FP6276AXR-G1
FP6276AXR-G1
    ANALOGYSEMI(类比半导体)
    SOP8_EP
    FP6276A 是一款电流模式升压 DC-DC 转换器,采用 PWM/PSM 控制。内置 40mΩ 高侧开关和 40mΩ 低侧开关,使该调节器具有高效率。内部补偿网络减少了外部组件的数量,仅需 6 个...
FP6276AXR-G1 数据手册
FP6276A 500kHz 6A High Efficiency Synchronous PWM Boost Converter General Description The FP6276A is a current mode boost DC-DC converter with PWM/PSM control. Its PWM circuitry with built-in 40mΩ high side switch and 40mΩ low side switch make this regulator highly power efficient. The internal compensation network also minimizes external component counts to only 6. An internal 0.6V voltage is connected to error amplifier the non-inverting input as precision reference voltage. Built-in soft-start function can reduce the inrush current. Features  Current mode with PWM/PSM control  Input voltage range: 2.4V~4.5V  Adjustable Output up to 5.3V  Shutdown current:
FP6276AXR-G1 价格&库存
很抱歉,暂时无法提供与“FP6276AXR-G1”相匹配的价格&库存,您可以联系我们找货
