FKP1R012204B00KSSD
FKP1R012204B00KSSD
    WIMA
    插件
FKP1R012204B00KSSD 数据手册
D WIMA FKP 1 Polypropylene (PP) Capacitors for Pulse Applications with Metal Foil Electrodes, Schoopage Contacts, Double-Sided Metallization and Self-Healing Internal Series Connection for Highest Current Carrying Capability PCM 15 mm to 37.5 mm Special Features Electrical Data ˜ Extremely high pulse duty ˜ Self-healing ˜ Internal series connection ˜ Very low dissipation factor ˜ Negative capacitance change versus temperature ˜ According to RoHS 2002/95/EC Typical Applications For high pulse and high frequency applications e.g. ˜ Switch mode power supplies ˜ Converters in drives and power electronics ˜ Deflection systems in monitors and TV-sets ˜ Electronic ballasts Construction Dielectric: Polypropylene (PP) film Capacitor electrodes: Aluminium foil and double-sided metallized plastic film Internal construction: Plastic film Metal foil electrode Electrode carrier plastic film metallized on both sides Metal contact layer (schoopage) Terminating wire Dissipation factors at +20+ C: tan d at f C0.1 mF 0.1 mF P C  0.22 mF    1 kHz   3 x 10-4   10 kHz   4 x 10-4 100 kHz 10 x 10-4  3 x 10-4  6 x 10-4 – Dielectric absorption: 0.05 % Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and from +75+ C for AC voltages Reliability: Operational life  300 000 hours Failure rate  1 fit (0.5 x Ur and 40+ C) Capacitance max. pulse rise time V/msec at T A < 40) C pF/mF 400 VDC 630 VDC 1000 VDC 1250 VDC 1600 VDC 2000 VDC 4000 VDC 6000 VDC 100   ... 330   ... 1000  ... 3300  ... 0.01  ... 0.033 ... 0.1   ... 220   – 680   – 2200  29000 6800    9000 0.022   9000 0.068   9000 0.22    7000 – – 29000 14000 11000 11000 11000 – – 29000 27000 11000 11000 11000 – – 29000 29000 11000 11000 11000 56000 51000 46000 29000 11000 11000 11000 56000 56000 51000 29000 13000 11000 – – 56000 51000 29000 13000 – – – 56000 51000 29000 13000 – – for pulses equal to the rated voltage Mechanical Tests Pull test on leads: d T 0.8 l: 10 N in direction of leads d > 0.8 l: 20 N in direction of leads according to IEC 60068-2-21 Vibration: 6 hours at 10 ... 2000 Hz and 0.75 mm displacement amplitude or 10 g in accordance with IEC 60068-2-6 Low air density: 1kPa = 10 mbar in accordance with IEC 60068-2-13 Bump test: 4000 bumps at 390 m/sec 2 in accordance with IEC 60068-2-29 Packing Available taped and reeled up to and including case size 15 x 26 x 31.5 / PCM 27.5 mm. Detailed taping information and graphs at the end of the catalogue. For further details and graphs please refer to Technical Information. 11.10 Encapsulation: Solvent-resistant, flame-retardant plastic case with epoxy resin seal, UL 94 V-0 Terminations: Tinned wire. Marking: Colour: Red. Marking: Black. Epoxy resin seal: Yellow Capacitance range: 100 pF to 0.22 mF (E12-values on request) Rated voltages: 400 VDC, 630 VDC, 1000 VDC, 1250 VDC, 1600 VDC, 2000 VDC, 4000 VDC, 6000 VDC Capacitance tolerances: ±20%, ±10%, ±5% (other tolerances are available subject to special enquiry) Operating temperature range: –55+ C to +100+ C Climatic test category: 55/100/56 in accordance with IEC Insulation resistance at +20+ C: C T 0.1 mF:  1 x 10 5 M¸ (mean value: 5 x 10 5 M¸) C  0.1 mF:  30 000 sec (M¸ x mF) (mean value: 100 000 sec) Measuring voltage: 100 V/1 min. Test voltage: 2 U r, 2 sec / 6 kV: 1.6 U r, 2 sec. Maximum pulse rise time: 66 D WIMA FKP 1 Continuation General Data Capacitance 1000 1500 2200 3300 4700 6800 W pF   5   „   5   „   5   „   5   „   5   „   5   H 18   18   18   18   18   18   15   15   15   15   15   15   FKP1J011004B00_ _ _ _ FKP1J011504B00_ _ _ _ FKP1J012204B00_ _ _ _ FKP1J013304B00_ _ _ _ FKP1J014704B00_ _ _ _ FKP1J016804C00_ _ _ _ 0.01  mF   5   11   18   15   FKP1G021004B00_ _ _ _   7     5   0.015 „   6   12.5 18   15   FKP1G021504C00_ _ _ _   8     6   0.022 „   7   14   18   15   FKP1G022204D00_ _ _ _   7     5   14   26.5 22.5 FKP1G022205A00_ _ _ _ 0.033 „   8   15   18   15   FKP1G023304F00_ _ _ _   8.5   6   15   26.5 22.5 FKP1G023305B00_ _ _ _ 0.047 „   7   16.5 26.5 22.5 FKP1G024705D00_ _ _ _ 10.5   9   0.068 „   8.5 18.5 26.5 22.5 FKP1G026805F00_ _ _ _ 11     9   14   14   15   15   16.5 18   26.5 18   26.5 26.5 15   22.5 15   22.5 22.5 FKP1J021004D00_ _ _ _ FKP1J021005A00_ _ _ _ FKP1J021504F00_ _ _ _ FKP1J021505B00_ _ _ _ FKP1J022205D00_ _ _ _ 18.5 26.5 22.5 FKP1J023305F00_ _ _ _ 20.5 19   21   19   26.5 31.5 31.5 41.5 22.5 27.5 27.5 37.5 FKP1J024705H00_ _ _ _ FKP1J024706A00_ _ _ _ FKP1J026806B00_ _ _ _ FKP1J026807A00_ _ _ _ 0.1   mF 10.5   9   0.15  „ 11   0.22  „ 13   13  11  13  15  24   22   24   26   31.5 41.5 41.5 41.5 27.5 37.5 37.5 37.5 FKP1J031006D00_ _ _ _ FKP1J031007B00_ _ _ _ FKP1J031507C00_ _ _ _ FKP1J032207D00_ _ _ _ W H W H 26.5 31.5 31.5 31.5 15   15   15   15   15   15   22.5 27.5 27.5 27.5 FKP1G031005H00_ _ _ _ FKP1G031006A00_ _ _ _ FKP1G031506B00_ _ _ _ FKP1G032206D00_ _ _ _ 1000 VDC/600 VAC* L PCM** Part number 1250 VDC/600 VAC* L PCM** Part number 1000 pF   5   11  18    15   FKP1O111004B00_ _ _ _   5   1500 „   5   11  18    15   FKP1O111504B00_ _ _ _   5   2200 „   5   11  18    15   FKP1O112204B00_ _ _ _   5   3300 „   5   11  18    15   FKP1O113304B00_ _ _ _   6   4700 „   6   12.5 18    15   FKP1O114704C00_ _ _ _   7   6800 „   7   14  18    15   FKP1O116804D00_ _ _ _   8     5   11   11   11   12.5 14   15   14   18   18   18   18   18   18   26.5 15   15   15   15   15   15   22.5 0.01  mF   8   15  18    15   FKP1O121004F00_ _ _ _   7     6   15  26.5 22.5 FKP1O121005B00_ _ _ _ 0.015 „   6   15  26.5 22.5 FKP1O121505B00_ _ _ _   8.5 0.022 „   8.5 18.5 26.5 22.5 FKP1O122205F00_ _ _ _ 10.5 0.033 „ 10.5 20.5 26.5 22.5 FKP1O123305H00_ _ _ _ 11     9   19  31.5 27.5 FKP1O123306A00_ _ _ _   9   0.047 „ 11   21  31.5 27.5 FKP1O124706B00_ _ _ _ 13   11   0.068 „ 13   24  31.5 27.5 FKP1O126806D00_ _ _ _ 11   11   22  41.5 37.5 FKP1O126807B00_ _ _ _ 16.5 26.5 22.5 FKP1R021005D00_ _ _ _ 18.5 20.5 21   19   24   22   22   26.5 26.5 31.5 41.5 31.5 41.5 41.5 22.5 22.5 27.5 37.5 27.5 37.5 37.5 26   29   32   41.5 41.5 41.5 37.5 FKP1R031007D00_ _ _ _ 37.5 FKP1R031507E00_ _ _ _ 37.5 FKP1R032207F00_ _ _ _ 0.1   mF 0.15  „ 0.22  „ 13   15   19   24  26  32  41.5 41.5 41.5 37.5 FKP1O131007C00_ _ _ _ 37.5 FKP1O131507D00_ _ _ _ 37.5 FKP1O132207F00_ _ _ _ 15   17   19   * AC voltage: f T 1000 Hz; 1.4 x U rms + UDC T U r W ** PCM = Printed circuit module = lead spacing L H Dims. in mm. Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. 11.10 630 VDC/400 VAC* L PCM** Part number H 11   11   11   11   11   12.5 20.5 19   21   24   18   18   18   18   18   18   W FKP1G011004B00_ _ _ _   5   FKP1G011504B00_ _ _ _   5   FKP1G012204B00_ _ _ _   5   FKP1G013304B00_ _ _ _   5   FKP1G014704B00_ _ _ _   5   FKP1G016804B00_ _ _ _   6   Capacitance 11   11   11   11   11   11   400 VDC/250 VAC* L PCM** Part number Rights reserved to amend design data without prior notification. Continuation page 68 l d PCM 0.8 15 - 27.5 1.0 37.5 6 -2 d PCM at the lead exit points ( 0.4) FKP1R011004B00_ _ _ _ FKP1R011504B00_ _ _ _ FKP1R012204B00_ _ _ _ FKP1R013304C00_ _ _ _ FKP1R014704D00_ _ _ _ FKP1R016804F00_ _ _ _ FKP1R016805A00_ _ _ _ FKP1R021505F00_ _ _ _ FKP1R022205H00_ _ _ _ FKP1R023306B00_ _ _ _ FKP1R023307A00_ _ _ _ FKP1R024706D00_ _ _ _ FKP1R024707B00_ _ _ _ FKP1R026807B00_ _ _ _ Part number completion: Tolerance: 20 % = M 10 % = K   5 % = J Packing: bulk = S Lead length: 6-2 = SD Taped version see page 127. 67 D WIMA FKP 14 Continuation General Data Capacitance   100   150   220   330   470   680 W H 1600 VDC/650 VAC* L PCM** Part number W H 2000 VDC/700 VAC* L PCM** Part number   pF   5     „   5     „   5     „   5     „   5     „   5   11   11   11   11   11   11   18   18   18   18   18   18   15   15   15   15   15   15   FKP1T001004B00_ _ _ _   5   FKP1T001504B00_ _ _ _   5   FKP1T002204B00_ _ _ _   5   FKP1T003304B00_ _ _ _   6   FKP1T004704B00_ _ _ _   6   FKP1T006804B00_ _ _ _   6   11   11   11   12.5 12.5 12.5 18   18   18   18   18   18   15   15   15   15   15   15   FKP1U001004B00_ _ _ _ FKP1U001504B00_ _ _ _ FKP1U002204B00_ _ _ _ FKP1U003304C00_ _ _ _ FKP1U004704C00_ _ _ _ FKP1U006804C00_ _ _ _ 1000   pF   6     5   1500   „   7     5   2200   „   8     5   3300   „   6   4700   „   7   6800   „   8.5 12.5 14   14   14   15   14   15   16.5 18.5 18   26.5 18   26.5 18   26.5 26.5 26.5 26.5 15   22.5 15   22.5 15   22.5 22.5 22.5 22.5 FKP1T011004C00_ _ _ _   7   FKP1T011005A00_ _ _ _   5   FKP1T011504D00_ _ _ _   6   FKP1T011505A00_ _ _ _ FKP1T012204F00_ _ _ _   7   FKP1T012205A00_ _ _ _ FKP1T013305B00_ _ _ _   7   FKP1T014705D00_ _ _ _   8.5 FKP1T016805F00_ _ _ _ 10.5 14   14   15   18   15   26.5 22.5 26.5 22.5 FKP1U011004D00_ _ _ _ FKP1U011005A00_ _ _ _ FKP1U011505B00_ _ _ _ 16.5 26.5 22.5 FKP1U012205D00_ _ _ _ 16.5 18.5 20.5 26.5 22.5 26.5 22.5 26.5 22.5 FKP1U013305D00_ _ _ _ FKP1U014705F00_ _ _ _ FKP1U016805H00_ _ _ _ 11   13   15   13   13   21   24   26   24   24   31.5 31.5 31.5 41.5 41.5 27.5 27.5 27.5 37.5 37.5 FKP1U021006B00_ _ _ _ FKP1U021506D00_ _ _ _ FKP1U022206F00_ _ _ _ FKP1U022207C00_ _ _ _ FKP1U023307C00_ _ _ _ 17   19   29   32   41.5 37.5 41.5 37.5 FKP1U024707E00_ _ _ _ FKP1U026807F00_ _ _ _ W H 0.01  mF 10.5 20.5 26.5 22.5 FKP1T021005H00_ _ _ _ 0.015 „ 11   21   31.5 27.5 FKP1T021506B00_ _ _ _ 0.022 „ 11   21   31.5 27.5 FKP1T022206B00_ _ _ _ 0.033 „ 13   24   31.5 27.5 FKP1T023306D00_ _ _ _ 13   24   41.5 37.5 FKP1T023307C00_ _ _ _ 0.047 „ 13   24   41.5 37.5 FKP1T024707C00_ _ _ _ 0.068 „ 15   26   41.5 37.5 FKP1T026807D00_ _ _ _ 0.1   mF 17   29   Capacitance W H 41.5 37.5 FKP1T031007E00_ _ _ _ 4000 VDC/700 VAC* L PCM** Part number 6000 VDC/700 VAC* L PCM** Part number   470   pF   5     680   „   5   14   14   26.5 26.5 22.5 FKP1X004705A00_ _ _ _   5   22.5 FKP1X006805A00_ _ _ _   5   14   14   26.5 26.5 22.5 FKP1Y004705A00_ _ _ _ 22.5 FKP1Y006805A00_ _ _ _ 1000 1500 2200 3300 4700 6800 14   16.5 18.5 20.5 21   24   26.5 26.5 26.5 26.5 31.5 31.5 22.5 22.5 22.5 22.5 27.5 27.5 14   16.5 20.5 20.5 21   24   26.5 26.5 26.5 26.5 31.5 31.5 22.5 22.5 22.5 22.5 27.5 27.5 0.01  mF 0.015 „ 0.022 „ 26   24   29   31.5 41.5 41.5 27.5 FKP1X021006F00_ _ _ _ 37.5 FKP1X021507C00_ _ _ _ 37.5 FKP1X022207E00_ _ _ _ 26   24   29   31.5 41.5 41.5 27.5 FKP1Y021006F00_ _ _ _ 37.5 FKP1Y021507C00_ _ _ _ 37.5 FKP1Y022207E00_ _ _ _   pF   5     „   7     „   8.5   „ 10.5   „ 11     „ 13   15   13   17   FKP1X011005A00_ _ _ _   5   FKP1X011505D00_ _ _ _   7   FKP1X012205F00_ _ _ _ 10.5 FKP1X013305H00_ _ _ _ 10.5 FKP1X014706B00_ _ _ _ 11   FKP1X016806D00_ _ _ _ 13   15   13   17   FKP1Y011005A00_ _ _ _ FKP1Y011505D00_ _ _ _ FKP1Y012205H00_ _ _ _ FKP1Y013305H00_ _ _ _ FKP1Y014706B00_ _ _ _ FKP1Y016806D00_ _ _ _ * AC voltage: f T 1000 Hz; 1.4 x U rms + UDC T U r ** PCM = Printed circuit module = lead spacing Dims. in mm. Ionisation inception level in isolated cases may be lower than admissible rated AC voltage. Part number completion: Tolerance: 20 % = M 10 % = K   5 % = J Packing: bulk = S Lead length: 6-2 = SD Taped version see page 127. Rights reserved to amend design data without prior notification. 11.10 AC voltage graphs see page 61. 68 D WIMA WIMAMKP FKP 10 4 Continuation Permissible AC voltage in relation to frequency at 10) C internal temperature rise (general guide). WIMA FKP 1 Permissible AC voltage in relation to frequency at 10) C internal temperature rise (general guide). Urms V 600 5 Urms V 5 250 2 0. 0. 1 102 02 2 µF 5 400 VDC 2 101 103 2 5 104 2 47 0. 0. 1 102 5 00 105 5 Urms V 5 400 2 10 0 22 0 p F p µF F 00 pF 0. 01 µF 0. 04 7 0. µF 22 µF 47 00 02 2 µF µF 630 VDC 10 pF 11.10 103 2 5 0. 22 104 2 5 105 102 5 0. 2 01 04 µF 7 µF µF 00 µF pF 10 00 pF 2 00 pF 02 2 µF 0. 1 µF 102 0. 1000 VDC 47 101 102 µF 5 2 5 104 2 105 5 47 02 µF 2 10 00 µF 00 pF 5 f 106 Hz 1600 VDC 47 00 22 22 0. 7 µF 01 µF 00 Technical information and general data see page 66. 5 104 2 5 105 104 2 105 5 0. µF 102 5 2000 VDC 4000 VDC 6000 VDC 2 2 5 2 pF 101 103 2 2 5 f 106 Hz 10 22 470 0 0 0. 0 p pF 2 pF 01 20 F pF µ 7 F 10 µF 00 47 pF 0 0. 02 0 p F 2 0. µF 06 8 µF 04 04 0. 103 Urms V 700 5 pF 0. 1250 VDC 5 f 106 Hz 2 2 101 5 101 103 Urms V 600 5 pF 10 100 00 pF 470 pF 02 pF 0. 2 µ 22 1 F 00 µF p 0. 01 F 0. 04 µF 7 µF 0. 2 2 0. 1 µF 01 04 7 22 0. pF 22 00 0. 0. 0. 00 2 101 5 f 106 Hz 2 2 22 0. Urms V 650 5 2 5 f 106 Hz 103 2 5 104 2 5 105 2 5 f 106 Hz 61 D Recommendation for Processing and Application of Through-Hole Capacitors Soldering Process Wave soldering T A preheating of through-hole WIMA capacitors is allowed for temperatures T max P 100 ° C. In practice a preheating duration of t P 5 min. has been proven to be best. 260 240 220 200 180 160 140 120 100 80 60 40 20 Single wave soldering Soldering bath temperature: T P 260 ° C Immersion time: t P 5 sec Double wave soldering Soldering bath temperature: T P 260 ° C Immersion time: 2 x t P 3 sec Due to different soldering processes and heat requirements the graphs are to be regarded as a recommendation only. 10 s [°C] see detailenlargement 2s 3s t 30 60 90 120 150 180 210 240 [sec] Typical temperature/time graph for double wave soldering WIMA Quality and Environmental Philosophy ISO 9001:2000 Certification ISO 9001:2000 is an international basic standard of quality assurance systems for all branches of industry. The approval according to ISO 9001:2000 of our factories by the VDE inspectorate certifies that organisation, equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards. WIMA WPCS The WIMA Process Control System (WPCS) is a quality surveillance and optimization system developed by WIMA. WPCS is a major part of the quality-oriented WIMA production. Points of application of WPCS during production process: All WIMA capacitors, irrespective of whether through-hole devices or SMD, are made of environmentally friendly materials. Neither during manufacture nor in the product itself any toxic substances are used, e.g. – – – – – Lead PCB CFC Hydrocarbon chloride Chromium 6+ – – – – – PBB/PBDE Arsenic Cadmium Mercury etc. RoHS Compliance According to the RoHS Directive 2002/95/EC certain hazardous substances like e.g. lead, cadmium, mercury must not be used any longer in electronic equipment as of July 1st, 2006. For the sake of the environment WIMA has refraind from using such substances since years already. We merely use pure, recyclable materials for packing our components, such as: ” carton ” cardboard ” adhesive tape made of paper ” polystyrene We almost completely refrain from using packing materials such as: ” foamed polystyrene (Styropor®) ” adhesive tapes made of plastic ” metal clips Tape for lead-free WIMA capacitors DIN EN ISO 14001:2005 WIMA’s environmental management has been established in accordance with the guidelines of DIN EN ISO 14001:2005. The certification has been granted in June 2006. 11.10 ” incoming material inspection ” metallization ” film inspection ” schoopage ” pre-healing ” lead attachment ” cast resin preparation/ encapsulation ” 100% final inspection ” AQL check WIMA Environmental Policy 14 D Typical Dimensions for Taping Configuration Vh P P2 Diagram 1: PCM 2.5/5/7.5mm W W1 W0 H H1 W2 P1 D0 d P t F P0 H1 P P1 H P1 d d F P0 P2 Diagram 2: PCM 10/15 mm Diagram 3: PCM 22.5 and 27.5*mm *PCM 27.5 taping possible with two feed holes between components Designation Carrier tape width Dimensions for Radial Taping Symbol PCM 2.5 taping W P0 P2 F 18.0 p0.5 PCM 5 taping PCM 7.5 taping PCM 10 taping* PCM 15 taping* PCM 22.5 taping PCM 27.5 taping 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 18.0 p0.5 for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing Hold-down tape width W0 6.0 6.0 12.0 12.0 12.0 12.0 12.0      adhesive tape      adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape       adhesive tape Hole position W 1 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 9.0 p0.5 Hold-down tape position W 2 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. 0.5 to 3.0 max. Feed hole diameter D 0 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 4.0 p0.2 12.7 p1.0 12.7 p1.0 12.7 p1.0 25.4 p1.0 25.4 p1.0 38.1 p1.5 4.0 p0.2 3*8.1 p1.5 or 50.8 p1.5 Pitch of component P Feed hole pitch P 0 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch 12.7 p0.3 cumulative pitch error max. 1.0 mm/20 pitch Feed hole centre to lead P 1 5.1 p0.5 3.85 p0.7 2.6 p0.7 7.7 p0.7 5.2 p0.7 7.8 p0.7 5.3 p0.7 Hole centre to component centre P 2 6.35 p1.3 6.35 p1.3 6.35 p1.3 12.7 p1.3 12.7 p1.3 19.05 p1.3 19.05 p1.3 Feed hole centre to bottom H edge of the component 16.5 p0.3 18.5 p0.5 16.5 p0.3 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 16.5 p0.5 18.5 p0.5 Feed hole centre to top H edge of the component 1 H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 32.25 max. H+Hcomponent < H1 24.5 to 31.5 H+Hcomponent < H1 25.0 to 31.5 H+Hcomponent < H1 26.0 to 37.0 H+Hcomponent < H1 30.0 to 43.0 H+Hcomponent < H1 35.0 to 45.0 7.5 p0.8 10.0 p0.8 15 p0.8 22.5 p0.8 27.5 p0.8 Lead spacing at +0.8 F 2.5 p0.5 5.0 upper edge of carrier tape     –0.2 +0.08 Dh p 2.0 max. p 2.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. p 3.0 max. 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 0.7 p0.2 ROLL/AMMO Package (see also page 128) P 360 max. 52 p2 depending on REEL P 30 p1 B 58 p2 comp. dimensions Unit 0.8 +0,08 –0.05 Component alignment t 0.8 +0,08 –0.05 0.4 p0.05 „ 0.5 +0,06 p0.05 or 0.6 –0.05 d „ 0.5 +0.06 p0.05 or 0.6 –0.05 Lead diameter Total tape thickness 0.5 p0.05 0.8 –0.05 AMMO 52 p2 54 p2 max. P 500 max. B 58 p2 or REEL B 60 p2 REEL PP 360 30 p1 P 25 p1 66 p2 68 p2 depending on PCM and component dimensions see details page 130. Dims in mm. 11.10 „ Diameter of leads see General Data. Please clarify customer-specific deviations with the manufacturer. * PCM 10 and PCM 15 can be crimped to PCM 7.5. Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible 127 D Packing Quantities for Bulk Capacitors and TPS* Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 27.5 mm 11.10 37.5 mm W   2.5  3   3.8   4.6   5.5   2.5  3   3.5   4.5   4.5  5   5.5   5.5   6.5   7.2   7.2   8.5   8.5 11   2.5  3  4   4.5  5   5.7   7.2  3  4  4  4  5  5  6  6  8  5  5  6  6  7  7  8  8  9  9 10 11  5  6  7  8   8.5 10 10.5 10.5 11 12  9 11 13 13 15 15 17 17 20 20  9 11 13 15 17 19 20 24 H  7   7.5   8.5  9 10   6.5   7.5   8.5  6   9.5 10  7 11.5  8   8.5 13 10 14 16  7   8.5  9   9.5 10.5 12.5 12.5  9   8.5  9   9.5 10 11 12 12.5 12 11 13 12.5 14 14 15 15 17 14 16 18 14 14 15 16.5 20 18.5 22 19 20.5 21 24 19 21 24 25 26 26 29 34.5 32 39.5 19 22 24 26 29 32 39.5 45.5 L   4.6   4.6   4.6   4.6   4.6   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2 10 10 10 10.3 10.3 10.3 10.3 13 13.5 13 13 13.5 13 13 13 13 18 19 18 19 18 19 18 19 18 18 19 18 26.5 26.5 26.5 28 26.5 28 26.5 26.5 26.5 28 31.5 31.5 31.5 33 31.5 33 31.5 31.5 33 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 Codes 0B 0C 0D 0E 0F 1A 1B 1C 1D 1E 1F 1G 1H 1I 1J 1K 1L 1M 1N 2A 2B 2C 2D 2E 2F 2G 3A FA 3C 3D FB 3F 3G 3H 3I 4B FC 4C FD 4D FE 4F FF 4H 4J FG 4M 5A 5B 5D FH 5F FI 5G 5H 5I FJ 6A 6B 6D FK 6F FL 6G 6I FM 6J 7A 7B 7C 7D 7E 7F 7G 7H Rights reserved to amend design data without prior notification. Samples and pre-production needs on request. pcs. per packaging unit bulk Mini Standard Maxi M S G 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 1000 5000 10 000 2000 5000 10 000 1000 5000 – 1000 5000 – 1000 6000 – 1000 4000 – 1000 3500 – 1000 4000 –   500 2500 – 1000 2500 –   500 2500 –   500 2000 –   500 2000 –   500 1500 –   250 1000 – 1000 5000 – 1000 5000 – 1000 4000 – 1000 3500 – 1000 3000 – 2000 –   500   500 1500 – 1000 3000 – 3000 –   500 1000 3000 – 1000 3000 –   500 2000 – 1000 3000 – 2400 –   800   800 2400 –   500 2000 –   800 2400 –   200 1000 2000 –   500   250 1000   400 1600 –   250 1000 1200 –   400   100   500 1200 –   400   300   900 –   100   500 –   300 1000 –   300 1200 –   250 1000 – –   190   760   125   500 – –   125   500 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – Moulded versions. pcs. per packaging unit/TPS* Mini Standard X Y – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – –   90 540 170 680 170 680 170 680   75 450 160 640 136 544 112 448   56 336   96 384   48 288   88 176   88 176   36 216   36 144   60 480   51 408   84 252   72 144   66 132   54 108   27 108   21   84 * Tray-Packing-System 129 D Packing Units for Taped Capacitors with Radial Leads ROLL Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 27.5 mm W   2.5  3   3.8   4.6   5.5   2.5  3   3.5   4.5   4.5  5   5.5   5.5   6.5   7.2   7.2   8.5   8.5 11   2.5  3  4   4.5  5   5.7   7.2  3  4  4  4  5  5  6  6  8  5  5  6  6  7  7  8  8  9  9 10 11  5  6  7  8   8.5 10 10.5 10.5 11 12  9 11 13 15 H  7   7.5   8.5  9 10   6.5   7.5   8.5  6   9.5 10  7 11.5  8   8.5 13 10 14 16  7   8.5  9   9.5 10.5 12.5 12.5  9   8.5  9   9.5 10 11 12 12.5 12 11 13 12.5 14 14 15 15 17 14 16 18 14 14 15 16.5 20 18.5 22 19 20.5 21 24 19 21 24 26 L   4.6   4.6   4.6   4.6   4.6   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2   7.2 10 10 10 10.3 10.3 10.3 10.3 13 13.5 13 13 13.5 13 13 13 13 18 19 18 19 18 19 18 19 18 18 19 18 26.5 26.5 26.5 28 26.5 28 26.5 26.5 26.5 28 31.5 31.5 31.5 31.5 Codes 0B 0C 0D 0E 0F 1A 1B 1C 1D 1E 1F 1G 1H 1I 1J 1K 1L 1M 1N 2A 2B 2C 2D 2E 2F 2G 3A FA 3C 3D FB 3F 3G 3H 3I 4B FC 4C FD 4D FE 4F FF 4H 4J FG 4M 5A 5B 5D FH 5F FI 5G 5H 5I FJ 6A 6B 6D 6F Moulded versions. AMMO 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 A C B D 2800 – 2300 – 1800 – 1500 – 1200 – 2800 – 2300 – 2000 – 1500 – 1500 – 1400 – 1200 – 1200 – 1000 – 1000 – 1000 –   800 –   800 –   700 – 2500 – 2300 4150 1700 3100 1400 2800 1300 – 1100 – 1000 – – 1900 – 1450 – 1450 – 1400 – 1200 – 1200 – 1000 – 1000 –   740 – 1150 – 1200 – 1000 – 1000 –   850 –   850 –   740 –   740 –   650 –   650 –   590 –   540 –   770 –   640 –   550 –   480 –   450 –   380 –   360 –   360 –   350 –   310 –   420 –   350 –   290 –   250 Rights reserved to amend design data without prior notification. 11.10 * for 2-inch transport pitches. Samples and pre-production needs 1 packing unit minimum. H16.5 H18.5 N O 2200 2000 1500 1200   900 2200 2000 1600 1300 1300 1100 1000 1000   800   700   700   600   600   500 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – REEL P 360 P 500 H16.5 H18.5 H16.5 H18.5 F I H J 2500 – 2300 – 1800 – 1500 – 1200 – 2500 – 2300 – 2000 – 1500 – 1500 – 1400 – 1200 – 1200 – 1000 – 1000 –   950 –   800 –   800 –   700 – 2500 4400 2200 4300 1700 3200 1500 2900 1300 2500 1000 2200   900 1800 1100 2200   900 1600   900 1600   900 1600   700 1300   700 1300   550 1100   550 1100   400   800   600 1200   600 1200   500 1000   500 1000   450   900   450   900   400   800   400   800   350   700   350   700   300   650   300   600 –   800 –   700 –   600 –   500 –   480 –   420 –   400 –   400 –   380 –   350 – 460/340* – 380/280* –   300 –   270 130 D WIMA Part Number System A WIMA part number consists of 18 digits and is composed as follows: Field   1 -   4: Type description Field   5 -   6: Rated voltage Field   7 - 10: Capacitance Field 11 - 12: Size and PCM Field 13 - 14: Special features (e.g. Snubber versions) Field 15: Capacitance tolerance Field 16: Packing Field 17 - 18: Lead length (untaped) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 M K S 2 C 0 2 1 0 0 1 A 0 0 M S S D 20 % bulk MKS 2 11.10 Type description: SMD-PET = SMD-PPS = FKP 02 = MKS 02 = FKS 2 = FKP 2 = MKS 2 = MKP 2 = FKS 3 = FKP 3 = MKS 4 = MKP 4 = MKP 10 = FKP 4 = FKP 1 = MKP-X2 = MKP-X2 R = MKP-Y2 = MP 3-X2 = MP 3-X1 = MP 3-Y2 = MP 3R-Y2 = Snubber MKP = Snubber FKP = GTO MKP = DC-LINK MKP 4 = DC-LINK MKP C = DC-LINK HC = SuperCap C = SuperCap MC = SuperCap R = SuperCap MR = 63 VDC SMDT SMDI FKP0 MKS0 FKS2 FKP2 MKS2 MKP2 FKS3 FKP3 MKS4 MKP4 MKP1 FKP4 FKP1 MKX2 MKXR MKY2 MPX2 MPX1 MPY2 MPRY SNMP SNFP GTOM DCP4 DCPC DCH_ SCSC SCMC SCSR SCMR Rated voltage: 2.5 VDC = A1 4 VDC = A2 14 VDC = A3 28 VDC = A4 40 VDC = A5 5 VDC = A6 50 VDC = B0 63 VDC = C0 100 VDC = D0 160 VDC = E0 250 VDC = F0 400 VDC = G0 450 VDC = H0 600 VDC = I0 630 VDC = J0 700 VDC = K0 800 VDC = L0 850 VDC = M0 900 VDC = N0 1000 VDC = O1 1100 VDC = P0 1200 VDC = Q0 1250 VDC = R0 1500 VDC = S0 1600 VDC = T0 2000 VDC = U0 2500 VDC = V0 3000 VDC = W0 4000 VDC = X0 6000 VDC = Y0 250 VAC = 0W 275 VAC = 1W 300 VAC = 2W 400 VAC = 3W 440 VAC = 4W 500 VAC = 5W ... 0.01 mF Capacitance: 22 pF = 0022 47 pF = 0047 100 pF = 0100 150 pF = 0150 220 pF = 0220 330 pF = 0330 470 pF = 0470 680 pF = 0680 1000 pF = 1100 1500 pF = 1150 2200 pF = 1220 3300 pF = 1330 4700 pF = 1470 6800 pF = 1680 0.01 mF = 2100 0.022 mF = 2220 0.047 mF = 2470 0.1 mF = 3100 0.22 mF = 3220 0.47 mF = 3470 = 4100 1 mF 2.2 mF = 4220 4.7 mF = 4470 = 5100 10 mF = 5220 22 mF = 5470 47 mF 100 mF = 6100 220 mF = 6220 1F = A010 2.5 F = A025 50 F = A500 100 F = B100 110 F = B110 600 F = B600 1200 F = C120 ... - 2.5 x 6.5 x 7.2 Size: 4.8 x 3.3 x 3 Size 1812 4.8 x 3.3 x 4 Size 1812 5.7 x 5.1 x 3.5 Size 2220 5.7 x 5.1 x 4.5 Size 2220 7.2 x 6.1 x 3 Size 2824 7.2 x 6.1 x 5 Size 2824 10.2 x 7.6 x 5 Size 4030 12.7 x 10.2 x 6 Size 5040 15.3 x 13.7 x 7 Size 6054 2.5 x 7 x 4.6 PCM 2.5 3 x 7.5 x 4.6 PCM 2.5 2.5 x 6.5 x 7.2 PCM 5 3 x 7.5 x 7.2 PCM 5 2.5 x 7 x 10 PCM 7.5 3 x 8.5 x 10 PCM 7.5 3 x 9 x 13 PCM 10 4 x 9 x 13 PCM 10 5 x 11 x 18 PCM 15 6 x 12.5 x 18 PCM 15 5 x 14 x 26.5 PCM 22.5 6 x 15 x 26.5 PCM 22.5 9 x 19 x 31.5 PCM 27.5 11 x21 x 31.5 PCM 27.5 9 x 19 x 41.5 PCM 37.5 11 x 22 x 41.5 PCM 37.5 94 x 49 x 182 DCH_ 94 x 77 x 182 DCH_ ... Special features: Standard = 00 Version A1 = 1A Version A1.1.1 = 1B Version A1.2 = 1C ... = = = = = = = = = = = = = = = = = = = = = = = = = = = X1 X2 Y1 Y2 T1 T2 K1 V1 Q1 0B 0C 1A 1B 2A 2B 3A 3C 4B 4C 5A 5B 6A 6B 7A 7B H0 H1 Tolerance: 20 % = 10 % = 5 % = 2.5 % = 1 % = ... 6 -2 M K J H E Packing: AMMO H16.5 340 x 340 AMMO H16.5 490 x 370 AMMO H18.5 340 x 340 AMMO H18.5 490 x 370 REEL H16.5 360 REEL H16.5 500 REEL H18.5 360 REEL H18.5 500 ROLL H16.5 ROLL H18.5 BLISTER W12 180 BLISTER W12 330 BLISTER W16 330 BLISTER W24 330 Bulk Mini Bulk Standard Bulk Maxi TPS Mini TPS Standard ... = = = = = = = = = = = = = = = = = = = A B C D F H I J N O P Q R T M S G X Y Lead length (untaped) 3.5 ±0.5 = C9 6 -2 = SD 16 ±1 = P1 ... The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the pages of the respective WIMA range. 125
FKP1R012204B00KSSD 价格&库存
很抱歉,暂时无法提供与“FKP1R012204B00KSSD”相匹配的价格&库存,您可以联系我们找货
FKP1R012204B00KSSD
  • 4800+1.84102
  • 24000+1.65536
FKP1R012204B00KSSD
    库存:2400
    FKP1R012204B00KSSD
    • 4800+1.982844800+0.25651
    • 24000+1.7819424000+0.23052
    FKP1R012204B00KSSD
