D
WIMA FKS 2
Polyester (PET) Film and Foil
Capacitors for Pulse Applications
in PCM 5 mm
Special Features
Electrical Data
˜ Pulse duty construction
˜ According to RoHS 2002/95/EC
Typical Applications
For general DC-applications e.g.
˜ Coupling
˜ Decoupling
Construction
Dielectric:
Polyethylene-terephthalate (PET) film
Capacitor electrodes:
Metal foil
Internal construction:
Plastic film
Metal foil electrode
Capacitance range:
1000 pF to 0.047 mF (E12-values on request)
Rated voltages:
100 VDC, 250 VDC, 400 VDC
Capacitance tolerances:
± 20%, ±10%, ±5%
Operating temperature range:
–55+ C to +100+ C
Test specifications:
In accordance with IEC 60384-11
and EN 130 100
Climatic test category:
55/100/56 in accordance with IEC
Insulation resistance at +20+ C:
3 x 104 M¸
(mean value: 8 x 10 5 M¸)
Measuring voltage: 100 V/1 min.
Test voltage: 2 U r, 2 sec.
Maximum pulse rise time:
1000 V/ msec for pulses equal to the
rated voltage
Dissipation factors at +20+ C: tan d
at f
1 kHz
10 kHz
100 kHz
C 0.047 mF
7 x 10 -3
15 x 10 -3
20 x 10 -3
Voltage derating:
A voltage derating factor of 1.25 % per K
must be applied from +85+ C for DC
voltages and from +75+ C for AC
voltages.
Reliability:
Operational life 300 000 hours
Failure rate 5 fit (0.5 x U r and 40+ C)
Terminating wire
Mechanical Tests
Pull test on leads:
10 N in direction of leads according to
IEC 60068-2-21
Vibration:
6 hours at 10 ... 2000 Hz and 0.75 mm
displacement amplitude or 10 g in
accordance with IEC 60068-2-6
Low air density:
1kPa = 10 mbar in accordance with
IEC 60068-2-13
Bump test:
4000 bumps at 390 m/sec 2 in
accordance with IEC 60068-2-29
Packing
Available taped and reeled.
Detailed taping information and graphs
at the end of the catalogue.
For further details and graphs please
refer to Technical Information.
11.10
Encapsulation:
Solvent-resistant, flame-retardant plastic
case with epoxy resin seal, UL 94 V-0
Terminations:
Tinned wire.
Marking:
Colour: Red. Marking: Silver.
Epoxy resin seal: Yellow.
28
D
WIMA FKS
FKP 24
Continuation
General Data
Capacitance
W
1000
1500
2200
3300
4700
6800
pF
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
FKS2D011001A00_ _ _ _ 2.5 6.5
FKS2D011501A00_ _ _ _ 2.5 6.5
FKS2D012201A00_ _ _ _ 2.5 6.5
FKS2D013301A00_ _ _ _ 2.5 6.5
FKS2D014701A00_ _ _ _ 2.5 6.5
FKS2D016801A00_ _ _ _ 2.5 6.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
FKS2F011001A00_ _ _ _
FKS2F011501A00_ _ _ _
FKS2F012201A00_ _ _ _
FKS2F013301A00_ _ _ _
FKS2F014701A00_ _ _ _
FKS2F016801A00_ _ _ _
0.01
0.015
0.022
0.033
0.047
mF
3 7.5
3.5 8.5
4.5 9.5
5.5 11.5
7.2 13
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
FKS2D021001B00_ _ _ _
3 7.5
FKS2D021501C00_ _ _ _ 3.5 8.5
FKS2D022201E00_ _ _ _ 4.5 9.5
FKS2D023301H00_ _ _ _ 5.5 11.5
FKS2D024701K00_ _ _ _ 7.2 13
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
FKS2F021001B00_ _ _ _
FKS2F021501C00_ _ _ _
FKS2F022201E00_ _ _ _
FKS2F023301H00_ _ _ _
FKS2F024701K00_ _ _ _
Capacitance
H
L
W
H
L
100 VDC/63 VAC*
PCM**
Part number
W
H
L
250 VDC/160 VAC*
PCM**
Part number
400 VDC/200 VAC*
PCM**
Part number
1000
1500
2200
3300
4700
6800
pF
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
2.5 6.5
3 7.5
7.2
7.2
7.2
7.2
7.2
7.2
5
5
5
5
5
5
FKS2G011001A00_ _ _ _
FKS2G011501A00_ _ _ _
FKS2G012201A00_ _ _ _
FKS2G013301A00_ _ _ _
FKS2G014701A00_ _ _ _
FKS2G016801B00_ _ _ _
0.01
0.015
0.022
0.033
mF
3.5 8.5
4.5 9.5
5.5 11.5
7.2 13
7.2
7.2
7.2
7.2
5
5
5
5
FKS2G021001C00_ _ _ _
FKS2G021501E00_ _ _ _
FKS2G022201H00_ _ _ _
FKS2G023301K00_ _ _ _
* AC voltage: f = 50 Hz; 1.4 x U rms + UDC U r
** PCM = Printed circuit module = lead spacing
Dims. in mm.
The values of the WIMA FKM 2 range according to the
main catalogue 2009 are still available on request.
W
L
H
d = 0.5 l
6
Impedance change with frequency
(general guide).
Part number completion:
Tolerance: 20 % = M
10 % = K
5 % = J
Packing:
bulk = S
Lead length: 6-2 = SD
Taped version see page 127.
-2
d
5
PCM
at the lead exit points
( 0.5)
11.10
Rights reserved to amend design data without prior notification.
29
D
Recommendation for Processing
and Application of
Through-Hole Capacitors
Soldering Process
Wave soldering
T
A preheating of through-hole WIMA
capacitors is allowed for temperatures
T max P 100 ° C.
In practice a preheating duration of
t P 5 min. has been proven to be best.
260
240
220
200
180
160
140
120
100
80
60
40
Single wave soldering
Soldering bath temperature: T P 260 ° C
Immersion time:
t P 5 sec
Double wave soldering
Immersion time:
2 x t P 3 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
10 s
[°C]
see detailenlargement
2s
3s
t
30
60
90
120
150
180
210
240 [sec]
Typical temperature/time graph for double wave soldering
WIMA Quality and Environmental Philosophy
ISO 9001:2000 Certification
ISO 9001:2000 is an international basic
standard of quality assurance systems for
all branches of industry. The approval
according to ISO 9001:2000 of our
factories by the VDE inspectorate certifies
that organisation, equipment and monitoring of quality assurance in our factories
correspond to internationally recognized
standards.
WIMA WPCS
The WIMA Process Control System (WPCS)
is a quality surveillance and optimization
system developed by WIMA. WPCS is a
major part of the quality-oriented WIMA
production. Points of application of WPCS
during production process:
All WIMA capacitors, irrespective of
whether through-hole devices or SMD,
are made of environmentally friendly
materials. Neither during manufacture
nor in the product itself any toxic
substances are used, e.g.
Lead
PCB
CFC
Hydrocarbon chloride
Chromium 6+
PBB/PBDE
Arsenic
Cadmium
Mercury
etc.
RoHS Compliance
According to the RoHS Directive 2002/95/EC
certain hazardous substances like e.g. lead,
cadmium, mercury must not be used any
longer in electronic equipment as of July 1st,
2006. For the sake of the environment WIMA
has refraind from using such substances since
years already.
We merely use pure, recyclable materials
for packing our components, such as:
” carton
” cardboard
” adhesive tape made of paper
” polystyrene
We almost completely refrain from using
packing materials such as:
” foamed polystyrene (Styropor®)
” adhesive tapes made of plastic
” metal clips
Tape for lead-free WIMA capacitors
DIN EN ISO 14001:2005
WIMA’s environmental management has
been established in accordance with the
guidelines of DIN EN ISO 14001:2005.
The certification has been granted in
June 2006.
11.10
” incoming material inspection
” metallization
” film inspection
” schoopage
” pre-healing
” lead attachment
” cast resin preparation/
encapsulation
” 100% final inspection
” AQL check
WIMA Environmental Policy
14
D
Typical Dimensions for
Taping Configuration
Vh
P
P2
Diagram 1:
PCM 2.5/5/7.5mm
W
W1
W0
H
H1
W2
P1
D0
d
P
t
F
P0
H1
P
P1
H
P1
d
d
F
P0
P2
Diagram 2: PCM 10/15 mm
Diagram 3: PCM 22.5 and 27.5*mm
*PCM 27.5 taping possible with two feed holes between components
Designation
Carrier tape width
Dimensions for Radial Taping
Symbol PCM 2.5 taping
W
P0
P2
F
18.0 p0.5
PCM 5 taping
PCM 7.5 taping
PCM 10 taping*
PCM 15 taping*
PCM 22.5 taping
PCM 27.5 taping
18.0 p0.5
18.0 p0.5
18.0 p0.5
18.0 p0.5
18.0 p0.5
18.0 p0.5
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
Hold-down tape width
W0 6.0
6.0
12.0
12.0
12.0
12.0
12.0
adhesive
tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape
Hole position
W 1
9.0 p0.5
9.0 p0.5
9.0 p0.5
9.0 p0.5
9.0 p0.5
9.0 p0.5
9.0 p0.5
Hold-down tape position
W 2
0.5 to 3.0 max.
0.5 to 3.0 max.
0.5 to 3.0 max.
0.5 to 3.0 max.
0.5 to 3.0 max.
0.5 to 3.0 max.
0.5 to 3.0 max.
Feed hole diameter
D 0
4.0 p0.2
4.0 p0.2
4.0 p0.2
4.0 p0.2
4.0 p0.2
4.0 p0.2
12.7 p1.0
12.7 p1.0
12.7 p1.0
25.4 p1.0
25.4 p1.0
38.1 p1.5
4.0 p0.2
3*8.1 p1.5 or 50.8 p1.5
Pitch of component
P
Feed hole pitch
P 0
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 p0.3
cumulative pitch
error max.
1.0 mm/20 pitch
Feed hole centre
to lead
P 1
5.1 p0.5
3.85 p0.7
2.6 p0.7
7.7 p0.7
5.2 p0.7
7.8 p0.7
5.3 p0.7
Hole centre to
component centre
P 2
6.35 p1.3
6.35 p1.3
6.35 p1.3
12.7 p1.3
12.7 p1.3
19.05 p1.3
19.05 p1.3
Feed hole centre to bottom
H
edge of the component
16.5 p0.3
18.5 p0.5
16.5 p0.3
18.5 p0.5
16.5 p0.5
18.5 p0.5
16.5 p0.5
18.5 p0.5
16.5 p0.5
18.5 p0.5
16.5 p0.5
18.5 p0.5
16.5 p0.5
18.5 p0.5
Feed hole centre to top
H
edge of the component 1
H+Hcomponent < H1
32.25 max.
H+Hcomponent < H1
32.25 max.
H+Hcomponent < H1
24.5 to 31.5
H+Hcomponent < H1
25.0 to 31.5
H+Hcomponent < H1
26.0 to 37.0
H+Hcomponent < H1
30.0 to 43.0
H+Hcomponent < H1
35.0 to 45.0
7.5 p0.8
10.0 p0.8
15 p0.8
22.5 p0.8
27.5 p0.8
Lead spacing at
+0.8
F
2.5 p0.5
5.0
upper edge of carrier tape –0.2
+0.08
Dh
p 2.0 max.
p 2.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
p 3.0 max.
0.7 p0.2
0.7 p0.2
0.7 p0.2
0.7 p0.2
0.7 p0.2
0.7 p0.2
0.7 p0.2
ROLL/AMMO
Package
(see also page 128)
P 360 max.
52 p2 depending on
REEL P 30 p1 B 58 p2 comp. dimensions
Unit
0.8
+0,08
–0.05
Component alignment
t
0.8
+0,08
–0.05
0.4 p0.05
0.5
+0,06
p0.05 or 0.6 –0.05
d
0.5
+0.06
p0.05 or 0.6 –0.05
Lead diameter
Total tape thickness
0.5 p0.05
0.8 –0.05
AMMO
52 p2 54 p2
max.
P 500 max.
B 58 p2 or REEL
B 60 p2
REEL PP 360
30 p1
P 25 p1
66 p2
68 p2
depending
on PCM and
component dimensions
see details page 130.
Dims in mm.
11.10
„ Diameter of leads see General Data.
Please clarify customer-specific deviations with the manufacturer.
* PCM 10 and PCM 15 can be crimped to PCM 7.5.
Position of components according to PCM 7.5 (sketch 1). P 0 = 12.7 or 15.0 is possible
127
D
Packing Quantities for Bulk Capacitors and TPS*
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
27.5 mm
11.10
37.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
2.5
3
4
4.5
5
5.7
7.2
3
4
4
4
5
5
6
6
8
5
5
6
6
7
7
8
8
9
9
10
11
5
6
7
8
8.5
10
10.5
10.5
11
12
9
11
13
13
15
15
17
17
11
13
15
17
19
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
7
8.5
9
9.5
10.5
12.5
12.5
9
8.5
9
9.5
10
11
12
12.5
12
11
13
12.5
14
14
15
15
17
14
16
18
14
14
15
16.5
22
19
20.5
21
24
19
21
24
25
26
26
29
34.5
32
39.5
19
22
24
26
29
32
39.5
45.5
L
4.6
4.6
4.6
4.6
4.6
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
10
10
10
10.3
10.3
10.3
10.3
13
13.5
13
13
13.5
13
13
13
13
18
19
18
19
18
19
18
19
18
18
19
18
26.5
26.5
26.5
28
26.5
28
26.5
26.5
26.5
28
31.5
31.5
31.5
33
31.5
33
31.5
31.5
33
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
Codes
0B
0C
0D
0E
0F
1A
1B
1C
1D
1E
1F
1G
1H
1I
1J
1K
1L
1M
1N
2A
2B
2C
2D
2E
2F
2G
3A
FA
3C
3D
FB
3F
3G
3H
3I
4B
FC
4C
FD
4D
FE
4F
FF
4H
4J
FG
4M
5A
5B
5D
FH
5F
FI
5G
5H
5I
FJ
6A
6B
6D
FK
6F
FL
6G
6I
FM
6J
7A
7B
7C
7D
7E
7F
7G
7H
Samples and pre-production needs on request.
pcs. per packaging unit bulk
Mini
Standard
Maxi
M
S
G
1000
5000
10 000
1000
5000
10 000
1000
5000
10 000
1000
5000
10 000
1000
5000
10 000
2000
5000
10 000
1000
5000
1000
5000
1000
6000
1000
4000
1000
3500
1000
4000
500
2500
1000
2500
500
2500
500
2000
500
2000
500
1500
250
1000
1000
5000
1000
5000
1000
4000
1000
3500
1000
3000
2000
500
500
1500
1000
3000
3000
500
1000
3000
1000
3000
500
2000
1000
3000
2400
800
800
2400
500
2000
800
2400
200
1000
2000
500
250
1000
400
1600
250
1000
1200
400
100
500
1200
400
300
900
100
500
300
1000
300
1200
250
1000
190
760
125
500
125
500
Moulded versions.
pcs. per packaging unit/TPS*
Mini
Standard
X
Y
90
540
170
680
170
680
170
680
75
450
160
640
136
544
112
448
56
336
96
384
48
288
88
176
88
176
36
216
36
144
60
480
51
408
84
252
72
144
66
132
54
108
27
108
21
84
* Tray-Packing-System
129
D
Packing Units for Taped Capacitors
with Radial Leads
ROLL
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
27.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
2.5
3
4
4.5
5
5.7
7.2
3
4
4
4
5
5
6
6
8
5
5
6
6
7
7
8
8
9
9
10
11
5
6
7
8
8.5
10
10.5
10.5
11
12
9
11
13
15
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
7
8.5
9
9.5
10.5
12.5
12.5
9
8.5
9
9.5
10
11
12
12.5
12
11
13
12.5
14
14
15
15
17
14
16
18
14
14
15
16.5
22
19
20.5
21
24
19
21
24
26
L
4.6
4.6
4.6
4.6
4.6
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
7.2
10
10
10
10.3
10.3
10.3
10.3
13
13.5
13
13
13.5
13
13
13
13
18
19
18
19
18
19
18
19
18
18
19
18
26.5
26.5
26.5
28
26.5
28
26.5
26.5
26.5
28
31.5
31.5
31.5
31.5
Codes
0B
0C
0D
0E
0F
1A
1B
1C
1D
1E
1F
1G
1H
1I
1J
1K
1L
1M
1N
2A
2B
2C
2D
2E
2F
2G
3A
FA
3C
3D
FB
3F
3G
3H
3I
4B
FC
4C
FD
4D
FE
4F
FF
4H
4J
FG
4M
5A
5B
5D
FH
5F
FI
5G
5H
5I
FJ
6A
6B
6D
6F
Moulded versions.
AMMO
340 x 340
490 x 370
H16.5 H18.5 H16.5 H18.5
A
C
B
D
2800
2300
1800
1500
1200
2800
2300
2000
1500
1500
1400
1200
1200
1000
1000
1000
800
800
700
2500
2300
4150
1700
3100
1400
2800
1300
1100
1000
1900
1450
1450
1400
1200
1200
1000
1000
740
1150
1200
1000
1000
850
850
740
740
650
650
590
540
770
640
550
480
450
380
360
360
350
310
420
350
290
250
11.10
* for 2-inch transport pitches.
Samples and pre-production needs 1 packing unit minimum.
H16.5 H18.5
N
O
2200
2000
1500
1200
900
2200
2000
1600
1300
1300
1100
1000
1000
800
700
700
600
600
500
REEL
P 360
P 500
F
I
H
J
2500
2300
1800
1500
1200
2500
2300
2000
1500
1500
1400
1200
1200
1000
1000
950
800
800
700
2500
4400
2200
4300
1700
3200
1500
2900
1300
2500
1000
2200
900
1800
1100
2200
900
1600
900
1600
900
1600
700
1300
700
1300
550
1100
550
1100
400
800
600
1200
600
1200
500
1000
500
1000
450
900
450
900
400
800
400
800
350
700
350
700
300
650
300
600
800
700
600
500
480
420
400
400
380
350
460/340*
380/280*
300
270
130
D
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Special features (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Lead length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
11.10
Type description:
SMD-PET
SMD-PPS
FKP 02
MKS 02
FKS 2
FKP 2
MKS 2
MKP 2
FKS 3
FKP 3
MKS 4
MKP 4
MKP 10
FKP 4
FKP 1
MKP-X2
MKP-X2 R
MKP-Y2
MP 3-X2
MP 3-X1
MP 3-Y2
MP 3R-Y2
Snubber MKP =
Snubber FKP
GTO MKP
DC-LINK MKP 4 =
DC-LINK MKP C =
DC-LINK HC
SuperCap C
SuperCap MC =
SuperCap R
SuperCap MR =
63 VDC
SMDT
SMDI
FKP0
MKS0
FKS2
FKP2
MKS2
MKP2
FKS3
FKP3
MKS4
MKP4
MKP1
FKP4
FKP1
MKX2
MKXR
MKY2
MPX2
MPX1
MPY2
MPRY
SNMP
SNFP
GTOM
DCP4
DCPC
DCH_
SCSC
SCMC
SCSR
SCMR
Rated voltage:
2.5 VDC = A1
4 VDC
= A2
14 VDC = A3
28 VDC = A4
40 VDC = A5
5 VDC
= A6
50 VDC = B0
63 VDC = C0
100 VDC = D0
160 VDC = E0
250 VDC = F0
400 VDC = G0
450 VDC = H0
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
250 VAC = 0W
275 VAC = 1W
300 VAC = 2W
400 VAC = 3W
440 VAC = 4W
500 VAC = 5W
0.01 mF
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 mF = 2100
0.022 mF = 2220
0.047 mF = 2470
0.1 mF = 3100
0.22 mF = 3220
0.47 mF = 3470
= 4100
1 mF
2.2 mF = 4220
4.7 mF = 4470
= 5100
10 mF
= 5220
22 mF
= 5470
47 mF
100 mF = 6100
220 mF = 6220
1F
= A010
2.5 F
= A025
50 F
= A500
100 F
= B100
110 F
= B110
600 F
= B600
1200 F = C120
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812
4.8 x 3.3 x 4 Size 1812
5.7 x 5.1 x 3.5 Size 2220
5.7 x 5.1 x 4.5 Size 2220
7.2 x 6.1 x 3 Size 2824
7.2 x 6.1 x 5 Size 2824
10.2 x 7.6 x 5 Size 4030
12.7 x 10.2 x 6 Size 5040
15.3 x 13.7 x 7 Size 6054
2.5 x 7 x 4.6 PCM 2.5
3 x 7.5 x 4.6 PCM 2.5
2.5 x 6.5 x 7.2 PCM 5
3 x 7.5 x 7.2 PCM 5
2.5 x 7 x 10 PCM 7.5
3 x 8.5 x 10 PCM 7.5
3 x 9 x 13 PCM 10
4 x 9 x 13 PCM 10
5 x 11 x 18 PCM 15
6 x 12.5 x 18 PCM 15
5 x 14 x 26.5 PCM 22.5
6 x 15 x 26.5 PCM 22.5
9 x 19 x 31.5 PCM 27.5
11 x21 x 31.5 PCM 27.5
9 x 19 x 41.5 PCM 37.5
11 x 22 x 41.5 PCM 37.5
94 x 49 x 182 DCH_
94 x 77 x 182 DCH_
Special features:
Standard
= 00
Version A1
= 1A
Version A1.1.1 = 1B
Version A1.2 = 1C
X1
X2
Y1
Y2
T1
T2
K1
V1
Q1
0B
0C
1A
1B
2A
2B
3A
3C
4B
4C
5A
5B
6A
6B
7A
7B
H0
H1
Tolerance:
20 %
10 %
5 %
2.5 %
1 %
6 -2
M
K
J
H
E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk Mini
Bulk Standard
Bulk Maxi
TPS Mini
TPS Standard
A
B
C
D
F
H
I
J
N
O
P
Q
R
T
M
S
G
X
Y
3.5 ±0.5 = C9
6 -2
= SD
16 ±1
= P1
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the
pages of the respective WIMA range.
125
很抱歉,暂时无法提供与“FKS2D011001A00JSSD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.65305
- 200+0.65967
- 500+0.63764
- 1000+0.62673
