FIELD TYPE RESET 7:2 Reserved W 0h 1:0 P[1:0] W 0h DESCRIPTION Always write 0h Register address pointer 00: Conversion register 01: Config register 10: Lo_thresh register 11: Hi_thresh register 8.1.2 CONVERSION REGISTER (P[1:0] = 0H) [RESET = 0000H] The 16-bit Conversion register contains the result of the last conversion in binary two's complement format. Following power-up, the Conversion register is cleared to 0, and remains 0 until the first conversion is completed. Table 17. Conversion Register 15 14 13 12 11 10 9 8 D15 R-0h D14 R-0h D13 R-0h D12 R-0h D11 R-0h D10 R-0h D9 R-0h D8 R-0h 7 6 5 4 3 2 1 0 D2 R-0h D1 R-0h D0 R-0h D7 D6 D5 D4 D3 R-0h R-0h R-0h R-0h R-0h LEGEND: R/W = Read/Write; R = Read only; -n = value after reset Table 18. Conversion Register Field Descriptions BIT FIELD TYPE RESET 15:0 D[15:0] R 0000h Page 24 of 39 | www.analogysemi.com DESCRIPTION 16-bit conversion result Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 8.1.3 CONFIG REGISTER (P[1:0] = 1H) [RESET = 8583H] The 16-bit Config register is used to control the operating mode, input selection, data rate, full-scale range, and comparator modes. Table 19. Config Register 15 14 OS R/W-1h 13 12 11 MUX[2:0] R/W-0h 7 6 10 9 PGA[2:0] R/W-2h 5 4 3 DR[2:0] COMP_MODE COMP_POL R/W-4h R/W-0h R/W-0h LEGEND: R/W = Read/Write; R = Read only; -n = value after reset 8 MODE R/W-1h 2 1 COMP_LAT R/W-0h 0 COMP_QUE[1:0] R/W-3h Table 20. Config Register Field Descriptions BIT FIELD TYPE RESET 15 OS R/W 1h 14:12 MUX[2:0] R/W 0h 11:9 PGA[2:0] R/W 2h 8 MODE R/W © 2023 AnalogySemi Ltd. All Rights Reserved. 1h DESCRIPTION Operational status or single-shot conversion start This bit determines the operational status of the device. OS can only be written when in power-down state and has no effect when a conversion is ongoing. When writing: 0: No effect 1: Start a single conversion (when in power-down state) When reading: 0: Device is currently performing a conversion. 1: Device is not currently performing a conversion. Input multiplexer configuration These bits configure the input multiplexer. 000: AINP = AIN0 and AINN = AIN1 (default) 001: AINP = AIN0 and AINN = AIN3 010: AINP = AIN1 and AINN = AIN3 011: AINP = AIN2 and AINN = AIN3 100: AINP = AIN0 and AINN = GND 101: AINP = AIN1 and AINN = GND 110: AINP = AIN2 and AINN = GND 111: AINP = AIN3 and AINN = GND Programmable gain amplifier configuration These bits set the FSR of the programmable gain amplifier. 000: FSR = ±6.144V(1) 001: FSR = ±4.096V(1) 010: FSR = ±2.048V (default) 011: FSR = ±1.024V 100: FSR = ±0.512V 101: FSR = ±0.256V 110: FSR = ±0.256V 111: FSR = ±0.256V Note: This parameter expresses the full-scale range of the ADC scaling. Do not apply more than VDD + 0.3V to the analog inputs of the device. Device operating mode This bit controls the operating mode. 0: Continuous-conversion mode 1: Single-shot mode or power-down state (default) Public www.analogysemi.com | Page 25 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator BIT 7:5 4 3 FIELD DR[2:0] COMP_MODE COMP_POL TYPE R/W R/W R/W RESET 4h 0h Comparator mode This bit configures the comparator operating mode. 0: Traditional comparator (default) 1: Window comparator 0h Comparator polarity This bit controls the polarity of the ALERT/RDY pin. 0: Active low (default) 1: Active high 2 COMP_LAT R/W 0h 1:0 COMP_QUE[1:0] R/W 3h Page 26 of 39 | www.analogysemi.com DESCRIPTION Data rate These bits control the data rate setting. 000: 8SPS 001: 16SPS 010: 32SPS 011: 64SPS 100: 128SPS (default) 101 : 250SPS 110: 475SPS 111 : 860SPS Latching comparator This bit controls whether the ALERT/RDY pin latches after being asserted or clears after conversions are within the margin of the upper and lower threshold values. 0: Nonlatching comparator. The ALERT/RDY pin does not latch when asserted (default). 1: Latching comparator. The asserted ALERT/RDY pin remains latched until conversion data are read by the master or an appropriate SMBus alert response is sent by the master. The device responds with its address, and it is the lowest address currently asserting the ALERT/RDY bus line. Comparator queue and disable These bits perform two functions. When set to 11, the comparator is disabled and the ALERT/RDY pin is set to a high-impedance state. When set to any other value, the ALERT/RDY pin and the comparator function are enabled, and the set value determines the number of successive conversions exceeding the upper or lower threshold required before asserting the ALERT/RDY pin. 00: Assert after one conversion 01: Assert after two conversions 10: Assert after four conversions 11: Disable comparator and set ALERT/RDY pin to high-impedance (default) Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 8.1.4 LO_THRESH (P[1:0] = 2H) [RESET = 8000H] AND HI_THRESH (P[1:0] = 3H) [RESET = 7FFFH] REGISTERS The upper and lower threshold values used by the comparator are stored in two 16-bit registers in two's complement format. The comparator is implemented as a digital comparator; therefore, the values in these registers must be updated whenever the PGA settings are changed. The conversion-ready function of the ALERT/RDY pin is enabled by setting the Hi_thresh register MSB to 1 and the Lo_thresh register MSB to 0. To use the comparator function of the ALERT/RDY pin, the Hi_thresh register value must always be greater than the Lo_thresh register value. The threshold register formats are shown in Table 21. When set to RDY mode, the ALERT/RDY pin outputs the OS bit when in single-shot mode, and provides a continuous-conversion ready pulse when in continuous-conversion mode. Table 21. Lo_thresh Register 15 14 13 12 11 10 9 8 Lo_thresh15 R/W-1h Lo_thresh14 R/W-0h Lo_thresh13 R/W-0h Lo_thresh12 R/W-0h Lo_thresh11 R/W-0h Lo_thresh10 R/W-0h Lo_thresh9 R/W-0h Lo_thresh8 R/W-0h 7 6 5 4 3 2 1 0 Lo_thresh2 R/W-0h Lo_thresh1 R/W-0h Lo_thresh0 R/W-0h Lo_thresh7 Lo_thresh6 Lo_thresh5 Lo_thresh4 Lo_thresh3 R/W-0h R/W-0h R/W-0h R/W-0h R/W-0h LEGEND: R/W = Read/Write; R = Read only; -n = value after reset Table 22. Hi _thresh Register 15 14 13 12 11 10 9 8 Hi_thresh15 Hi_thresh14 Hi_thresh13 Hi_thresh12 Hi_thresh11 Hi_thresh10 Hi_thresh9 Hi_thresh8 R/W-0h R/W-1h R/W-1h R/W-1h R/W-1h R/W-1h R/W-1h R/W-1h 7 6 5 4 3 2 1 0 Hi_thresh2 R/W-1h Hi_thresh1 R/W-1h Hi_thresh0 R/W-1h Hi_thresh7 Hi_thresh6 Hi_thresh5 Hi_thresh4 Hi_thresh3 R/W-1h R/W-1h R/W-1h R/W-1h R/W-1h LEGEND: R/W = Read/Write; R = Read only; -n = value after reset Table 23. Lo_thresh and Hi_thresh Register Field Descriptions BIT FIELD TYPE RESET 15:0 15:0 Lo_thresh[15:0] Hi_thresh[15:0] R/W R/W 8000h 7FFFh © 2023 AnalogySemi Ltd. All Rights Reserved. DESCRIPTION Low threshold value High threshold value Public www.analogysemi.com | Page 27 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 9. AnalogySemi AnalogySemi 9.1 ADX111(Q) 9.1.1 ADX111(Q) I2C Figure 26 10 Device VDD 1kΩ to 10kΩ (typ) Pullup Resistors Microcontroller or Microprocessor with I2C Port VDD SCL 1 ADDR SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 4 AIN0 AIN2 6 0.1µ F (typ) AIN1 5 SCL SDA GPIO Inputs Selected from Configuration Register Figure 26. Typical Connections of the ADX111(Q) ADX111(Q) ADX111(Q) ADX111(Q) 0.1μF I2C ADX111(Q) ADX111(Q) ADX111(Q) I2C ( I 2C ) I2C SDA SCL Page 28 of 39 | www.analogysemi.com I2C Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 9.1.2 ADX111(Q) Figure 27 ADX111(Q) ADX111(Q) CONFIG REGISTER 0V +FS ADX111(Q) ADX111(Q) ADX111(Q) MUX[2:0] FSR ADC VDD 10 Device Output Codes 0-32767 SCL 1 ADDR SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 4 AIN0 AIN2 6 0.1µ F (typ) AIN1 5 Inputs Selected from Configuration Register NOTE: Digital pin connections omitted for clarity. Figure 27. Measuring Single-Ended Inputs MUX[2:0] ADX111(Q) ADX111(Q) GND < V(AIN3) < VDD AIN3 AIN0 AIN1 AIN2 AIN3 AIN3 9.1.3 ADX111(Q) ADX111(Q) ADX111(Q) 300mV 10mA 9.1.4 VDD ALERT/RDY © 2023 AnalogySemi Ltd. All Rights Reserved. GND VDD Public www.analogysemi.com | Page 29 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 9.1.5 1. 2. ADC ( ) (fMOD) Figure 28 Magnitude Sensor Signal Output Data Rate Magnitude Unwanted Signals Unwanted Signals fMOD / 2 fMOD Frequency fMOD Frequency fMOD Frequency Digital Filter Aliasing of Unwanted Signals Output Data Rate fMOD / 2 Magnitude External Antialiasing Filter Roll-Off Output Data Rate fMOD / 2 Figure 28. Effect of Aliasing ΔΣ ADC (EMI) (RC) ( fMOD/2 (RFI) (PCB) ) ADC ADX111(Q) 10 RC Page 30 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 9.1.6 SDA I2 C GND VDD ADX111(Q) I2C 100ns I 2C ADX111(Q) SCL Figure 29 SDA SCL I 2C ADX111(Q) VDD GND 10 Device SCL 1 ADDR 1kΩ to 10kΩ (typ) I2C Pullup Resistors Microcontroller or Microprocessor with I2C Port VDD SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 AIN2 6 1 ADDR SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 AIN2 6 1 ADDR SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 AIN2 6 1 ADDR SDA 9 2 ALERT/RDY VDD 8 3 GND AIN3 7 AIN2 6 4 AIN0 AIN1 5 SCL SDA 10 Device SCL 4 AIN0 AIN1 5 10 Device SCL 4 AIN0 AIN1 5 10 Device SCL 4 AIN0 AIN1 5 NOTE: Device power and input connections omitted for clarity. The ADDR pin selects the I 2C address. Figure 29. Connecting Multiple ADX111(Q) Devices © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 31 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 9.1.7 I2C ADX111(Q) 1001000 ADX111(Q) Figure 30 ADX111(Q) ADX111(Q) I2C I2C ( 2V ) SCL 5V SDA SCL ADX111(Q) ADX111(Q) POINTER REGISTER 22 Figure 23 R/W P[1:0] START ADX111(Q) ADDRESS Figure STOP ADX111(Q) 1. 2. 3. Config register 0b10010000 ( 0b00000001 ( 0b10000100 ( 0b10000011 ( Address Pointer register 0b10010000 ( 0b00000000 ( 7 I2C Config register) Config Config R/W ) MSB) LSB) 7 I2C Conversion R/W ) Conversion register 0b10010001 ( 7 I 2C ADX111(Q) Conversion register ADX111(Q) Conversion register ) R/W MSB LSB ) 3.3V Device VDD 0.1μF GND 3.3V AIN0 I2C-Capable Master AIN1 ADDR AIN2 AIN3 10kΩ 3.3V 10kΩ SCL SCL SDA SDA VDD 0.1μF GND ALERT JTAG Serial/UART Figure 30. Basic Hardware Configuration Page 32 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 10. VDD 10.1 VDD 50µs 10.2 VDD (ESR) 0.1µF Figure 31 (ESL) 0.1µF (MLCC) VDD ADDR 1 10 SCL ALERT/RDY 2 9 SDA 3 8 AIN0 4 7 AIN3 AIN1 5 6 AIN2 GND VDD 0.1µ F Figure 31. ADX111(Q) Power-Supply Decoupling © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 33 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 11. 11.1 ADX111(Q) ADC • • • AIN0 AIN1 AIN2 AIN3 C0G (NPO) 11.2 EVM AnalogySemi Page 34 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 12. PACKAGE INFORMATION The ADX111(Q) is available in the MSOP-10 and QFN-10 packages. 12.1 MSOP-10 PACKAGE Figure 32 shows the MSOP-10 package view. b c E1 E L e A2 A1 A D Figure 32. MSOP-10 Package View Table 24 provides detailed information about the dimensions of the MSOP-10 package. Table 24. Dimensions of the MSOP-10 Package SYMBOL DIMENSIONS IN MILLIMETERS MIN MAX DIMENSIONS IN INCHES MIN MAX A A1 A2 b --0.020 0.750 0.180 1.100 0.150 0.950 0.330 --0.001 0.030 0.007 0.043 0.006 0.037 0.013 c D e E E1 L θ 0.090 2.900 0.230 3.100 0.004 0.114 0.009 0.122 5.050 3.100 0.800 6° 0.187 0.114 0.016 0° 0.500 (BSC) 4.750 2.900 0.400 0° © 2023 AnalogySemi Ltd. All Rights Reserved. 0.020 (BSC) Public 0.199 0.122 0.031 6° www.analogysemi.com | Page 35 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 12.2 QFN-10 PACKAGE Figure 33 shows the QFN-10 package view. N9 L1 D N1 N6 N4 b2 b E e L b1 Top View A3 A A1 Bottom View Figure 33. QFN-10 Package View Table 25 provides detailed information about the dimensions of the QFN-10 package. Table 25. Dimensions of the QFN-10 Package SYMBOL A A1 A3 b b1 b2 D E e L L1 Page 36 of 39 | www.analogysemi.com DIMENSIONS IN MILLIMETERS MIN MAX 0.500 0.000 DIMENSIONS IN INCHES MIN MAX 0.600 0.050 0.020 0.000 0.250 0.350 0.300 1.550 2.050 0.006 0.010 0.008 0.057 0.077 0.400 0.450 0.012 0.014 0.152REF. 0.150 0.250 0.200 1.450 1.950 0.006REF. 0.500TYP. 0.300 0.350 0.024 0.002 0.010 0.014 0.012 0.061 0.081 0.020TYP. Public 0.016 0.018 © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 13. TAPE AND REEL INFORMATION 13.1 MSOP-10 PACKAGE Figure 34 illustrates the carrier tape of the MSOP-10 package. 8.00± 0.10 +0.10 4.00± 0.10 1.50 0 2.00± 0.05 1.75± 0.10 0.25± 0.02 +0.30 12.00 –0.10 A 5.50± 0.05 B A 3.30± 0.10 7º MAX +0.25 1.50 –0 1.50± 0.10 8º MAX B-B 1.20 3.20 B 5.20±0.10 A-A Notes: 1. Cover tape width: 9.5 ± 0.10. 2. Cumulative tolerance of 10 sprocket hole pitch: ± 0.20 (max). 3. Camber: not to exceed 1mm in 100mm. 4. Mold#: MSOP-10 (3*3). 5. All dimensions: mm. 6. Direction of view: Figure 34. Carrier Tape Drawing (MSOP-10 Package) Table 26 provides information about tape and reel (MSOP-10 package). Table 26. Tape and Reel Information (MSOP-10 Package) PACKAGE TYPE REEL QTY/REEL REEL/ INNER BOX INNER BOX/ CARTON QTY/CARTON INNER BOX SIZE (MM) CARTON SIZE (MM) MSOP-10 3*3 13’’ 3000 1 8 24000 358*340*50 430*380*390 Figure 35 shows the product loading orientation—pin 1 is assigned on the upper left corner. Pin 1 Figure 35. Product Loading Orientation (MSOP-10 Package) © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 37 of 39 ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator 13.2 QFN-10 PACKAGE Figure 36 illustrates the carrier tape (QFN-10 package). 4± 0.1 4± 0.1 2.3± 0.08 +0.3 8 –0.1 3.5± 0.05 1.75± 0.1 2± 0.05 0.2± 0.03 0.75± 0.05 1.7± 0.08 Notes: 1. Cover tape width: 5.5 ± 0.10. 2. Cumulative tolerance of 10 sprocket hole pitch: ± 0.20 (max). 3. Camber: not to exceed 1mm in 100mm. 4. Mold#: QFN-10 (1.5*2). 5. All dimensions: mm. 6. Direction of view: Figure 36. Carrier Tape Drawing (QFN-10 Package) Table 27 provides information about tape and reel (QFN-10 package). Table 27. Tape and Reel Information (QFN-10 Package) PACKAGE TYPE REEL QTY/REEL REEL/ INNER BOX INNER BOX/ CARTON QTY/CARTON INNER BOX SIZE (MM) CARTON SIZE (MM) QFN-10 1.5*2 7’’ 4000 10 4 160000 210*208*203 440*440*230 Figure 37 shows the product loading orientation—pin 1 is assigned on the upper left corner. Pin 1 Figure 37. Product Loading Orientation (QFN-10 Package) Page 38 of 39 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. ADX111/ADX111Q Ultra-Small, Low-Power, I2C-Compatible, 860-SPS, 16-Bit ADCs With Internal Reference, Oscillator, and Programmable Comparator REVISION HISTORY REVISION DATE Rev A 13 January 2023 © 2023 AnalogySemi Ltd. All Rights Reserved. DESCRIPTION Rev A release. Public www.analogysemi.com | Page 39 of 39
ADX111AMSOP10 价格&库存
很抱歉,暂时无法提供与“ADX111AMSOP10”相匹配的价格&库存,您可以联系我们找货
