FKP1T001004B00JH00
FKP1T001004B00JH00
    WIMA
    FKP1T001004B00JH00
FKP1T001004B00JH00 数据手册
D WIMA FKP 1 Polypropylene (PP) Capacitors for Pulse Applications with Metal Foil Electrodes, Schoopage Contacts, Double-Sided Metallization and Self-Healing Internal Series Connection for Highest Current Carrying Capability PCM 15 mm to 37.5 mm Special Features Electrical Data ˜ Extremely high pulse duty ˜ Self-healing ˜ Internal series connection ˜ Very low dissipation factor ˜ Negative capacitance change versus temperature ˜ According to RoHS 2011/65/EC Typical Applications For high pulse and high frequency applications e.g. ˜ Switch mode power supplies ˜ Converters in drives and power electronics ˜ Deflection systems in monitors and TV-sets ˜ Electronic ballasts Construction Dielectric: Polypropylene (PP) film Capacitor electrodes: Aluminium foil and double-sided metallized plastic film Internal construction: Plastic film Metal foil electrode Electrode carrier plastic film metallized on both sides Metal contact layer (schoopage) Terminating wire Dissipation factors at +20+ C: tan d at f C0.1 mF 0.1 mF P C  0.22 mF    1 kHz   3 x 10-4   10 kHz   4 x 10-4 100 kHz 10 x 10-4  3 x 10-4  6 x 10-4 – Dielectric absorption: 0.05 % Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and from +75+ C for AC voltages Reliability: Operational life  300 000 hours Failure rate  1 fit (0.5 x Ur and 40+ C) Capacitance max. pulse rise time V/msec at T A < 40) C pF/mF 400 VDC 630 VDC 1000 VDC 1250 VDC 1600 VDC 2000 VDC 4000 VDC 6000 VDC 100   ... 330   ... 1000  ... 3300  ... 0.01  ... 0.033 ... 0.1   ... 220   – 680   – 2200  29000 6800    9000 0.022   9000 0.068   9000 0.22    7000 – – 29000 14000 11000 11000 11000 – – 29000 27000 11000 11000 11000 – – 29000 29000 11000 11000 11000 56000 51000 46000 29000 11000 11000 11000 56000 56000 51000 29000 13000 11000 – – 56000 51000 29000 13000 – – – 56000 51000 29000 13000 – – for pulses equal to the rated voltage Mechanical Tests Pull test on pins: d T 0.8 l: 10 N in direction of pins d > 0.8 l: 20 N in direction of pins according to IEC 60068-2-21 Vibration: 6 hours at 10 ... 2000 Hz and 0.75 mm displacement amplitude or 10 g in accordance with IEC 60068-2-6 Low air density: 1kPa = 10 mbar in accordance with IEC 60068-2-13 Bump test: 4000 bumps at 390 m/sec 2 in accordance with IEC 60068-2-29 Packing Available taped and reeled up to and including case size 15 x 26 x 31.5 / PCM 27.5 mm. Detailed taping information and graphs at the end of the catalogue. For further details and graphs please refer to Technical Information. 11.12 Encapsulation: Solvent-resistant, flame-retardant plastic case with epoxy resin seal, UL 94 V-0 Terminations: Tinned wire. Marking: Colour: Red. Marking: Black. Epoxy resin seal: Yellow Capacitance range: 100 pF to 0.22 mF (E12-values on request) Rated voltages: 400 VDC, 630 VDC, 1000 VDC, 1250 VDC, 1600 VDC, 2000 VDC, 4000 VDC, 6000 VDC Capacitance tolerances: ±20%, ±10%, ±5% (other tolerances are available subject to special enquiry) Operating temperature range: –55+ C to +100+ C Climatic test category: 55/100/56 in accordance with IEC Insulation resistance at +20+ C: C T 0.1 mF:  1 x 10 5 M¸ (mean value: 5 x 10 5 M¸) C  0.1 mF:  30 000 sec (M¸ x mF) (mean value: 100 000 sec) Measuring voltage: 100 V/1 min. Test voltage: 2 U r, 2 sec / 6 kV: 1.6 U r, 2 sec. Maximum pulse rise time: 66 D WIMA FKP 1 Continuation General Data Capacitance 1000 1500 2200 3300 4700 6800 W pF   5   „   5   „   5   „   5   „   5   „   5   H 15   15   15   15   15   15   FKP1J011004B00_ _ _ _ FKP1J011504B00_ _ _ _ FKP1J012204B00_ _ _ _ FKP1J013304B00_ _ _ _ FKP1J014704B00_ _ _ _ FKP1J016804C00_ _ _ _ 0.01  mF   5   11   18   15   FKP1G021004B00_ _ _ _   7     5   0.015 „   6   12.5 18   15   FKP1G021504C00_ _ _ _   8     6   0.022 „   7   14   18   15   FKP1G022204D00_ _ _ _   7     5   14   26.5 22.5 FKP1G022205A00_ _ _ _ 0.033 „   8   15   18   15   FKP1G023304F00_ _ _ _   8.5   6   15   26.5 22.5 FKP1G023305B00_ _ _ _ 0.047 „   7   16.5 26.5 22.5 FKP1G024705D00_ _ _ _ 10.5   9   0.068 „   8.5 18.5 26.5 22.5 FKP1G026805F00_ _ _ _ 11     9   14   14   15   15   16.5 18   26.5 18   26.5 26.5 15   22.5 15   22.5 22.5 FKP1J021004D00_ _ _ _ FKP1J021005A00_ _ _ _ FKP1J021504F00_ _ _ _ FKP1J021505B00_ _ _ _ FKP1J022205D00_ _ _ _ 18.5 26.5 22.5 FKP1J023305F00_ _ _ _ 20.5 19   21   19   26.5 31.5 31.5 41.5 22.5 27.5 27.5 37.5 FKP1J024705H00_ _ _ _ FKP1J024706A00_ _ _ _ FKP1J026806B00_ _ _ _ FKP1J026807A00_ _ _ _ 0.1   mF 10.5   9   0.15  „ 11   0.22  „ 13   13  11  13  15  24   22   24   26   31.5 41.5 41.5 41.5 27.5 37.5 37.5 37.5 FKP1J031006D00_ _ _ _ FKP1J031007B00_ _ _ _ FKP1J031507C00_ _ _ _ FKP1J032207D00_ _ _ _ W H W H 22.5 27.5 27.5 27.5 FKP1G031005H00_ _ _ _ FKP1G031006A00_ _ _ _ FKP1G031506B00_ _ _ _ FKP1G032206D00_ _ _ _ 1000 VDC/600 VAC* L PCM** Part number 1250 VDC/600 VAC* L PCM** Part number 1000 pF   5   11  18    15   FKP1O111004B00_ _ _ _   5   1500 „   5   11  18    15   FKP1O111504B00_ _ _ _   5   2200 „   5   11  18    15   FKP1O112204B00_ _ _ _   5   3300 „   5   11  18    15   FKP1O113304B00_ _ _ _   6   4700 „   6   12.5 18    15   FKP1O114704C00_ _ _ _   7   6800 „   7   14  18    15   FKP1O116804D00_ _ _ _   8     5   11   11   11   12.5 14   15   14   18   18   18   18   18   18   26.5 15   15   15   15   15   15   22.5 0.01  mF   8   15  18    15   FKP1O121004F00_ _ _ _   7     6   15  26.5 22.5 FKP1O121005B00_ _ _ _ 0.015 „   6   15  26.5 22.5 FKP1O121505B00_ _ _ _   8.5 0.022 „   8.5 18.5 26.5 22.5 FKP1O122205F00_ _ _ _ 10.5 0.033 „ 10.5 20.5 26.5 22.5 FKP1O123305H00_ _ _ _ 11     9   19  31.5 27.5 FKP1O123306A00_ _ _ _   9   0.047 „ 11   21  31.5 27.5 FKP1O124706B00_ _ _ _ 13   11   0.068 „ 13   24  31.5 27.5 FKP1O126806D00_ _ _ _ 11   11   22  41.5 37.5 FKP1O126807B00_ _ _ _ 16.5 26.5 22.5 FKP1R021005D00_ _ _ _ 18.5 20.5 21   19   24   22   22   26.5 26.5 31.5 41.5 31.5 41.5 41.5 22.5 22.5 27.5 37.5 27.5 37.5 37.5 26   29   32   41.5 41.5 41.5 37.5 FKP1R031007D00_ _ _ _ 37.5 FKP1R031507E00_ _ _ _ 37.5 FKP1R032207F00_ _ _ _ 0.1   mF 0.15  „ 0.22  „ 13   15   19   24  26  32  41.5 41.5 41.5 37.5 FKP1O131007C00_ _ _ _ 37.5 FKP1O131507D00_ _ _ _ 37.5 FKP1O132207F00_ _ _ _ 15   17   19   * AC voltage: f T 1000 Hz; 1.4 x U rms + UDC T U r Part number completion: ** PCM = Printed circuit module = pin spacing Tolerance: 20 % = M 10 % = K   5 % = J Packing: bulk = S Pin length: 6-2 = SD Dims. in mm. Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. 11.12 630 VDC/400 VAC* L PCM** Part number 18   18   18   18   18   18   26.5 31.5 31.5 31.5 15   15   15   15   15   15   H 11   11   11   11   11   12.5 20.5 19   21   24   18   18   18   18   18   18   W FKP1G011004B00_ _ _ _   5   FKP1G011504B00_ _ _ _   5   FKP1G012204B00_ _ _ _   5   FKP1G013304B00_ _ _ _   5   FKP1G014704B00_ _ _ _   5   FKP1G016804B00_ _ _ _   6   Capacitance 11   11   11   11   11   11   400 VDC/250 VAC* L PCM** Part number Rights reserved to amend design data without prior notification. Continuation page 68 FKP1R011004B00_ _ _ _ FKP1R011504B00_ _ _ _ FKP1R012204B00_ _ _ _ FKP1R013304C00_ _ _ _ FKP1R014704D00_ _ _ _ FKP1R016804F00_ _ _ _ FKP1R016805A00_ _ _ _ FKP1R021505F00_ _ _ _ FKP1R022205H00_ _ _ _ FKP1R023306B00_ _ _ _ FKP1R023307A00_ _ _ _ FKP1R024706D00_ _ _ _ FKP1R024707B00_ _ _ _ FKP1R026807B00_ _ _ _ Taped version see page 148. 67 D WIMA FKP 14 Continuation General Data Capacitance   100   150   220   330   470   680 W H 1600 VDC/650 VAC* L PCM** Part number W H 2000 VDC/700 VAC* L PCM** Part number   pF   5     „   5     „   5     „   5     „   5     „   5   11   11   11   11   11   11   18   18   18   18   18   18   15   15   15   15   15   15   FKP1T001004B00_ _ _ _   5   FKP1T001504B00_ _ _ _   5   FKP1T002204B00_ _ _ _   5   FKP1T003304B00_ _ _ _   6   FKP1T004704B00_ _ _ _   6   FKP1T006804B00_ _ _ _   6   11   11   11   12.5 12.5 12.5 18   18   18   18   18   18   15   15   15   15   15   15   FKP1U001004B00_ _ _ _ FKP1U001504B00_ _ _ _ FKP1U002204B00_ _ _ _ FKP1U003304C00_ _ _ _ FKP1U004704C00_ _ _ _ FKP1U006804C00_ _ _ _ 1000   pF   6     5   1500   „   7     5   2200   „   8     5   3300   „   6   4700   „   7   6800   „   8.5 12.5 14   14   14   15   14   15   16.5 18.5 18   26.5 18   26.5 18   26.5 26.5 26.5 26.5 15   22.5 15   22.5 15   22.5 22.5 22.5 22.5 FKP1T011004C00_ _ _ _   7   FKP1T011005A00_ _ _ _   5   FKP1T011504D00_ _ _ _   6   FKP1T011505A00_ _ _ _ FKP1T012204F00_ _ _ _   7   FKP1T012205A00_ _ _ _ FKP1T013305B00_ _ _ _   7   FKP1T014705D00_ _ _ _   8.5 FKP1T016805F00_ _ _ _ 10.5 14   14   15   18   15   26.5 22.5 26.5 22.5 FKP1U011004D00_ _ _ _ FKP1U011005A00_ _ _ _ FKP1U011505B00_ _ _ _ 16.5 26.5 22.5 FKP1U012205D00_ _ _ _ 16.5 18.5 20.5 26.5 22.5 26.5 22.5 26.5 22.5 FKP1U013305D00_ _ _ _ FKP1U014705F00_ _ _ _ FKP1U016805H00_ _ _ _ 11   13   15   13   13   21   24   26   24   24   31.5 31.5 31.5 41.5 41.5 27.5 27.5 27.5 37.5 37.5 FKP1U021006B00_ _ _ _ FKP1U021506D00_ _ _ _ FKP1U022206F00_ _ _ _ FKP1U022207C00_ _ _ _ FKP1U023307C00_ _ _ _ 17   19   29   32   41.5 37.5 41.5 37.5 FKP1U024707E00_ _ _ _ FKP1U026807F00_ _ _ _ 0.01  mF 10.5 20.5 26.5 22.5 FKP1T021005H00_ _ _ _ 0.015 „ 11   21   31.5 27.5 FKP1T021506B00_ _ _ _ 0.022 „ 11   21   31.5 27.5 FKP1T022206B00_ _ _ _ 0.033 „ 13   24   31.5 27.5 FKP1T023306D00_ _ _ _ 13   24   41.5 37.5 FKP1T023307C00_ _ _ _ 0.047 „ 13   24   41.5 37.5 FKP1T024707C00_ _ _ _ 0.068 „ 15   26   41.5 37.5 FKP1T026807D00_ _ _ _ 0.1   mF 17   29   41.5 37.5 FKP1T031007E00_ _ _ _ * AC voltage: f T 1000 Hz; 1.4 x U rms + UDC T U r ** PCM = Printed circuit module = pin spacing Part number completion: Dims. in mm. Tolerance: 20 % = M 10 % = K   5 % = J Packing: bulk = S Pin length: 6-2 = SD Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Taped version see page 148. l d PCM 0.8 15 - 27.5 1.0 37.5 pin Rights reserved to amend design data without prior notification. 11.12 Continuation page 69 68 D WIMA FKP 1 Continuation General Data Capacitance W 4000 VDC/700 VAC* L PCM** Part number H W H 6000 VDC/700 VAC* L PCM** Part number   470   pF   5     680   „   5   14   14   26.5 26.5 22.5 FKP1X004705A00_ _ _ _   5   22.5 FKP1X006805A00_ _ _ _   5   14   14   26.5 26.5 22.5 FKP1Y004705A00_ _ _ _ 22.5 FKP1Y006805A00_ _ _ _ 1000 1500 2200 3300 4700 6800 14   16.5 18.5 20.5 21   24   26.5 26.5 26.5 26.5 31.5 31.5 22.5 22.5 22.5 22.5 27.5 27.5 14   16.5 20.5 20.5 21   24   26.5 26.5 26.5 26.5 31.5 31.5 22.5 22.5 22.5 22.5 27.5 27.5 0.01  mF 0.015 „ 0.022 „ 26   24   29   31.5 41.5 41.5 27.5 FKP1X021006F00_ _ _ _ 37.5 FKP1X021507C00_ _ _ _ 37.5 FKP1X022207E00_ _ _ _ 26   24   29   31.5 41.5 41.5 27.5 FKP1Y021006F00_ _ _ _ 37.5 FKP1Y021507C00_ _ _ _ 37.5 FKP1Y022207E00_ _ _ _   pF   5     „   7     „   8.5   „ 10.5   „ 11     „ 13   15   13   17   FKP1X011005A00_ _ _ _   5   FKP1X011505D00_ _ _ _   7   FKP1X012205F00_ _ _ _ 10.5 FKP1X013305H00_ _ _ _ 10.5 FKP1X014706B00_ _ _ _ 11   FKP1X016806D00_ _ _ _ 13   15   13   17   FKP1Y011005A00_ _ _ _ FKP1Y011505D00_ _ _ _ FKP1Y012205H00_ _ _ _ FKP1Y013305H00_ _ _ _ FKP1Y014706B00_ _ _ _ FKP1Y016806D00_ _ _ _ * AC voltage: f T 1000 Hz; 1.4 x U rms + UDC T U r Part number completion: ** PCM = Printed circuit module = pin spacing Tolerance: 20 % = M 10 % = K   5 % = J Packing: bulk = S Pin length: 6-2 = SD Dims. in mm. Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Taped version see page 148. Rights reserved to amend design data without prior notification. Urms V 5 400 Permissible AC voltage in relation to frequency at 10) C internal temperature rise (general guide). 47 0. 2 0. 1 102 5 Urms V 650 5 00 02 2 00 pF µF µF 10 630 VDC 0. 0. 0. 22 2 101 pF 22 00 01 04 7 µF 2 pF 102 µF 5 2 5 104 2 105 5 Urms V 600 5 22 0. 102 5 1000 VDC 0. 5 f 106 Hz 2 250 2 0. 0. 1 102 02 µF 2 µF 5 400 VDC 2 00 103 2 5 104 2 5 105 2 5 104 2 00 5 f 106 Hz 105 5 0. 1 47 2 5 104 2 105 5 47 0.0 22 2 00 µF 5 f 106 Hz 2 pF 0.0 10 0 22 pF 0 pF 00 pF 0.0 1µ F 15 68 102 µF 5 2000 VDC 101 103 0. 47 02 µF 2 10 00 µF 00 pF 22 1250 VDC 22 0. 04 0. 103 7 µF 01 µF 00 104 2 5 105 2 5 µF 2 5 f 106 Hz 2 00 47 pF 0 02 0 p F 2 µF 0. 5 5 f 106 Hz 105 22 470 0 0. 0 p pF 01 F µF 10 4000 VDC 6000 VDC 2 5 104 102 101 2 5 2 pF 2 103 2 Urms V 700 5 pF 0. 5 5 f 106 Hz 2 102 101 2 103 2 5 104 2 5 105 2 5 f 106 Hz 11.12 101 10 0 2 0p pF 200 F pF 0. 01 µF 0. 04 7 0. µF 22 µF 00 2 Urms V 600 5 Urms V 5 103 Urms V 700 5 2 101 47 2 0. pF 01 10 00 µF 04 pF 7 µ F 22 4 7 µF 0. 00 pF 02 2 µF 0. 1 µF 2 1600 VDC µF 101 103 10 100 00 pF 470 pF 02 pF 0. 2 µ 22 1 F 00 µF p 0. 01 F 0. 04 µF 7 µF 0. 69 D Recommendation for Processing and Application of Through-Hole Capacitors Soldering Process Wave soldering T A preheating of through-hole WIMA capacitors is allowed for temperatures T max P 100 ° C. In practice a preheating duration of t P 5 min. has been proven to be best. 260 240 220 200 180 160 140 120 100 80 60 40 20 Single wave soldering Soldering bath temperature: T P 260 ° C Immersion time: t P 5 sec Double wave soldering Soldering bath temperature: T P 260 ° C Immersion time: 2 x t P 3 sec Due to different soldering processes and heat requirements the graphs are to be regarded as a recommendation only. 10 s [°C] see detailenlargement 2s 3s t 30 60 90 120 150 180 210 240 [sec] Typical temperature/time graph for double wave soldering WIMA Quality and Environmental Philosophy ISO 9001:2008 Certification ISO 9001:2008 is an international basic standard of quality assurance systems for all branches of industry. The approval according to ISO 9001:2008 of our factories by the VDE inspectorate certifies that organisation, equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards. WIMA WPCS The WIMA Process Control System (WPCS) is a quality surveillance and optimization system developed by WIMA. WPCS is a major part of the quality-oriented WIMA production. Points of application of WPCS during production process: All WIMA capacitors, irrespective of whether through-hole devices or SMD, are made of environmentally friendly materials. Neither during manufacture nor in the product itself any toxic substances are used, e.g. – – – – – Lead PCB CFC Hydrocarbon chloride Chromium 6+ – – – – – PBB/PBDE Arsenic Cadmium Mercury etc. We merely use pure, recyclable materials for packing our components, such as: ” carton ” cardboard ” adhesive tape made of paper ” polystyrene We almost completely refrain from using packing materials such as: ” foamed polystyrene (Styropor®) ” adhesive tapes made of plastic ” metal clips RoHS Compliance According to the RoHS Directive 2011/65/EC certain hazardous substances like e.g. lead, cadmium, mercury must not be used any longer in electronic equipment as of July 1st, 2006. For the sake of the environment WIMA has refraind from using such substances since years already. WIMA Kondensatoren sind bleifrei konform RoHS 2011/65/EC WIMA capacitors are lead free in accordance with RoHS 2011/65/EC Tape for lead-free WIMA capacitors DIN EN ISO 14001:2004 WIMA’s environmental management has been established in accordance with the guidelines of DIN EN ISO 14001:2004 to optimize the production processes with regard to energy and resources. 11.12 ” incoming material inspection ” metallization ” film inspection ” schoopage ” pre-healing ” pin attachment ” cast resin preparation/ encapsulation ” 100% final inspection ” AQL check WIMA Environmental Policy 14 D Typical Dimensions for Taping Configuration Vh P P2 Diagram 1: PCM 2.5/5/7.5mm W W1 W0 H H1 W2 P1 D0 d P t F P0 H1 P P1 H P1 d d F P0 P2 Diagram 2: PCM 10/15 mm Diagram 3: PCM 22.5 and 27.5*mm *PCM 27.5 taping possible with two feed holes between components Designation Carrier tape width Dimensions for Radial Taping Symbol PCM 2.5 taping W P0 P2 F 18.0 p0.5 PCM 5 taping PCM 7.5 taping PCM 10 taping* PCM 15 taping* PCM 22.5 taping PCM 27.5 taping 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing Hold-down tape width W0 6.0 6.0 12.0 12.0 12.0 12.0 12.0      adhesive tape      adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape Hole position W 1 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 Hold-down tape position W 2 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. Feed hole diameter D 0 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 12.7 p1.0 12.7 p1.0 12.7 p1.0 25.4 p1.0 25.4 p1.0 38.1 p1.5 4.0 p0.2 3*8.1 p1.5 or 50.8 p1.5 Pitch of component P Feed hole pitch P 0 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch Feed hole centre to pin P 1 5.1 p0.5 3.85 p0.7 2.6 p0.7 7.7 p0.7 5.2 p0.7 7.8 p0.7 5.3 p0.7 Hole centre to component centre P 2 6.35 p1.3 6.35 p1.3 6.35 p1.3 12.7 p1.3 12.7 p1.3 19.05 p1.3 19.05 p1.3 Feed hole centre to bottom H edge of the component 16.5 p0.3 18.5 p0.5 16.5 p0.3 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 Feed hole centre to top H edge of the component 1 H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 24.5 to 31.5 H+Hcomponent < H1 25.0 to 31.5 H+Hcomponent < H1 26.0 to 37.0 H+Hcomponent < H1 30.0 to 43.0 H+Hcomponent < H1 35.0 to 45.0 7.5 p0.8 10.0 p0.8 15 p0.8 22.5 p0.8 27.5 p0.8 Pin spacing at +0.8 F 2.5 p0.5 5.0 upper edge of carrier tape     –0.2 +0.08 Dh p 2.0 max. p 2.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 ROLL/AMMO Package (see also page 149) P 360 max. 52 p2 depending on REEL P 30 p1 B 58 p2 comp. dimensions Unit 0.8 +0,08 –0.05 Component alignment t 0.8 +0,08 –0.05 0.4 p0.05 „ 0.5 +0,06 p0.05 or 0.6 –0.05 d „ 0.5 +0.06 p0.05 or 0.6 –0.05 Pin diameter Total tape thickness 0.5 p0.05 0.8 –0.05 AMMO 52 p2 54 p2 max. P 500 max. B 58 p2 or REEL B 60 p2 REEL PP 360 30 p1 P 25 p1 66 p2 68 p2 depending on PCM and component dimensions see details page 150. Dims in mm. * PCM 10 and PCM 15 can be crimped to PCM 7.5. Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible 148 Please clarify customer-specific deviations with the manufacturer. 11.12 „ Diameter of pins see General Data. D Types of Tape Packaging of Capacitors for Automatic Radial Insertion ˜ REEL Packaging 340 max. � 30±1 25±1 360 max. 500 max. ˜ AMMO Packaging 340 max. 370 max. ˜ ROLL Packaging 34 0m ax. 50 max. 50 max. 70 max. . ax 0 m ax. 34 0 m 49 B BAR CODE (Labelling) Labelling of package units in plain text and with alphanumerical Bar Code BARCODE „Code 39” Scanner decoding of „ WIMA supplier number „ Customer‘s P/O number „ Customer‘s part number „ WIMA confirmation number „ WIMA part number „ Lot number „ Date code „ Quantity In addition part description of – – – – – – article capacitance value rated voltage dimensions capacitance tolerance packing 11.12 as well as gross weight and customer‘s name are indicated in plain text. 149 D Packing Quantities for Capacitors with Radial Pins in PCM 2.5 mm to 22.5 mm Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm W   2.5  3   3.8   4.6   5.5   2.5  3   3.5   4.5   4.5  5   5.5   5.5   6.5   7.2   7.2   8.5   8.5 11   2.5  3  4   4.5  5   5.7   7.2  3  4  4  4  5  5  6  6  8  5  5  6  6  7  7  8  8  9  9 10 11  5  6  7  8   8.5 10 10.5 10.5 11 12 H  7   7.5   8.5  9 10   6.5   7.5   8.5  6   9.5 10  7 11.5  8   8.5 13 10 14 16  7   8.5  9   9.5 10.5 12.5 12.5  9   8.5  9   9.5 10 11 12 12.5 12 11 13 12.5 14 14 15 15 17 14 16 18 14 14 15 16.5 20 18.5 22 19 20.5 21 24 bulk L   4.6   4.6   4.6   4.6   4.6   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2 10 10 10 10.3 10.3 10.3 10.3 13 13.5 13 13 13.5 13 13 13 13 18 19 18 19 18 19 18 19 18 18 19 18 26.5 26.5 26.5 28 26.5 28 26.5 26.5 26.5 28 Codes 0B 0C 0D 0E 0F 1A 1B 1C 1D 1E 1F 1G 1H 1I 1J 1K 1L 1M 1N 2A 2B 2C 2D 2E 2F 2G 3A FA 3C 3D FB 3F 3G 3H 3I 4B FC 4C FD 4D FE 4F FF 4H 4J FG 4M 5A 5B 5D FH 5F FI 5G 5H 5I FJ S 5000 5000 5000 5000 5000 5000 5000 5000 6000 4000 3500 4000 2500 2500 2500 2000 2000 1500 1000 5000 5000 4000 3500 3000 2000 1500 3000 3000 3000 3000 2000 3000 2400 2400 2000 2400 1000 2000 1000 1600 1000 1200   500 1200   900   500 1000 1200 1000   760   500   500 540* 680* 680* 680* 450* Moulded versions. Rights reserved to amend design data without prior notification. 11.12 * TPS (Tray-Packing-System). Plate versions may have different packing units. Samples and pre-production needs on request. pcs. per packing unit REEL AMMO P 360 P 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D 2200 2500 – 2800 – 2000 2300 – 2300 – 1500 1800 – 1800 – 1200 1500 – 1500 –   900 1200 – 1200 – 2200 2500 – 2800 – 2000 2300 – 2300 – 1600 2000 – 2000 – 1300 1500 – 1500 – 1300 1500 – 1500 – 1100 1400 – 1400 – 1000 1200 – 1200 – 1000 1200 – 1200 –   800 1000 – 1000 –   700 1000 – 1000 –   700   950 – 1000 –   600   800 –   800 –   600   800 –   800 –   500   600 –   400 – – 2500 4400 2500 – – 2200 4300 2300 4150 – 1700 3200 1700 3100 – 1500 2900 1400 2800 – 1300 2500 1300 – – 1000 2200 1100 – –   900 1800 1000 – – 1100 2200 – 1900 –   900 1600 – 1450 –   900 1600 – 1450 –   900 1600 – 1400 –   700 1300 – 1200 –   700 1300 – 1200 –   550 1100 – 1000 –   550 1100 – 1000 –   400   800 –   740 –   600 1200 – 1150 –   600 1200 – 1200 –   500 1000 – 1000 –   500 1000 – 1000 –   450   900 –   850 –   450   900 –   850 –   400   800 –   740 –   400   800 –   740 –   350   700 –   650 –   350   700 –   650 –   300   650 –   590 –   300   600 –   540 – –   800 –   770 – –   700 –   640 – –   600 –   550 – –   500 –   480 – –   480 –   450 – –   420 –   380 – –   400 –   360 – –   400 –   360 – –   380 –   350 – –   350 –   310 ROLL 150 D Packing Quantities for Capacitors with Radial Pins in PCM 27.5 mm to 52.5 mm Size PCM pcs. per packing unit REEL AMMO P 360 P 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D – – 460/340* –   420 – – 380/280* –   350 – –   300 –   290 – – – – –   270 –   250 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – ROLL bulk W  9 11 13 13 15 15 17 17 19 20 20 H 19 21 24 25 26 26 29 34.5 30 32 39.5 L 31.5 31.5 31.5 33 31.5 33 31.5 31.5 31.5 33 31.5 Codes 6A 6B 6D FK 6F FL 6G 6I 6L FM 6J S 640* 544* 448* 336* 384* 288* 176* 176*   50* 216* 144* 37.5 mm  9 11 13 15 17 19 20 24 31 35 40 19 22 24 26 29 32 39.5 45.5 46 50 55 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 7A 7B 7C 7D 7E 7F 7G 7H 7I 7J 7K 480* 408* 252* 144* 132* 108* 108*   84*   72*   35*   28* – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 48.5 mm 19 23 27 33 37 31 34 37.5 48 54 56 56 56 56 56 8D 8E 8H 8J 8L   50*   72*   60*   48*   25* – – – – – – – – – – – – – – – – – – – – – – – – – 52.5 mm 35 45 45 50 55 65 57 57 57 9F 9H 9J   25*   20*   20* – – – – – – – – – – – – – – – 27.5 mm Moulded versions. Rights reserved to amend design data without prior notification. 11.12 * for 2-inch transport pitches. * TPS (Tray-Packing-System). Plate versions may have different packing units. Samples and pre-production needs on request. 151 D WIMA Part Number System A WIMA part number consists of 18 digits and is composed as follows: Field   1 -   4: Type description Field   5 -   6: Rated voltage Field   7 - 10: Capacitance Field 11 - 12: Size and PCM Field 13 - 14: Version code (e.g. Snubber versions) Field 15: Capacitance tolerance Field 16: Packing Field 17 - 18: Lead length (untaped) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 M K S 2 C 0 2 1 0 0 1 A 0 0 M S S D 20 % bulk Type description: SMD-PET = SMD-PPS = FKP 02 = MKS 02 = FKS 2 = FKP 2 = MKS 2 = MKP 2 = FKS 3 = FKP 3 = MKS 4 = MKP 4 = MKP 10 = FKP 4 = FKP 1 = MKP-X2 = MKP-X2 R = MKP-Y2 = MP 3-X2 = MP 3-X1 = MP 3-Y2 = MP 3R-Y2 = Snubber MKP = Snubber FKP = GTO MKP = DC-LINK MKP 3 = DC-LINK MKP 4 = DC-LINK MKP 4S = DC-LINK MKP 5 = DC-LINK MKP 6 = DC-LINK HC = DC-LINK HY = SuperCap C = SuperCap MC = SuperCap C60 = SuperCap R = SuperCap MR = 63 VDC SMDT SMDI FKP0 MKS0 FKS2 FKP2 MKS2 MKP2 FKS3 FKP3 MKS4 MKP4 MKP1 FKP4 FKP1 MKX2 MKXR MKY2 MPX2 MPX1 MPY2 MPRY SNMP SNFP GTOM DCP3 DCP4 DCPS DCP5 DCP6 DCH_ DCHY SCSC MC_ _ SCSC SCSR MRPP Rated voltage: 2.5 VDC = A1 4 VDC = A2 14 VDC = A3 28 VDC = A4 40 VDC = A5 5 VDC = A6 50 VDC = B0 63 VDC = C0 100 VDC = D0 160 VDC = E0 250 VDC = F0 400 VDC = G0 450 VDC = H0 600 VDC = I0 630 VDC = J0 700 VDC = K0 800 VDC = L0 850 VDC = M0 900 VDC = N0 1000 VDC = O1 1100 VDC = P0 1200 VDC = Q0 1250 VDC = R0 1500 VDC = S0 1600 VDC = T0 2000 VDC = U0 2500 VDC = V0 3000 VDC = W0 4000 VDC = X0 6000 VDC = Y0 250 VAC = 0W 275 VAC = 1W 300 VAC = 2W 400 VAC = 3W 440 VAC = 4W 500 VAC = 5W ... 0.01 mF Capacitance: 22 pF = 0022 47 pF = 0047 100 pF = 0100 150 pF = 0150 220 pF = 0220 330 pF = 0330 470 pF = 0470 680 pF = 0680 1000 pF = 1100 1500 pF = 1150 2200 pF = 1220 3300 pF = 1330 4700 pF = 1470 6800 pF = 1680 0.01 mF = 2100 0.022 mF = 2220 0.047 mF = 2470 0.1 mF = 3100 0.22 mF = 3220 0.47 mF = 3470 = 4100 1 mF 2.2 mF = 4220 4.7 mF = 4470 = 5100 10 mF = 5220 22 mF = 5470 47 mF 100 mF = 6100 220 mF = 6220 1F = A010 2.5 F = A025 50 F = A500 100 F = B100 110 F = B110 600 F = B600 1200 F = C120 ... - 2.5 x 6.5 x 7.2 Size: 4.8 x 3.3 x 3 Size 1812 4.8 x 3.3 x 4 Size 1812 5.7 x 5.1 x 3.5 Size 2220 5.7 x 5.1 x 4.5 Size 2220 7.2 x 6.1 x 3 Size 2824 7.2 x 6.1 x 5 Size 2824 10.2 x 7.6 x 5 Size 4030 12.7 x 10.2 x 6 Size 5040 15.3 x 13.7 x 7 Size 6054 2.5 x 7 x 4.6 PCM 2.5 3 x 7.5 x 4.6 PCM 2.5 2.5 x 6.5 x 7.2 PCM 5 3 x 7.5 x 7.2 PCM 5 2.5 x 7 x 10 PCM 7.5 3 x 8.5 x 10 PCM 7.5 3 x 9 x 13 PCM 10 4 x 9 x 13 PCM 10 5 x 11 x 18 PCM 15 6 x 12.5 x 18 PCM 15 5 x 14 x 26.5 PCM 22.5 6 x 15 x 26.5 PCM 22.5 9 x 19 x 31.5 PCM 27.5 11 x21 x 31.5 PCM 27.5 9 x 19 x 41.5 PCM 37.5 11 x 22 x 41.5 PCM 37.5 94 x 49 x 182 DCH_ 94 x 77 x 182 DCH_ ... Version code: Standard = Version A1 = Version A1.1.1 = Version A2 = ... 00 1A 1B 2A = = = = = = = = = = = = = = = = = = = = = = = = = = = KA KB QA QB TA TB VA XA YA 0B 0C 1A 1B 2A 2B 3A 3C 4B 4C 5A 5B 6A 6B 7A 7B H0 H1 Tolerance: 20 % = 10 % = 5 % = 2.5 % = 1 % = ... 6 -2 M K J H E Packing: AMMO H16.5 340 x 340 AMMO H16.5 490 x 370 AMMO H18.5 340 x 340 AMMO H18.5 490 x 370 REEL H16.5 360 REEL H16.5 500 REEL H18.5 360 REEL H18.5 500 ROLL H16.5 ROLL H18.5 BLISTER W12 180 BLISTER W12 330 BLISTER W16 330 BLISTER W24 330 Bulk/TPS Standard ... A B C D F H I J N O P Q R T S Lead length (untaped) 3.5 ±0.5 = C9 6 -2 = SD 16 ±1 = P1 ... The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the pages of the respective WIMA range. 146 = = = = = = = = = = = = = = = 11.12 MKS 2
FKP1T001004B00JH00 价格&库存
很抱歉,暂时无法提供与“FKP1T001004B00JH00”相匹配的价格&库存,您可以联系我们找货
FKP1T001004B00JH00
