HY_45T05A-830
HY_45T05A-830
    SEPA
    SEPA - HY_45T05A-830 - Fan Blower, Radial, 5 VDC, DC, 45 mm, 5 mm, 1.34 CFM
HY_45T05A-830 数据手册
Radial fans GmbH ® SEPA HY_45T05AP RADIAL FAN HIGH PERFORMANCE FAN HY_45T05AP HIGH PERFORMANCE FAN AIR PERFORMANCE SHAPE AND DIMENSION PERFORMANCE HY_45T05AP Operating Voltage [V] 4.5 ... 5.0 ... 5.5 Typ. Operating Current [mA] 150 Max. Start Current [mA] 250 3 Max. Air Flow [l/min - m /h] 38 – 2.28 Max. Air Pressure [mmH2O Pa] 9.6 – 94 Typ. Noise @ 1m [dB(A)] 27 Typ. Rotor Speed [RPM] 5200 FG Output [Imp./rev.] 2 PWM signal (frequency, duty cycle) [VDC] 0.7 … 2.5 (23KHz, 30…100%) Operating Temperature [°C] -10 … +70 Life Expectancy L10/MTBF [h] 75000/2250000 @20°C Bearing System Sleeve bearing Weight [g] 9 Packing Quantity [Pcs] 50-500 ® This SEPA high-tech miniature fan is suitable for industrial or automotive use and has a remarkable air flow performance despite its small dimensions. Thanks to the very low power input, this fan is highly suitable for battery-operated devices. It is permanently protected electrically against reverse polarity, blocking and thermal overloading. Due to the low rotor weight and precision balancing, it is virtually vibration-free. It is also insensitive to shock. Further features of this fan are its extremely robust and torsionally stiff housing of PBT (UL E54695) with metal base, sleeve bearing with narrow tolerances, polyester-based PCB (UL E44247) and absolute reliability due to a 100% burn-in. SEPA EUROPE GmbH 04/14 D-79108 FREIBURG Tel:Technical +49(0)761/1561025 Fax: +49(0)761/1561027 changes without notice • 02/15 Technical changes without notice SEPA EUROPE GmbH • D-79427 Eschbach • Tel.: +49/7634/59459-0 • Fax: +49/7634/59459-199
HY_45T05A-830 价格&库存
很抱歉,暂时无法提供与“HY_45T05A-830”相匹配的价格&库存,您可以联系我们找货
