FKP1T012205A00KSSD
FKP1T012205A00KSSD
    WIMA
    插件
    薄膜电容 18.00 x 8.00mm 插件
FKP1T012205A00KSSD 数据手册
® WIMA FKP 1 Polypropylene (PP) Capacitors for Very High Pulse Applications with Metal Foil Electrodes and Metallized Internal Series Connection in PCM 15 mm to 52.5 mm. Capacitances from 100 pF to 4.7 F. Rated Voltages from 400 VDC to 6000 VDC. Special Features Electrical Data O Extremely high pulse duty O Self-healing O Internal series connection O Very low dissipation factor O Negative capacitance change versus temperature O AEC-Q200 qualified O According to RoHS 2011/65/EU Typical Applications For high pulse and high frequency applications e.g. O Switch mode power supplies O Converters in drives and power electronics O Deflection systems in monitors and TV-sets O Electronic ballasts Dielectric: Polypropylene (PP) film Capacitor electrodes: Aluminium foil and double-sided metallized plastic film Internal construction: Plastic film Metal foil electrode Electrode carrier plastic film metallized on both sides Metal contact layer (schoopage) Terminating wire Encapsulation: Solvent-resistant, flame-retardant plastic case with epoxy resin seal, UL 94 V-0 Terminations: Tinned wire. Marking: Colour: Red. Marking: Black. Dielectric absorption: 0.05 % Insulation resistance at +20° C: C T 0.1 F:  1 x 105 MΩ C  0.1 F:  30 000 sec (MΩ x F) Measuring voltage: 100 V/1 min. Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85° C for DC voltages and from +75° C for AC voltages Reliability: Operational life  300 000 hours Failure rate  1 fit (0.5 x Ur and 40° C) PCM  4000 VDC 4000 VDC 6000 VDC  37.5  37.5 2 Ur 2 Ur   2 Ur 1.6 U r 1.6 U r 1.2 U r Dissipation factors at +20° C: tan  Construction 04.23 Capacitance range: 100 pF to 4.7 F (E12-values on request) Rated voltages: 400 VDC, 630 VDC, 1000 VDC, 1250 VDC, 1600 VDC, 2000 VDC, 4000 VDC, 6000 VDC Capacitance tolerances: ±20%, ±10%, ±5% (other tolerances are available subject to special enquiry) Operating temperature range: –55° C to +105° C Climatic test category: 55/100/56 in accordance with IEC Test voltage: 2 sec at f   1 kHz   10 kHz 100 kHz C  0.1 F 0.1  F P C  1.0 F C  1.0 F    5 x10-4  5 x 10-4  5 x 10-4 -4 -4 –    6 x10  6 x 10 –  10 x 10-4 – Maximum pulse rise time: Capacitance max. pulse rise time V/sec at TA < 40° C pF/F 400 VDC 630 VDC 1000 VDC 1250 VDC 1600 VDC 2000 VDC 4000 VDC 6000 VDC 100   ... 220   – – – – 56000 56000 – – 330   ... 680   – – – – 51000 56000 56000 56000 1000  ... 2200  29000 29000 29000 29000 46000 51000 51000 51000 3300  ... 6800    9000 14000 27000 29000 29000 29000 29000 29000 0.01  ... 0.022   9000 11000 11000 11000 11000 13000 13000 13000 0.033... 0.068   9000 11000 11000 11000 11000 11000 13000 13000 0.1   ... 0.22    7000 11000 11000 11000 11000 11000 13000 13000 0.33 ... 0.68   6000 10000 11000 11000 11000 11000 – – 1.0  ... 2.2    5000  6600 8300  9500 11000 – – – 3.3  ... 4.7    2500 – – – – – – – Mechanical Tests Pull test on pins: d T 0.8 Ø: 10 N in direction of pins d > 0.8 Ø: 20 N in direction of pins according to IEC 60068-2-21 Vibration: 6 hours at 10 ... 2000 Hz and 0.75 mm displacement amplitude or 10 g in accordance with IEC 60068-2-6 Low air density: 1kPa = 10 mbar in accordance with IEC 60068-2-13 Bump test: 4000 bumps at 390 m/sec2 in accordance with IEC 60068-2-29 Packing Available taped and reeled up to and including case size 15 x 26 x 31.5 / PCM 27.5 mm. Detailed taping information and graphs at the end of the catalogue. For further details and graphs please refer to Technical Information. 81 ® WIMA FKP 1 Continuation General Data Capacitance 1000 1500 2200 3300 4700 6800 W pF  5   „  5   „  5   „  5   „  5   „  5   H 11   11   11   11   11   11   400 VDC/250 VAC* L PCM** Part number 18   18   18   18   18   18   15   15   15   15   15   15   W FKP1G011004B_ _ _ _ _ _  5   FKP1G011504B_ _ _ _ _ _  5   FKP1G012204B_ _ _ _ _ _  5   FKP1G013304B_ _ _ _ _ _  5   FKP1G014704B_ _ _ _ _ _  5   FKP1G016804B_ _ _ _ _ _  6   H 11   11   11   11   11   12.5 630 VDC/400 VAC* L PCM** Part number 18   18   18   18   18   18   15   15   15   15   15   15   FKP1J011004B_ _ _ _ _ _ FKP1J011504B_ _ _ _ _ _ FKP1J012204B_ _ _ _ _ _ FKP1J013304B_ _ _ _ _ _ FKP1J014704B_ _ _ _ _ _ FKP1J016804C_ _ _ _ _ _ 0.01  F  5   11   18   15   FKP1G021004B_ _ _ _ _ _  7   14   18   15   FKP1J021004D_ _ _ _ _ _  5   14   26.5 22.5 FKP1J021005A_ _ _ _ _ _ 0.015 „  6   12.5 18   15   FKP1G021504C_ _ _ _ _ _  8   15   18   15   FKP1J021504F_ _ _ _ _ _  6   15   26.5 22.5 FKP1J021505B_ _ _ _ _ _ 0.022 „  7   14   18   15   FKP1G022204D_ _ _ _ _ _  7   16.5 26.5 22.5 FKP1J022205D_ _ _ _ _ _  5   14   26.5 22.5 FKP1G022205A_ _ _ _ _ _ 0.033 „  8   15   18   15   FKP1G023304F_ _ _ _ _ _  8.5 18.5 26.5 22.5 FKP1J023305F_ _ _ _ _ _  6   15   26.5 22.5 FKP1G023305B_ _ _ _ _ _ 0.047 „  7   16.5 26.5 22.5 FKP1G024705D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1J024705H_ _ _ _ _ _  9   19   31.5 27.5 FKP1J024706A_ _ _ _ _ _ 0.068 „  8.5 18.5 26.5 22.5 FKP1G026805F_ _ _ _ _ _ 11   21   31.5 27.5 FKP1J026806B_ _ _ _ _ _  9   19   41.5 37.5 FKP1J026807A_ _ _ _ _ _ 0.1   F 10.5 20.5 26.5 22.5 FKP1G031005H_ _ _ _ _ _  9   19   31.5 27.5 FKP1G031006A_ _ _ _ _ _ 0.15  „ 11   21   31.5 27.5 FKP1G031506B_ _ _ _ _ _ 0.22  „ 13   24   31.5 27.5 FKP1G032206D_ _ _ _ _ _ 11   22   41.5 37.5 FKP1G032207B_ _ _ _ _ _ 0.33  „ 13   24   41.5 37.5 FKP1G033307C_ _ _ _ _ _ 0.47  „ 17   29   41.5 37.5 FKP1G034707E_ _ _ _ _ _ 0.68  „ 19   32   41.5 37.5 FKP1G036807F_ _ _ _ _ _ 13  11  13  15  24   22   24   26   19 20 24 32   41.5 37.5 FKP1J033307F_ _ _ _ _ _ 39.5 41.5 37.5 FKP1J034707G_ _ _ _ _ _ 45.5 41.5 37.5 FKP1J036807H_ _ _ _ _ _ 1.0   F 20   39.5 41.5 37.5 FKP1G041007G_ _ _ _ _ _ 1.5   „ 31   46  41.5 37.5 FKP1G041507I_ _ _ _ _ _ 2.2   „ 35   50   41.5 37.5 FKP1G042207J_ _ _ _ _ _ 3.3   „ 35   50   57  52.5 FKP1G043309F_ _ _ _ _ _ 4.7   „ 45   65   57   52.5 FKP1G044709J_ _ _ _ _ _ 35 50   41.5 37.5 FKP1J041007J_ _ _ _ _ _ 40 55   41.5 37.5 FKP1J041507K_ _ _ _ _ _ 35 50   57   52.5 FKP1J041509F_ _ _ _ _ _ 45 55   57   52.5 FKP1J042209H_ _ _ _ _ _ 31.5 41.5 41.5 41.5 27.5 37.5 37.5 37.5 FKP1J031006D_ _ _ _ _ _ FKP1J031007B_ _ _ _ _ _ FKP1J031507C_ _ _ _ _ _ FKP1J032207D_ _ _ _ _ _ * AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur ** PCM = Printed circuit module = pin spacing Dims. in mm. Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Part number completeion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 = = = = = = = 00 D4 M K J S SD Taped version see page 157. Rights reserved to amend design data without prior notification. 04.23 Continuation page 83 82 ® WIMA FKP 1 Continuation General Data Capacitance 1000 1500 2200 3300 4700 6800 W pF  5   „  5   „  5   „  5   „   6   „  7   1000 VDC/600 VAC* L PCM** H 11  11  11  11  12.5 14  18    18    18    18    18    18    Part number 15   15   15   15   15   15   FKP1O111004B_ _ _ _ _ _ FKP1O111504B_ _ _ _ _ _ FKP1O112204B_ _ _ _ _ _ FKP1O113304B_ _ _ _ _ _ FKP1O114704C_ _ _ _ _ _ FKP1O116804D_ _ _ _ _ _ 0.01  F  8   15  18    15   FKP1O121004F_ _ _ _ _ _  6   15  26.5 22.5 FKP1O121005B_ _ _ _ _ _ 0.015 „  6   15  26.5 22.5 FKP1O121505B_ _ _ _ _ _ 0.022 „   8.5 18.5 26.5 22.5 FKP1O122205F_ _ _ _ _ _ 0.033 „ 10.5 20.5 26.5 22.5 FKP1O123305H_ _ _ _ _ _  9   19  31.5 27.5 FKP1O123306A_ _ _ _ _ _ 0.047 „ 11   21  31.5 27.5 FKP1O124706B_ _ _ _ _ _ 0.068 „ 13   24  31.5 27.5 FKP1O126806D_ _ _ _ _ _ 11   22  41.5 37.5 FKP1O126807B_ _ _ _ _ _ 0.1   0.15  0.22  0.33  0.47  0.68  F „ „ „ „ „ 13   15   19   20   31   35   24  26  32  39.5 46  50  41.5 41.5 41.5 41.5 41.5 41.5 37.5 37.5 37.5 37.5 37.5 37.5 FKP1O131007C_ _ _ _ _ _ FKP1O131507D_ _ _ _ _ _ FKP1O132207F_ _ _ _ _ _ FKP1O133307G_ _ _ _ _ _ FKP1O134707I_ _ _ _ _ _ FKP1O136807J_ _ _ _ _ _ 1.0   F 1.5   „ 2.2   „ 40   35   45   45   55  50  55  65  41.5 57   57   57   37.5 52.5 52.5 52.5 FKP1O141007K_ _ _ _ _ _ FKP1O141009F_ _ _ _ _ _ FKP1O141509H_ _ _ _ _ _ FKP1O142209J_ _ _ _ _ _ * AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur ** PCM = Printed circuit module = pin spacing Part number completion: Dims. in mm. Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. = = = = = = = 00 D4 M K J S SD Taped version see page 157. 2-pin version 4-pin version Ø d W PCM b Ø d c PCM 0.8 15 - 27.5 1.0 37.5 pin pin c pin c 17 37.5 10   1.0 0.4 19 37.5 10   1.0 0.4 20 37.5 12.5 1.0 0.4 24 37.5 12.5 1.0 0.4 31 37.5 20   1.0 0.4 35 37.5 20   1.0 0.4 40 37.5 20   1.0 0.4 35 52.5 20   1.2 0.8 45 52.5 20   1.2 0.8 Rights reserved to amend design data without prior notification 04.23 Continuation page 84 83 ® WIMA FKP 1 Continuation General Data Capacitance  100  150  220  330  470  680 W H 1250 VDC/600 VAC* L PCM** Part number W H  pF  5   11    „  5   11    „  5   11    „  5   11    „  5   11    „  5   11   1600 VDC/650 VAC* L PCM** Part number 18   18   18   18   18   18   15   15   15   15   15   15   FKP1T001004B_ _ _ _ _ _ FKP1T001504B_ _ _ _ _ _ FKP1T002204B_ _ _ _ _ _ FKP1T003304B_ _ _ _ _ _ FKP1T004704B_ _ _ _ _ _ FKP1T006804B_ _ _ _ _ _ 1000   pF  5   11   18   15   FKP1R011004B_ _ _ _ _ _  6   12.5 18   15   FKP1T011004C_ _ _ _ _ _   5   14   26.5 22.5 FKP1T011005A_ _ _ _ _ _ 1500   „  5   11   18   15   FKP1R011504B_ _ _ _ _ _  7   14   18   15   FKP1T011504D_ _ _ _ _ _   5   14   26.5 22.5 FKP1T011505A_ _ _ _ _ _ 2200   „  5   11   18   15   FKP1R012204B_ _ _ _ _ _  8   15   18   15   FKP1T012204F_ _ _ _ _ _   5   14   26.5 22.5 FKP1T012205A_ _ _ _ _ _ 3300   „  6   12.5 18   15   FKP1R013304C_ _ _ _ _ _  6   15   26.5 22.5 FKP1T013305B_ _ _ _ _ _ 4700   „  7   14   18   15   FKP1R014704D_ _ _ _ _ _  7   16.5 26.5 22.5 FKP1T014705D_ _ _ _ _ _ 6800   „  8   15   18   15   FKP1R016804F_ _ _ _ _ _  8.5 18.5 26.5 22.5 FKP1T016805F_ _ _ _ _ _ 5   14   26.5 22.5 FKP1R016805A_ _ _ _ _ _ 0.01  0.015 0.022 0.033 0.047 0.068 0.1   0.15  0.22  0.33  0.47  0.68  „  7   16.5 26.5 22.5 FKP1R021005D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1T021005H_ _ _ _ _ _  8.5 18.5 26.5 22.5 FKP1R021505F_ _ _ _ _ _ 11   21   31.5 27.5 FKP1T021506B_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1R022205H_ _ _ _ _ _ 11   21   31.5 27.5 FKP1T022206B_ _ _ _ _ _ 11   21   31.5 27.5 FKP1R023306B_ _ _ _ _ _ 13   24   31.5 27.5 FKP1T023306D_ _ _ _ _ _  9   19   41.5 37.5 FKP1R023307A_ _ _ _ _ _ 13   24   41.5 37.5 FKP1T023307C_ _ _ _ _ _ 13   24   31.5 27.5 FKP1R024706D_ _ _ _ _ _ 13   24   41.5 37.5 FKP1T024707C_ _ _ _ _ _ 11   22   41.5 37.5 FKP1R024707B_ _ _ _ _ _ 11   22   41.5 37.5 FKP1R026807B_ _ _ _ _ _ 15   26   41.5 37.5 FKP1T026807D_ _ _ _ _ _ F „ „ „ „ „ 15   26   41.5 37.5 17   29   41.5 37.5 19   32   41.5 37.5 24   45.5 41.5 37.5 31   46   41.5 37.5 40   55   41.5 37.5 F „ „ „ „ 1.0   F 1.5   „ 35   45   50   65   FKP1R031007D_ _ _ _ _ _ 17   29   41.5 37.5 FKP1R031507E_ _ _ _ _ _ 20   39.5 41.5 37.5 FKP1R032207F_ _ _ _ _ _ 24   45.5 41.5 37.5 FKP1R033307H_ _ _ _ _ _ 31   46   41.5 37.5 FKP1R034707I_ _ _ _ _ _ 40   55   41.5 37.5 FKP1R036807K_ _ _ _ _ _ 35   50   57   52.5 FKP1T031007E_ _ _ _ _ _ FKP1T031507G_ _ _ _ _ _ FKP1T032207H_ _ _ _ _ _ FKP1T033307I_ _ _ _ _ _ FKP1T034707K_ _ _ _ _ _ FKP1T036809F_ _ _ _ _ _ 57   52.5 FKP1R041009F_ _ _ _ _ _ 45   55   57   52.5 57   52.5 FKP1R041509J_ _ _ _ _ _ FKP1T041009H_ _ _ _ _ _ * AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur ** PCM = Printed circuit module = pin spacing Dims. in mm. Part number completion: Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 = = = = = = = 00 D4 M K J S SD Taped version see page 157. Rights reserved to amend design data without prior notification 04.23 Continuation page 85 84 ® WIMA FKP 1 Continuation General Data Capacitance W 2000 VDC/700 VAC* L PCM** Part number H   5   11   18   15     5   11   18   15     5   11   18   15     6   12.5 18   15    6   12.5 18   15    6   12.5 18   15   W H 4000 VDC/700 VAC* L PCM** Part number  100  150  220   330  470  680  pF  „  „  „  „  „ FKP1U001004B_ _ _ _ _ _ FKP1U001504B_ _ _ _ _ _ FKP1U002204B_ _ _ _ _ _ FKP1U003304C_ _ _ _ _ _ FKP1U004704C_ _ _ _ _ _  5   14   26.5 22.5 FKP1X004705A_ _ _ _ _ _ FKP1U006804C_ _ _ _ _ _  5   14   26.5 22.5 FKP1X006805A_ _ _ _ _ _ 1000 1500 2200 3300 4700 6800   pF  7   14   18   15   FKP1U011004D_ _ _ _ _ _  5   14   26.5 22.5 FKP1X011005A_ _ _ _ _ _   5   14   26.5 22.5 FKP1U011005A_ _ _ _ _ _   „   6   15   26.5 22.5 FKP1U011505B_ _ _ _ _ _  7   16.5 26.5 22.5 FKP1X011505D_ _ _ _ _ _   „   7   16.5 26.5 22.5 FKP1U012205D_ _ _ _ _ _  8.5 18.5 26.5 22.5 FKP1X012205F_ _ _ _ _ _   „   7   16.5 26.5 22.5 FKP1U013305D_ _ _ _ _ _ 10.5 20.5 26.5 22.5 FKP1X013305H_ _ _ _ _ _   „   8.5 18.5 26.5 22.5 FKP1U014705F_ _ _ _ _ _ 11   21   31.5 27.5 FKP1X014706B_ _ _ _ _ _   „ 10.5 20.5 26.5 22.5 FKP1U016805H_ _ _ _ _ _ 13   24   31.5 27.5 FKP1X016806D_ _ _ _ _ _ 0.01  0.015 0.022 0.033 0.047 0.068 F „ „ „ „ „ 11  21   31.5 27.5 FKP1U021006B_ _ _ _ _ _ 15   26   31.5 27.5 FKP1X021006F_ _ _ _ _ _ 13  24   31.5 27.5 FKP1U021506D_ _ _ _ _ _ 13   24   41.5 37.5 FKP1X021507C_ _ _ _ _ _ 15  26   31.5 27.5 FKP1U022206F_ _ _ _ _ _ 17   29   41.5 37.5 FKP1X022207E_ _ _ _ _ _ 13  24   41.5 37.5 FKP1U022207C_ _ _ _ _ _ 13   24   41.5 37.5 FKP1U023307C_ _ _ _ _ _ 20   39.5 41.5 37.5 FKP1X023307G_ _ _ _ _ _ 17   29   41.5 37.5 FKP1U024707E_ _ _ _ _ _ 24   45.5 41.5 37.5 FKP1X024707H_ _ _ _ _ _ 19   32   41.5 37.5 FKP1U026807F_ _ _ _ _ _ 31   46   41.5 37.5 FKP1X026807I_ _ _ _ _ _ 0.1   0.15  0.22  0.33  0.47  0.68  F „ „ „ „ „ 20   39.5 41.5 37.5 24   45.5 41.5 37.5 35   50   41.5 37.5 40   55   41.5 37.5 45   55   57   52.5 45   65   57   52.5 FKP1U031007G_ _ _ _ _ _ 35   50   41.5 37.5 FKP1X031007J_ _ _ _ _ _ FKP1U031507H_ _ _ _ _ _ 40   55   41.5 37.5 FKP1X031507K_ _ _ _ _ _ FKP1U032207J_ _ _ _ _ _ 45   55   57   52.5 FKP1X032209H_ _ _ _ _ _ FKP1U033307K_ _ _ _ _ _ FKP1U034709H_ _ _ _ _ _ FKP1U036809J_ _ _ _ _ _ * AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur ** PCM = Printed circuit module = pin spacing Part number completion: Dims. in mm. Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. = = = = = = = 00 D4 M K J S SD Taped version see page 157. 2-pin version 4-pin version Ø d W PCM b Ø d c PCM 0.8 15 - 27.5 1.0 37.5 pin pin c pin c 17 37.5 10   1.0 0.4 19 37.5 10   1.0 0.4 20 37.5 12.5 1.0 0.4 24 37.5 12.5 1.0 0.4 31 37.5 20   1.0 0.4 35 37.5 20   1.0 0.4 40 37.5 20   1.0 0.4 35 52.5 20   1.2 0.8 45 52.5 20   1.2 0.8 Rights reserved to amend design data without prior notificationn. 04.23 Continuation page 86 85 ® WIMA FKP 1 Continuation General Data Capacitance W 6000 VDC/700 VAC* L PCM** Part number H Dims. in mm.  470  pF  5   14   26.5 22.5 FKP1Y004705A_ _ _ _ _ _  680  „  5   14   26.5 22.5 FKP1Y006805A_ _ _ _ _ _ 1000 1500 2200 3300 4700 6800   pF  5   14   26.5 22.5 FKP1Y011005A_ _ _ _ _ _  „  7   16.5 26.5 22.5 FKP1Y011505D_ _ _ _ _ _   „ 10.5 20.5 26.5 22.5 FKP1Y012205H_ _ _ _ _ _  „ 10.5 20.5 26.5 22.5 FKP1Y013305H_ _ _ _ _ _   „ 11   21   31.5 27.5 FKP1Y014706B_ _ _ _ _ _   „ 13   24   31.5 27.5 FKP1Y016806D_ _ _ _ _ _ 0.01  0.015 0.022 0.033 0.047 0.068 F 15   26   31.5 27.5 FKP1Y021006F_ _ _ _ _ _ „ 13   24   41.5 37.5 FKP1Y021507C_ _ _ _ _ _ „ 17   29   41.5 37.5 FKP1Y022207E_ _ _ _ _ _ „ 20   39.5 41.5 37.5 FKP1Y023307G_ _ _ _ _ _ „ 24   45.5 41.5 37.5 FKP1Y024707H_ _ _ _ _ _ „ 31   46   41.5 37.5 FKP1Y026807I_ _ _ _ _ _ 0.1   F 0.15  „ 0.22  „ Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Part number completion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 35   50   41.5 37.5 FKP1Y031007J_ _ _ _ _ _ 40   55   41.5 37.5 FKP1Y031507K_ _ _ _ _ _ 45   55   57   52.5 FKP1Y032209H_ _ _ _ _ _ = = = = = = = 00 D4 M K J S SD Taped version see page 157. * AC voltages: f T 1000 Hz; 1.4 x Urms + UDC T Ur ** PCM = Printed circuit module = pin spacing Rights reserved to amend design data without prior notificationn. 10 Impedance change with frequency (general guide). 1 PCM 22.5 Z  Z  7 5 -- -- 22 0. 47 0. µF 0 1. 107 108 0.001 106 3 5 7 107 f/Hz PCM 15 0 pF -- 7 5 -- 3 00 7 5 pF 3 µF 0.1 7 5 3 0.01 7 5 µF 03 0.01 00 5 3 pF 68 01 0. pF 7 5 22 -- 3 -0. 0.1 47 0. -- 7 5 Z  -- 0.1 -0 15 Z  pF 00 F 47 µ -01 0. µF -2 F 02 µ 0. 33 µF -- 0.0 47 µF -- 0.0.068 -- - 0 - 1 1 PCM 52.5 10 Z  108 f/Hz 1 10 PCM 37.5 µF F 7 -- 3 µF 5 -- 7 5 7µ 3 -- pF 0.01 22 04 0. 106 3 -- 00 22 0 0. -- 3 pF 00 F 47 1 µ 0 0. -- 7 5 0.01 10 ---- 0.1 pF F 0 p 68 00 -- 3 µF 2 02 3 µF 0. F 03 8 µ -0. 06 0. µF 1 µF 0. 0.1 7 5 -- 1 4.7 µF 3 PCM 27.5 3 106 3 5 7 µF 107 108 f/Hz 86 0.001 106 3 5 7 107 108 f/Hz 0.001 105 3 5 7 106 107 f/Hz Continuation page 87 04.23 0.01 ® WIMA FKP 1 Continuation Permissible AC voltage in relation to frequency till 15° C internal temperature rise (general guide). The information behind the cross bar denote the PCM of the measured value. 103 103 Urms V 650 Urms V 250 2 1.0 µF /3 7.5 102 5 400 VDC 103 2 5 2 0.0 33 µF /15 0.2 2µ F/2 4. 7.5 7µ F/ 52 .5 2 101 0.0 47 µF /22 .5 104 2 5 105 2 5 f 106 Hz 630 VDC 2 2 5 104 2 5 105 2 5 f 106 Hz 103 150 0p F/1 5 0.0 22 µ F/2 0.0 7.5 4 0.0 7 µF /27 68 .5 µF /3 7.5 2 102 2 5 104 2 5 105 1000 VDC 2 5 f 106 Hz 470 pF/15 15 00 pF /22 0.0 .5 1µ F/ 0.0 27 68 . 5 µF /3 7.5 102 5 2000 VDC 2 101 103 2 5 104 2 Urms V 5 0. 1µ F/ 37 .5 2 102 5 2 4000 VDC 105 2 5 f 106 Hz 15 00 68 pF/ 0 p 22 F/2 .5 2.5 0.0 1µ F/ 27 0. 04 .5 7µ F/ 37 .5 2 103 2 5 104 2 5 105 2 5 f 106 Hz 68 00 pF /15 0.0 33 µF /27 .5 0.01 5µ 0.1 F/2 5µ 2.5 F/3 7.5 2 102 5 101 103 2 5 104 2 5 103 700 103 600 Urms V 1250 VDC 2 2 5 f 106 Hz 10 00 pF/ 22 47 .5 00 pF /2 7.5 0. 04 7 0. µF 15 /3 7. µF 5 /3 7. 5 Urms V 2 102 5 105 6000 VDC 2 103 2 5 104 2 5 105 2 5 f 106 Hz 101 103 2 5 104 2 5 105 2 5 f 106 Hz 04.23 101 103 103 700 600 Urms V 101 101 2 0.0 1µ F/2 2.5 0.0 68 µF /2 0. 7.5 47 µF /3 7. 5 102 5 1600 VDC Urms V 0.0 15 0.2 µF 2µ /1 5 F/ 37 .5 103 5 103 700 2 101 102 47 00 pF/ 22 .5 0.0 22 µF/ 27 .5 2 103 Urms V 400 5 100 pF/15 0.0 47 0. µF 33 /3 7.5 µF /3 7. 5 Continuation page 88 87 ® WIMA FKP 1 Continuation Permissible AC current in relation to frequency till 15° C internal temperature rise (general guide). The information behind the cross bar denote the PCM of the measured value. 102 Irms A 102 Irms A 4.7 µF/52.5 10 10 0.33 µF/37.5 0,047 µF/37.5 0.022 µF/27.5 4700 pF/22.5 1.0 µF/37.5 0.047 µF/22.5 1 10-1 10-2 0.22 µF/27.5 0.033 µF/15 10-1 400 VDC 103 2 5 104 2 5 105 2 5 f 106 Hz 10 0.47 µF/37.5 0.22 µF/37.5 0.015 µF/15 1 10-1 103 2 5 104 0.01 µF/22.5 5 105 103 2 5 104 2 5 105 10 2 5 f 106 Hz 0.068 µF/37.5 2 0.01 µF/27.5 1500 pF/22.5 1 10-1 630 VDC 5 f 106 Hz 10-2 15 pF/ 470 103 2 5 104 2 102 Irms A 10 10 0.068 µF/37.5 0.022 µF/22.5 1 5 2000 VDC 105 0.1 µF/37.5 2 5 f 106 Hz 0.047 µF/37.5 0,01 µF/27.5 0.047 µF/27.5 1 1500 pF/15 1500 pF/22.5 680 pF/22.5 10-1 10-1 1000 VDC 4000 VDC 10-2 103 2 5 104 2 5 105 2 5 f 106 Hz 103 2 5 104 2 5 105 2 5 f 106 Hz 102 Irms A 102 Irms A 10 0.15 µF/37.5 0.033 µF/27,5 0.015 µF/22.5 6800 pF/15 1 0.15 µF/37.5 10 0.047 µF/37.5 4700 pF/27.5 1 2.5 F/2 0p 100 10-1 10-1 1250 VDC 102 2 5 103 2 5 104 2 5 f 105 Hz 10-2 103 2 5 104 2 5 6000 VDC 105 2 5 f 106 Hz 04.23 10-2 2 0.068 µF/27.5 102 Irms A 10-2 10-2 1600 VDC 15 pF/ 100 102 Irms A 102 Irms A 10-2 1 88 ® Recommendation for Processing and Application of Through-Hole Capacitors Soldering Process Internal temperature of the capacitor must be kept as follows: Polyester: preheating: Tmax. T125° C soldering: Tmax. T135° C Polypropylene: preheating: Tmax. T100° C soldering: Tmax. T110° C Single wave soldering Soldering bath temperature: T P 260 ° C Dwell time: t P 5 sec Double wave soldering Soldering bath temperature: T P 260 ° C Dwell time: ∑t P 5 sec Due to different soldering processes and heat requirements the graphs are to be regarded as a recommendation only. WIMA Quality and Environmental Philosophy ISO 9001:2015 Certification ISO 9001:2015 is an international basic standard of quality assurance systems for all branches of industry. The approval according to ISO 9001:2015 of our factories certifies that organisation, equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards. WIMA WPCS The WIMA Process Control System (WPCS) is a quality surveillance and optimization system developed by WIMA. WPCS is a major part of the quality-oriented WIMA production. Points of application during production process: All WIMA capacitors, irrespective of whether through-hole devices or SMD, are made of environmentally friendly materials. Neither during manufacture nor in the product itself any toxic substances are used, e.g. – Lead – PBB/PBDE – PCB – Arsenic – CFC – Cadmium – Hydrocarbon chloride – Mercury – Chromium 6+ – etc. We merely use pure, recyclable materials for packing our components, such as: ! ! ! ! carton cardboard adhesive tape made of paper polystyrene We almost completely refrain from using packing materials such as: ! adhesive tapes made of plastic ! metal clips RoHS Compliance According to the RoHS Directive 2015/863/EU as amended from time to time certain hazardous substances like e.g. lead, cadmium, mercury must not be used any longer in electronic equipment as of July 1st, 2006. For the sake of the environment WIMA has re-fraind from using such substances since years already. WIMA Kondensatoren sind bleifrei konform RoHS 2015/863/EU WIMA capacitors are lead free in accordance with RoHS 2015/863/EU Tape for lead-free WIMA capacitors DIN EN ISO 14001:2004 WIMA’s environmental management has been established in accordance with the guidelines of DIN EN ISO 14001:2004 to optimize the production processes with regard to energy and resources. 04.23 ! incoming material inspection ! metallization ! film inspection ! schoopage ! pre-healing ! pin attachment ! cast resin preparation/encapsu lation ! 100% final inspection ! Testing as per customer require ments WIMA Environmental Policy 15 ® Typical Dimensions for Taping Configuration Vh P P2 Diagram 1: PCM 2.5/5/7.5mm W W1 W0 H H1 W2 P1 D0 d P t F P0 H1 P P1 H P1 d d F P0 P2 Diagram 2: PCM 10/15 mm Diagram 3: PCM 22.5 and 27.5*mm *PCM 27.5 taping possible with two feed holes between components Designation Carrier tape width Dimensions for Radial Taping Symbol PCM 2.5 taping W P0 P2 F PCM 5 taping PCM 7.5 taping PCM 10 taping* PCM 15 taping* PCM 22.5 taping PCM 27.5 taping 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing Hold-down tape width W0 6.0 6.0 12.0 12.0 12.0 12.0 12.0       adhesive tape       adhesive tape        adhesive tape        adhesive tape        adhesive tape        adhesive tape        adhesive tape Hole position W1 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 Hold-down tape position W2 Feed hole diameter D0 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 *38.1 ±1.5 or 50.8 ±1.5 P 12.7 ±1.0 12.7 ±1.0 12.7 ±1.0 25.4 ±1.0 25.4 ±1.0 38.1 ±1.5 0.5 to 3.0 max. 0.5 to 3.0 max. Pitch of component cumulative pitch Feed hole pitch P0 12.7  ±0.3 error max. 12.7 ±0.3 1.0 mm/20 pitch 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch 0.5 to 3.0 max. 12.7 ±0.3 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch 0.5 to 3.0 max. 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch Feed hole centre to pin P1 5.1 ±0.5 3.85 ±0.7 2.6 ±0.7 7.7 ±0.7 5.2 ±0.7 7.8 ±0.7 5.3 ±0.7 Hole centre to component centre P2 6.35 ±1.3 6.35 ±1.3 6.35 ±1.3 12.7 ±1.3 12.7 ±1.3 19.05 ±1.3 19.05 ±1.3 Feed hole centre to bottom H▲ edge of the component 16.5 ±0.3 16.5 ±0.3 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 Feed hole centre to top H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H edge of the component 1 32.25 max. 32.25 max. 24.5 to 31.5 25.0 to 31.5 26.0 to 37.0 30.0 to 43.0 35.0 to 45.0 Pin spacing at +0.8 F 2.5 ±0.5 5.0 7.5 ±0.8 10.0 ±0.8 15 ±0.8 22.5 ±0.8 27.5 ±0.8 upper edge of carrier tape     –0.2 Pin diameter d Component alignment ∆h Total tape thickness t 0.4 ±0.05 0.5 ±0.05 ± 2.0 max. ± 2.0 max. $ +0.06 ± 3.0 max. ± 3.0 max. 04.23 +0.08 +0.08 ± 3.0 max. ± 3.0 max. ± 3.0 max. AMMO 52 ±2 max. REEL   Ø 360 max. B 58 ±2 or REEL ØØ 500 25 ±1  Ø 30 ±1 66 ±2 Unit ▲ +0.08 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 ROLL/AMMO Package ▲ 52 ±2 depending on Ø 360 max. (see also page 158) B REEL Ø 30 ±1 58 ±2 comp. dimensions  +0.06 0.5 ±0.05 or 0.6–0.05 $0.5 ±0.05 or 0.6 –0.05 0.8  –0.05 0.8  –0.05 0.8  –0.05 When ordering please specify dimension H and required packaging type. $ Diameter of pins see General Data.  54 ±2 B 60 ±2  68 ±2 depending on PCM and component dimensions see details page 159. Dims in mm. Please clarify customer-specific deviations with the manufacturer. * PCM 10 and PCM 15 can be crimped to PCM 7.5. Position of components according to PCM 7.5 (sketch 1). P0 = 12.7 or 15.0 is possible 157 ® Types of Tape Packaging of Capacitors for Automatic Radial Insertion O REEL Packaging 340 max.  30±1 25±1 360 max. 500 max. O AMMO Packaging 340 max. 370 max. O ROLL Packaging 34 0m ax. 50 max. 50 max. 70 max. . ax 0 m ax. 34 0 m 49 B BAR CODE (Labelling) Labelling of package units in plain text and with alphanumerical Bar Code BARCODE PDF417 BARCODE 2D Datamatrix ! WIMA supplier number ! Date code ! Customer‘s P/O number ! P/O line ! Customer‘s part number ! WIMA part number ! Quantity ! WIMA confirmation number ! Country of origin ! Customer name ! Handling unit number ! Week of delivery. In addition part description of article capacitance value rated voltage dimensions technical note capacitance tolerance packing connecting information 04.23 – – – – – – – – 158 ® Packing Quantities for Capacitors with Radial Pins in PCM 2.5 mm to 27.5 mm Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 04.23 27.5 mm W  2.5  3  3.8  4.6  5.5  2.5  3  3.5  4.5  4.5  5  5.5  5.5  6.5  7.2  7.2  8.5  8.5 11  2.5  3  4  4.5  5  5.7  7.2  3  4  4  5  6  6  8  5  6  7  8  9  9 11  5  6  7  8.5 10.5 10.5 11  9 11 13 15 17 17 20 H  7  7.5  8.5  9 10  6.5  7.5  8.5  6  9.5 10  7 11.5  8  8.5 13 10 14 16  7  8.5  9  9.5 10.5 12.5 12.5  9  9  9.5 11 12 12.5 12 11 12.5 14 15 14 16 14 14 15 16.5 18.5 19 20.5 21 19 21 24 26 29 34.5 39.5 pcs. per packing unit REEL AMMO Ø 360 Ø 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D 2200 2500 – 2800 – 2000 2300 – 2300 – 1500 1800 – 1800 – 1200 1500 – 1500 –  900 1200 – 1200 – 2200 2500 – 2800 – 2000 2300 – 2300 – 1600 2000 – 2000 – 1300 1500 – 1500 – 1300 1500 – 1500 – 1100 1400 – 1400 – 1000 1200 – 1200 – 1000 1200 – 1200 –  800 1000 – 1000 –  700 1000 – 1000 –  700  950 – 1000 –  600  800 –  800 –  600  800 –  800 –  500  600 –  640 – – 2500 4400 2500 – – 2200 4300 2300 4150 – 1700 3200 1700 3000 – 1500 2900 1400 2700 – 1300 2500 1300 – – 1000 2200 1100 – –  900 1800 1000 – – 1100 2200 – 1900 –  900 1600 – 1450 –  900 1600 – 1400 –  700 1300 – 1100 –  550 1100 – 1000 –  550 1100 – 1000 –  400  800 –  740 –  600 1200 – 1150 –  500 1000 – 1000 –  450  900 –  850 –  400  800 –  740 –  350  700 –  650 –  350  700 –  650 –  300  600 –  540 – –  800 –  770 – –  700 –  640 – –  600 –  550 – –  480 –  450 – –  400 –  360 – –  400 –  360 – –  380 –  350 – – 460/340* – – – – 380/280* – – – –  300 – – – –  270 – – – – – – – – – – – – – – – – – ROLL bulk L Codes  4.6 0B  4.6 0C  4.6 0D  4.6 0E  4.6 0F  7.2 1A  7.2 1B  7.2 1C  7.2 1D  7.2 1E  7.2 1F  7.2 1G  7.2 1H  7.2 1I  7.2 1J  7.2 1K  7.2 1L  7.2 1M  7.2 1N 10 2A 10 2B 10 2C 10.3 2D 10.3 2E 10.3 2F 10.3 2G 13 3A 13 3C 13 3D 13 3F 13 3G 13 3H 13 3I 18 4B 18 4C 18 4D 18 4F 18 4H 18 4J 18 4M 26.5 5A 26.5 5B 26.5 5D 26.5 5F 26.5 5G 26.5 5H 26.5 5I 31.5 6A 31.5 6B 31.5 6D 31.5 6F 31.5 6G 31.5 6I 31.5 6J S 5000 5000 5000 5000 5000 5000 5000 5000 6000 4000 3500 4000 2500 2500 2500 2000 2000 1500 1000 5000 5000 4000 3500 3000 2000 1500 3000 3000 3000 3000 2400 2400 2000 2400 2000 1600 1200 1200  900 1000 1200 1000  760  500 594* 594* 561*  567*  459*  378*  324*  198*  198*   162* * for 2-inch transport pitches. * TPS (Tray-Packing-System). Plate versions may have different packing units. Samples and pre-production needs on request. Rights reserved to amend design data without prior notification. 159 ® Packing Quantities for Capacitors with Radial Pins in PCM 37.5 mm to 52.5 mm Size PCM pcs. per packing unit REEL AMMO Ø 360 Ø 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – ROLL bulk W  9 11 13 15 17 19 20 24 28 31 35 40 H 19 22 24 26 29 32 39.5 45.5 38 46 50 55 L Codes 41.5 7A 41.5 7B 41.5 7C 41.5 7D 41.5 7E 41.5 7F 41.5 7G 41.5 7H 41.5 7L 41.5 7I 41.5 7J 41.5 7K S 441* 357* 294* 252* 154* 140* 126* 112*  84*  84*  35*  28* 48.5 mm** 19 23 27 33 37 31 34 37.5 48 54 56 56 56 56 56 8D 8E 8H 8J 8L 120*  80*  84*  25*  25* – – – – – – – – – – – – – – – – – – – – – – – – – 52.5 mm 25 30 35 45 45 45 45 50 55 65 57 57 57 57 57 9D 9E 9F 9H 9J  70*  60*  25*  20*  20* – – – – – – – – – – – – – – – – – – – – – – – – – 37.5 mm** * TPS (Tray-Packing-System). Plate versions may have different packing units. **For Snubber capacitors in 2-pin version the PCM is changing to 38.5 respective 49.5 mm. Samples and pre-production needs on request. Rights reserved to amend design data without prior notification. 04.23 Updated data on www.wima.com 160 ® WIMA Part Number System A WIMA part number consists of 18 digits and is composed as follows: Field   1 -   4: Type description Field   5 -   6: Rated voltage Field   7 - 10: Capacitance Field 11 - 12: Size and PCM Field 13 - 14: Version code (e.g. Snubber versions) Field 15: Capacitance tolerance Field 16: Packing Field 17 - 18: Pin length (untaped) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 M K S 2 C 0 2 1 0 0 1 A 0 0 M S S D 20 % bulk MKS 2 04.23 Type description: SMD-PET = SMDT SMD-PEN = SMDN SMD-PPS = SMDI FKP 02 = FKP0 MKS 02 = MKS0 FKS 2 = FKS2 FKP 2 = FKP2 FKS 3 = FKS3 FKP 3 = FKP 3 MKS 2 = MKS2 MKP 2 = MKP2 MKS 4 = MKS4 MKP 4 = MKP4 MKP 10 = MKP1 FKP 4 = FKP4 FKP 1 = FKP1 MKP-X2 = MKX2 MKP-X1 R = MKX1 MKP-Y2 = MKY2 MKP 4F = MKPF Snubber MKP = SNMP Snubber FKP = SNFP GTO MKP = GTOM DC-LINK MKP 4 = DCP4 DC-LINK MKP 6 = DCP6 DC-LINK HC = DCHC 63 VDC Rated voltage: 50 VDC = B0 63 VDC = C0 100 VDC = D0 250 VDC = F0 400 VDC = G0 450 VDC = H0 520 VDC = H2 600 VDC = I0 630 VDC = J0 700 VDC = K0 800 VDC = L0 850 VDC = M0 900 VDC = N0 1000 VDC = O1 1100 VDC = P0 1200 VDC = Q0 1250 VDC = R0 1500 VDC = S0 1600 VDC = T0 1700 VDC = TA 2000 VDC = U0 2500 VDC = V0 3000 VDC = W0 4000 VDC = X0 6000 VDC = Y0 230 VAC = 3Y 275 VAC = 1W 300 VAC = 2W 305 VAC = AW 350 VAC = BW 440 VAC = 4W ... 0.01 F Capacitance: 22 pF = 0022 47 pF = 0047 100 pF = 0100 150 pF = 0150 220 pF = 0220 330 pF = 0330 470 pF = 0470 680 pF = 0680 1000 pF = 1100 1500 pF = 1150 2200 pF = 1220 3300 pF = 1330 4700 pF = 1470 6800 pF = 1680 0.01 F = 2100 0.022 F = 2220 0.047 F = 2470 0.1 F = 3100 0.22 F = 3220 0.47 F = 3470 = 4100 1 F 2.2 F = 4220 4.7 F = 4470 = 5100 10 F = 5220 22 F = 5470 47 F 100 F = 6100 220 F = 6220 1000 F = 7100 1500 F = 7150 ... 2.5 x 6.5 x 7.2 Size: 4.8 x 3.3 x 3 Size 1812 4.8 x 3.3 x 4 Size 1812 5.7 x 5.1 x 3.5 Size 2220 5.7 x 5.1 x 4.5 Size 2220 7.2 x 6.1 x 3 Size 2824 7.2 x 6.1 x 5 Size 2824 10.2 x 7.6 x 5 Size 4030 12.7 x 10.2 x 6 Size 5040 15.3 x 13.7 x 7 Size 6054 2.5 x 7 x 4.6 PCM 2.5 3 x 7.5 x 4.6 PCM 2.5 2.5 x 6.5 x 7.2 PCM 5 3 x 7.5 x 7.2 PCM 5 2.5 x 7 x 10 PCM 7.5 3 x 8.5 x 10 PCM 7.5 3 x 9 x 13 PCM 10 4 x 9 x 13 PCM 10 5 x 11 x 18 PCM 15 6 x 12.5 x 18 PCM 15 5 x 14 x 26.5 PCM 22.5 6 x 15 x 26.5 PCM 22.5 9 x 19 x 31.5 PCM 27.5 11 x21 x 31.5 PCM 27.5 9 x 19 x 41.5 PCM 37.5 11 x 22 x 41.5 PCM 37.5 19 x 31 x 56 PCM 48.5 25 x 45 x 57 PCM 52.5 ... Version code: Standard Version A1 Version A1.1.1 Version A2 ... = 00 = 1A = 1B = 2A - = KA = KB = QA = QB = TA = TB = VA = XA = YA = 0B = 0C = 1A = 1B = 2A = 2B = 3A = 3C = 4B = 4C = 5A = 5B = 6A = 6B = 7A = 7B = 8D = 9D 6 -2 Tolerance: ±20 % = M ±10 % = K ±5 % =J ±2.5 % = H ±1 % =E ... Packing: AMMO H16.5 340 x 340 AMMO H16.5 490 x 370 AMMO H18.5 340 x 340 AMMO H18.5 490 x 370 REEL H16.5 360 REEL H16.5 500 REEL H18.5 360 REEL H18.5 500 ROLL H16.5 ROLL H18.5 BLISTER W12 180 BLISTER W12 330 BLISTER W16 330 BLISTER W24 330 Bulk/TPS Standard ... =A =B =C =D =F =H =I =J =N =O =P =Q =R =T =S Pin length (untaped) 3.5 ±0.5 = C9 6 -2 = SD 16 ±1 = P1 ... Pin length (taped) none = 00 The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the pages of the respective WIMA range. 155
FKP1T012205A00KSSD
物料型号:WIMA FKP 1系列
器件简介:这些是具有金属箔电极和内部串联金属化系列连接的聚丙烯(PP)薄膜电容器,适用于非常高脉冲应用。
引脚分配引脚分配信息未在文档中明确列出,但通常这类电容器会有2针或4针的版本。
参数特性: - 电容范围:100 pF至4.7 µF - 额定电压:从400 VDC至6000 VDC - 电容公差:±20%, ±10%, ±5%(特殊公差可询) - 工作温度范围:-55°C至+105°C
功能详解: - 极高脉冲负荷能力 - 自愈特性 - 内部串联连接 - 极低的耗散因子 - 负电容随温度变化 - AEC-Q200认证 - 符合RoHS 2011/65/EU指令
应用信息:适用于高脉冲和高频率应用,例如开关电源、驱动和功率电子转换器、显示器和电视的偏转系统、电子镇流器等。
封装信息: - 封装:耐溶剂、阻燃塑料外壳,UL 94 V-0认证 - 端子:镀锡导线 - 标记:红色外壳,黑色标记
电气数据: - 介电吸收:0.05% - 绝缘电阻在+20°C时:对于0.1 µF的电容,大于1 x 10^5 MΩ;对于0.1 µF的电容,大于30,000秒(MΩ x µF) - 测量电压:100 V/1分钟 - 电压降额:对于DC电压,从+85°C起每K降额1.35%;对于AC电压,从+75°C起每K降额1.35%
机械测试: - 针脚拉力测试:根据IEC 60068-2-21标准,直径0.8mm的针脚10N,直径大于0.8mm的针脚20N - 振动测试:根据IEC 60068-2-6标准,10至2000 Hz,0.75 mm位移幅度或10 g,持续6小时 - 低气压测试:1kPa(10 mbar),根据IEC 60068-2-13标准 - 冲击测试:根据IEC 60068-2-29标准,4000次冲击,390 m/s^2
包装信息:提供卷带和卷轴包装,具体包装信息和图表在目录末尾提供。
FKP1T012205A00KSSD 价格&库存
很抱歉,暂时无法提供与“FKP1T012205A00KSSD”相匹配的价格&库存,您可以联系我们找货
FKP1T012205A00KSSD
    • 3600+3.660983600+0.47361
