FHP10N65A
FHP10N65A
    FEIHONG(飞虹)
    TO-220-3
    1个N沟道 耐压:650V 电流:10A
FHP10N65A 数据手册
N ⋏䚃໎ᕪර൪᭸ᓄᲦփ㇑ N-CHANNEL MOSFET FHP10N65A/FHF10N65A ѫ㾱৲ᮠ MAIN CHARACTERISTICS ID ӗ૱⢩ᙗ FEATURES  10A վḵᶱ⭥㦧 Low gate charge VDSS 650V վ Crss (ިර٬ 18pF) Low Crss (typical 18pF ) Rdson-typ˄@Vgs=10V˅ 0.8Ω ᔰ‫ޣ‬䙏ᓖᘛ Fast switching Qg-typ 29nC 100%㓿䗷䴚ፙ⍻䈅 100% avalanche tested 儈ᣇ dv/dt 㜭࣋ Improved dv/dt capability RoHS ӗ૱ RoHS product ⭘䙄 APPLICATION High efficiency switch 儈仁ᔰ‫⭥ޣ‬Ⓚ mode power supplies ⭥ᆀ䭷⍱ಘ Electronic ballast LED ⭥Ⓚ LED power supply ሱ㻵ᖒᔿ Package ㅹ᭸⭥䐟 Equivalent Circuit TO-220 TO-220F FHP ㌫ࡇ FHF ㌫ࡇ 㔍ሩᴰབྷ仍ᇊ٬ ABSOLUTE RATINGS (Tc=25ć) 亩ⴞ Parameter ㅖਧ Symbol ᮠ٬ Value FHP10N65A FHF10N65A অս Unit VDS 650 V ID˄TC=25ć˅ ID˄TC=100ć) 10* 6.2* A A IDM 40* A VGS ±30 V EAS 700 mJ IAR 10 A EAR 15.5 mJ dv/dt 5.0 V/ns ᴰ儈┿ᶱˉⓀᶱⴤ⍱⭥঻ Drain-Source Voltage 䘎㔝┿ᶱ⭥⍱* Drain Current -continuous * ᴰབྷ㜹ߢ┿ᶱ⭥⍱˄⌘ 1˅ Drain Current – pulse˄note 1˅ ᴰ儈ḵⓀ⭥঻ Gate-Source Voltage অ㜹ߢ䴚ፙ㜭䟿˄⌘ 2˅ Single Pulsed Avalanche Energy˄note 2˅ 䴚ፙ⭥⍱˄⌘ 1˅ Avalanche Current˄note 1˅ 䟽༽䴚ፙ㜭䟿˄⌘ 1˅ Repetitive Avalanche Current˄note 1˅ Ҽᶱ㇑৽ੁᚒ༽ᴰབྷ⭥঻ਈॆ䙏⦷˄⌘ 3˅ Peak Diode Recovery dv/dt˄note 3˅ 㙇ᮓ࣏⦷ Power Dissipation ᴰ儈㔃⑙৺ᆈۘ⑙ᓖ Operating and Storage Temperature Range PD ˄TC=25ć˅ -Derate above 25ć 156 1.43 50 0.48 W W/ć TJˈTSTG 150ˈ–55 to 150 ć TL 300 ć ᕅ㓯ᴰ儈✺᧕⑙ᓖ Maximum Lead Temperature for Soldering Purposes *┿ᶱ⭥⍱⭡ᴰ儈㔃⑙䲀ࡦDrain current limited by maximum junction temperature  9HU ⭥⢩ᙗ ELECTRICAL CHARACTERISTICS 亩ⴞ Parameter ㅖਧ Symbol ⍻䈅ᶑԦ Tests conditions ᴰሿ Min ިර Typ ᴰབྷ Max অս Units ID=250μA, VGS=0V 650 - - V ID=250μA, referenced to 25ć - 0.67 - V/ć VDS=650V,VGS=0V, TC=25ć VDS=520V, TC=125ć - - 10 100 μA μA - - ±100 μA 2.0 - 4.0 V VGS =10V , ID=5A - 0.75 0.9 Ω VDS = 40V, ID=5.0A˄note 4˅ - 5.7 - S - 1350 - - 150 - - 10 - - 23 - ns - 69 - ns - 144 - ns - 77 - ns - 29 - nC - 6.8 - nC - 10.3 - nC - - 10 A - - 40 A - - 1.4 V - 360 - ns - 3.3 - μC ‫ޣ‬ᘱ⢩ᙗ Off –Characteristics ┿ˉⓀࠫク⭥঻ Drain-Source Voltage ࠫク⭥঻⑙ᓖ⢩ᙗ Breakdown Voltage Temperature Coefficient 䴦ḵ঻л┿ᶱ┿⭥⍱ Zero Gate Voltage Drain Current ḵᶱփ┿⭥⍱ Gate-body leakage current BVDSS ΔBVDSS/Δ TJ IDSS IGSS˄F/R˅ VDS=0V, VGS =±30V - 䙊ᘱ⢩ᙗ On-Characteristics 䰸٬⭥঻ Gate Threshold Voltage 䶉ᘱሬ䙊⭥䱫 Static Drain-Source On-Resistance ↓ੁ䐘ሬ Forward Transconductance VGS(th) RDS(ON) gfs VDS = VGS , ID=250μA ࣘᘱ⢩ᙗ Dynamic Characteristics 䗃‫⭥ޕ‬ᇩ Ciss Input capacitance VDS=25V, 䗃ࠪ⭥ᇩ Coss VGS =0V, Output capacitance f=1.0MHz ৽ੁՐ䗃⭥ᇩ Crss Reverse transfer capacitance ᔰ‫ޣ‬⢩ᙗ Switching Characteristics ᔦ䘏ᰦ䰤 td(on) Turn-On delay time VDS=325V, кॷᰦ䰤 tr ID=10A, Turn-On rise time RG=25Ω ᔦ䘏ᰦ䰤 td(off) ˄note 4ˈ5˅ Turn-Off delay time л䱽ᰦ䰤 tf Turn-Off Fall time ḵᶱ⭥㦧ᙫ䟿 Qg Total Gate Charge VDS =520V , ID=10A , ḵˉⓀ⭥㦧 Qgs VGS =10V Gate-Source charge ˄note 4ˈ5˅ ḵˉ┿⭥㦧 Qgd Gate-Drain charge ┿ˉⓀҼᶱ㇑⢩ᙗ৺ᴰབྷ仍ᇊ٬ Drain-Source Diode Characteristics and Maximum Ratings ↓ੁᴰབྷ䘎㔝⭥⍱ Maximum Continuous Drain -Source IS Diode Forward Current ↓ੁᴰབྷ㜹ߢ⭥⍱ Maximum Pulsed Drain-Source Diode ISM Forward Current ↓ੁ঻䱽 VSD VGS=0V, IS=10A Drain-Source Diode Forward Voltage ৽ੁᚒ༽ᰦ䰤 trr VGS=0V, Reverse recovery time IS=10A ,dIF/dt=100A/μs (note ৽ੁᚒ༽⭥㦧 4) Qrr Reverse recovery charge  9HU pF ✝⢩ᙗ THERMAL CHARACTERISTIC 亩ⴞ Parameter 㔃ࡠ㇑༣Ⲵ✝䱫 Thermal Resistance, Junction to Case 㔃ࡠ⧟ຳⲴ✝䱫 Thermal Resistance, Junction to Ambient ㅖਧ অս FHP10N65A FHF10N65A Rth(j-c) 0.8 2.5 ć/W Rth(j-A) 62.5 62.5 ć/W Symbol Unit ⌘䟺˖ Notes: 1˖㜹ߢᇭᓖ⭡ᴰ儈㔃⑙䲀ࡦ 2˖L=10mH, IAS=10A, VDD=48V, RG=25 Ω,䎧࿻㔃⑙ TJ=25ć 3˖ISD ≤10A,di/dt ≤300A/μs,VDD≤BVDSS,䎧࿻㔃⑙ TJ=25ć 4˖㜹ߢ⍻䈅˖㜹ߢᇭᓖ ≤300μs,ঐオ∄≤2ˁ 5˖สᵜоᐕ֌⑙ᓖᰐ‫ޣ‬ 1˖Pulse width limited by maximum junction temperature 2˖L=10mH, ID=10A, VDD=48V, RG=25 Ω,Start TJ=25ć. 3˖ISD ≤10A,di/dt ≤300A/μs,VDD≤BVDSS, Starting TJ=25ć 4˖Pulse Test˖Pulse Width ≤300μs,Duty Cycle≤2ˁ 5˖Essentially independent of operating temperatur  9HU ⢩ᙗᴢ㓯 ELECTRICAL CHARACTERISTICS (curves)     9HU  ⢩ᙗᴢ㓯 ELECTRICAL CHARACTERISTICS (curves)                                9HU  ঠ䇠 Marking ⭏ӗᢩ⅑ԓ⸱ ASSEMMBLY LOT CODE 伎㲩LOGO FEIHONG LOGO ӗ૱ԓ⸱ PRODUCT CODE A FHP10N65 ẓս GRANDING CODE ӗ૱රਧ PART.NO 伎㲩LOGO FEIHONG LOGO ӗ૱ԓ⸱ PRODUCT CODE ⭏ӗᢩ⅑ԓ⸱ ASSEMMBLY LOT CODE A )+)1 FHF10N65 ẓս GRANDING CODE ӗ૱රਧ PART.NO  9HU ཆᖒቪረ˖ Package Dimension˖ TO-220 ',0 $ $ $ % & & ' ( ) * + - . 0 1 3 4 6 7 8 ',$ 0,//,0(7(56 f f f f f f f f f f f f f f 7\SLFDO f f f f f ᇭ f ␡ 0$; ˄Units˖PP˅  9HU ཆᖒቪረ˖ Package Dimension˖ TO-220F ',0 0,//,0(7(56 $ f $ f $ f $ f % f % f % f % f & f & f & f ' 7\SLFDO ' ˄0$;˅ ' f ( f ( f ( he ( f ( f ˄UnitsPP˅  9HU
FHP10N65A 价格&库存
很抱歉,暂时无法提供与“FHP10N65A”相匹配的价格&库存,您可以联系我们找货
