FP9102-18XR-LF
FP9102-18XR-LF
    ANALOGYSEMI(类比半导体)
    SOP8_EP
FP9102-18XR-LF 数据手册
FP9102 2A Low Dropout Regulator with Enable General Description The FP9102 is a high performance positive voltage regulator designed for use in applications requiring very low Input voltage with very low dropout output voltage at up to 2A load. It can regulate the programmable output voltage to as low as 0.8V with a 5V VCC voltage and a minimum 1.6V VIN. The FP9102 features include ultra low dropout. It is ideal for applications where VOUT is very close to VIN. Additionally, there is an ENABLE pin to further reduce power dissipation while shutdown. The FP9102 provides excellent regulation over variations in line, load and temperature. The FP9102 provides a power GOOD signal to indicate if the voltage level of VOUT reaches 90% of its rating value. The FP9102 is available in the SOP-8L (Exposed Pad) package. It is available with 1.2V, 1.5V, 1.8V and 2.5V internally preset outputs that are also adjustable using external resistors. Features  Adjustable Output Low to 0.8V  Input Voltage as Low as 1.6V and VCC Voltage 5V  High Accuracy Output Voltage: ±2%  1.2V, 1.5V, 1.8V, 2.5V Options and Adjustable Externally Using Resistors  360mV Dropout at 2A Load Typically  OCP, OVP & Thermal Shutdown Protections  Power Good Output  Output Voltage Pull Low Resistance when Disable  Package: SOP-8L (EP) Applications  Motherboard Applications  Notebook PC Applications  Network Cards VIN Typical Application Circuit 1 2 POK VOUT EN ADJ 6 VOUT 7 FP9102 3 VIN 4 VIN NC VCC GND 5 8 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 1/10 FP9102 Function Block Diagram VOUT VIN OTP Pin Descriptions SOP-8L(EP) Name No. I / O Description POK 1 O Power GOOD Open Drain Output EN 2 I Enable Control VIN 3 P VOUT Pin Power Supply VCC 4 P NC 5 VOUT 6 O ADJ 7 I GND 8 P Output Voltage Adjust Feedback Resistors or connect to Ground IC Ground EP 9 P Exposed PAD is GND Chip Power Supply No Internal Connection This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 2/10 FP9102 Marking Information SOP-8L (EP) Output Voltage Code: For Example: 12  Fix VOUT=1.2V 15  Fix VOUT=1.5V 18  Fix VOUT=1.8V 25  Fix VOUT=2.5V Halogen Free: Halogen free product indicator Lot Number: Wafer lot number’s last two digits For Example: 132386TB  86 Internal ID: Internal Identification Code Per-Half Month: Production period indicated in half month time unit For Example: January → A(Front Half Month),B (Last Half Month) February → C(Front Half Month),D (Last Half Month) Year: Production year’s last digit This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 3/10 FP9102 Ordering Information Output Voltage Output Voltage Code Operating Temp. FP9102-12XR-LF 1.2V / ADJ 12 -25°C ~ +85°C FP9102-15XR-LF 1.5V / ADJ 15 -25°C ~ +85°C FP9102-18XR-LF 1.8V / ADJ 18 -25°C ~ +85°C FP9102-25XR-LF 2.5V / ADJ 25 -25°C ~ +85°C Part Number Package SOP-8L (EP) SOP-8L (EP) SOP-8L (EP) SOP-8L (EP) MOQ Description 2500EA Tape & Reel 2500EA Tape & Reel 2500EA Tape & Reel 2500EA Tape & Reel Absolute Maximum Ratings Max. Unit Power Supply Voltage VIN 1.6 5.5 V Power Supply Voltage VCC 4.5 5.5 V Output Voltage VOUT 0.8 5.5 V 1.2 W Parameter Symbol Maximum Power Dissipation Thermal Resistance Junction Temperature Conditions PD SOP-8L(EP) @TA=25℃ θJA (Note2) Min. θJC TJ - Typ. 70 ℃/W 15 ℃/W 150 ℃ Operating Temperature TOP -25 85 ℃ Storage Temperature TST -55 125 ℃ IR Re-flow Lead Temperature TIR 260 ℃ Soldering 10 sec. Note: 1. 2. Absolute Maximum Ratings are limits beyond which damage to the device may occur. Operating conditions are conditions under which the device functions but the specifications might not be guaranteed for guaranteed specifications and test conditions see the Electrical Characteristics. Mounted on Recommended Minimum Footprint. IR Re-flow Soldering Curve This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 4/10 FP9102 Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit Power Supply Voltage VIN 1.6 5.5 V Power Supply Voltage VCC 4.5 5.5 V Operating Temperature Range TOP -20 +85 °C Electrical Characteristics VIN=VOUT+500mV, VCC=5V, CIN=COUT=10µF, TA=TJ=25°C, unless otherwise specified (Note 3) Parameter ADJ section Symbol Reference Voltage VREF Adjust Pin Current IADJ Adjust Pin Threshold VADJ Conditions VADJ=VO Min. Typ. Max. Unit 0.788 0.8 0.812 V 20 100 nA 0.15 0.2 0.25 V Chip Enable (EN) Section EN Input Bias Current IEN EN Threshold Voltage VEN=0V 12 VENH Logic-High Voltage VENL Logic-Low Voltage µA 1.6 V 0.4 V Power Good (POK) Section Power Good Rising Threshold Voltage VTHPOK % 92 Power Good Hysteresis ΔVTHPOK Power Good Sink Capability IPOK_SINK IPOK=10mA % 7 0.2 0.4 V Thermal Shutdown Protection Section Thermal Shutdown Temperature Thermal Shutdown Hysteresis TSD 150 °C ΔTSD 30 °C Output Section ΔVOUT Fixed Output Voltage Range Line Regulation (VIN) ΔVLINE_VIN Load Regulation(VOUT) (Note 3) Dropout Voltage (Note 4) Current Limit ΔVLOAD__ VOUT ΔVDROP VIN=VOUT+0.5V VIN=VOUT+0.5V to 5V, IOUT=1mA VIN=VOUT+1V, IOUT=1mA to 2A IOUT=2A ILIM 2.4 Short Circuit Current VOUT Pull Low Resistance -2 VEN=0V 0 2 % 0.2 0.6 % 0.2 1 % 360 400 mV 3.0 A 1.8 A 90 Ω This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 5/10 FP9102 Parameter Total Device Section Symbol Conditions VIN Input Voltage Range VIN VCC Input Voltage Range VCC Quiescent Current(Ground current) (Note 4) IQH VOUT=Fix Output Voltage IQL VEN=0V Min. Typ. Max. Unit 1.6 5.5 V 4.5 5.5 V 0.5 0.7 mA 26 50 µA Note 1: Low duty pulse techniques are used during test to maintain junction temperature as close to ambient as possible. Note 2: Regulation is measured at constant junction temperature by using a 2ms current pulse. Devices are tested for load regulation in the load range from 1mA to 2A Note 3: The dropout voltage is defined as VIN-VOUT, which is measured when VOUT is normal VOUT-100mV Note 4: Quiescent current is the difference between input and outputs. It is defined by IQ=IIN-IOUT under no load condition (IOUT=0mA). The total current drawn from the supply is the sum of the load current plus the ground pin current. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 6/10 FP9102 Application Information VIN 100K 1 Chip Enable 2 POK VOUT EN ADJ 6 VOUT 7 FP9102 3 VIN VCC VIN NC VCC GND 5 10µF 4 8 10µF 1µF Figure 1 Fixed Voltage Regulator Circuit VIN 100K 1 POK VOUT 6 VOUT R1 Chip Enable 2 ADJ EN 7 FP9102 3 VIN VCC VIN NC VCC GND 5 R2 10µF 4 8 10µF 1µF Figure 2 Adjustable Voltage Regulator Circuit For example: The output voltage equation is VOUT = 0.8 * R1 + R2 15K + 10K = 0 .8 V × = 2 .0 V R2 10K This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 7/10 FP9102 Typical Operating Characteristics Dropout Voltage vs. Load Current Short Circuit Current vs. Temperature Short Circuit Current (A) Dropout Voltage (mV) 400 350 85℃ 300 25℃ 250 200 -40℃ 150 100 50 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.6 2.4 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 -60 -40 -20 Quiescent Current (uA) VDD Standby Current (uA) 32 VIN=1.8V,VEN=0V,VDD=5V 24 20 16 12 8 4 0 20 40 60 80 100 120 140 80 100 120 140 Temperature (℃) Output Voltage vs. Temperature Reference Voltage vs. Temperature 0.84 1.25 0.83 1.24 0.82 1.23 Output Voltage (V) Reference Voltage (V) 60 1200 1100 VIN=3.3V,VOUT=2.5V,IOUT=0A 1000 900 800 700 600 500 400 300 200 100 0 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature (℃) 0.81 0.80 0.79 0.78 0.77 0.76 0.75 0.74 -60 -40 -20 40 Quiescent Current vs. Temperature VDD Standby Current vs. Temperature 0 -60 -40 -20 20 Temperature (℃) Load Current (A) 28 0 VIN=1.8V,VADJ=0V,VDD=5V,IOUT=0A 1.22 1.21 1.20 1.19 1.18 1.17 1.16 0 20 40 60 1.15 -60 -40 -20 80 100 120 140 Temperature (℃) 0 20 40 60 80 100 120 140 Temperature (℃) This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 8/10 FP9102 ADJ Threshold Voltage Range (V) VDD POR Threshold Voltage vs. Temperature 3.10 POR Voltage (V) 3.08 3.06 3.04 Rising 3.02 Falling 3.00 2.98 2.96 -60 -40 -20 0 20 40 60 80 100 120 Temperature (℃) ADJ Threshold Voltage vs. Temperature 0.30 0.28 0.26 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.10 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature(℃) Enable Threshold Voltage (V) Enable Threshold Voltage vs. Temperature 2.2 2.0 1.8 1.6 Rising 1.4 1.2 1.0 Falling 0.8 0.6 0.4 -60 -40 -20 0 20 40 60 80 100 120 140 Temperature (℃) This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 9/10 FP9102 Package Outline SOP-8L (EP) UNIT: mm Symbols Min. (mm) Max. (mm) A 1.346 1.752 A1 0.050 0.152 A2 1.498 D 4.800 4.978 E 3.810 3.987 H 5.791 6.197 L 0.406 1.270 θ° 0° 8° Exposed PAD Dimensions: Symbols Min. (mm) Max. (mm) E1 2.184 REF D1 2.971 REF Note: 1. Package dimensions are in compliance with JEDEC outline: MS-012 AA. 2. Dimension “D” does not include molding flash, protrusions or gate burrs. 3. Dimension “E” does not include inter-lead flash or protrusions. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.62 10/10
FP9102-18XR-LF
物料型号:FP9102
器件简介:FP9102是一款高性能的正电压稳压器,专为需要在极低输入电压下实现极低下拉输出电压的应用而设计,最大负载可达2A。它能够在5V VCC电压和最低1.6V VIN的条件下,将可编程输出电压调节至低至0.8V。FP9102具有超低下拉特性,非常适合VOUT非常接近VIN的应用场景。
引脚分配:FP9102采用SOP-8L (Exposed Pad)封装,引脚功能如下: - POK1:电源良好开漏输出 - EN2:使能控制 - VIN3:输出电压输入引脚 - Vcc4:芯片电源供应 - NC5:无内部连接 - VOUT6:输出电压 - ADJ7:调整反馈电阻或接地 - GND8:IC地 - EP9:裸露PAD是GND
参数特性:包括可调节的输出电压低至0.8V,输入电压低至1.6V,VCC电压5V,高准确度输出电压±2%,360mV的下拉电压在2A负载下典型值,过流保护(OCP)、过压保护(OVP)和热关断保护,电源良好输出,以及在禁用时输出电压下拉电阻。
功能详解:FP9102提供了一个使能引脚以进一步降低关机时的功耗。它在线路、负载和温度变化下提供出色的调节性能,并提供了一个电源良好信号,以指示VOUT是否达到其额定值的90%。
应用信息:适用于主板、笔记本电脑、网络卡等应用。
封装信息:FP9102提供SOP-8L (Exposed Pad)封装,具有1.2V、1.5V、1.8V和2.5V内部预设输出,也可以使用外部电阻进行调整。
FP9102-18XR-LF 价格&库存
很抱歉,暂时无法提供与“FP9102-18XR-LF”相匹配的价格&库存,您可以联系我们找货
