HY_60Q05AP
HY_60Q05AP
    SEPA
    SEPA - HY_60Q05AP - Fan Blower, Radial, 5 VDC, DC, 60 mm, 5 mm, 2.76 CFM
HY_60Q05AP 数据手册
® SEPA RADIAL FAN HY_60Q05AP HIGH PERFORMANCE FAN AIR PERFORMANCE SHAPE AND DIMENSIONS Pa Wires AWG28 blk=GND, red=+VCC (yel=FG) Air Pressure 100 75 50 25 0 0 20 40 60 80 l/min Air Performance PERFORMANCE Operating Voltage Typ. Operating Current Max. Start Current Max. Air Flow Max. Pressure Noise @ 1m (typ.) Operating Temperature Typ. Rotor Speed FG Output PWM Signal (Frequency, Duty Cycle) Life Expectancy L10/MTBF Bearing System Weight Packing Quantity [VDC] [mA] [mA] 3 [l/min - m /h] [mmH2O - Pa] [dB(A)] [°C] [RPM] [PPR] [VDC] [h] [g] [Pc] HY_60Q05AP 4.5 ... 5.0 ... 5.5 140 400 78 – 4.69 10.7 – 105 28 -10 … +60 4400 2 0.7 … 2.5 (23KHz, 30…100%) 75000/225000 @20°C Magfix Sleeve Bearing 18 50-500 ® This SEPA high-tech miniature fan is suitable for industrial and has a remarkable air flow performance despite its small dimensions. The air intake is on the top and on the bottom side, the air exit is on the side. The fan is permanently electrically protected against reverse polarity, blocking and thermal overloading. Due to the low rotor weight and precision balancing, it is virtually vibration-free. It is also insensitive to shock. Further features of this fan are its extremely robust and torsionally stiff housing of PBT (UL E54695) with metal base, long-life-sleeve bearing with very high oil volume, polyester-based PCB (UL E44247) and absolute reliability due to a 100% burn-in. SEPA EUROPE GmbH 11.14 D-79108 FREIBURG Tel: +49(0)761 3842273 0 Fax: +49(0)761 3842273 99 Subject to technical changes! • ALAR OUTPUT ® The SEPA -fan HY_60Q05AP includes a speed impulse output (FG) which enables monitoring the correct function of the fan. The pulse is like a rectangular wave, the frequency correlates to 2 x rotor speed. At blocked rotor the output signal could be L (≤ 0,2V) or H (Vcc). IMPORTANT: The pulse output is not protected against short circuit and must not connect to GND or Vcc without pre-resistor. A pull-up-resistor is needed. ® The SEPA -fan HY_60QAP has a PWM control input (L=0.7Vmax; H=2.5...Vcc; f=23 kHz). Start-up PWM duty percentage 35% min, frequency of PWM duty cycle 23 KHz, range of PWM duty cycle 35…100%. Do not inputs a PWM input signal if the fan power supply is off! Otherwise the fan will be destroyed. Please follow the handling instructions. The fan has tinned lead wire ends (without connector). FAN HY_60Q05QAP ALARME-CIRCUIT rt + OUTPUT SIGNAL + ge (5mA max.) T sw - - 1n Run: T=6.8msec; L=0.2Vmax; H=Vcc; Stop: H or L • ACCESSORIES: CONNECTOR: on request • ORDER INFORMATION: HY_60Q05AP SEPA Radial fan, 60x60x12.5mm, 5VDC, Long-Life-Sleeve bearing, CE 1060Q1040 ® SEPA is the brand name for fans and CPU-Cooler, made by Nippon Keiki Works LTD., Tokyo SEPA EUROPE GmbH 11.14 D 79108 FREIBURG Tel: +49(0)761 3842273 0 Fax: +49(0)761 3842273 99 Technical changes without notice
HY_60Q05AP 价格&库存
很抱歉,暂时无法提供与“HY_60Q05AP”相匹配的价格&库存,您可以联系我们找货
