FKP2F004701D00JSSD
FKP2F004701D00JSSD
    WIMA
    插件,P=5mm
    薄膜电容 7.20 x 4.50mm 插件
FKP2F004701D00JSSD 数据手册
D WIMA FKP 2 Polypropylene (PP) Film and Foil Capacitors for Pulse Applications in PCM 5 mm Special Features Electrical Data ˜ Pulse duty construction ˜ Close tolerances up to ±2.5 % (±1 % on request) ˜ Very low dissipation factor ˜ Negative capacitance change versus temperature ˜ Very low dielectric absorption ˜ According to RoHS 2002/95/EC Typical Applications For high frequency applications e.g. ˜ Sample and hold ˜ Timing ˜ LC-Filtering ˜ Oscillating circuits ˜ Audio equipment Construction Dielectric: Polypropylene (PP) film Capacitor electrodes: Metal foil Internal construction: Capacitance range: 33 pF to 0.033 mF (E12-values on request) Rated voltages: 63 VDC, 100 VDC, 250 VDC, 400 VDC, 630 VDC, 800 VDC, 1000 VDC Capacitance tolerances: ±10%, ±5%, ±2.5% (±2%, ±1.5% or ±1% available as precision capacitors subject to special enquiry) Operating temperature range: –55+ C to +100+ C Test specifications: In accordance with IEC 60384-13 and EN 131 800 Climatic test category: 55/100/56 in accordance with IEC Insulation resistance at +20+ C:  5 x 105 M¸ (mean value: 1 x 10 6 M¸) Measuring voltage: Ur  =   63 V: U test =   50 V/1 min. Ur 100 V: U test = 100 V/1 min. Dissipation factors at +20) C: tan d Plastic film at f    1 kHz   10 kHz 100 kHz    1 MHz C  1000 pF      3  3  4 10 x x x x 10 -4 10 -4 10 -4 10 -4 Test voltage: 2 U r, 2 sec. Maximum pulse rise time: 1000 V/ msec for pulses equal to the rated voltage Dielectric absorption: 0.05% Temperature coefficient: –200 x 10 -6/+ C (typical) Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and from +75+ C for AC voltages Reliability: Operational life  300 000 hours Failure rate  5 fit (0.5 x U r and 40+ C) 1000 pF < C T 4700 pF C > 4700 pF  4 x 10 -4  4 x 10 -4  5 x 10 -4 –  4 x 10 -4  4 x 10 -4 – – Metal foil electrode Terminating wire Pull test on leads: 10 N in direction of leads according to IEC 60068-2-21 Vibration: 6 hours at 10 ... 2000 Hz and 0.75 mm displacement amplitude or 10 g in accordance with IEC 60068-2-6 Low air density: 1kPa = 10 mbar in accordance with IEC 60068-2-13 Bump test: 4000 bumps at 390 m/sec 2 in accordance with IEC 60068-2-29 Packing Available taped and reeled. Detailed taping information and graphs at the end of the catalogue. For further details and graphs please refer to Technical Information. 11.10 Encapsulation: Solvent-resistant, flame-retardant plastic case with epoxy resin seal, UL 94 V-0 Terminations: Tinned wire. Marking: Colour: Red. Marking: Black. Epoxy resin seal: Yellow Mechanical Tests 30 D WIMA FKP 24 Continuation General Data Capacitance W H L 63 VDC/40 VAC* PCM** Part number   100   150   220   330   470   680 pF „ „ „ „ „ 4.5 4.5 4.5 4.5 4.5 4.5 6 6 6 6 6 6 7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2C001001D00_ _ _ _ FKP2C001501D00_ _ _ _ FKP2C002201D00_ _ _ _ FKP2C003301D00_ _ _ _ FKP2C004701D00_ _ _ _ FKP2C006801D00_ _ _ _ 4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2D001001D00_ _ _ _ FKP2D001501D00_ _ _ _ FKP2D002201D00_ _ _ _ FKP2D003301D00_ _ _ _ FKP2D004701D00_ _ _ _ FKP2D006801D00_ _ _ _ 1000 1500 2200 3300 4700 6800 pF „ „ „ „ „ 4.5 6 4.5 6 4.5   6   4.5   6   4.5   6   4.5   6   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2C011001D00_ _ _ _ FKP2C011501D00_ _ _ _ FKP2C012201D00_ _ _ _ FKP2C013301D00_ _ _ _ FKP2C014701D00_ _ _ _ FKP2C016801D00_ _ _ _ 4.5   6   4.5   6   4.5   6   5.5   7   5.5   7   5.5   7   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2D011001D00_ _ _ _ FKP2D011501D00_ _ _ _ FKP2D012201D00_ _ _ _ FKP2D013301G00_ _ _ _ FKP2D014701G00_ _ _ _ FKP2D016801G00_ _ _ _ 0.01  0.015 0.022 0.033 mF „ „ „ 5.5   7   6.5   8   7.2   8.5 8.5 10   7.2 7.2 7.2 7.2 5 5 5 5 FKP2C021001G00_ _ _ _ FKP2C021501I00_ _ _ _ FKP2C022201J00_ _ _ _ FKP2C023301L00_ _ _ _ 6.5   8   7.2   8.5 8.5 10   7.2 7.2 7.2 5 5 5 FKP2D021001I00_ _ _ _ FKP2D021501J00_ _ _ _ FKP2D022201L00_ _ _ _ 250 VDC/160 VAC* L PCM** Part number W H L 100 VDC/63 VAC* PCM** Part number Capacitance W   100   150   220   330   470   680 pF „ „ „ „ „ 4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2F001001D00_ _ _ _ FKP2F001501D00_ _ _ _ FKP2F002201D00_ _ _ _ FKP2F003301D00_ _ _ _ FKP2F004701D00_ _ _ _ FKP2F006801D00_ _ _ _ 4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2G001001D00_ _ _ _ FKP2G001501D00_ _ _ _ FKP2G002201D00_ _ _ _ FKP2G003301D00_ _ _ _ FKP2G004701D00_ _ _ _ FKP2G006801D00_ _ _ _ 1000 1500 2200 3300 4700 6800 pF „ „ „ „ „ 4.5   6   4.5   6   4.5   6   5.5   7   6.5   8   6.5   8   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2F011001D00_ _ _ _ FKP2F011501D00_ _ _ _ FKP2F012201D00_ _ _ _ FKP2F013301G00_ _ _ _ FKP2F014701I00_ _ _ _ FKP2F016801I00_ _ _ _ 4.5   6   4.5   6   4.5   6   5.5   7   6.5   8   7.2   8.5 7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2G011001D00_ _ _ _ FKP2G011501D00_ _ _ _ FKP2G012201D00_ _ _ _ FKP2G013301G00_ _ _ _ FKP2G014701I00_ _ _ _ FKP2G016801J00_ _ _ _ 0.01  mF 0.015 „ 7.2   8.5 8.5 10   7.2 7.2 5 5 FKP2F021001J00_ _ _ _ FKP2F021501L00_ _ _ _ 8.5 7.2 5 FKP2G021001L00_ _ _ _ H W H 10   * AC voltage: f  1000 Hz; 1.4 x U rms + UDC  U r ** PCM = Printed circuit module = lead spacing. E12 values and individual values available from 27 pF up on request. L H d = 0.5 l 6 -2 d 5 PCM at the lead exit points ( 0.5) Rights reserved to amend design data without prior notification. 400 VDC/220 VAC* PCM** Part number 10 Part number completion: Tolerance:  10 % = K   5 % = J 2.5 % = H   2 % = G 1.5 % = F   1 % = E Packing: bulk = S Lead length: 6-2 = SD Taped version see page 127. Z  1 7 5 3 pF 337 pF 4 -F p -100 pF -220 F p -470 pF -0 F 100 -0 p F 220 -0 p 470 µF -1 0.0 2 µF -2 0.0 3 µF -3 0.0 -- W Dims. in mm. L 0.1 7 5 3 0.01 1 3 5 7 10 3 5 7 100 f/MHz 1000 Impedance change with frequency (general guide). 11.10 Continuation page 32 31 D WIMA FKP 24 Continuation General Data Capacitance W 630 VDC/250 VAC* L PCM** Part number   100   150   220   330   470   680 pF „ „ „ „ „ 4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   4.5   6   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2J001001D00_ _ _ _ FKP2J001501D00_ _ _ _ FKP2J002201D00_ _ _ _ FKP2J003301D00_ _ _ _ FKP2J004701D00_ _ _ _ FKP2J006801D00_ _ _ _ 4.5   6   4.5   6   4.5   6   4.5   6   5.5   7   5.5   7   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2L001001D00_ _ _ _ FKP2L001501D00_ _ _ _ FKP2L002201D00_ _ _ _ FKP2L003301D00_ _ _ _ FKP2L004701G00_ _ _ _ FKP2L006801G00_ _ _ _ 1000 1500 2200 3300 4700 6800 pF „ „ „ „ „ 4.5   6   4.5   6   5.5   7   6.5   8   6.5   8   7.2   8.5 7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2J011001D00_ _ _ _ FKP2J011501D00_ _ _ _ FKP2J012201G00_ _ _ _ FKP2J013301I00_ _ _ _ FKP2J014701I00_ _ _ _ FKP2J016801J00_ _ _ _ 5.5   7   5.5   7   6.5   8   7.2   8.5 8.5 10   7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 FKP2L011001G00_ _ _ _ FKP2L011501G00_ _ _ _ FKP2L012201I00_ _ _ _ FKP2L013301J00_ _ _ _ FKP2L014701L00_ _ _ _ 0.01  mF 8.5 10   7.2 5 FKP2J021001L00_ _ _ _ Capacitance W H    33 pF    47 „    68 „ 4.5   6    4.5   6   4.5   6   7.2 7.2 7.2 5 5 5 FKP2O100331D00_ _ _ _ FKP2O100471D00_ _ _ _ FKP2O100681D00_ _ _ _   100   150   220   330   470   680 pF „ „ „ „ „ 4.5   6    4.5   6   4.5   6   4.5   6   5.5   7   5.5   7   7.2 7.2 7.2 7.2 7.2 7.2 5 5 5 5 5 5 FKP2O101001D00_ _ _ _ FKP2O101501D00_ _ _ _ FKP2O102201D00_ _ _ _ FKP2O103301D00_ _ _ _ FKP2O104701G00_ _ _ _ FKP2O106801G00_ _ _ _ 1000 pF 1500 „ 2200 „ 6.5   8   7.2   8.5 8.5 10   7.2 7.2 7.2 5 5 5 FKP2O111001I00_ _ _ _ FKP2O111501J00_ _ _ _ FKP2O112201L00_ _ _ _ H 1000 VDC/250 VAC* L PCM** Part number W H L 800 VDC/250 VAC* PCM** Part number E12 values and individual values available from 27 pF up on request. Dims. in mm. Part number completion: Tolerance:  10 % = K   5 % = J 2.5 % = H   2 % = G 1.5 % = F   1 % = E Packing: bulk = S Lead length: 6-2 = SD Taped version see page 127. * AC voltage: f  1000 Hz; 1.4 x U rms + UDC  U r ** PCM = Printed circuit module = lead spacing. Rights reserved to amend design data without prior notification. Permissible AC voltage in relation to frequency at 10) C internal temperature rise (general guide). Urms V 5 102 00 630 VDC 800 VDC 1000 VDC 2 32 00 47 5 101 22 10 104 2 5 47 33 pF pF 10 0 5 0 22 01 2 pF 47 pF 0. 105 0 pF 00 µF 106 2 pF pF pF 5 f 107 Hz 11.10 250 2 D Recommendation for Processing and Application of Through-Hole Capacitors Soldering Process Wave soldering T A preheating of through-hole WIMA capacitors is allowed for temperatures T max P 100 ° C. In practice a preheating duration of t P 5 min. has been proven to be best. 260 240 220 200 180 160 140 120 100 80 60 40 20 Single wave soldering Soldering bath temperature: T P 260 ° C Immersion time: t P 5 sec Double wave soldering Soldering bath temperature: T P 260 ° C Immersion time: 2 x t P 3 sec Due to different soldering processes and heat requirements the graphs are to be regarded as a recommendation only. 10 s [°C] see detailenlargement 2s 3s t 30 60 90 120 150 180 210 240 [sec] Typical temperature/time graph for double wave soldering WIMA Quality and Environmental Philosophy ISO 9001:2000 Certification ISO 9001:2000 is an international basic standard of quality assurance systems for all branches of industry. The approval according to ISO 9001:2000 of our factories by the VDE inspectorate certifies that organisation, equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards. WIMA WPCS The WIMA Process Control System (WPCS) is a quality surveillance and optimization system developed by WIMA. WPCS is a major part of the quality-oriented WIMA production. Points of application of WPCS during production process: All WIMA capacitors, irrespective of whether through-hole devices or SMD, are made of environmentally friendly materials. Neither during manufacture nor in the product itself any toxic substances are used, e.g. – – – – – Lead PCB CFC Hydrocarbon chloride Chromium 6+ – – – – – PBB/PBDE Arsenic Cadmium Mercury etc. RoHS Compliance According to the RoHS Directive 2002/95/EC certain hazardous substances like e.g. lead, cadmium, mercury must not be used any longer in electronic equipment as of July 1st, 2006. For the sake of the environment WIMA has refraind from using such substances since years already. We merely use pure, recyclable materials for packing our components, such as: ” carton ” cardboard ” adhesive tape made of paper ” polystyrene We almost completely refrain from using packing materials such as: ” foamed polystyrene (Styropor®) ” adhesive tapes made of plastic ” metal clips Tape for lead-free WIMA capacitors DIN EN ISO 14001:2005 WIMA’s environmental management has been established in accordance with the guidelines of DIN EN ISO 14001:2005. The certification has been granted in June 2006. 11.10 ” incoming material inspection ” metallization ” film inspection ” schoopage ” pre-healing ” lead attachment ” cast resin preparation/ encapsulation ” 100% final inspection ” AQL check WIMA Environmental Policy 14 D Typical Dimensions for Taping Configuration Vh P P2 Diagram 1: PCM 2.5/5/7.5mm W W1 W0 H H1 W2 P1 D0 d P t F P0 H1 P P1 H P1 d d F P0 P2 Diagram 2: PCM 10/15 mm Diagram 3: PCM 22.5 and 27.5*mm *PCM 27.5 taping possible with two feed holes between components Designation Carrier tape width Dimensions for Radial Taping Symbol PCM 2.5 taping W P0 P2 F 18.0 p0.5 PCM 5 taping PCM 7.5 taping PCM 10 taping* PCM 15 taping* PCM 22.5 taping PCM 27.5 taping 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing Hold-down tape width W0 6.0 6.0 12.0 12.0 12.0 12.0 12.0      adhesive tape      adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape Hole position W 1 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 Hold-down tape position W 2 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. Feed hole diameter D 0 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 12.7 p1.0 12.7 p1.0 12.7 p1.0 25.4 p1.0 25.4 p1.0 38.1 p1.5 4.0 p0.2 3*8.1 p1.5 or 50.8 p1.5 Pitch of component P Feed hole pitch P 0 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch Feed hole centre to lead P 1 5.1 p0.5 3.85 p0.7 2.6 p0.7 7.7 p0.7 5.2 p0.7 7.8 p0.7 5.3 p0.7 Hole centre to component centre P 2 6.35 p1.3 6.35 p1.3 6.35 p1.3 12.7 p1.3 12.7 p1.3 19.05 p1.3 19.05 p1.3 Feed hole centre to bottom H edge of the component 16.5 p0.3 18.5 p0.5 16.5 p0.3 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 Feed hole centre to top H edge of the component 1 H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 24.5 to 31.5 H+Hcomponent < H1 25.0 to 31.5 H+Hcomponent < H1 26.0 to 37.0 H+Hcomponent < H1 30.0 to 43.0 H+Hcomponent < H1 35.0 to 45.0 7.5 p0.8 10.0 p0.8 15 p0.8 22.5 p0.8 27.5 p0.8 Lead spacing at +0.8 F 2.5 p0.5 5.0 upper edge of carrier tape     –0.2 +0.08 Dh p 2.0 max. p 2.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 ROLL/AMMO Package (see also page 128) P 360 max. 52 p2 depending on REEL P 30 p1 B 58 p2 comp. dimensions Unit 0.8 +0,08 –0.05 Component alignment t 0.8 +0,08 –0.05 0.4 p0.05 „ 0.5 +0,06 p0.05 or 0.6 –0.05 d „ 0.5 +0.06 p0.05 or 0.6 –0.05 Lead diameter Total tape thickness 0.5 p0.05 0.8 –0.05 AMMO 52 p2 54 p2 max. P 500 max. B 58 p2 or REEL B 60 p2 REEL PP 360 30 p1 P 25 p1 66 p2 68 p2 depending on PCM and component dimensions see details page 130. Dims in mm. 11.10 „ Diameter of leads see General Data. Please clarify customer-specific deviations with the manufacturer. * PCM 10 and PCM 15 can be crimped to PCM 7.5. Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible 127 D Packing Quantities for Bulk Capacitors and TPS* Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 27.5 mm 11.10 37.5 mm W   2.5  3   3.8   4.6   5.5   2.5  3   3.5   4.5   4.5  5   5.5   5.5   6.5   7.2   7.2   8.5   8.5 11   2.5  3  4   4.5  5   5.7   7.2  3  4  4  4  5  5  6  6  8  5  5  6  6  7  7  8  8  9  9 10 11  5  6  7  8   8.5 10 10.5 10.5 11 12  9 11 13 13 15 15 17 17 20 20  9 11 13 15 17 19 20 24 H  7   7.5   8.5  9 10   6.5   7.5   8.5  6   9.5 10  7 11.5  8   8.5 13 10 14 16  7   8.5  9   9.5 10.5 12.5 12.5  9   8.5  9   9.5 10 11 12 12.5 12 11 13 12.5 14 14 15 15 17 14 16 18 14 14 15 16.5 20 18.5 22 19 20.5 21 24 19 21 24 25 26 26 29 34.5 32 39.5 19 22 24 26 29 32 39.5 45.5 L   4.6   4.6   4.6   4.6   4.6   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2 10 10 10 10.3 10.3 10.3 10.3 13 13.5 13 13 13.5 13 13 13 13 18 19 18 19 18 19 18 19 18 18 19 18 26.5 26.5 26.5 28 26.5 28 26.5 26.5 26.5 28 31.5 31.5 31.5 33 31.5 33 31.5 31.5 33 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 Codes 0B 0C 0D 0E 0F 1A 1B 1C 1D 1E 1F 1G 1H 1I 1J 1K 1L 1M 1N 2A 2B 2C 2D 2E 2F 2G 3A FA 3C 3D FB 3F 3G 3H 3I 4B FC 4C FD 4D FE 4F FF 4H 4J FG 4M 5A 5B 5D FH 5F FI 5G 5H 5I FJ 6A 6B 6D FK 6F FL 6G 6I FM 6J 7A 7B 7C 7D 7E 7F 7G 7H Rights reserved to amend design data without prior notification. Samples and pre-production needs on request. pcs. per packaging unit bulk Mini Standard Maxi M S G 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 2000 5000 10 000 1000 5000 – 1000 5000 – 1000 6000 – 1000 4000 – 1000 3500 – 1000 4000 –   500 2500 – 1000 2500 –   500 2500 –   500 2000 –   500 2000 –   500 1500 –   250 1000 – 1000 5000 – 1000 5000 – 1000 4000 – 1000 3500 – 1000 3000 – 2000 –   500   500 1500 – 1000 3000 – 3000 –   500 1000 3000 – 1000 3000 –   500 2000 – 1000 3000 – 2400 –   800   800 2400 –   500 2000 –   800 2400 –   200 1000 2000 –   500   250 1000   400 1600 –   250 1000 1200 –   400   100   500 1200 –   400   300   900 –   100   500 –   300 1000 –   300 1200 –   250 1000 – –   190   760   125   500 – –   125   500 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – Moulded versions. pcs. per packaging unit/TPS* Mini Standard X Y – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – –   90 540 170 680 170 680 170 680   75 450 160 640 136 544 112 448   56 336   96 384   48 288   88 176   88 176   36 216   36 144   60 480   51 408   84 252   72 144   66 132   54 108   27 108   21   84 * Tray-Packing-System 129 D Packing Units for Taped Capacitors with Radial Leads ROLL Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 27.5 mm W   2.5  3   3.8   4.6   5.5   2.5  3   3.5   4.5   4.5  5   5.5   5.5   6.5   7.2   7.2   8.5   8.5 11   2.5  3  4   4.5  5   5.7   7.2  3  4  4  4  5  5  6  6  8  5  5  6  6  7  7  8  8  9  9 10 11  5  6  7  8   8.5 10 10.5 10.5 11 12  9 11 13 15 H  7   7.5   8.5  9 10   6.5   7.5   8.5  6   9.5 10  7 11.5  8   8.5 13 10 14 16  7   8.5  9   9.5 10.5 12.5 12.5  9   8.5  9   9.5 10 11 12 12.5 12 11 13 12.5 14 14 15 15 17 14 16 18 14 14 15 16.5 20 18.5 22 19 20.5 21 24 19 21 24 26 L   4.6   4.6   4.6   4.6   4.6   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2 10 10 10 10.3 10.3 10.3 10.3 13 13.5 13 13 13.5 13 13 13 13 18 19 18 19 18 19 18 19 18 18 19 18 26.5 26.5 26.5 28 26.5 28 26.5 26.5 26.5 28 31.5 31.5 31.5 31.5 Codes 0B 0C 0D 0E 0F 1A 1B 1C 1D 1E 1F 1G 1H 1I 1J 1K 1L 1M 1N 2A 2B 2C 2D 2E 2F 2G 3A FA 3C 3D FB 3F 3G 3H 3I 4B FC 4C FD 4D FE 4F FF 4H 4J FG 4M 5A 5B 5D FH 5F FI 5G 5H 5I FJ 6A 6B 6D 6F Moulded versions. AMMO 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 A C B D 2800 – 2300 – 1800 – 1500 – 1200 – 2800 – 2300 – 2000 – 1500 – 1500 – 1400 – 1200 – 1200 – 1000 – 1000 – 1000 –   800 –   800 –   700 – 2500 – 2300 4150 1700 3100 1400 2800 1300 – 1100 – 1000 – – 1900 – 1450 – 1450 – 1400 – 1200 – 1200 – 1000 – 1000 –   740 – 1150 – 1200 – 1000 – 1000 –   850 –   850 –   740 –   740 –   650 –   650 –   590 –   540 –   770 –   640 –   550 –   480 –   450 –   380 –   360 –   360 –   350 –   310 –   420 –   350 –   290 –   250 Rights reserved to amend design data without prior notification. 11.10 * for 2-inch transport pitches. Samples and pre-production needs 1 packing unit minimum. H16.5 H18.5 N O 2200 2000 1500 1200   900 2200 2000 1600 1300 1300 1100 1000 1000   800   700   700   600   600   500 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – REEL P 360 P 500 H16.5 H18.5 H16.5 H18.5 F I H J 2500 – 2300 – 1800 – 1500 – 1200 – 2500 – 2300 – 2000 – 1500 – 1500 – 1400 – 1200 – 1200 – 1000 – 1000 –   950 –   800 –   800 –   700 – 2500 4400 2200 4300 1700 3200 1500 2900 1300 2500 1000 2200   900 1800 1100 2200   900 1600   900 1600   900 1600   700 1300   700 1300   550 1100   550 1100   400   800   600 1200   600 1200   500 1000   500 1000   450   900   450   900   400   800   400   800   350   700   350   700   300   650   300   600 –   800 –   700 –   600 –   500 –   480 –   420 –   400 –   400 –   380 –   350 – 460/340* – 380/280* –   300 –   270 130 D WIMA Part Number System A WIMA part number consists of 18 digits and is composed as follows: Field   1 -   4: Type description Field   5 -   6: Rated voltage Field   7 - 10: Capacitance Field 11 - 12: Size and PCM Field 13 - 14: Special features (e.g. Snubber versions) Field 15: Capacitance tolerance Field 16: Packing Field 17 - 18: Lead length (untaped) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 M K S 2 C 0 2 1 0 0 1 A 0 0 M S S D 20 % bulk MKS 2 11.10 Type description: SMD-PET = SMD-PPS = FKP 02 = MKS 02 = FKS 2 = FKP 2 = MKS 2 = MKP 2 = FKS 3 = FKP 3 = MKS 4 = MKP 4 = MKP 10 = FKP 4 = FKP 1 = MKP-X2 = MKP-X2 R = MKP-Y2 = MP 3-X2 = MP 3-X1 = MP 3-Y2 = MP 3R-Y2 = Snubber MKP = Snubber FKP = GTO MKP = DC-LINK MKP 4 = DC-LINK MKP C = DC-LINK HC = SuperCap C = SuperCap MC = SuperCap R = SuperCap MR = 63 VDC SMDT SMDI FKP0 MKS0 FKS2 FKP2 MKS2 MKP2 FKS3 FKP3 MKS4 MKP4 MKP1 FKP4 FKP1 MKX2 MKXR MKY2 MPX2 MPX1 MPY2 MPRY SNMP SNFP GTOM DCP4 DCPC DCH_ SCSC SCMC SCSR SCMR Rated voltage: 2.5 VDC = A1 4 VDC = A2 14 VDC = A3 28 VDC = A4 40 VDC = A5 5 VDC = A6 50 VDC = B0 63 VDC = C0 100 VDC = D0 160 VDC = E0 250 VDC = F0 400 VDC = G0 450 VDC = H0 600 VDC = I0 630 VDC = J0 700 VDC = K0 800 VDC = L0 850 VDC = M0 900 VDC = N0 1000 VDC = O1 1100 VDC = P0 1200 VDC = Q0 1250 VDC = R0 1500 VDC = S0 1600 VDC = T0 2000 VDC = U0 2500 VDC = V0 3000 VDC = W0 4000 VDC = X0 6000 VDC = Y0 250 VAC = 0W 275 VAC = 1W 300 VAC = 2W 400 VAC = 3W 440 VAC = 4W 500 VAC = 5W ... 0.01 mF Capacitance: 22 pF = 0022 47 pF = 0047 100 pF = 0100 150 pF = 0150 220 pF = 0220 330 pF = 0330 470 pF = 0470 680 pF = 0680 1000 pF = 1100 1500 pF = 1150 2200 pF = 1220 3300 pF = 1330 4700 pF = 1470 6800 pF = 1680 0.01 mF = 2100 0.022 mF = 2220 0.047 mF = 2470 0.1 mF = 3100 0.22 mF = 3220 0.47 mF = 3470 = 4100 1 mF 2.2 mF = 4220 4.7 mF = 4470 = 5100 10 mF = 5220 22 mF = 5470 47 mF 100 mF = 6100 220 mF = 6220 1F = A010 2.5 F = A025 50 F = A500 100 F = B100 110 F = B110 600 F = B600 1200 F = C120 ... - 2.5 x 6.5 x 7.2 Size: 4.8 x 3.3 x 3 Size 1812 4.8 x 3.3 x 4 Size 1812 5.7 x 5.1 x 3.5 Size 2220 5.7 x 5.1 x 4.5 Size 2220 7.2 x 6.1 x 3 Size 2824 7.2 x 6.1 x 5 Size 2824 10.2 x 7.6 x 5 Size 4030 12.7 x 10.2 x 6 Size 5040 15.3 x 13.7 x 7 Size 6054 2.5 x 7 x 4.6 PCM 2.5 3 x 7.5 x 4.6 PCM 2.5 2.5 x 6.5 x 7.2 PCM 5 3 x 7.5 x 7.2 PCM 5 2.5 x 7 x 10 PCM 7.5 3 x 8.5 x 10 PCM 7.5 3 x 9 x 13 PCM 10 4 x 9 x 13 PCM 10 5 x 11 x 18 PCM 15 6 x 12.5 x 18 PCM 15 5 x 14 x 26.5 PCM 22.5 6 x 15 x 26.5 PCM 22.5 9 x 19 x 31.5 PCM 27.5 11 x21 x 31.5 PCM 27.5 9 x 19 x 41.5 PCM 37.5 11 x 22 x 41.5 PCM 37.5 94 x 49 x 182 DCH_ 94 x 77 x 182 DCH_ ... Special features: Standard = 00 Version A1 = 1A Version A1.1.1 = 1B Version A1.2 = 1C ... = = = = = = = = = = = = = = = = = = = = = = = = = = = X1 X2 Y1 Y2 T1 T2 K1 V1 Q1 0B 0C 1A 1B 2A 2B 3A 3C 4B 4C 5A 5B 6A 6B 7A 7B H0 H1 Tolerance: 20 % = 10 % = 5 % = 2.5 % = 1 % = ... 6 -2 M K J H E Packing: AMMO H16.5 340 x 340 AMMO H16.5 490 x 370 AMMO H18.5 340 x 340 AMMO H18.5 490 x 370 REEL H16.5 360 REEL H16.5 500 REEL H18.5 360 REEL H18.5 500 ROLL H16.5 ROLL H18.5 BLISTER W12 180 BLISTER W12 330 BLISTER W16 330 BLISTER W24 330 Bulk Mini Bulk Standard Bulk Maxi TPS Mini TPS Standard ... = = = = = = = = = = = = = = = = = = = A B C D F H I J N O P Q R T M S G X Y Lead length (untaped) 3.5 ±0.5 = C9 6 -2 = SD 16 ±1 = P1 ... The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the pages of the respective WIMA range. 125
FKP2F004701D00JSSD
物料型号:WIMA FKP 2
器件简介:WIMA FKP 2系列是专为脉冲应用设计的聚丙烯(PP)膜和箔电容,具有脉冲工作构造,测试电压为额定电压的两倍,持续2秒。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 紧密的容差范围可达±2.5%(可按要求提供±1%) - 最大脉冲上升时间:对于等于额定电压的脉冲为1000 V/毫秒 - 非常低的耗散因子 - 随温度变化的负电容变化 - 介电吸收:0.05% - 温度系数:-200 x 10^-6/°C(典型值) - 电压降额:根据RoHS 2002/95/EC
功能详解: - 典型应用包括采样保持、定时、LC滤波、振荡电路和音频设备。 - 在+85°C时直流电压的电压降额因子为1.35%/K,交流电压从+75°C开始。 - 可靠性:操作寿命超过300,000小时,故障率小于5FIT(在0.5 x Ur和40°C下)。
应用信息:适用于高频应用,如采样保持、定时、LC滤波和振荡电路。
封装信息: - 封装为低空气密度、耐溶剂、阻燃的塑料外壳,采用环氧树脂密封,符合UL 94 V-0标准。 - 引线为镀锡线。 - 标记颜色为红色,黑色标记。
机械测试: - 引线拉力测试:按照IEC 60068-2-21标准,10N力作用于引线方向。 - 振动测试:根据IEC 60068-2-6标准,6小时10...2000 Hz和0.75 mm位移幅度或10 g。
电气数据: - 电容范围:33 pF至0.033 mF(可按要求提供E12值) - 额定电压:63 VDC、100 VDC、250 VDC、400 VDC、630 VDC、800 VDC、1000 VDC - 电容容差:±10%、±5%、±2.5%(可提供±2%、±1.5%或±1%的精密电容器,需特别询问) - 工作温度范围:-55°C至+100°C - 绝缘电阻:在+20°C时,最小值为5 × 10^5 MΩ(平均值:1 x 10^6 MΩ)
包装信息:可提供卷带和卷轴包装。详细卷带信息和图表在目录末尾提供。
FKP2F004701D00JSSD 价格&库存
很抱歉,暂时无法提供与“FKP2F004701D00JSSD”相匹配的价格&库存,您可以联系我们找货
FKP2F004701D00JSSD
  • 12000+1.2829312000+0.16597
FKP2F004701D00JSSD
  • 12000+1.1617512000+0.15029
