ACMA4532-110Y
ACMA4532-110Y
    KOHER(科或)
ACMA4532-110Y 数据手册
ACMA Series Common Mode Filters For Automotive Signal Line Size 4532 FEATURES ■ ■ Common mode filters for Signal Line 0 ■ ■ ■ Compliant with AEC-Q200 Quan�ty: 500pcs APPLICATION ■ CAN-BUS, FlexRay system Dimensions: [mm] 0.75±0.2 0.6±0.2 1.7 3.6 2.8±0.2 4.5±0.2 0.85±0.2 Land Pattern: [mm] 3.4 5.0 0.75±0.2 0.6±0.2 0.85±0.2 3.2±0.2 Electrical Properties: Part No Z @ 10 MHz Min. (Ω) Z @ 10 MHz L @ 100kHz/0.1V Typ. +50%/-30% (Ω) (μH) IR Max. (mA) RDC Max. (Ω) VDC (Volts) IR (MΩ) ACMA4532-110Y 300 600 11 360 0.6 50 10 ACMA4532-220Y 500 1200 22 310 1.0 50 10 ACMA4532-510Y 1000 ACMA4532-101Y 2000 2800 51 230 1.0 50 10 5800 100 200 2.0 50 10 IR KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Typical Electrical Characteristics: ACMA4532-110Y 10000 10000 100 1000 10 0.1 1 10 100 1000 10000 FREQUENCY(MHz) 100000 0 Common Mode 1 Common Mode 10000 100 10 Normal Mode ACMA4532-510Y 100000 0 IMPEDANCE(Ω) 1000 IMPEDANCE(Ω) IMPEDANCE(Ω) Common Mode 1 ACMA4532-220Y 100000 0 1000 100 10 Normal Mode Normal Mode 1 1 10 100 1000 FREQUENCY(MHz) 10000 1 10 100 1000 10000 FREQUENCY(MHz) ACMA4532-101Y Common Mode IMPEDANCE(Ω) 10000 1000 100 10 1 Normal Mode 1 10 100 1000 10000 FREQUENCY(MHz) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com
ACMA4532-110Y 价格&库存
很抱歉,暂时无法提供与“ACMA4532-110Y”相匹配的价格&库存,您可以联系我们找货
