D
WIMA FKP 1
Polypropylene (PP) Capacitors for Pulse Applications with Metal Foil
Electrodes and Metallized Internal Series Connection in PCM 15 mm to 52.5 mm.
Capacitances from 100 pF to 4.7 mF. Rated Voltages from 400 VDC to 6000 VDC.
Special Features
Electrical Data
˜ Extremely high pulse duty
˜ Self-healing
˜ Internal series connection
˜ Very low dissipation factor
˜ Negative capacitance change
versus temperature
˜ According to RoHS 2011/65/EU
Typical Applications
For high pulse and high frequency
applications e.g.
˜ Switch mode power supplies
˜ Converters in drives and power
electronics
˜ Deflection systems in monitors
and TV-sets
˜ Electronic ballasts
Dielectric absorption: 0.05 %
Insulation resistance at +20+ C:
C T 0.1 mF: 1 x 10 5 M¸
C 0.1 mF: 30 000 sec (M¸ x mF)
Measuring voltage: 100 V/1 min.
Voltage derating:
A voltage derating factor of 1.35 % per K
must be applied from +85+ C for DC
voltages and from +75+ C for AC
voltages
Reliability:
Operational life 300 000 hours
Failure rate 1 fit (0.5 x U r and 40+ C)
PCM
4000 VDC
4000 VDC
6000 VDC
37.5
37.5
2 Ur
2 Ur
2 Ur
1.6 U r
1.6 U r
1.2 U r
Dissipation factors at +20+ C: tan d
Dielectric:
Polypropylene (PP) film
Capacitor electrodes:
Aluminium foil and double-sided metallized
plastic film
Internal construction:
Plastic film
Metal foil electrode
Electrode carrier
plastic film metallized
on both sides
Metal contact layer
(schoopage)
Terminating wire
Encapsulation:
Solvent-resistant, flame-retardant plastic
case with epoxy resin seal, UL 94 V-0
Terminations:
Tinned wire.
Marking:
Colour: Red. Marking: Black.
at f
1 kHz
10 kHz
100 kHz
C 0.1 mF 0.1
mF P C 1.0 mF C 1.0 mF
5 x10 -4
5 x 10-4
5 x 10-4
-4
-4
6 x10
6 x 10
10 x 10-4 –
Maximum pulse rise time: for pulses equal to the rated voltage
Capacitance max. pulse rise time V/msec at T A < 40) C
pF/mF
400 VDC 630 VDC 850 VDC 1000 VDC 1250 VDC 1600 VDC 2000 VDC 4000 VDC 6000 VDC
100
... 220
56000
56000
... 680
330
51000
56000
56000
56000
1000 ... 2200 29000 29000 29000 29000 29000 46000 51000 51000 51000
3300 ... 6800 9000 14000 27000 27000 29000 29000 29000 29000 29000
0.01 ... 0.022 9000 11000 11000 11000 11000 11000 13000 13000 13000
0.033 ... 0.068 9000 11000 11000 11000 11000 11000 11000 13000 13000
0.1 ... 0.22 7000 11000 11000 11000 11000 11000 11000 13000 13000
0.33 ... 0.68 6000 10000 11000 11000 11000 11000 11000 –
1.0 ... 2.2 5000 6600 8300 8300 9500 11000 –
3.3 ... 4.7 2500
Mechanical Tests
Pull test on pins:
d T 0.8 l: 10 N in direction of pins
d > 0.8 l: 20 N in direction of pins
according to IEC 60068-2-21
Vibration:
6 hours at 10 ... 2000 Hz and 0.75 mm
displacement amplitude or 10 g in
accordance with IEC 60068-2-6
Low air density:
1kPa = 10 mbar in accordance with
IEC 60068-2-13
Bump test:
4000 bumps at 390 m/sec 2
in accordance with IEC 60068-2-29
Packing
Available taped and reeled up to and
including case size 15 x 26 x 31.5 /
PCM 27.5 mm.
Detailed taping information and graphs
at the end of the catalogue.
For further details and graphs please
refer to Technical Information.
01.19
Construction
72
Capacitance range:
100 pF to 4.7 mF (E12-values on request)
Rated voltages:
400 VDC, 630 VDC, 850 VDC, 1000 VDC,
1250 VDC, 1600 VDC, 2000 VDC,
4000 VDC, 6000 VDC
Capacitance tolerances:
±20%, ±10%, ±5% (other tolerances are
available subject to special enquiry)
Operating temperature range:
–55+ C to +100+ C
Climatic test category:
55/100/56 in accordance with IEC
Test voltage: 2 sec
D
WIMA FKP 1
Continuation
General Data
Capacitance
1000
1500
2200
3300
4700
6800
W
pF 5
„ 5
„ 5
„ 5
„ 5
„ 5
400 VDC/250 VAC*
PCM**
Part number
H
L
11
11
11
11
11
11
18
18
18
18
18
18
15
15
15
15
15
15
W
FKP1G011004B_ _ _ _ _ _ 5
FKP1G011504B_ _ _ _ _ _ 5
FKP1G012204B_ _ _ _ _ _ 5
FKP1G013304B_ _ _ _ _ _ 5
FKP1G014704B_ _ _ _ _ _ 5
FKP1G016804B_ _ _ _ _ _ 6
630 VDC/400 VAC*
PCM**
Part number
H
L
11
11
11
11
11
12.5
18
18
18
18
18
18
15
15
15
15
15
15
FKP1J011004B_ _ _ _ _ _
FKP1J011504B_ _ _ _ _ _
FKP1J012204B_ _ _ _ _ _
FKP1J013304B_ _ _ _ _ _
FKP1J014704B_ _ _ _ _ _
FKP1J016804C_ _ _ _ _ _
0.01 mF 5 11 18 15 FKP1G021004B_ _ _ _ _ _ 7 14 18 15 FKP1J021004D_ _ _ _ _ _
5 14 26.5 22.5 FKP1J021005A_ _ _ _ _ _
0.015 „ 6 12.5 18 15 FKP1G021504C_ _ _ _ _ _ 8 15 18 15 FKP1J021504F_ _ _ _ _ _
6 15 26.5 22.5 FKP1J021505B_ _ _ _ _ _
0.022 „ 7 14 18 15 FKP1G022204D_ _ _ _ _ _ 7 16.5 26.5 22.5 FKP1J022205D_ _ _ _ _ _
5 14 26.5 22.5 FKP1G022205A_ _ _ _ _ _
0.033 „ 8 15 18 15 FKP1G023304F_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1J023305F_ _ _ _ _ _
6 15 26.5 22.5 FKP1G023305B_ _ _ _ _ _
0.047 „ 7 16.5 26.5 22.5 FKP1G024705D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1J024705H_ _ _ _ _ _
9 19 31.5 27.5 FKP1J024706A_ _ _ _ _ _
0.068 „
8.5 18.5 26.5 22.5 FKP1G026805F_ _ _ _ _ _
11 21 31.5 27.5 FKP1J026806B_ _ _ _ _ _
9 19 41.5 37.5 FKP1J026807A_ _ _ _ _ _
0.1 mF 10.5 20.5 26.5 22.5 FKP1G031005H_ _ _ _ _ _
9 19 31.5 27.5 FKP1G031006A_ _ _ _ _ _
0.15 „
11 21 31.5 27.5 FKP1G031506B_ _ _ _ _ _
0.22 „
13 24 31.5 27.5 FKP1G032206D_ _ _ _ _ _
11 22 41.5 37.5 FKP1G032207B_ _ _ _ _ _
0.33 „
13 24 41.5 37.5 FKP1G033307C_ _ _ _ _ _
0.47 „
17 29 41.5 37.5 FKP1G034707E_ _ _ _ _ _
0.68 „
19 32 41.5 37.5 FKP1G036807F_ _ _ _ _ _
13
11
13
15
24
22
24
26
19
32 41.5 37.5 FKP1J033307F_ _ _ _ _ _
39.5 41.5 37.5 FKP1J034707G_ _ _ _ _ _
45.5 41.5 37.5 FKP1J036807H_ _ _ _ _ _
1.0 mF 20 39.5 41.5 37.5 FKP1G041007G_ _ _ _ _ _
1.5 „
31 46 41.5 37.5 FKP1G041507I_ _ _ _ _ _
2.2 „
35 50 41.5 37.5 FKP1G042207J_ _ _ _ _ _
3.3 „
35 50 57 52.5 FKP1G043309F_ _ _ _ _ _
4.7 „
45 65 57 52.5 FKP1G044709J_ _ _ _ _ _
35
50 41.5 37.5 FKP1J041007J_ _ _ _ _ _
40
55 41.5 37.5 FKP1J041507K_ _ _ _ _ _
35
50 57 52.5 FKP1J041509F_ _ _ _ _ _
45
55 57 52.5 FKP1J042209H_ _ _ _ _ _
31.5
41.5
41.5
41.5
27.5
37.5
37.5
37.5
FKP1J031006D_ _ _ _ _ _
FKP1J031007B_ _ _ _ _ _
FKP1J031507C_ _ _ _ _ _
FKP1J032207D_ _ _ _ _ _
* AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur
** PCM = Printed circuit module = pin spacing
Dims. in mm.
The values of the WIMA FKP 4 range according to
main catalogue 2015 are still available on request.
Ionisation inception level in isolated cases may
be lower than admissible rated AC voltage.
Part number completeion:
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
00
D4
M
K
J
S
SD
Taped version see page 149.
Rights reserved to amend design data without prior notification.
01.19
Continuation page 74
73
D
WIMA FKP 14
Continuation
General Data
Capacitance
1000
1500
2200
3300
4700
6800
W
850 VDC/450 VAC*
L PCM**
Part number
H
pF 5 11
„ 5 11
„ 5 11
„ 5 11
„ 6 12.5
„ 7 14
18
18
18
18
18
18
15
15
15
15
15
15
W
1000 VDC/600 VAC*
L PCM**
Part number
H
FKP1M011004B_ _ _ _ _ _ 5 11
FKP1M011504B_ _ _ _ _ _ 5 11
FKP1M012204B_ _ _ _ _ _ 5 11
FKP1M013304B_ _ _ _ _ _ 5 11
FKP1M014704C_ _ _ _ _ _ 6 12.5
FKP1M016804D_ _ _ _ _ _ 7 14
18
18
18
18
18
18
15
15
15
15
15
15
FKP1O111004B_ _ _ _ _ _
FKP1O111504B_ _ _ _ _ _
FKP1O112204B_ _ _ _ _ _
FKP1O113304B_ _ _ _ _ _
FKP1O114704C_ _ _ _ _ _
FKP1O116804D_ _ _ _ _ _
0.01 mF 8 15 18 15 FKP1M021004F_ _ _ _ _ _ 8 15 18 15 FKP1O121004F_ _ _ _ _ _
6 15 26.5 22.5 FKP1M021005B_ _ _ _ _ _
6 15 26.5 22.5 FKP1O121005B_ _ _ _ _ _
0.015 „ 6 15 26.5 22.5 FKP1M021505B_ _ _ _ _ _ 6 15 26.5 22.5 FKP1O121505B_ _ _ _ _ _
0.022 „
8.5 18.5 26.5 22.5 FKP1M022205F_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1O122205F_ _ _ _ _ _
0.033 „
10.5 20.5 26.5 22.5 FKP1M023305H_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1O123305H_ _ _ _ _ _
9 19 31.5 27.5 FKP1M023306A_ _ _ _ _ _ 9 19 31.5 27.5 FKP1O123306A_ _ _ _ _ _
0.047 „
11 21 31.5 27.5 FKP1M024706B_ _ _ _ _ _ 11 21 31.5 27.5 FKP1O124706B_ _ _ _ _ _
0.068 „
13 24 31.5 27.5 FKP1M026806D_ _ _ _ _ _ 13 24 31.5 27.5 FKP1O126806D_ _ _ _ _ _
11 22 41.5 37.5 FKP1M026807B_ _ _ _ _ _
11 22 41.5 37.5 FKP1O126807B_ _ _ _ _ _
0.1
0.15
0.22
0.33
0.47
0.68
mF
1.0 mF
1.5 „
2,2 „
13
15
19
35
24
26
32
39.5
46
50
41.5
41.5
41.5
41.5
41.5
41.5
37.5
37.5
37.5
37.5
37.5
37.5
FKP1M031007C_ _ _ _ _ _ 13 24 41.5 37.5 FKP1O131007C_ _ _ _ _ _
FKP1M031507D_ _ _ _ _ _ 15 26 41.5 37.5 FKP1O131507D_ _ _ _ _ _
FKP1M032207F_ _ _ _ _ _ 19 32 41.5 37.5 FKP1O132207F_ _ _ _ _ _
FKP1M033307G_ _ _ _ _ _ 20 39.5 41.5 37.5 FKP1O133307G_ _ _ _ _ _
FKP1M034707I_ _ _ _ _ _ 31 46 41.5 37.5 FKP1O134707I_ _ _ _ _ _
FKP1M036807J_ _ _ _ _ _ 35 50 41.5 37.5 FKP1O136807J_ _ _ _ _ _
40
35
45
45
55
50
55
65
41.5
57
57
57
37.5
52.5
52.5
52,5
FKP1M041007K_ _ _ _ _ _
FKP1M041009F_ _ _ _ _ _
FKP1M041509H_ _ _ _ _ _
FKP1M042209J_ _ _ _ _ _
40
35
45
45
55
50
55
65
41.5
57
57
57
37.5
52.5
52.5
52,5
FKP1O141007K_ _ _ _ _ _
FKP1O141009F_ _ _ _ _ _
FKP1O141509H_ _ _ _ _ _
FKP1O142209J_ _ _ _ _ _
New range
Part number completion:
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
Dims. in mm.
00
D4
M
K
J
S
SD
2-pin version
4-pin version
P d
W PCM b P d c
PCM
0.8 15 - 27.5
1.0 37.5
pin
pin
c
pin
c
17
19
31
35
40
35
45
37.5 10
37.5 10
37.5 12.5
37.5 12.5
37.5 20
37.5 20
37.5 20
52.5 20
52.5 20
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.2 0.8
1.2 0.8
01.19
Continuation page 75
74
D
WIMA FKP 14
Continuation
General Data
Capacitance
100
150
220
330
470
680
W
H
1250 VDC/600 VAC*
L PCM**
Part number
W
H
pF 5 11
„ 5 11
„ 5 11
„ 5 11
„ 5 11
„ 5 11
1600 VDC/650 VAC*
L PCM**
Part number
18
18
18
18
18
18
15
15
15
15
15
15
FKP1T001004B_ _ _ _ _ _
FKP1T001504B_ _ _ _ _ _
FKP1T002204B_ _ _ _ _ _
FKP1T003304B_ _ _ _ _ _
FKP1T004704B_ _ _ _ _ _
FKP1T006804B_ _ _ _ _ _
1000 pF
5 11 18 15 FKP1R011004B_ _ _ _ _ _ 6 12.5 18 15 FKP1T011004C_ _ _ _ _ _
5 14 26.5 22.5 FKP1T011005A_ _ _ _ _ _
1500 „
5 11 18 15 FKP1R011504B_ _ _ _ _ _ 7 14 18 15 FKP1T011504D_ _ _ _ _ _
5 14 26.5 22.5 FKP1T011505A_ _ _ _ _ _
2200 „
5 11 18 15 FKP1R012204B_ _ _ _ _ _ 8 15 18 15 FKP1T012204F_ _ _ _ _ _
5 14 26.5 22.5 FKP1T012205A_ _ _ _ _ _
3300 „
6 12.5 18 15 FKP1R013304C_ _ _ _ _ _ 6 15 26.5 22.5 FKP1T013305B_ _ _ _ _ _
4700 „
7 14 18 15 FKP1R014704D_ _ _ _ _ _ 7 16.5 26.5 22.5 FKP1T014705D_ _ _ _ _ _
6800 „
8 15 18 15 FKP1R016804F_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1T016805F_ _ _ _ _ _
5 14 26.5 22.5 FKP1R016805A_ _ _ _ _ _
0.01
0.015
0.022
0.033
0.047
0.068
mF
7 16.5 26.5 22.5 FKP1R021005D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1T021005H_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1R021505F_ _ _ _ _ _ 11 21 31.5 27.5 FKP1T021506B_ _ _ _ _ _
10.5 20.5 26.5 22.5 FKP1R022205H_ _ _ _ _ _ 11 21 31.5 27.5 FKP1T022206B_ _ _ _ _ _
11 21 31.5 27.5 FKP1R023306B_ _ _ _ _ _ 13 24 31.5 27.5 FKP1T023306D_ _ _ _ _ _
9 19 41.5 37.5 FKP1R023307A_ _ _ _ _ _ 13 24 41.5 37.5 FKP1T023307C_ _ _ _ _ _
13 24 31.5 27.5 FKP1R024706D_ _ _ _ _ _ 13 24 41.5 37.5 FKP1T024707C_ _ _ _ _ _
11 22 41.5 37.5 FKP1R024707B_ _ _ _ _ _
11 22 41.5 37.5 FKP1R026807B_ _ _ _ _ _ 15 26 41.5 37.5 FKP1T026807D_ _ _ _ _ _
mF
15
17
19
24
31
40
26
29
32
45.5
46
55
41.5
41.5
41.5
41.5
41.5
41.5
37.5
37.5
37.5
37.5
37.5
37.5
FKP1R031007D_ _ _ _ _ _ 17 29 41.5 37.5
FKP1R031507E_ _ _ _ _ _ 20 39.5 41.5 37.5
FKP1R032207F_ _ _ _ _ _ 24 45.5 41.5 37.5
FKP1R033307H_ _ _ _ _ _ 31 46 41.5 37.5
FKP1R034707I_ _ _ _ _ _ 40 55 41.5 37.5
FKP1R036807K_ _ _ _ _ _ 35 50 57 52.5
FKP1T031007E_ _ _ _ _ _
FKP1T031507G_ _ _ _ _ _
FKP1T032207H_ _ _ _ _ _
FKP1T033307I_ _ _ _ _ _
FKP1T034707K_ _ _ _ _ _
FKP1T036809F_ _ _ _ _ _
1.0 mF
1.5 „
35
45
50
65
57
57
52.5
52.5
FKP1R041009F_ _ _ _ _ _ 45 55 57 52.5
FKP1R041509J_ _ _ _ _ _
FKP1T041009H_ _ _ _ _ _
0.1
0.15
0.22
0.33
0.47
0.68
Dims. in mm.
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
00
D4
M
K
J
S
SD
01.19
Continuation page 76
75
D
WIMA FKP 14
Continuation
General Data
Capacitance
W
2000 VDC/700 VACZ*
L PCM**
Part number
H
W
4000 VDC/700 VAC*
L PCM**
Part number
H
100
150
220
330
470
680
pF
5 11 18 15
5 11 18 15
5 11 18 15
6 12.5 18 15
6 12.5 18 15
6 12.5 18 15
1000
1500
2200
3300
4700
6800
pF
7 14 18 15 FKP1U011004D_ _ _ _ _ _
5 14 26.5 22.5 FKP1X011005A_ _ _ _ _ _
5 14 26.5 22.5 FKP1U011005A_ _ _ _ _ _
6 15 26.5 22.5 FKP1U011505B_ _ _ _ _ _ 7 16.5 26.5 22.5 FKP1X011505D_ _ _ _ _ _
7 16.5 26.5 22.5 FKP1U012205D_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1X012205F_ _ _ _ _ _
7 16.5 26.5 22.5 FKP1U013305D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1X013305H_ _ _ _ _ _
8.5 18.5 26.5 22.5 FKP1U014705F_ _ _ _ _ _ 11 21 31.5 27.5 FKP1X014706B_ _ _ _ _ _
10.5 20.5 26.5 22.5 FKP1U016805H_ _ _ _ _ _ 13 24 31.5 27.5 FKP1X016806D_ _ _ _ _ _
FKP1U001004B_ _ _ _ _ _
FKP1U001504B_ _ _ _ _ _
FKP1U002204B_ _ _ _ _ _
FKP1U003304C_ _ _ _ _ _
FKP1U004704C_ _ _ _ _ _
5 14 26.5 22.5 FKP1X004705A_ _ _ _ _ _
FKP1U006804C_ _ _ _ _ _ 5 14 26.5 22.5 FKP1X006805A_ _ _ _ _ _
0.01
0.015
0.022
0.033
0.047
0.068
mF
11 21 31.5 27.5 FKP1U021006B_ _ _ _ _ _ 15 26 31.5 27.5 FKP1X021006F_ _ _ _ _ _
13 24 31.5 27.5 FKP1U021506D_ _ _ _ _ _ 13 24 41.5 37.5 FKP1X021507C_ _ _ _ _ _
15 26 31.5 27.5 FKP1U022206F_ _ _ _ _ _ 17 29 41.5 37.5 FKP1X022207E_ _ _ _ _ _
13 24 41.5 37.5 FKP1U022207C_ _ _ _ _ _
13 24 41.5 37.5 FKP1U023307C_ _ _ _ _ _ 20 39.5 41.5 37.5 FKP1X023307G_ _ _ _ _ _
17 29 41.5 37.5 FKP1U024707E_ _ _ _ _ _ 24 45.5 41.5 37.5 FKP1X024707H_ _ _ _ _ _
19 32 41.5 37.5 FKP1U026807F_ _ _ _ _ _ 31 46 41.5 37.5 FKP1X026807I_ _ _ _ _ _
0.1
0.15
0.22
0.33
0.47
0.68
mF
20 39.5 41.5 37.5
24 45.5 41.5 37.5
35 50 41.5 37.5
40 55 41.5 37.5
45 55 57 52.5
45 65 57 52.5
FKP1U031007G_ _ _ _ _ _ 35 50 41.5 37.5 FKP1X031007J_ _ _ _ _ _
FKP1U031507H_ _ _ _ _ _ 40 55 41.5 37.5 FKP1X031507K_ _ _ _ _ _
FKP1U032207J_ _ _ _ _ _ 45 55 57 52.5 FKP1X032209H_ _ _ _ _ _
FKP1U033307K_ _ _ _ _ _
FKP1U034709H_ _ _ _ _ _
FKP1U036809J_ _ _ _ _ _
Dims. in mm.
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
00
D4
M
K
J
S
SD
2-pin version
4-pin version
P d
W PCM b P d c
PCM
0.8 15 - 27.5
1.0 37.5
pin
pin
c
pin
c
17
19
31
35
40
35
45
37.5 10
37.5 10
37.5 12.5
37.5 12.5
37.5 20
37.5 20
37.5 20
52.5 20
52.5 20
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.0 0.4
1.2 0.8
1.2 0.8
Rights reserved to amend design data without prior notificationn.
01.19
Continuation page 77
76
D
WIMA FKP 14
Continuation
General Data
Capacitance
W
6000 VDC/700 VAC*
L PCM**
Part number
H
Dims. in mm.
470 pF 5 14 26.5 22.5 FKP1Y004705A_ _ _ _ _ _
680 „ 5 14 26.5 22.5 FKP1Y006805A_ _ _ _ _ _
1000
1500
2200
3300
4700
6800
pF
5 14 26.5 22.5 FKP1Y011005A_ _ _ _ _ _
„ 7 16.5 26.5 22.5 FKP1Y011505D_ _ _ _ _ _
10.5 20.5 26.5 22.5 FKP1Y012205H_ _ _ _ _ _
„ 10.5 20.5 26.5 22.5 FKP1Y013305H_ _ _ _ _ _
11 21 31.5 27.5 FKP1Y014706B_ _ _ _ _ _
13 24 31.5 27.5 FKP1Y016806D_ _ _ _ _ _
0.01
0.015
0.022
0.033
0.047
0.068
mF 15 26 31.5 27.5 FKP1Y021006F_ _ _ _ _ _
13 24 41.5 37.5 FKP1Y021507C_ _ _ _ _ _
17 29 41.5 37.5 FKP1Y022207E_ _ _ _ _ _
20 39.5 41.5 37.5 FKP1Y023307G_ _ _ _ _ _
24 45.5 41.5 37.5 FKP1Y024707H_ _ _ _ _ _
31 46 41.5 37.5 FKP1Y026807I_ _ _ _ _ _
0.1 mF
0.15 „
0.22 „
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
35 50 41.5 37.5 FKP1Y031007J_ _ _ _ _ _
40 55 41.5 37.5 FKP1Y031507K_ _ _ _ _ _
45 55 57 52.5 FKP1Y032209H_ _ _ _ _ _
00
D4
M
K
J
S
SD
Urms
V
650
5
Urms
V
5
400
Permissible AC voltage
in relation to frequency
at 10) C internal temperature rise
(general guide).
47
0.
2
02
0.
2
1
102
pF
pF
22
00
630 VDC
0.
22
2
101
01
04
7
102
µF
5
µF
µF
2
5
104
2
105
5
22
0.
0.
2
0.
102
5
01
04
22
7
5 f 106
Hz
2
00
pF
µF
10
00
µF
µF
pF
47
00
pF
02
2
µF
0.
1
µF
0.
1000 VDC
0.
02
1
102
µF
2
2
5
104
2
10
2 0p
pF 200 F
pF
0.
01
µF
0.
04
7
0.
µF
22
µF
5
400 VDC
2
101
2
5
104
2
5
105
2
5 f 106
Hz
00
2
00
pF
pF
µF
104
2
5
105
2
5 f 106
Hz
10
47
22
pF
pF
0.0
15 0 pF
22
00
µF
p
0.0
1µ F
F
0.0
68
µF
104
2
5
105
2
2
102
5
2000 VDC
04
0.
5
22
1250 VDC
01
7
103
2
5
Urms
V 700
5
00
µF
pF
µF
00
47 pF
02 0 p
F
2
µF
0.
102
5
µF
5 f 106
Hz
22 470
0. 0 p pF
01
F
µF
10
2
22
0.
0.
102
4000 VDC
6000 VDC
2
2
101
5
101
103
2
5
104
2
5
105
2
5 f 106
Hz
103
2
5
104
2
5
105
2
5 f 106
Hz
01.19
103
µF
5 f 106
Hz
2
10
47
02
1
00
105
5
0.
47
µF
2
101
103
0.
0.
103
Urms
V 700
5
2
Urms
V
600
5
250
2
1600 VDC
2
2
Urms
V
5
00
101
103
Urms
V
600
5
101
02
2
pF
0.
0.
5
47
0.
00
µF
µF
10 100
00
pF 470
pF
pF
2
0.
µF
22
1
00
µF
p
0.
01 F
0.
04
µF
7
µF
10
00
77
D
Recommendation for Processing
and Application of
Through-Hole Capacitors
Soldering Process
Internal temperature of the capacitor must
be kept as follows:
Polyester:
preheating: T max. T 125° C
soldering: T max. T 135° C
Polypropylene: preheating: Tmax. T 100° C
soldering: T max. T 110° C
Single wave soldering
Soldering bath temperature: T P 260 ° C
Dwell time:
t P 5 sec
Double wave soldering
Dwell time:
St P 5 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
WIMA Quality and Environmental Philosophy
ISO 9001:2015 Certification
ISO 9001:2015 is an international basic
standard of quality assurance systems
for all branches of industry. The approval
according to ISO 9001:2015 of our factories by the infaz (Institut für Auditierung und
Zertifizierung) certifies that organisation,
equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards.
WIMA WPCS
The WIMA Process Control System (WPCS)
is a quality surveillance and optimization
system developed by WIMA. WPCS is a
major part of the quality-oriented WIMA
production. Points of application during
production process:
All WIMA capacitors, irrespective of
whether through-hole devices or SMD,
are made of environmentally friendly
materials. Neither during manufacture
nor in the product itself any toxic substances are used, e.g.
Lead
PCB
CFC
Hydrocarbon chloride
Chromium 6+
PBB/PBDE
Arsenic
Cadmium
Mercury
etc.
We merely use pure, recyclable materials
for packing our components, such as:
” carton
” cardboard
” adhesive tape made of paper
” polystyrene
We almost completely refrain from using
packing materials such as:
” adhesive tapes made of plastic
” metal clips
RoHS Compliance
According to the RoHS Directive 2011/65/EU
as amended from time to time certain hazardous substances like e.g. lead, cadmium,
mercury must not be used any longer in
electronic equipment as of July 1st, 2006. For
the sake of the environment WIMA has refraind from using such substances since years
already.
WIMA Kondensatoren sind bleifrei
konform RoHS 2011/65/EU
WIMA capacitors are lead free
in accordance with RoHS 2011/65/EU
Tape for lead-free WIMA capacitors
DIN EN ISO 14001:2004
WIMA’s environmental management has
been established in accordance with the
guidelines of DIN EN ISO 14001:2004 to
optimize the production processes with
regard to energy and resources.
01.19
” incoming material inspection
” metallization
” film inspection
” schoopage
” pre-healing
” pin attachment
” cast resin preparation/
encapsulation
” 100% final inspection
” Testing as per customer requirements
WIMA Environmental Policy
15
D
Typical Dimensions for
Taping Configuration
Vh
P
P2
Diagram 1:
PCM 2.5/5/7.5mm
W
W1
W0
H
H1
W2
P1
D0
d
P
t
F
P0
H1
P
P1
H
P1
d
d
F
P0
P2
Diagram 2: PCM 10/15 mm
Diagram 3: PCM 22.5 and 27.5*mm
*PCM 27.5 taping possible with two feed holes between components
Designation
Carrier tape width
Dimensions for Radial Taping
Symbol PCM 2.5 taping
W
P0
P2
F
PCM 5 taping
PCM 7.5 taping
PCM 10 taping*
PCM 15 taping*
PCM 22.5 taping
PCM 27.5 taping
18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
Hold-down tape width
W0 6.0
6.0
12.0
12.0
12.0
12.0
12.0
adhesive
tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape
Hole position
W1 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5
Hold-down tape position
W 2
Feed hole diameter
D0 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2
P
12.7 p1.0 12.7 p1.0 12.7 p1.0 25.4 p1.0 25.4 p1.0 38.1 p1.5 3*8.1 p1.5 or 50.8 p1.5
0.5 to 3.0 max.
Pitch of component
Feed hole pitch
P0 12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 p0.3
Feed hole centre
to pin
P1 5.1 p0.5 3.85 p0.7 2.6 p0.7 7.7 p0.7 5.2 p0.7 7.8 p0.7 5.3 p0.7
Hole centre to
component centre
P2 6.35 p1.3 6.35 p1.3 6.35 p1.3 12.7 p1.3 12.7 p1.3 19.05 p1.3 19.05 p1.3
Feed hole centre to bottom
H
edge of the component
cumulative pitch
error max.
1.0 mm/20 pitch
16.5 p0.3 16.5 p0.3 16.5 p0.5 16.5 p0.5 16.5 p0.5 16.5 p0.5 16.5 p0.5
18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5 18.5 p0.5
Feed hole centre to top
H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1
H
edge of the component 1
32.25 max.
32.25 max.
24.5 to 31.5
25.0 to 31.5
26.0 to 37.0
30.0 to 43.0
35.0 to 45.0
Pin spacing at
+0.8
F 2.5 p0.5 5.0 7.5 p0.8 10.0 p0.8 15 p0.8 22.5 p0.8 27.5 p0.8
upper edge of carrier tape –0.2
Pin diameter
d
0.4 p0.05 0.5 p0.05
Component alignment
Dh
p 2.0 max.
Total tape thickness
t
p 2.0 max.
+0.06 +0,06
+0,08 +0,08 +0.08
0.5 p0.05 or 0.6 –0.05 „ 0.5 p0.05 or 0.6 –0.05 0.8 –0.05 0.8 –0.05 0.8 –0.05
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
0.6 p0.2 0.6 p0.2 0.6 p0.2 0.6 p0.2 0.6 p0.2 0.6 p0.2 0.6 p0.2
ROLL/AMMO
Package
(see also page 150)
52 p2 depending on
P 360 max.
B p2 comp. dimensions
REEL P 30 p1 58
Unit
AMMO
52 p2 54 p2
500 max.
B 60 p2
REEL P 360 max. B 58 p2 or REEL PP 25
p1
P 30 p1 66 p2
68 p2
depending
on PCM and
component dimensions
see details page 151.
Dims in mm.
01.19
„ Diameter of pins see General Data.
Please clarify customer-specific deviations with the manufacturer.
* PCM 10 and PCM 15 can be crimped to PCM 7.5.
Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible
149
D
Types of Tape Packaging of
Capacitors for Automatic
Radial Insertion
˜ REEL Packaging
340 max.
30±1
25±1
360 max.
500 max.
˜ AMMO Packaging
340 max.
370 max.
˜ ROLL Packaging
34
0m
ax.
50 max.
50 max.
70 max.
ax
0 m ax.
34 0 m
49
B
BAR CODE (Labelling)
Labelling of package units in
plain text and with
alphanumerical Bar Code
BARCODE „Code 39”
Scanner decoding of
„ WIMA supplier number
„ Customer‘s P/O number
„ Customer‘s part number
„ WIMA confirmation number
„ WIMA part number
„ Lot number
„ Date code
„ Quantity
In addition part description of
article
capacitance value
rated voltage
dimensions
capacitance tolerance
packing
01.19
as well as gross weight and customer‘s
name are indicated in plain text.
150
D
Packing Quantities for Capacitors with
Radial Pins in PCM 2.5 mm to 22.5 mm
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
2.5
3
4
4.5
5
5.7
7.2
3
4
4
4
5
5
6
6
8
5
5
6
6
7
7
8
8
9
9
10
11
5
6
7
8
8.5
10
10.5
10.5
11
12
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
7
8.5
9
9.5
10.5
12.5
12.5
9
8.5
9
9.5
10
11
12
12.5
12
11
13
12.5
14
14
15
15
17
14
16
18
14
14
15
16.5
22
19
20.5
21
24
bulk
L
4.6
4.6
4.6
4.6
4.6
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
10
10
10
10.3
10.3
10.3
10.3
13
13.5
13
13
13.5
13
13
13
13
18
19
18
19
18
19
18
19
18
18
19
18
26.5
26.5
26.5
28
26.5
28
26.5
26.5
26.5
28
Codes
0B
0C
0D
0E
0F
1A
1B
1C
1D
1E
1F
1G
1H
1I
1J
1K
1L
1M
1N
2A
2B
2C
2D
2E
2F
2G
3A
FA
3C
3D
FB
3F
3G
3H
3I
4B
FC
4C
FD
4D
FE
4F
FF
4H
4J
FG
4M
5A
5B
5D
FH
5F
FI
5G
5H
5I
FJ
S
5000
5000
5000
5000
5000
5000
5000
5000
6000
4000
3500
4000
2500
2500
2500
2000
2000
1500
1000
5000
5000
4000
3500
3000
2000
1500
3000
3000
3000
3000
2000
3000
2400
2400
2000
2400
1000
2000
1000
1600
1000
1200
500
1200
900
500
1000
1200
1000
760
500
500
570*
594*
594*
561*
480*
Moulded versions.
01.19
* TPS (Tray-Packing-System). Plate versions may have different packing units.
Samples and pre-production needs on request.
pcs. per packing unit
REEL
AMMO
P 360
P 500
340 x 340
490 x 370
H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5
N
O
F
I
H
J
A
C
B
D
2200
2500
2800
2000
2300
2300
1500
1800
1800
1200
1500
1500
900
1200
1200
2200
2500
2800
2000
2300
2300
1600
2000
2000
1300
1500
1500
1300
1500
1500
1100
1400
1400
1000
1200
1200
1000
1200
1200
800
1000
1000
700
1000
1000
700
950
1000
600
800
800
600
800
800
500
600
640
2500
4400
2500
2200
4300
2300
4150
1700
3200
1700
3100
1500
2900
1400
2700
1300
2500
1300
1000
2200
1100
900
1800
1000
1100
2200
1900
900
1600
1450
900
1600
1450
900
1600
1400
700
1300
1200
700
1300
1200
550
1100
1000
550
1100
1000
400
800
740
600
1200
1150
600
1200
1200
500
1000
1000
500
1000
1000
450
900
850
450
900
850
400
800
740
400
800
740
350
700
650
350
700
650
300
650
590
300
600
540
800
770
700
640
600
550
500
480
480
450
420
380
400
360
400
360
380
350
350
310
ROLL
151
D
Radial Pins in PCM 27.5 mm to 52.5 mm
Size
PCM
REEL
AMMO
P 360
P 500
340 x 340
490 x 370
N
O
F
I
H
J
A
C
B
D
460/340*
420
380/280*
350
300
290
270
250
ROLL
bulk
W
9
11
13
13
15
15
17
17
H
19
21
24
25
26
26
29
34.5
32
39.5
L
31.5
31.5
31.5
33
31.5
33
31.5
31.5
33
31.5
Codes
6A
6B
6D
FK
6F
FL
6G
6I
FM
6J
S
567*
459*
378*
405*
324*
324*
198*
198*
162*
162*
37.5 mm
9
11
13
15
17
19
31
35
40
19
22
24
26
29
32
39.5
45.5
46
50
55
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
7A
7B
7C
7D
7E
7F
7G
7H
7I
7J
7K
441*
357*
294*
252*
154*
140*
126*
112*
84*
35*
28*
48.5 mm
19
23
27
33
37
31
34
37.5
48
54
56
56
56
56
56
8D
8E
8H
8J
8L
120*
80*
84*
25*
25*
45
45
50
55
65
57
57
57
57
57
9D
9E
9F
9H
9J
70*
60*
25*
20*
20*
52.5 mm
25
30
35
45
45
27.5 mm
* for 2-inch transport pitches.
Moulded versions.
01.19
Updated data on www.wima.com
152
D
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Version code (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Pin length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
01.19
Type description:
SMD-PET
= SMDT
SMD-PEN
= SMDN
SMD-PPS
= SMDI
FKP 02
= FKP0
MKS 02
= MKS0
FKS 2
= FKS2
FKP 2
= FKP2
FKS 3
= FKS3
FKP 3
= FKP 3
MKS 2
= MKS2
MKP 2
= MKP2
MKS 4
= MKS4
MKP 4C
= MKPC
MKP 4
= MKP4
MKP 10
= MKP1
FKP 1
= FKP1
MKP-X2
= MKX2
MKP-X1 R
= MKX1
MKP-Y2
= MKY2
MP 3-X2
= MPX2
MP 3-X1
= MPX1
MP 3-Y2
= MPY2
MP 3R-Y2
= MPRY
MKP 4F
= MKPF
Snubber MKP = SNMP
Snubber FKP
= SNFP
GTO MKP
= GTOM
DC-LINK MKP 3 = DCP3
DC-LINK MKP 4 = DCP4
DC-LINK MKP 4S = DCPS
DC-LINK MKP 5 = DCP5
DC-LINK MKP 6 = DCP6
DC-LINK HC
= DCHC
DC-LINK HY
= DCHY
63 VDC
Rated voltage:
50 VDC = B0
63 VDC = C0
100 VDC = D0
250 VDC = F0
400 VDC = G0
450 VDC = H0
520 VDC = H2
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
250 VAC = 0W
275 VAC = 1W
300 VAC = 2W
305 VAC = AW
350 VAC = BW
440 VAC = 4W
500 VAC = 5W
0.01 mF
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 mF = 2100
0.022 mF = 2220
0.047 mF = 2470
0.1 mF = 3100
0.22 mF = 3220
0.47 mF = 3470
= 4100
1 mF
2.2 mF = 4220
4.7 mF = 4470
= 5100
10 mF
= 5220
22 mF
= 5470
47 mF
100 mF = 6100
220 mF = 6220
1000 mF = 7100
1500 mF = 7150
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812 = KA
4.8 x 3.3 x 4 Size 1812 = KB
5.7 x 5.1 x 3.5 Size 2220 = QA
5.7 x 5.1 x 4.5 Size 2220 = QB
7.2 x 6.1 x 3 Size 2824 = TA
7.2 x 6.1 x 5 Size 2824 = TB
10.2 x 7.6 x 5 Size 4030 = VA
12.7 x 10.2 x 6 Size 5040 = XA
15.3 x 13.7 x 7 Size 6054 = YA
2.5 x 7 x 4.6 PCM 2.5 = 0B
3 x 7.5 x 4.6 PCM 2.5 = 0C
2.5 x 6.5 x 7.2 PCM 5 = 1A
3 x 7.5 x 7.2 PCM 5
= 1B
2.5 x 7 x 10 PCM 7.5
= 2A
3 x 8.5 x 10 PCM 7.5
= 2B
3 x 9 x 13 PCM 10
= 3A
4 x 9 x 13 PCM 10
= 3C
5 x 11 x 18 PCM 15
= 4B
6 x 12.5 x 18 PCM 15 = 4C
5 x 14 x 26.5 PCM 22.5 = 5A
6 x 15 x 26.5 PCM 22.5 = 5B
9 x 19 x 31.5 PCM 27.5 = 6A
11 x21 x 31.5 PCM 27.5 = 6B
9 x 19 x 41.5 PCM 37.5 = 7A
11 x 22 x 41.5 PCM 37.5 = 7B
19 x 31 x 56 PCM 48.5 = 8D
25 x 45 x 57 PCM 52.5 = 9D
Version code:
Standard
Version A1
Version A1.1.1 =
Version A2
00
1A
1B
2A
Tolerance:
±20 % =
±10 % =
±5 %
±2.5 % =
±1 %
6 -2
M
K
J
H
E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk/TPS Standard
=A
=B
=C
=D
=F
=H
=I
=J
=N
=O
=P
=Q
=R
=T
=S
3.5 ±0.5 = C9
6 -2
= SD
16 ±1
= P1
Pin length (taped)
none
= 00
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the
pages of the respective WIMA range.
147
很抱歉,暂时无法提供与“FKP1R031007D00KSSD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+22.99776
- 5+18.37425
- 10+17.09261
- 25+16.15832
- 50+15.60733
- 100+15.23602
- 252+14.68503
- 504+14.50536
- 756+14.31371
