FHC7030-2R0M
FHC7030-2R0M
    KOHER(科或)
    SMD,7x6.7mm
    2UH ±20% 9A 停产
FHC7030-2R0M 数据手册
FHC Series SMD Flat Wire High Current Inductor Size 7030 CHARACTERISTICS ■ ■ ■ ■ Low Rdc with flat wire design Low cooper losses at high frequency Magnetic shielded structure Quantity: 1500pcs APPLICATION ■ ■ High current DC/DC converter LC filter Dimensions: [mm] Land Pattern: [mm] 3.0±0.3 2.5 2.5 5.0 7.2 0-0.2 Marking 6.9±0.3 7.0±0.5 1.2±0.3 1.8±0.3 6.9±0.3 Electrical Properties: Part No Inductance (μH) Tolerance Temperature Rise Current (A) Saturation Current (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) FHC7030-R13M 0.13 ±20% 22.0 48.0 0.91 1.00 FHC7030-R22M 0.22 ±20% 18.0 40.0 1.80 1.98 FHC7030-R52M 0.52 ±20% 14.0 20.0 3.70 4.07 FHC7030-R95M 0.95 ±20% 11.0 13.0 6.20 6.82 FHC7030-1R2M 1.20 ±20% 8.50 13.0 8.60 9.46 FHC7030-1R5M 1.50 ±20% 7.50 12.0 12.7 14.0 FHC7030-2R0M 2.00 ±20% 6.50 9.00 14.2 15.6 FHC7030-3R3M 3.30 ±20% 6.00 7.00 18.6 21.0 Operating Temperature : -40 ℃ to +125℃ Temperature Rise Current: the actual value of DC current when the temperature rise is ΔT50℃ Saturation Current that will cause initial inductance to drop approximately 30% KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Typical Electrical Characteristics: 0.15 0.24 60 0.60 60 0.13 50 0.20 50 0.50 50 0.10 40 0.16 40 0.40 40 0.08 30 0.12 30 0.30 30 0.05 20 0.08 20 0.20 20 0.03 10 0.04 10 0.10 10 24.0 36.0 48.0 0.00 0.0 0 60.0 11.0 DC CURRENT(A) 33.0 44.0 0.00 0.0 0 55.0 6.0 DC CURRENT(A) FHC7030-R95M 18.0 24.0 0 30.0 FHC7030-1R5M 2.10 70 0.12 60 0.12 60 1.80 60 0.10 50 0.10 50 1.50 50 0.08 40 0.06 30 0.04 20 0.02 10 4.0 8.0 12.0 16.0 40 30 0.04 20 0.02 10 0.00 0.0 0 20.0 4.0 DC CURRENT(A) 16.0 0 20.0 3.60 60 1.50 50 3.00 50 1.20 40 2.40 40 0.90 30 1.80 30 0.60 20 1.20 20 0.30 10 0.60 10 4.8 7.2 9.6 0 12.0 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com INDUCTANCE(μH) 70 60 2.4 0.60 20 0.30 10 3.2 6.4 9.6 12.8 0 16.0 FHC7030-3R3M 70 0.00 0.0 30 DC CURRENT(A) 4.20 TEMP·RISE(ºC) 1.80 12.0 40 0.00 0.0 DC CURRENT(A) FHC7030-2R0M 2.10 8.0 1.20 0.90 0.00 0.0 2.0 4.0 6.0 8.0 TEMP·RISE(ºC) 0.00 0.0 0.08 0.06 INDUCTANCE(μH) 70 TEMP·RISE(ºC) 0.14 INDUCTANCE(μH) 70 12.0 DC CURRENT(A) FHC7030-1R2M 0.14 TEMP·RISE(ºC) INDUCTANCE(μH) 22.0 TEMP·RISE(ºC) 12.0 INDUCTANCE(μH) 70 60 TEMP·RISE(ºC) 0.70 INDUCTANCE(μH) 70 0.00 0.0 INDUCTANCE(μH) FHC7030-R52M 0.28 TEMP·RISE(ºC) FHC7030-R22M 70 TEMP·RISE(ºC) INDUCTANCE(μH) FHC7030-R13M 0.18 0 10.0 DC CURRENT(A) www.kohergroup.com
FHC7030-2R0M 价格&库存
很抱歉,暂时无法提供与“FHC7030-2R0M”相匹配的价格&库存,您可以联系我们找货
