FHC1365-R82M
FHC1365-R82M
    KOHER(科或)
    SMD,12.8x13mm
    820NH ±20% 35A 停产
FHC1365-R82M 数据手册
FHC Series SMD Flat Wire High Current Inductor Size 1365 CHARACTERISTICS ■ ■ ■ ■ Low Rdc with flat wire design Low cooper losses at high frequency Magnetic shielded structure Quantity:400pcs APPLICATION ■ ■ High current DC/DC converter LC filter Dimensions: [mm] 6.2±0.3 5.5 4.5 10.5 0-0.2 Marking 2.0 +0.5/-1.0 12.8±0.5 3.0±1.0 12.8±0.5 3.0±1.0 Land Pattern: [mm] 13.3 Electrical Properties: Tolerance Temperature Rise Current (A) Saturation Current (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) 0.20 ±20% 32.0 65.0 0.35 0.40 FHC1365-R47M 0.47 ±20% 30.0 50.0 0.67 0.85 FHC1365-R82M 0.82 ±20% 27.0 35.0 0.90 1.10 FHC1365-1R3M 1.30 ±20% 25.0 25.0 1.80 2.00 FHC1365-2R0M 2.00 ±20% 23.0 22.0 2.60 2.90 FHC1365-2R8M 2.80 ±20% 20.0 17.5 3.30 3.60 FHC1365-3R7M 3.70 ±20% 17.0 16.0 4.90 5.40 FHC1365-4R7M 4.70 ±20% 13.0 15.0 7.00 7.70 FHC1365-6R0M 6.00 ±20% 12.0 14.0 8.40 9.20 FHC1365-7R3M 7.30 ±20% 13.0 12.0 5.90 6.50 FHC1365-9R2M 9.20 ±20% 12.0 10.5 7.80 8.60 FHC1365-110M 11.0 ±20% 11.0 9.50 9.10 10.0 FHC1365-130M 13.0 ±20% 10.0 9.00 11.2 12.3 Part No Inductance (μH) FHC1365-R20M KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com www.kohergroup.com Tolerance Temperature Rise Current (A) Saturation Current (A) DC Resistance Typ. (mΩ) DC Resistance Max. (mΩ) 15.0 ±20% 9.00 8.00 14.8 16.3 FHC1365-180M 18.0 ±20% 7.50 7.50 22.0 24.2 FHC1365-220M 22.0 ±20% 6.00 6.50 24.7 27.2 FHC1365-330M 33.0 ±20% 5.50 5.50 30.5 33.6 Part No Inductance (μH) FHC1365-150M Test Frequency : Inductance : 100KHz /0.1V. Operating Temperature : -40 ℃ to +125℃ Temperature Rise Current: the actual value of DC current when the temperature rise is ΔT50℃ Saturation Current that will cause initial inductance to drop approximately 30% Typical Electrical Characteristics: 0.20 40 0.48 40 0.8 40 0.15 30 0.36 30 0.6 30 0.10 20 0.24 20 0.4 20 0.05 10 0.12 10 0.2 10 22.0 33.0 44.0 55.0 0.00 0.0 0 66.0 10.0 DC CURRENT(A) 30.0 40.0 0.0 0.0 0 50.0 7.0 14.0 21.0 0 35.0 28.0 DC CURRENT(A) DC CURRENT(A) FHC1365-1R3M FHC1365-2R0M FHC1365-2R8M 50 3.5 50 1.6 40 2.0 40 2.8 40 1.2 30 1.5 30 2.1 30 0.8 20 1.0 20 1.4 20 0.4 10 0.5 10 0.7 10 0.0 0.0 5.0 10.0 15.0 20.0 0.0 0 25.0 0.0 5.0 10.0 15.0 20.0 INDUCTANCE(μH) 2.5 TEMP·RISE(ºC) 50 INDUCTANCE(μH) 2.0 TEMP·RISE(ºC) 0.0 0 25.0 0.0 4.0 DC CURRENT(A) DC CURRENT(A) FHC1365-3R7M 8.0 12.0 16.0 0 20.0 DC CURRENT(A) FHC1365-4R7M FHC1365-6R0M 6.0 50 7.5 50 3.2 40 4.8 40 6.0 40 2.4 30 3.6 30 4.5 30 1.6 20 2.4 20 3.0 20 0.8 10 1.2 10 1.5 10 0.0 0.0 4.0 8.0 12.0 0 16.0 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com INDUCTANCE(μH) 50 TEMP·RISE(ºC) 4.0 0.0 0.0 3.0 6.0 9.0 DC CURRENT(A) 12.0 0 15.0 INDUCTANCE(μH) INDUCTANCE(μH) 20.0 TEMP·RISE(ºC) 11.0 INDUCTANCE(μH) 50 TEMP·RISE(ºC) 1.0 INDUCTANCE(μH) 50 0.00 0.0 INDUCTANCE(μH) FHC1365-R82M 0.60 TEMP·RISE(ºC) FHC1365-R47M 50 TEMP·RISE(ºC) INDUCTANCE(μH) FHC1365-R20M 0.25 0.0 0.0 7.0 14.0 21.0 28.0 0 35.0 DC CURRENT(A) www.kohergroup.com Typical Electrical Characteristics: 50 6.4 40 12.0 40 12.0 40 4.8 30 9.0 30 9.0 30 3.2 20 6.0 20 6.0 20 1.6 10 3.0 10 3.0 10 14.0 21.0 28.0 0.0 0.0 0 35.0 3.0 DC CURRENT(A) 0.0 0.0 0 12.0 9.0 3.0 6.0 9.0 0 12.0 DC CURRENT(A) DC CURRENT(A) FHC1365-130M FHC1365-150M FHC1365-180M 50 20.0 50 14.4 40 16.0 40 16.0 40 10.8 30 12.0 30 12.0 30 7.2 20 8.0 20 8.0 20 3.6 10 4.0 10 4.0 10 3.0 6.0 9.0 0 12.0 0.0 0.0 2.0 DC CURRENT(A) 4.0 6.0 8.0 FHC1365-220M 24.0 40 28.0 40 18.0 30 21.0 30 12.0 20 14.0 20 6.0 10 7.0 10 6.0 0 8.0 DC CURRENT(A) KOHER Electronic 4546 BATES DRIVE, YORBLINDA CA 92886 USA 714-325-4789 Contact@kohergroup.com INDUCTANCE(μH) 50 TEMP·RISE(ºC) 35.0 4.0 4.0 6.0 0 8.0 FHC1365-330M 50 2.0 2.0 DC CURRENT(A) DC CURRENT(A) 30.0 0.0 0.0 0.0 0.0 0 10.0 0.0 0.0 1.0 2.0 3.0 4.0 5.0 TEMP·RISE(ºC) 0.0 0.0 INDUCTANCE(μH) 20.0 TEMP·RISE(ºC) 50 INDUCTANCE(μH) 18.0 TEMP·RISE(ºC) INDUCTANCE(μH) 6.0 TEMP·RISE(ºC) 7.0 INDUCTANCE(μH) 15.0 TEMP·RISE(ºC) 50 0.0 0.0 INDUCTANCE(μH) FHC1365-110M 15.0 TEMP·RISE(ºC) FHC1365-9R2M 50 INDUCTANCE(μH) INDUCTANCE(μH) FHC1365-7R3M 8.0 0 6.0 DC CURRENT(A) www.kohergroup.com
FHC1365-R82M 价格&库存
很抱歉,暂时无法提供与“FHC1365-R82M”相匹配的价格&库存,您可以联系我们找货
